[PATCH 3/4] GPIO API: Add GPIO API
Duc Doan
dtbpkmte at gmail.com
Tue Jul 5 13:05:06 UTC 2022
bsps/include/bsp/gpio2.h | 538 ++++++++++++++++++++++++++++++++++++
bsps/shared/dev/gpio/gpio.c | 196 +++++++++++++
spec/build/bsps/obj.yml | 2 +-
3 files changed, 735 insertions(+), 1 deletion(-)
create mode 100644 bsps/include/bsp/gpio2.h
create mode 100644 bsps/shared/dev/gpio/gpio.c
diff --git a/bsps/include/bsp/gpio2.h b/bsps/include/bsp/gpio2.h
new file mode 100644
index 0000000000..e99967cd47
--- /dev/null
+++ b/bsps/include/bsp/gpio2.h
@@ -0,0 +1,538 @@
+ * @file
+ * @ingroup rtems_gpio2
+ * @brief RTEMS GPIO new API definition.
+* Copyright (c) 2022 Duc Doan <dtbpkmte at gmail.com>
+* The license and distribution terms for this file may be
+* found in the file LICENSE in this distribution or at
+* http://www.rtems.org/license/LICENSE.
+#ifndef LIBBSP_BSP_GPIO2_H
+#define LIBBSP_BSP_GPIO2_H
+#include <bsp.h>
+#include <rtems.h>
+ * Configure the maximum number of GPIO controllers used in
+ * a application.
+ * The macro CONFIGURE_GPIO_MAXIMUM_CONTROLLERS can be
+ * defined in application code. If it is not defined,
+ * it will default to BSP_GPIO_NUM_CONTROLLERS. If BSP's
+ * number of controllers is not defined, it will default
+ * to 1.
+#ifndef CONFIGURE_GPIO_MAXIMUM_CONTROLLERS
+#ifndef BSP_GPIO_NUM_CONTROLLERS
+#define CONFIGURE_GPIO_MAXIMUM_CONTROLLERS 1
+#else
+#define CONFIGURE_GPIO_MAXIMUM_CONTROLLERS BSP_GPIO_NUM_CONTROLLERS
+#endif /* BSP_GPIO_NUM_CONTROLLERS */
+#endif /* CONFIGURE_GPIO_MAXIMUM_CONTROLLERS */
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @name GPIO data structures
+ * @brief GPIO bit set and reset enumeration.
+typedef enum {
+ RTEMS_GPIO_PIN_RESET = 0,
+ RTEMS_GPIO_PIN_SET = 1
+} rtems_gpio_pin_state;
+ * @brief GPIO pin modes.
+typedef enum {
+ RTEMS_GPIO_PINMODE_OUTPUT = 0,
+ RTEMS_GPIO_PINMODE_OUTPUT_PP = 0,
+ RTEMS_GPIO_PINMODE_OUTPUT_OD = 1,
+ RTEMS_GPIO_PINMODE_INPUT = 2,
+ RTEMS_GPIO_PINMODE_ANALOG = 3,
+ RTEMS_GPIO_PINMODE_BSP_SPECIFIC = 4
+} rtems_gpio_pin_mode;
+ * @brief GPIO pull resistor configuration. Defines pull-up or
+ * pull-down activation.
+typedef enum {
+ RTEMS_GPIO_NOPULL,
+ RTEMS_GPIO_PULLUP,
+ RTEMS_GPIO_PULLDOWN
+} rtems_gpio_pull;
+ * @brief Interrupt modes enumeration.
+typedef enum {
+ RTEMS_GPIO_INT_TRIG_NONE = 0,
+ RTEMS_GPIO_INT_TRIG_FALLING,
+ RTEMS_GPIO_INT_TRIG_RISING,
+ RTEMS_GPIO_INT_TRIG_BOTH_EDGES,
+ RTEMS_GPIO_INT_TRIG_LOW,
+ RTEMS_GPIO_INT_TRIG_HIGH
+} rtems_gpio_interrupt_trig;
+typedef struct rtems_gpio_handlers rtems_gpio_handlers;
+typedef struct rtems_gpio rtems_gpio;
+ * @brief Typedef of the function pointer of an ISR.
+typedef void (*rtems_gpio_isr)(void *);
+ * @brief Structure containing pointers to handlers of a
+ * BSP/driver. Each BSP/driver must define its own
+ * handlers and create an object of this structure
+ * with pointers to those handlers.
+struct rtems_gpio_handlers {
+ * @brief This member is the pointer to an initialize handler.
+ * This handler could be used to perform some set up steps for
+ * a GPIO object (which means a pin or a port).
+ rtems_status_code (*init)(rtems_gpio *);
+ * @brief This member is the pointer to a deinitialize handler.
+ * This handler could be used to deinitialize a GPIO object.
+ rtems_status_code (*deinit)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for setting
+ * pin mode.
+ * Pin modes are from rtems_gpio_pin_mode enumeration.
+ rtems_status_code (*set_pin_mode)(rtems_gpio *, rtems_gpio_pin_mode);
+ * pull resistor mode.
+ * Pull resistor modes are from rtems_gpio_pull enumeration.
+ rtems_status_code (*set_pull)(rtems_gpio *, rtems_gpio_pull);
+ * @brief This member is the pointer to a handler for configuring
+ * interrupt of a pin.
+ * This handler should register ISR and its argument, interrupt
+ * trigger mode, and pull resister mode for the pin.
+ * @note Enabling interrupt should be done in enable_interrupt()
+ * handler.
+ rtems_status_code (*configure_interrupt)(rtems_gpio *, rtems_gpio_isr, void *, rtems_gpio_interrupt_trig, rtems_gpio_pull);
+ * @brief This member is the pointer to a handler for removing
+ * interrupt settings of a pin.
+ * Interrupt settings can be ISR address, pin configuration, etc.
+ rtems_status_code (*remove_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for enabling
+ * interrupt functionality of a pin.
+ rtems_status_code (*enable_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for disabling
+ rtems_status_code (*disable_interrupt)(rtems_gpio *);
+ * @brief This member is the pointer to a handler for reading
+ * the digital value of a pin.
+ * The returned value should be in rtems_gpio_pin_state enum.
+ rtems_status_code (*read)(rtems_gpio *, rtems_gpio_pin_state *);
+ * @brief This member is the pointer to a handler for writing
+ * a digital value to a pin.
+ rtems_status_code (*write)(rtems_gpio *, rtems_gpio_pin_state);
+ * @brief This member is the pointer to a handler for toggling
+ * a pin.
+ * It should change pin state from SET to RESET or vice versa.
+ rtems_status_code (*toggle)(rtems_gpio *);
+ * @brief Structure representing a GPIO object.
+ * BSP/drivers need to define their own GPIO structures with
+ * rtems_gpio being the first member.
+struct rtems_gpio {
+ * @brief This member is a pointer to a structure containing
+ * pointers to handlers of a GPIO controller.
+ const rtems_gpio_handlers *handlers;
+ * @brief This member is a virtual pin number, counting from
+ * 0 (zero).
+ uint32_t virtual_pin;
+ * @name GPIO BSP functions
+ * BSP and drivers need to implement these.
+ * @brief Wrapper to perform all BSP controllers registering
+ * with the GPIO manager.
+ * This function must be implemented by BSP. It should call
+ * rtems_gpio_register() to register each integrated GPIO
+ * controller.
+extern rtems_status_code bsp_gpio_register_controllers(
+ void
+ * @name GPIO operations
+ * @brief Get the GPIO object containing information
+ * about the specified pin.
+ * This function maps the virtual pin to intermediate pin,
+ * and pass to the BSP/driver-specific function to get a
+ * GPIO object.
+ * @note Warning: this function may use malloc(). When you
+ * are done with the GPIO object, call rtems_gpio_destroy()
+ * to avoid memory leak.
+ * @param virt_pin The virtual pin number.
+ * @param[out] out The pointer to the pointer to the output
+ * GPIO object.
+ * @retval RTEMS_SUCCESSFUL
+ * @retval RTEMS_UNSTISFIED if the virtual pin number
+ * is invalid (i.e. out of range)
+extern rtems_status_code rtems_gpio_get(
+ uint32_t virt_pin,
+ rtems_gpio **out
+ * @brief Destroy a GPIO object
+ * This function should be called on an GPIO object which is
+ * no longer used to avoid memory leak. Internally it can
+ * use free().
+ * @param[in] base The pointer to the GPIO object.
+ * @retval RTEMS_UNSATISFIED
+extern rtems_status_code rtems_gpio_destroy(
+ rtems_gpio *base
+ * @brief Registers a GPIO controller with GPIO manager.
+ * This function registers the pointer to BSP/driver-specific
+ * get_gpio() and destroy_gpio() functions. Those two functions
+ * are for creating and destroying GPIO objects. It also takes
+ * the number of pins of each BSP/driver for mapping into a
+ * flat pin numbering system (virtual pin number).
+ * @param get_gpio The pointer to BSP/driver-specific get_gpio()
+ * @param destroy_gpio The pointer to BSP/driver-specific
+ * destroy_gpio()
+ * @param pin_count The number of GPIO pins in the controller
+ * @retval RTEMS_SUCCESSFUL Controller registered successfully
+ * @retval RTEMS_TOO_MANY if the maximum number of controllers are
+ * already registered
+extern rtems_status_code rtems_gpio_register(
+ rtems_status_code (*get_gpio)(uint32_t, rtems_gpio **),
+ rtems_status_code (*destroy_gpio)(rtems_gpio *),
+ uint32_t pin_count
+ * @brief Performs setup for GPIO functionality.
+ * This function calls bsp_gpio_register_controllers() and may
+ * perform additional initialization steps for GPIO functionality.
+ * It should be called by users before all GPIO operations, ideally
+ * when the application starts.
+extern void rtems_gpio_begin(
+ void
+ * @brief Initialize a GPIO object
+ * This function calls the registered BSP/driver-specific handler.
+ * It can be used to initialize a GPIO object/pin/port. It should
+ * be called once for each pin, before all non-setup operations.
+ * @param[in] base The pointer to a GPIO object
+ * @retval RTEMS_SUCCESSFUL GPIO object initialized successfully.
+ * @retval RTEMS_UNSATISFIED Could not initialize a GPIO object.
+ * @retval @see BSP/driver-specific function for other return codes.
+extern rtems_status_code rtems_gpio_init(
+ rtems_gpio *base
+ * @brief Deinitialize a GPIO object
+ * It can be used to deinitialize a GPIO object/pin/port. It
+ * should be called once for each pin, before all non-setup
+ * operations.
+ * @retval RTEMS_SUCCESSFUL GPIO object deinitialized successfully.
+ * @retval RTEMS_UNSATISFIED Could not deinitialize a GPIO object.
+extern rtems_status_code rtems_gpio_deinit(
+ rtems_gpio *base
+ * @brief Sets the pin mode of a pin.
+ * It can be used to set the pin mode for a pin.
+ * @param[in] base The GPIO object to be configured.
+ * @param mode The pin mode from the enumeration rtems_gpio_pin_mode
+ * @retval RTEMS_SUCCESSFUL GPIO configured successfully.
+ * @retval RTEMS_UNSATISFIED Could not set the pin mode.
+extern rtems_status_code rtems_gpio_set_pin_mode(
+ rtems_gpio *base,
+ rtems_gpio_pin_mode mode
+ * @brief Sets the pin's pull resistor configuration.
+ * It can be used to set the pull resistor mode for a pin.
+ * @param mode The pull mode from the enumeration rtems_gpio_pull
+ * @retval RTEMS_UNSATISFIED Could not set the pull resistor mode.
+extern rtems_status_code rtems_gpio_set_pull(
+ rtems_gpio *base,
+ rtems_gpio_pull pull
+ * @brief Configure interrupt on a GPIO pin.
+ * It can be used to set up a pin for interrupt mode.
+ * @note This only configures the interrupt but not enable it. Use
+ * rtems_gpio_enable_interrupt() to actually enable interrupt.
+ * @param isr The pointer to the ISR to be attached to this pin.
+ * @param[in] arg The pointer to the argument of the ISR.
+ * @param trig The trigger mode
+ * @param pull The pull resistor mode
+ * @retval RTEMS_SUCCESSFUL Interrupt configured successfully.
+ * @retval RTEMS_UNSATISFIED Could not configure interrupt.
+extern rtems_status_code rtems_gpio_configure_interrupt(
+ rtems_gpio *base,
+ rtems_gpio_isr isr,
+ void *arg,
+ rtems_gpio_interrupt_trig trig,
+ * @brief Remove interrupt settings for a pin.
+ * It can be used to remove interrupt configuration of a pin like
+ * ISR, ISR argument, pin mode, etc.
+ * @note This only removes the interrupt but not disable it. Use
+ * rtems_gpio_disable_interrupt() to actually disable
+ * interrupt.
+ * @retval RTEMS_SUCCESSFUL Interrupt removed successfully.
+ * @retval RTEMS_UNSATISFIED Could not remove interrupt.
+extern rtems_status_code rtems_gpio_remove_interrupt(
+ rtems_gpio *base
+ * @brief Enable interrupt on a GPIO pin.
+ * @note This function only enables the interrupt (e.g. the vector)
+ * but not configure the pin. Use
+ * rtems_gpio_configure_interrupt() for pin configuration.
+ * @retval RTEMS_SUCCESSFUL Interrupt enabled successfully.
+ * @retval RTEMS_UNSATISFIED Could not enable interrupt.
+extern rtems_status_code rtems_gpio_enable_interrupt(
+ rtems_gpio *base
+ * @brief Disable interrupt on a GPIO pin.
+ * @note This function only disables the interrupt (e.g. the vector)
+ * but not remove the pin's configurations. Use
+ * rtems_gpio_remove_interrupt() for the latter purpose.
+ * @retval RTEMS_SUCCESSFUL Interrupt disabled successfully.
+ * @retval RTEMS_UNSATISFIED Could not disable interrupt.
+extern rtems_status_code rtems_gpio_disable_interrupt(
+ rtems_gpio *base
+ * @brief Writes a digital value to a pin.
+ * @param[in] base The GPIO object that has information about the
+ * pin.
+ * @param value The state to be written to the pin.
+ * @retval RTEMS_SUCCESSFUL Pin successfully written.
+extern rtems_status_code rtems_gpio_write(
+ rtems_gpio *base,
+ rtems_gpio_pin_state value
+ * @brief Reads the digital value of a pin.
+ * pin.
+ * @param[out] value The state of the pin.
+ * @retval RTEMS_SUCCESSFUL Pin succesfully read.
+extern rtems_status_code rtems_gpio_read(
+ rtems_gpio *base,
+ rtems_gpio_pin_state *value
+ * @brief Toggles the state of a GPIO pin.
+ * pin.
+ * @retval RTEMS_SUCCESSFUL Pin successfully toggled.
+extern rtems_status_code rtems_gpio_toggle(
+ rtems_gpio *base
+#ifdef __cplusplus
+#endif /* LIBBSP_BSP_GPIO2_H */
diff --git a/bsps/shared/dev/gpio/gpio.c b/bsps/shared/dev/gpio/gpio.c
index 0000000000..f3aaf0f597
--- /dev/null
+++ b/bsps/shared/dev/gpio/gpio.c
@@ -0,0 +1,196 @@
+ * @file
+ * @brief RTEMS GPIO API implementation.
+ * Copyright (c) 2022 Duc Doan <dtbpkmte at gmail.com>
+#include <bsp/gpio2.h>
+#include <rtems/sysinit.h>
+ * @brief An array to store all registered GPIO controllers.
+static rtems_status_code (*get_gpio_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(uint32_t, rtems_gpio **);
+static rtems_status_code (*destroy_gpio_table[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS])(rtems_gpio *);
+ * @brief An array to store the boundaries of pin index of
+ * GPIO controllers.
+ * Example with 2 16-pin controllers and 1 32-pin controller,
+ * the pin_map will be:
+ * { 0, 16, 32, 64}
+ * Value 0 is always at index 0 for convenience of calculation.
+ * The length of this array is always 1+(number of controllers).
+static uint32_t pin_map[CONFIGURE_GPIO_MAXIMUM_CONTROLLERS+1] = {0};
+ * @brief The number of controllers registered.
+static uint32_t num_ctrl = 0;
+void rtems_gpio_begin(
+ void
+ bsp_gpio_register_controllers();
+rtems_status_code rtems_gpio_register(
+// rtems_interrupt_level level;
+ if (num_ctrl == CONFIGURE_GPIO_MAXIMUM_CONTROLLERS)
+ return RTEMS_TOO_MANY;
+// rtems_interrupt_disable(level);
+ get_gpio_table[num_ctrl] = get_gpio;
+ destroy_gpio_table[num_ctrl] = destroy_gpio;
+ pin_map[num_ctrl+1] = pin_map[num_ctrl] + pin_count;
+ ++num_ctrl;
+// rtems_interrupt_enable(level);
+ return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_gpio_get(
+ rtems_gpio **out
+ uint32_t i, pin;
+ // TODO: binary search
+ for (i = 1; i <= num_ctrl; ++i) {
+ if (virt_pin < pin_map[i]) {
+ pin = virt_pin - pin_map[i-1];
+ break;
+ if (i > num_ctrl)
+ return RTEMS_UNSATISFIED;
+ rtems_status_code sc = (*get_gpio_table[i-1])(pin, out);
+ if (sc == RTEMS_SUCCESSFUL) {
+ (*out)->virtual_pin = virt_pin;
+ return sc;
+rtems_status_code rtems_gpio_destroy(
+ rtems_gpio *base
+ uint32_t i;
+ if (base->virtual_pin < pin_map[i]) {
+ return (*destroy_gpio_table[i-1])(base);
+rtems_status_code rtems_gpio_init(
+ rtems_gpio *base
+ return base->handlers->init(base);
+rtems_status_code rtems_gpio_deinit(
+ rtems_gpio *base
+ return base->handlers->deinit(base);
+rtems_status_code rtems_gpio_set_pin_mode(
+ rtems_gpio *base,
+ return base->handlers->set_pin_mode(base, mode);
+rtems_status_code rtems_gpio_set_pull(
+ rtems_gpio *base,
+ return base->handlers->set_pull(base, pull);
+rtems_status_code rtems_gpio_configure_interrupt(
+ rtems_gpio *base,
+ void *arg,
+ return base->handlers->configure_interrupt(base, isr, arg, trig, pull);
+rtems_status_code rtems_gpio_remove_interrupt(
+ rtems_gpio *base
+ return base->handlers->remove_interrupt(base);
+rtems_status_code rtems_gpio_enable_interrupt(
+ rtems_gpio *base
+ return base->handlers->enable_interrupt(base);
+rtems_status_code rtems_gpio_disable_interrupt(
+ rtems_gpio *base
+ return base->handlers->disable_interrupt(base);
+rtems_status_code rtems_gpio_write(
+ rtems_gpio *base,
+ return base->handlers->write(base, value);
+rtems_status_code rtems_gpio_read(
+ rtems_gpio *base,
+ return base->handlers->read(base, value);
+rtems_status_code rtems_gpio_toggle(
+ rtems_gpio *base
+ return base->handlers->toggle(base);
diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
index ce05c11c0e..a734c1a1f4 100644
--- a/spec/build/bsps/obj.yml
+++ b/spec/build/bsps/obj.yml
@@ -16,7 +16,6 @@ install:
- bsps/include/bsp/default-initial-extension.h
- bsps/include/bsp/fatal.h
- bsps/include/bsp/fdt.h
- - bsps/include/bsp/gpio.h
- bsps/include/bsp/gpio2.h
- bsps/include/bsp/irq-default.h
- bsps/include/bsp/irq-generic.h
@@ -71,6 +70,7 @@ links:
- role: build-dependency
uid: objnosmp
source:
+- bsps/shared/dev/gpio/gpio.c
- bsps/shared/dev/display/disp_hcms29xx.c
- bsps/shared/dev/display/font_hcms29xx.c
- bsps/shared/dev/i2c/i2c-2b-eeprom.c
2.36.1
