[PATCH 01/23] bsps/i386/pc386: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:28 UTC 2022
Updates #3053.
bsps/i386/pc386/clock/ckinit.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/conscfg.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/console_control.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/console_select.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/exar17d15x.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/gdb_glue.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/gdb_select.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/printk_support.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/rtd316.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/serial_mouse_config.c | 25 ++++++++++++++++---
bsps/i386/pc386/console/vgacons.c | 25 ++++++++++++++++---
bsps/i386/pc386/include/bsp/bspimpl.h | 25 ++++++++++++++++---
bsps/i386/pc386/include/bsp/exar17d15x.h | 25 ++++++++++++++++---
bsps/i386/pc386/include/bsp/rtd316.h | 25 ++++++++++++++++---
bsps/i386/pc386/include/rtems/vgacons.h | 25 ++++++++++++++++---
bsps/i386/pc386/start/bsp_fatal_halt.c | 25 ++++++++++++++++---
bsps/i386/pc386/start/bspidle.S | 2 ++
bsps/i386/pc386/start/bspreset.c | 25 ++++++++++++++++---
18 files changed, 376 insertions(+), 51 deletions(-)
diff --git a/bsps/i386/pc386/clock/ckinit.c b/bsps/i386/pc386/clock/ckinit.c
index 2df1818dd3..3fdb0d5afe 100644
--- a/bsps/i386/pc386/clock/ckinit.c
+++ b/bsps/i386/pc386/clock/ckinit.c
@@ -1,3 +1,5 @@
* @file
@@ -18,9 +20,26 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/conscfg.c b/bsps/i386/pc386/console/conscfg.c
index 8aa8ab5c2a..e45631504c 100644
--- a/bsps/i386/pc386/console/conscfg.c
+++ b/bsps/i386/pc386/console/conscfg.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2014, 2016.
+ * are met:
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/console_control.c b/bsps/i386/pc386/console/console_control.c
index a04ae2bc3b..9647c56630 100644
--- a/bsps/i386/pc386/console/console_control.c
+++ b/bsps/i386/pc386/console/console_control.c
@@ -1,3 +1,5 @@
* This file is an extension of the generic console driver
* shell used by all console drivers using libchip, it contains
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/console_select.c b/bsps/i386/pc386/console/console_select.c
index 1c064fb271..6c7af215ba 100644
--- a/bsps/i386/pc386/console/console_select.c
+++ b/bsps/i386/pc386/console/console_select.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 2011-2012, 2016.
+ * are met:
#include <limits.h>
diff --git a/bsps/i386/pc386/console/exar17d15x.c b/bsps/i386/pc386/console/exar17d15x.c
index 5cf615ac86..1e6cb6fbeb 100644
--- a/bsps/i386/pc386/console/exar17d15x.c
+++ b/bsps/i386/pc386/console/exar17d15x.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/gdb_glue.c b/bsps/i386/pc386/console/gdb_glue.c
index aededea7e8..74f086ba72 100644
--- a/bsps/i386/pc386/console/gdb_glue.c
+++ b/bsps/i386/pc386/console/gdb_glue.c
@@ -1,3 +1,5 @@
/* gdb_glue
* Interface to initialize the GDB.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1998.
+ * are met:
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/gdb_select.c b/bsps/i386/pc386/console/gdb_select.c
index 0fe3b2cdad..c8797ebe5d 100644
--- a/bsps/i386/pc386/console/gdb_select.c
+++ b/bsps/i386/pc386/console/gdb_select.c
@@ -1,3 +1,5 @@
* @file
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 2016.
* Chris Johns <chrisj at rtems.org>
+ * are met:
diff --git a/bsps/i386/pc386/console/printk_support.c b/bsps/i386/pc386/console/printk_support.c
index c9e003dab0..324bc58cd9 100644
--- a/bsps/i386/pc386/console/printk_support.c
+++ b/bsps/i386/pc386/console/printk_support.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/bsps/i386/pc386/console/rtd316.c b/bsps/i386/pc386/console/rtd316.c
index c8f3c3a6ef..1669c633b7 100644
--- a/bsps/i386/pc386/console/rtd316.c
+++ b/bsps/i386/pc386/console/rtd316.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
#include <bsp.h>
diff --git a/bsps/i386/pc386/console/serial_mouse_config.c b/bsps/i386/pc386/console/serial_mouse_config.c
index a8a0313954..f1ff2dab17 100644
--- a/bsps/i386/pc386/console/serial_mouse_config.c
+++ b/bsps/i386/pc386/console/serial_mouse_config.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/bsps/i386/pc386/console/vgacons.c b/bsps/i386/pc386/console/vgacons.c
index 2886496e51..9aa1ed4fb1 100644
--- a/bsps/i386/pc386/console/vgacons.c
+++ b/bsps/i386/pc386/console/vgacons.c
@@ -1,3 +1,5 @@
* This file contains the termios TTY driver for the i386
* vga.
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/i386/pc386/include/bsp/bspimpl.h b/bsps/i386/pc386/include/bsp/bspimpl.h
index 314fb91eb9..35d2c0974c 100644
--- a/bsps/i386/pc386/include/bsp/bspimpl.h
+++ b/bsps/i386/pc386/include/bsp/bspimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef __BSPIMPL_h
diff --git a/bsps/i386/pc386/include/bsp/exar17d15x.h b/bsps/i386/pc386/include/bsp/exar17d15x.h
index ea785a397b..79de882219 100644
--- a/bsps/i386/pc386/include/bsp/exar17d15x.h
+++ b/bsps/i386/pc386/include/bsp/exar17d15x.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _BSP_EXAR17D15X__h
diff --git a/bsps/i386/pc386/include/bsp/rtd316.h b/bsps/i386/pc386/include/bsp/rtd316.h
index 28fe6f47db..9a2bb62fd6 100644
--- a/bsps/i386/pc386/include/bsp/rtd316.h
+++ b/bsps/i386/pc386/include/bsp/rtd316.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _BSP_RTD_316_h
diff --git a/bsps/i386/pc386/include/rtems/vgacons.h b/bsps/i386/pc386/include/rtems/vgacons.h
index de80ef3664..61a55bf86a 100644
--- a/bsps/i386/pc386/include/rtems/vgacons.h
+++ b/bsps/i386/pc386/include/rtems/vgacons.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _VGACONS_H_
diff --git a/bsps/i386/pc386/start/bsp_fatal_halt.c b/bsps/i386/pc386/start/bsp_fatal_halt.c
index 954955dee1..e55de824c2 100644
--- a/bsps/i386/pc386/start/bsp_fatal_halt.c
+++ b/bsps/i386/pc386/start/bsp_fatal_halt.c
@@ -1,10 +1,29 @@
+ * are met:
#include <rtems/score/cpuimpl.h>
diff --git a/bsps/i386/pc386/start/bspidle.S b/bsps/i386/pc386/start/bspidle.S
index 740671afc1..1bd030f6b5 100644
--- a/bsps/i386/pc386/start/bspidle.S
+++ b/bsps/i386/pc386/start/bspidle.S
@@ -1,3 +1,5 @@
* Idle Thread Body
diff --git a/bsps/i386/pc386/start/bspreset.c b/bsps/i386/pc386/start/bspreset.c
index 0fbcd0f201..93ebf23f82 100644
--- a/bsps/i386/pc386/start/bspreset.c
+++ b/bsps/i386/pc386/start/bspreset.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2017.
+ * are met:
