[PATCH 08/23] bsps/m68k/csv360: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:35 UTC 2022
Updates #3053.
bsps/m68k/csb360/console/console-io.c | 25 ++++++++++++++++++++++---
bsps/m68k/csb360/start/idle-mcf5272.c | 25 ++++++++++++++++++++++---
2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/bsps/m68k/csb360/console/console-io.c b/bsps/m68k/csb360/console/console-io.c
index 9b0aeac5bb..1cd11b8697 100644
--- a/bsps/m68k/csb360/console/console-io.c
+++ b/bsps/m68k/csb360/console/console-io.c
@@ -1,3 +1,5 @@
* This file contains the hardware specific portions of the TTY driver
* for the serial ports on the mcf5272
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2000.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/m68k/csb360/start/idle-mcf5272.c b/bsps/m68k/csb360/start/idle-mcf5272.c
index 651b212539..ac52b9b9ef 100644
--- a/bsps/m68k/csb360/start/idle-mcf5272.c
+++ b/bsps/m68k/csb360/start/idle-mcf5272.c
@@ -1,3 +1,5 @@
* Motorola MC68xxx Dependent Idle Body Source
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2002.
+ * are met:
2.24.4
