[PATCH 14/23] bsps/m68k/mcf52235: Change license to BSD-2
Fri Jul 8 14:02:41 UTC 2022
Updates #3053.
 .../m68k/mcf52235/start/bspgetcpuclockspeed.c | 25 ++++++++++++++++---
 bsps/m68k/mcf52235/start/linkcmds             | 25 ++++++++++++++++---
 bsps/m68k/mcf52235/start/start.S              | 25 ++++++++++++++++---
 3 files changed, 66 insertions(+), 9 deletions(-)
diff --git a/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c b/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
index 563044394a..3d6c365109 100644
--- a/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
+++ b/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf52235/start/linkcmds b/bsps/m68k/mcf52235/start/linkcmds
index e20d3031d7..efe48117d0 100644
--- a/bsps/m68k/mcf52235/start/linkcmds
+++ b/bsps/m68k/mcf52235/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Freescale ColdFire mcf52235
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1999.
- *  http://www.rtems.org/license/LICENSE.e
+ * are met:
+ * POSSIBILITY OF SUCH DAMAGE.e
diff --git a/bsps/m68k/mcf52235/start/start.S b/bsps/m68k/mcf52235/start/start.S
index c71f4fed8a..f5dcfb53da 100644
--- a/bsps/m68k/mcf52235/start/start.S
+++ b/bsps/m68k/mcf52235/start/start.S
@@ -1,3 +1,5 @@
  *  mcf52235 startup code
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-1998.
+ * are met:
 #include <rtems/asm.h>
2.24.4
