[PATCH 4/4] STM32F4 GPIO: Add GPIO implementation for STM32F4
Duc Doan dtbpkmte at gmail.com
Tue Jul 5 13:05:07 UTC 2022
 bsps/arm/stm32f4/gpio/gpio.c                  | 595 ++++++++++++++++++
 bsps/arm/stm32f4/include/bsp.h                |   4 -
 bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h   |  37 ++
 bsps/arm/stm32f4/include/bsp/stm32f4_hal.h    |  17 +
 bsps/arm/stm32f4/start/bspstart.c             |  11 +-
 spec/build/bsps/arm/stm32f4/grp.yml           |   4 +-
 .../build/bsps/arm/stm32f4/optnumgpioctrl.yml |  16 +
 7 files changed, 674 insertions(+), 10 deletions(-)
 create mode 100644 bsps/arm/stm32f4/gpio/gpio.c
 create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
 create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
 create mode 100644 spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
diff --git a/bsps/arm/stm32f4/gpio/gpio.c b/bsps/arm/stm32f4/gpio/gpio.c
new file mode 100644
index 0000000000..e971f91140
--- /dev/null
+++ b/bsps/arm/stm32f4/gpio/gpio.c
@@ -0,0 +1,595 @@
+  * @file
+  * @ingroup rtems_bsp/arm/stm32f4
+  * @brief RTEMS GPIO new API implementation for STM32F4.
+  * @note RTEMS_GPIO_PINMODE_BSP_SPECIFIC is Alternate mode for STM32F4 BSP
+ *  Copyright (c) 2022 Duc Doan <dtbpkmte at gmail.com>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
+#include <rtems.h>
+#include <bsp/stm32f4_gpio.h>
+#include <stdlib.h>
+/*********** Helpers *****************/
+static stm32f4_gpio *get_gpio_from_base(
+    rtems_gpio *base
+/*********** GPIO API ***************/
+static rtems_status_code stm32f4_gpio_get(
+    uint32_t interm_pin,
+    rtems_gpio **out
+static rtems_status_code stm32f4_gpio_destroy(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_init(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_deinit(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_set_pin_mode(
+    rtems_gpio *base,
+    rtems_gpio_pin_mode mode
+static rtems_status_code stm32f4_gpio_set_pull(
+    rtems_gpio *base,
+    rtems_gpio_pull pull
+static rtems_status_code stm32f4_gpio_configure_interrupt(
+    rtems_gpio *base,
+    rtems_gpio_isr isr,
+    void *arg,
+    rtems_gpio_interrupt_trig trig,
+static rtems_status_code stm32f4_gpio_remove_interrupt(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_enable_interrupt(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_disable_interrupt(
+    rtems_gpio *base
+static rtems_status_code stm32f4_gpio_read(
+    rtems_gpio *base,
+    rtems_gpio_pin_state *value
+static rtems_status_code stm32f4_gpio_write(
+    rtems_gpio *base,
+    rtems_gpio_pin_state value
+static rtems_status_code stm32f4_gpio_toggle(
+    rtems_gpio *base
+  * @brief STM32F4 GPIO handlers
+static const rtems_gpio_handlers stm32f4_gpio_handlers = {
+    .init = stm32f4_gpio_init,
+    .deinit = stm32f4_gpio_deinit,
+    .set_pin_mode = stm32f4_gpio_set_pin_mode,
+    .set_pull = stm32f4_gpio_set_pull,
+    .configure_interrupt = stm32f4_gpio_configure_interrupt,
+    .remove_interrupt = stm32f4_gpio_remove_interrupt,
+    .enable_interrupt = stm32f4_gpio_enable_interrupt,
+    .disable_interrupt = stm32f4_gpio_disable_interrupt,
+    .read = stm32f4_gpio_read,
+    .write = stm32f4_gpio_write,
+    .toggle = stm32f4_gpio_toggle
+static GPIO_TypeDef *GPIOx[] = {
+    GPIOA, GPIOB, GPIOC, GPIOD, GPIOE,
+    GPIOF, GPIOG, GPIOH, GPIOI,
+#ifdef STM32F429X
+    GPIOJ, GPIOK
+#endif /* STM32F429X */
+static uint16_t GPIO_PIN_x[] = {
+    GPIO_PIN_0,
+    GPIO_PIN_1,
+    GPIO_PIN_2,
+    GPIO_PIN_3,
+    GPIO_PIN_4,
+    GPIO_PIN_5,
+    GPIO_PIN_6,
+    GPIO_PIN_7,
+    GPIO_PIN_8,
+    GPIO_PIN_9,
+    GPIO_PIN_10,
+    GPIO_PIN_11,
+    GPIO_PIN_12,
+    GPIO_PIN_13,
+    GPIO_PIN_14,
+    GPIO_PIN_15
+static uint32_t LL_EXTI_LINE_x[] = {
+    LL_EXTI_LINE_0,
+    LL_EXTI_LINE_1,
+    LL_EXTI_LINE_2,
+    LL_EXTI_LINE_3,
+    LL_EXTI_LINE_4,
+    LL_EXTI_LINE_5,
+    LL_EXTI_LINE_6,
+    LL_EXTI_LINE_7,
+    LL_EXTI_LINE_8,
+    LL_EXTI_LINE_9,
+    LL_EXTI_LINE_10,
+    LL_EXTI_LINE_11,
+    LL_EXTI_LINE_12,
+    LL_EXTI_LINE_13,
+    LL_EXTI_LINE_14,
+    LL_EXTI_LINE_15
+static unsigned int EXTIx_IRQn[] = {
+    EXTI0_IRQn,
+    EXTI1_IRQn,
+    EXTI2_IRQn,
+    EXTI3_IRQn,
+    EXTI4_IRQn,
+    EXTI9_5_IRQn,
+    EXTI9_5_IRQn,
+    EXTI9_5_IRQn,
+    EXTI9_5_IRQn,
+    EXTI9_5_IRQn,
+    EXTI15_10_IRQn,
+    EXTI15_10_IRQn,
+    EXTI15_10_IRQn,
+    EXTI15_10_IRQn,
+    EXTI15_10_IRQn,
+    EXTI15_10_IRQn
+  * @brief Converts intermediate pin number to port pointer.
+  * Intermediate pin number is a way of numerically labeling
+  * pins. Pins are labeled incrementally across all ports.
+  * Pins 0-15 from port A are 0-15. Pins 0-15 from port B are
+  * 16-31. And so on.
+  * @param interm_pin is the intermediate pin number
+#define STM32F4_GET_PORT(interm_pin) (GPIOx[ ( interm_pin ) / 16 ])
+  * @brief Converts intermediate pin number to 0-15.
+#define STM32F4_GET_PIN_0_15(interm_pin) (( interm_pin ) % 16)
+  * @brief Converts pin number from 0-15 to HAL pin mask.
+  * @param pin is the pin number from 0-15
+#define STM32F4_GET_HAL_GPIO_PIN(pin) (GPIO_PIN_x[( pin )])
+  * @brief Get EXTI Line from pin number 0-15
+#define STM32F4_GET_LL_EXTI_LINE(pin) (LL_EXTI_LINE_x[( pin )])
+  * @brief Get EXTI IRQ number from pin 0-15
+#define STM32F4_GET_EXTI_IRQn(pin) (EXTIx_IRQn[( pin )])
+/************** Interrupt manager *****************/
+typedef struct {
+    void *arg;
+    stm32f4_gpio *gpio;
+} stm32f4_interrupt_arg;
+typedef struct {
+    stm32f4_interrupt_arg arg;
+    rtems_gpio_isr isr;
+} stm32f4_interrupt;
+static stm32f4_interrupt isr_table[16];
+void exti_handler(void *arg);
+/************* Helpers implementation ********************/
+    rtems_gpio *base
+    return RTEMS_CONTAINER_OF(base, stm32f4_gpio, base);
+/********** STM32F4 GPIO API functions ************/
+rtems_status_code bsp_gpio_register_controllers(
+    void
+    return rtems_gpio_register(
+            stm32f4_gpio_get,
+            stm32f4_gpio_destroy,
+            sizeof(GPIOx)/sizeof(GPIOx[0])*16
+rtems_status_code stm32f4_gpio_get(
+    rtems_gpio **out
+    stm32f4_gpio *tmp = malloc(sizeof(stm32f4_gpio));
+    if (tmp == NULL) {
+        return RTEMS_NO_MEMORY;
+    tmp->base = (rtems_gpio) { .handlers = &stm32f4_gpio_handlers };
+    tmp->pin = STM32F4_GET_PIN_0_15(interm_pin);
+    tmp->port = STM32F4_GET_PORT(interm_pin);
+    *out = (rtems_gpio *) tmp;
+    return RTEMS_SUCCESSFUL;
+rtems_status_code stm32f4_gpio_destroy(
+    rtems_gpio *base
+    stm32f4_gpio *gpio = get_gpio_from_base(base);
+    free(gpio);
+rtems_status_code stm32f4_gpio_init(rtems_gpio *base) {
+    switch ((uintptr_t) gpio->port) {
+        case (uintptr_t) GPIOA:
+            __HAL_RCC_GPIOA_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOB:
+            __HAL_RCC_GPIOB_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOC:
+            __HAL_RCC_GPIOC_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOD:
+            __HAL_RCC_GPIOD_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOE:
+            __HAL_RCC_GPIOE_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOF:
+            __HAL_RCC_GPIOF_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOG:
+            __HAL_RCC_GPIOG_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOH:
+            __HAL_RCC_GPIOH_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOI:
+            __HAL_RCC_GPIOI_CLK_ENABLE();
+            break;
+#ifdef STM32F429X
+        case (uintptr_t) GPIOJ:
+            __HAL_RCC_GPIOJ_CLK_ENABLE();
+            break;
+        case (uintptr_t) GPIOK:
+            __HAL_RCC_GPIOK_CLK_ENABLE();
+            break;
+        default:
+            return RTEMS_UNSATISFIED;
+rtems_status_code stm32f4_gpio_deinit(rtems_gpio *base) {
+            __HAL_RCC_GPIOA_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOB_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOC_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOD_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOE_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOF_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOG_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOH_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOI_CLK_DISABLE();
+            break;
+#ifdef STM32F429X
+            __HAL_RCC_GPIOJ_CLK_DISABLE();
+            break;
+            __HAL_RCC_GPIOK_CLK_DISABLE();
+            break;
+        default:
+  * @note Warning: only one pin can be passed as argument
+  * @note If using interrupt mode, use rtems_gpio_configure_interrupt().
+  * @note If using alternate mode, use rtems_gpio_configure().
+rtems_status_code stm32f4_gpio_set_pin_mode(
+    rtems_gpio *base,
+    uint32_t pin_mask = STM32F4_GET_HAL_GPIO_PIN(gpio->pin);
+    uint32_t stm32f4_mode, stm32f4_output_type;
+    switch (mode) {
+    case RTEMS_GPIO_PINMODE_OUTPUT_PP:
+        stm32f4_mode = LL_GPIO_MODE_OUTPUT;
+        stm32f4_output_type = LL_GPIO_OUTPUT_PUSHPULL;
+        break;
+    case RTEMS_GPIO_PINMODE_OUTPUT_OD:
+        stm32f4_output_type = LL_GPIO_OUTPUT_OPENDRAIN;
+        break;
+    case RTEMS_GPIO_PINMODE_INPUT:
+        stm32f4_mode = LL_GPIO_MODE_INPUT;
+        break;
+    case RTEMS_GPIO_PINMODE_ANALOG:
+        stm32f4_mode = LL_GPIO_MODE_ANALOG;
+        break;
+    case RTEMS_GPIO_PINMODE_BSP_SPECIFIC:
+        stm32f4_mode = LL_GPIO_MODE_ALTERNATE;
+        break;
+    default:
+        /* illegal argument */
+    LL_GPIO_SetPinMode(gpio->port, pin_mask, stm32f4_mode);
+    if (stm32f4_mode == LL_GPIO_MODE_OUTPUT) {
+        LL_GPIO_SetPinOutputType(gpio->port, pin_mask, stm32f4_output_type);
+rtems_status_code stm32f4_gpio_set_pull(
+    rtems_gpio *base,
+    uint32_t stm32f4_pull;
+    switch (pull) {
+    case RTEMS_GPIO_NOPULL:
+        stm32f4_pull = LL_GPIO_PULL_NO;
+        break;
+    case RTEMS_GPIO_PULLUP:
+        stm32f4_pull = LL_GPIO_PULL_UP;
+        break;
+    case RTEMS_GPIO_PULLDOWN:
+        stm32f4_pull = LL_GPIO_PULL_DOWN;
+        break;
+    default:
+        /* Illegal argument */
+    LL_GPIO_SetPinPull(gpio->port, pin_mask, stm32f4_pull);
+  * TODO
+  * @note This function defaults to not using pull resistor.
+  *       Use rtems_gpio_set_pull() afterwards to change.
+rtems_status_code stm32f4_gpio_configure_interrupt(
+    rtems_gpio *base,
+    void *arg,
+    // configure pin
+    GPIO_InitTypeDef hal_conf;
+    switch (trig) {
+    case RTEMS_GPIO_INT_TRIG_NONE:
+    case RTEMS_GPIO_INT_TRIG_FALLING:
+        hal_conf.Mode = GPIO_MODE_IT_FALLING;
+        break;
+    case RTEMS_GPIO_INT_TRIG_RISING:
+        hal_conf.Mode = GPIO_MODE_IT_RISING;
+        break;
+    case RTEMS_GPIO_INT_TRIG_BOTH_EDGES:
+        hal_conf.Mode = GPIO_MODE_IT_RISING_FALLING;
+        break;
+    default:
+        /* Invalid argument */
+    switch (pull) {
+        hal_conf.Pull = GPIO_NOPULL;
+        break;
+        hal_conf.Pull = GPIO_PULLUP;
+        break;
+        hal_conf.Pull = GPIO_PULLDOWN;
+        break;
+    default:
+    hal_conf.Pin = pin_mask;
+    HAL_GPIO_Init(gpio->port, &hal_conf);
+    // RTEMS interrupt config
+    isr_table[gpio->pin] = (stm32f4_interrupt){
+        .arg = {
+            .arg = arg,
+            .gpio = gpio
+        .isr = isr
+    rtems_option opt = gpio->pin < 5 ?
+                        RTEMS_INTERRUPT_UNIQUE :
+                        RTEMS_INTERRUPT_SHARED;
+    rtems_status_code sc = rtems_interrupt_handler_install(
+            STM32F4_GET_EXTI_IRQn(gpio->pin),
+            NULL,
+            opt,
+            exti_handler,
+            &isr_table[gpio->pin].arg
+    return sc;
+rtems_status_code stm32f4_gpio_remove_interrupt(
+    rtems_gpio *base
+    rtems_status_code sc = rtems_interrupt_handler_remove(
+            exti_handler,
+            &isr_table[gpio->pin].arg);
+    if (sc == RTEMS_SUCCESSFUL) {
+        isr_table[gpio->pin] = (stm32f4_interrupt){0};
+    return sc;
+rtems_status_code stm32f4_gpio_enable_interrupt(
+    rtems_gpio *base
+    LL_EXTI_EnableIT_0_31(STM32F4_GET_LL_EXTI_LINE(gpio->pin));
+rtems_status_code stm32f4_gpio_disable_interrupt(
+    rtems_gpio *base
+    LL_EXTI_DisableIT_0_31(STM32F4_GET_LL_EXTI_LINE(gpio->pin));
+rtems_status_code stm32f4_gpio_write(
+    rtems_gpio *base,
+    HAL_GPIO_WritePin(gpio->port, pin_mask, value);
+rtems_status_code stm32f4_gpio_read(
+    rtems_gpio *base,
+    *value = HAL_GPIO_ReadPin(gpio->port, pin_mask);
+rtems_status_code stm32f4_gpio_toggle(
+    rtems_gpio *base
+    HAL_GPIO_TogglePin(gpio->port, pin_mask);
+void exti_handler(void *arg) {
+    stm32f4_interrupt_arg *stm32_arg = (stm32f4_interrupt_arg *) arg;
+    uint32_t pin_mask = STM32F4_GET_HAL_GPIO_PIN(stm32_arg->gpio->pin);
+    if(__HAL_GPIO_EXTI_GET_IT(pin_mask) != RESET)
+        __HAL_GPIO_EXTI_CLEAR_IT(pin_mask);
+        (*isr_table[stm32_arg->gpio->pin].isr)(stm32_arg->arg);
diff --git a/bsps/arm/stm32f4/include/bsp.h b/bsps/arm/stm32f4/include/bsp.h
index 42a74e109d..968545cd5a 100644
--- a/bsps/arm/stm32f4/include/bsp.h
+++ b/bsps/arm/stm32f4/include/bsp.h
@@ -42,10 +42,6 @@ extern "C" {
 #define BSP_ARMV7M_SYSTICK_FREQUENCY STM32F4_HCLK
-#ifdef __rtems__
-void Error_Handler(void);
-#endif /* __rtems__ */
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h b/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
index 0000000000..8f21539709
--- /dev/null
+++ b/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
@@ -0,0 +1,37 @@
+#ifndef LIBBSP_ARM_STM32F4_BSP_GPIO
+#define LIBBSP_ARM_STM32F4_BSP_GPIO
+#include <stdbool.h>
+#include <stm32f4xx.h>
+#include <stm32f4xx_ll_gpio.h>
+#include <stm32f4xx_ll_exti.h>
+#include <bsp/gpio2.h>
+  * @brief STM32F4 BSP GPIO structure
+typedef struct {
+      * @brief This member is a rtems_gpio object.
+    rtems_gpio base;
+      *@brief This member is the pin number from 0 to 15.
+    uint32_t pin;
+      * @brief This member is HAL GPIOx pointer.
+    GPIO_TypeDef *port;
+} stm32f4_gpio;
+#endif /* LIBBSP_ARM_STM32F4_BSP_GPIO */
diff --git a/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h b/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
index 0000000000..9e88b39067
--- /dev/null
+++ b/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
@@ -0,0 +1,17 @@
+#ifndef LIBBSP_ARM_STM32F4_BSP_STM32F4HAL_H
+#define LIBBSP_ARM_STM32F4_BSP_STM32F4HAL_H
+#include <stm32f4xx_hal.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+void stm32f4_clk_enable();
+void stm32f4_clk_disable();
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/arm/stm32f4/start/bspstart.c b/bsps/arm/stm32f4/start/bspstart.c
index bec99dee25..46569a93d5 100644
--- a/bsps/arm/stm32f4/start/bspstart.c
+++ b/bsps/arm/stm32f4/start/bspstart.c
@@ -19,7 +19,6 @@
 #ifdef __rtems__
-#include <bsp/gpio2.h>
 #ifdef STM32F4_FAMILY_F4XXXX
@@ -47,7 +46,7 @@ uint32_t HAL_GetTick(void)
   * @brief  This function is executed in case of error occurrence.
   * @retval None
+static void Error_Handler(void)
   /* USER CODE BEGIN Error_Handler_Debug */
   /* User can add his own implementation to report the HAL error return state */
@@ -213,11 +212,13 @@ static void init_main_osc( void )
 #ifdef __rtems__
     HAL_Init();
-    rtems_status_code status = rtems_gpio_initialize();
+   rtems_status_code status = rtems_gpio_initialize();
     if (status != RTEMS_SUCCESSFUL) {
         Error_Handler();
-    status = SystemClock_Config();
+    rtems_status_code status = SystemClock_Config();
         Error_Handler();
@@ -470,7 +471,7 @@ void bsp_start( void )
     init_main_osc();
-#ifdef __rtems__
+#ifndef __rtems__
     stm32f4_gpio_set_config_array( &stm32f4_start_config_gpio[ 0 ] );
diff --git a/spec/build/bsps/arm/stm32f4/grp.yml b/spec/build/bsps/arm/stm32f4/grp.yml
index 410233b10e..2d5d9412db 100644
--- a/spec/build/bsps/arm/stm32f4/grp.yml
+++ b/spec/build/bsps/arm/stm32f4/grp.yml
@@ -14,7 +14,7 @@ links:
 - role: build-dependency
   uid: abi
-  uid: obj
+  uid: optnumgpioctrl
   uid: optenhal
@@ -63,6 +63,8 @@ links:
   uid: ../../objirq
   uid: ../../objmem
+- role: build-dependency
+  uid: obj
   uid: ../../bspopts
 type: build
diff --git a/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml b/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
index 0000000000..da21d9c62c
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 Duc Doan (dtbpkmte at gmail.com)
+default: 1
+default-by-variant: []
+description: |
+  Number of GPIO controllers of this BSP.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_GPIO_NUM_CONTROLLERS
+type: build
2.36.1
