[tools] tester: Remove hard coded time limit for SIS
Thu Jul 7 07:34:06 UTC 2022
On 07/07/2022 09:29, Chris Johns wrote:
> -1 from me.
> On 7/7/2022 4:44 pm, Sebastian Huber wrote:
>> Remove the hard coded time limit in the SIS configuration which would overrule
>> the general tester settings (for example the --timeout command line option).
>> Users can set a SIS time limit in the configuration if necessary.
> I would this to be left as is and not to be the other way around.
> What is the problem with you having a user config for this?
> I am now starting to wonder if you have made some dependencies on this for
> reasons I cannot explain.
I have no idea way you are so hesitant to remove this default limit. I
just want to run the tests with a higher timeout defined by the command
line --timeout option. That's it. I didn't anticipate that this is such
an issue.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
