[PATCH] rtems: Simplify rtems_scheduler_ident()
Gedare Bloom
gedare at rtems.org
Wed Jul 6 18:15:35 UTC 2022
ok
On Tue, Jul 5, 2022 at 2:19 AM Sebastian Huber
> Use early returns to simplify rtems_scheduler_ident().
> cpukit/rtems/src/schedulerident.c | 27 +++++++++++----------------
> 1 file changed, 11 insertions(+), 16 deletions(-)
> diff --git a/cpukit/rtems/src/schedulerident.c b/cpukit/rtems/src/schedulerident.c
> index e73d3d743a..60e7765ccd 100644
> --- a/cpukit/rtems/src/schedulerident.c
> +++ b/cpukit/rtems/src/schedulerident.c
> @@ -10,7 +10,7 @@
> - * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> + * Copyright (C) 2014, 2022 embedded brains GmbH
> * Redistribution and use in source and binary forms, with or without
> * modification, are permitted provided that the following conditions
> @@ -46,25 +46,20 @@ rtems_status_code rtems_scheduler_ident(
> rtems_id *id
> - rtems_status_code sc;
> + size_t i;
> - if ( id != NULL ) {
> - size_t n = _Scheduler_Count;
> - size_t i;
> - sc = RTEMS_INVALID_NAME;
> + if ( id == NULL ) {
> + return RTEMS_INVALID_ADDRESS;
> - for ( i = 0 ; i < n && sc == RTEMS_INVALID_NAME ; ++i ) {
> - const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
> + for ( i = 0; i < _Scheduler_Count; ++i ) {
> + const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
> - if ( scheduler->name == name ) {
> - *id = _Scheduler_Build_id( i );
> - sc = RTEMS_SUCCESSFUL;
> + if ( scheduler->name == name ) {
> + *id = _Scheduler_Build_id( i );
> + return RTEMS_SUCCESSFUL;
> - } else {
> - sc = RTEMS_INVALID_ADDRESS;
> - return sc;
> + return RTEMS_INVALID_NAME;
> 2.35.3
> devel mailing list
> devel at rtems.org
