[tools] tester: Remove hard coded time limit for SIS
Chris Johns
chrisj at rtems.org
Thu Jul 7 07:29:33 UTC 2022
-1 from me.
On 7/7/2022 4:44 pm, Sebastian Huber wrote:
> Remove the hard coded time limit in the SIS configuration which would overrule
> the general tester settings (for example the --timeout command line option).
> Users can set a SIS time limit in the configuration if necessary.
I would this to be left as is and not to be the other way around.
What is the problem with you having a user config for this?
I am now starting to wonder if you have made some dependencies on this for
reasons I cannot explain.
