[newlib 43/65] Add tcgetwinsize(3) and tcsetwinsize(3) to termios
Sebastian Huber
Thu Jul 7 11:58:50 UTC 2022
These functions get/set tty winsize respectively, and are trivial wrappers
around corresponding termio ioctls.
The functions are expected to be a part of POSIX.1 issue 8:
https://www.austingroupbugs.net/view.php?id=1151#c3856.
They are currently available in NetBSD and in musl libc.
PR: 251868
Submitted by: Soumendra Ganguly <soumendraganguly at gmail.com>
MFC after: 1 week
Differential Revision: https://reviews.freebsd.org/D27650
newlib/libc/sys/rtems/include/sys/_winsize.h | 49 ++++++++++++++++++++
newlib/libc/sys/rtems/include/sys/ttycom.h | 12 +----
newlib/libc/sys/rtems/include/termios.h | 6 +++
3 files changed, 56 insertions(+), 11 deletions(-)
create mode 100644 newlib/libc/sys/rtems/include/sys/_winsize.h
diff --git a/newlib/libc/sys/rtems/include/sys/_winsize.h b/newlib/libc/sys/rtems/include/sys/_winsize.h
new file mode 100644
index 000000000..78d0b8a6e
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/sys/_winsize.h
@@ -0,0 +1,49 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1988, 1989, 1993, 1994
+ * The Regents of the University of California. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)ttycom.h 8.1 (Berkeley) 3/28/94
+ * $FreeBSD$
+#ifndef _SYS__WINSIZE_H_
+#define _SYS__WINSIZE_H_
+ * Window/terminal size structure. This information is stored by the kernel
+ * in order to provide a consistent interface, but is not used by the kernel.
+struct winsize {
+ unsigned short ws_row; /* rows, in characters */
+ unsigned short ws_col; /* columns, in characters */
+ unsigned short ws_xpixel; /* horizontal size, pixels */
+ unsigned short ws_ypixel; /* vertical size, pixels */
+#endif /* !_SYS__WINSIZE_H_ */
diff --git a/newlib/libc/sys/rtems/include/sys/ttycom.h b/newlib/libc/sys/rtems/include/sys/ttycom.h
index 5aabb074a..a7309d4c5 100644
--- a/newlib/libc/sys/rtems/include/sys/ttycom.h
+++ b/newlib/libc/sys/rtems/include/sys/ttycom.h
@@ -41,23 +41,13 @@
#define _SYS_TTYCOM_H_
#include <sys/ioccom.h>
+#include <sys/_winsize.h>
* Tty ioctl's except for those supported only for backwards compatibility
* with the old tty driver.
- * Window/terminal size structure. This information is stored by the kernel
- * in order to provide a consistent interface, but is not used by the kernel.
-struct winsize {
- unsigned short ws_row; /* rows, in characters */
- unsigned short ws_col; /* columns, in characters */
- unsigned short ws_xpixel; /* horizontal size, pixels */
- unsigned short ws_ypixel; /* vertical size, pixels */
/* 0-2 compat */
/* 3-7 unused */
/* 8-10 compat */
diff --git a/newlib/libc/sys/rtems/include/termios.h b/newlib/libc/sys/rtems/include/termios.h
index ce31d447f..9b808329a 100644
--- a/newlib/libc/sys/rtems/include/termios.h
+++ b/newlib/libc/sys/rtems/include/termios.h
@@ -38,6 +38,9 @@
#include <sys/cdefs.h>
#include <sys/_termios.h>
#include <sys/_types.h>
+#if __BSD_VISIBLE
+#endif
#ifndef _PID_T_DECLARED
typedef __pid_t pid_t;
@@ -92,6 +95,9 @@ int tcsetsid(int, pid_t);
void cfmakeraw(struct termios *);
void cfmakesane(struct termios *);
int cfsetspeed(struct termios *, speed_t);
+int tcgetwinsize(int, struct winsize *);
+int tcsetwinsize(int, const struct winsize *);
#endif
__END_DECLS
2.35.3
