[PATCH] score: Use RTEMS_SMP in _Thread_Create_idle()
Tue Jul 5 07:06:17 UTC 2022
Conditional expressions with inline functions are not optimized away if
optimization is disabled.  Avoid such expressions to prevent dead
branches.
 cpukit/score/src/threadcreateidle.c | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index 9f3c01d118..2f3b09c323 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -111,10 +111,10 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
 void _Thread_Create_idle( void )
+#if defined(RTEMS_SMP)
   uint32_t cpu_max;
   uint32_t cpu_index;
-  _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
   cpu_max = _SMP_Get_processor_maximum();
   for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
@@ -124,4 +124,9 @@ void _Thread_Create_idle( void )
       _Thread_Create_idle_for_CPU( cpu );
+#else
+  _Thread_Create_idle_for_CPU( _Per_CPU_Get() );
+#endif
+  _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
2.35.3
