[PATCH 07/23] m68k/bsps/av5282: Change license to BSD-2
Fri Jul 8 14:02:34 UTC 2022
Updates #3053.
 bsps/m68k/av5282/start/bspstart.c    | 25 ++++++++++++++++++++++---
 bsps/m68k/av5282/start/linkcmds      | 25 ++++++++++++++++++++++---
 bsps/m68k/av5282/start/linkcmdsflash | 25 ++++++++++++++++++++++---
 bsps/m68k/av5282/start/linkcmdsram   | 25 ++++++++++++++++++++++---
 bsps/m68k/av5282/start/start.S       | 25 ++++++++++++++++++++++---
 5 files changed, 110 insertions(+), 15 deletions(-)
diff --git a/bsps/m68k/av5282/start/bspstart.c b/bsps/m68k/av5282/start/bspstart.c
index c2dd362a6d..1f95474f2f 100644
--- a/bsps/m68k/av5282/start/bspstart.c
+++ b/bsps/m68k/av5282/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialisation.
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 1989-1998.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/av5282/start/linkcmds b/bsps/m68k/av5282/start/linkcmds
index 0c0b3df561..e74c30c7b6 100644
--- a/bsps/m68k/av5282/start/linkcmds
+++ b/bsps/m68k/av5282/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Arcturus uC DIMM ColdFire 5282
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/bsps/m68k/av5282/start/linkcmdsflash b/bsps/m68k/av5282/start/linkcmdsflash
index 83d761bc56..b7670e5134 100644
--- a/bsps/m68k/av5282/start/linkcmdsflash
+++ b/bsps/m68k/av5282/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/bsps/m68k/av5282/start/linkcmdsram b/bsps/m68k/av5282/start/linkcmdsram
index 354a26c383..a28c402eaa 100644
--- a/bsps/m68k/av5282/start/linkcmdsram
+++ b/bsps/m68k/av5282/start/linkcmdsram
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/av5282/start/start.S b/bsps/m68k/av5282/start/start.S
index 1142316877..47c5c7fde9 100644
--- a/bsps/m68k/av5282/start/start.S
+++ b/bsps/m68k/av5282/start/start.S
@@ -1,3 +1,5 @@
  *  uC5282 startup code
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2014.
+ * are met:
 #include <bsp.h>
2.24.4
