[PATCH] validation: Test scheduler detail
Sebastian Huber
Tue Jul 5 06:35:07 UTC 2022
This particular state during a reconsider help request scheduler operation was
only covered by the existing test suites under some timing conditions.
testsuites/validation/tc-sched-smp.c | 137 ++++++++++++++++++++++++++-
1 file changed, 135 insertions(+), 2 deletions(-)
diff --git a/testsuites/validation/tc-sched-smp.c b/testsuites/validation/tc-sched-smp.c
index 957a978980..6eb98b5360 100644
--- a/testsuites/validation/tc-sched-smp.c
+++ b/testsuites/validation/tc-sched-smp.c
@@ -7,7 +7,7 @@
- * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2021, 2022 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -55,6 +55,7 @@
#include <rtems/test-scheduler.h>
+#include <rtems/score/schedulersmp.h>
#include "tx-support.h"
@@ -213,6 +214,24 @@
* - Clean up all used resources.
+ * - Create three worker threads and a mutex. Use the mutex and the worker to
+ * check that a not scheduled thread does not get removed from the set of
+ * ready threads of a scheduler when a help request is reconsidered.
+ * - Prevent that worker B can perform a post-switch cleanup.
+ * - Give worker C a lower priority than worker B. Worker B will try to
+ * finish the thread dispatch by doing a post-switch cleanup. The
+ * post-switch cleanup cannot progress since the runner owns the thread
+ * state lock. Wait until the other processor waits on the thread state
+ * lock of worker B.
+ * - Give worker C a higher priority than worker B. Let worker B do its
+ * post-switch cleanup which will carry out the reconsider help requests
+ * for a not scheduled thread.
+ * - Clean up all used resources.
@@ -250,7 +269,17 @@ typedef struct {
* @brief This member contains the worker busy status.
- volatile bool busy[ WORKER_COUNT ];;
+ volatile bool busy[ WORKER_COUNT ];
+ * @brief This member contains an ISR lock context.
+ ISR_lock_Context lock_context;
+ * @brief This member contains a counter.
+ uint32_t counter;
* @brief If this member is true, then the worker shall be in the busy loop.
@@ -686,6 +715,51 @@ static void CleanupOwnerBlocked( Context *ctx )
SetScheduler( ctx->worker_id[ WORKER_C ], SCHEDULER_A_ID, PRIO_HIGH );
+static void ReconsiderHelpRequestB(
+ void *arg,
+ const T_scheduler_event *event,
+ T_scheduler_when when
+ Context *ctx;
+ (void) when;
+ ctx = arg;
+ if ( event->operation == T_SCHEDULER_RECONSIDER_HELP_REQUEST ) {
+ Scheduler_SMP_Node *node;
+ node = (Scheduler_SMP_Node *) event->node;
+ T_eq_int( node->state, SCHEDULER_SMP_NODE_READY );
+ ++ctx->counter;
+static void ReleaseThreadLockB(
+ void *arg,
+ Context *ctx;
+ ctx = arg;
+ if (
+ when == T_SCHEDULER_AFTER &&
+ event->operation == T_SCHEDULER_UPDATE_PRIORITY
+ Thread_Control *worker_b;
+ T_scheduler_set_event_handler( ReconsiderHelpRequestB, ctx );
+ worker_b = GetThread( ctx->worker_id[ WORKER_B ] );
+ T_eq_int( worker_b->Scheduler.state, THREAD_SCHEDULER_READY );
+ _Thread_State_release_critical( worker_b, &ctx->lock_context );
static void Worker( rtems_task_argument arg, WorkerIndex worker )
Context *ctx;
@@ -1232,6 +1306,64 @@ static void ScoreSchedSmpValSmp_Action_16( ScoreSchedSmpValSmp_Context *ctx )
CleanupOwnerBlocked( ctx );
+ * @brief Create three worker threads and a mutex. Use the mutex and the
+ * worker to check that a not scheduled thread does not get removed from the
+ * set of ready threads of a scheduler when a help request is reconsidered.
+static void ScoreSchedSmpValSmp_Action_17( ScoreSchedSmpValSmp_Context *ctx )
+ SetScheduler( ctx->worker_id[ WORKER_B ], SCHEDULER_B_ID, PRIO_NORMAL );
+ SetScheduler( ctx->worker_id[ WORKER_C ], SCHEDULER_B_ID, PRIO_HIGH );
+ SendAndSync( ctx, WORKER_B, EVENT_OBTAIN );
+ SendEvents( ctx->worker_id[ WORKER_A ], EVENT_OBTAIN );
+ SetPriority( ctx->worker_id[ WORKER_A ], PRIO_LOW );
+ MakeBusy( ctx, WORKER_B );
+ WaitForBusy( ctx, WORKER_B );
+ MakeBusy( ctx, WORKER_C );
+ WaitForBusy( ctx, WORKER_C );
+ * Prevent that worker B can perform a post-switch cleanup.
+ _Thread_State_acquire( worker_b, &ctx->lock_context );
+ _ISR_lock_ISR_enable( &ctx->lock_context );
+ * Give worker C a lower priority than worker B. Worker B will try to finish
+ * the thread dispatch by doing a post-switch cleanup. The post-switch
+ * cleanup cannot progress since the runner owns the thread state lock. Wait
+ * until the other processor waits on the thread state lock of worker B.
+ SetPriority( ctx->worker_id[ WORKER_C ], PRIO_LOW );
+ TicketLockWaitForOthers( &worker_b->Join_queue.Queue.Lock, 1 );
+ * Give worker C a higher priority than worker B. Let worker B do its
+ * post-switch cleanup which will carry out the reconsider help requests for
+ * a not scheduled thread.
+ ctx->counter = 0;
+ T_scheduler_set_event_handler( ReleaseThreadLockB, ctx );
+ SetPriority( ctx->worker_id[ WORKER_C ], PRIO_HIGH );
+ T_scheduler_set_event_handler( NULL, NULL );
+ T_eq_u32( ctx->counter, 4 );
+ * Clean up all used resources.
+ StopBusy( ctx, WORKER_B );
+ StopBusy( ctx, WORKER_C );
+ SendAndSync( ctx, WORKER_B, EVENT_RELEASE );
+ SetPriority( ctx->worker_id[ WORKER_A ], PRIO_HIGH );
+ SendEvents( ctx->worker_id[ WORKER_A ], EVENT_RELEASE );
+ SetScheduler( ctx->worker_id[ WORKER_B ], SCHEDULER_A_ID, PRIO_HIGH );
+ SetScheduler( ctx->worker_id[ WORKER_C ], SCHEDULER_A_ID, PRIO_HIGH );
* @fn void T_case_body_ScoreSchedSmpValSmp( void )
@@ -1258,6 +1390,7 @@ T_TEST_CASE_FIXTURE( ScoreSchedSmpValSmp, &ScoreSchedSmpValSmp_Fixture )
ScoreSchedSmpValSmp_Action_14( ctx );
ScoreSchedSmpValSmp_Action_15( ctx );
ScoreSchedSmpValSmp_Action_16( ctx );
+ ScoreSchedSmpValSmp_Action_17( ctx );
2.35.3
