[PATCH] rtems: Simplify rtems_scheduler_ident()
Sebastian Huber
Tue Jul 5 08:19:19 UTC 2022
Use early returns to simplify rtems_scheduler_ident().
cpukit/rtems/src/schedulerident.c | 27 +++++++++++----------------
1 file changed, 11 insertions(+), 16 deletions(-)
diff --git a/cpukit/rtems/src/schedulerident.c b/cpukit/rtems/src/schedulerident.c
index e73d3d743a..60e7765ccd 100644
--- a/cpukit/rtems/src/schedulerident.c
+++ b/cpukit/rtems/src/schedulerident.c
@@ -10,7 +10,7 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * Copyright (C) 2014, 2022 embedded brains GmbH
* modification, are permitted provided that the following conditions
@@ -46,25 +46,20 @@ rtems_status_code rtems_scheduler_ident(
rtems_id *id
- rtems_status_code sc;
+ size_t i;
- if ( id != NULL ) {
- size_t n = _Scheduler_Count;
- size_t i;
- sc = RTEMS_INVALID_NAME;
+ if ( id == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
- for ( i = 0 ; i < n && sc == RTEMS_INVALID_NAME ; ++i ) {
- const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
+ for ( i = 0; i < _Scheduler_Count; ++i ) {
+ const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
- if ( scheduler->name == name ) {
- *id = _Scheduler_Build_id( i );
- sc = RTEMS_SUCCESSFUL;
+ if ( scheduler->name == name ) {
+ *id = _Scheduler_Build_id( i );
+ return RTEMS_SUCCESSFUL;
- } else {
- sc = RTEMS_INVALID_ADDRESS;
- return sc;
+ return RTEMS_INVALID_NAME;
2.35.3
