[newlib 44/65] Catch up with 6edfd179c86: mechanically rename IFCAP_NOMAP to IFCAP_MEXTPG.
Sebastian Huber
Thu Jul 7 11:58:51 UTC 2022
Originally IFCAP_NOMAP meant that the mbuf has external storage pointer
that points to unmapped address. Then, this was extended to array of
such pointers. Then, such mbufs were augmented with header/trailer.
Basically, extended mbufs are extended, and set of features is subject
to change. The new name should be generic enough to avoid further
renaming.
newlib/libc/sys/rtems/include/net/if.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/newlib/libc/sys/rtems/include/net/if.h b/newlib/libc/sys/rtems/include/net/if.h
index 23d6cc756..a469a1f60 100644
--- a/newlib/libc/sys/rtems/include/net/if.h
+++ b/newlib/libc/sys/rtems/include/net/if.h
@@ -245,7 +245,7 @@ struct if_data {
#define IFCAP_HWSTATS 0x800000 /* manages counters internally */
#define IFCAP_TXRTLMT 0x1000000 /* hardware supports TX rate limiting */
#define IFCAP_HWRXTSTMP 0x2000000 /* hardware rx timestamping */
-#define IFCAP_NOMAP 0x4000000 /* can TX unmapped mbufs */
+#define IFCAP_MEXTPG 0x4000000 /* understands M_EXTPG mbufs */
#define IFCAP_TXTLS4 0x8000000 /* can do TLS encryption and segmentation for TCP */
#define IFCAP_TXTLS6 0x10000000 /* can do TLS encryption and segmentation for TCP6 */
#define IFCAP_VXLAN_HWCSUM 0x20000000 /* can do IFCAN_HWCSUM on VXLANs */
2.35.3
