[PATCH 02/23] bsps/i386/shared/pci/pci_io.c:Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:29 UTC 2022
Updates #3053.
bsps/i386/shared/pci/pci_io.c | 25 ++++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/bsps/i386/shared/pci/pci_io.c b/bsps/i386/shared/pci/pci_io.c
index b6cd1005f0..60b855ed81 100644
--- a/bsps/i386/shared/pci/pci_io.c
+++ b/bsps/i386/shared/pci/pci_io.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 2016.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
