[PATCH 15/23] bsps/m68k/mcf5225x: Change license to BSD-2
Fri Jul 8 14:02:42 UTC 2022
Updates #3053.
 bsps/m68k/mcf5225x/start/bspclean.c | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5225x/start/bspstart.c | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5225x/start/linkcmds   | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5225x/start/start.S    | 25 ++++++++++++++++++++++---
 4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/bsps/m68k/mcf5225x/start/bspclean.c b/bsps/m68k/mcf5225x/start/bspclean.c
index 5cd1aed1e9..7c777de9c7 100644
--- a/bsps/m68k/mcf5225x/start/bspclean.c
+++ b/bsps/m68k/mcf5225x/start/bspclean.c
@@ -1,3 +1,5 @@
  *  This routine returns control from RTEMS to the monitor.
@@ -8,9 +10,26 @@
  *  COPYRIGHT (c) 1989-1998.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf5225x/start/bspstart.c b/bsps/m68k/mcf5225x/start/bspstart.c
index d5e0f37dc8..779a7ad2a5 100644
--- a/bsps/m68k/mcf5225x/start/bspstart.c
+++ b/bsps/m68k/mcf5225x/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialisation.
@@ -10,9 +12,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf5225x/start/linkcmds b/bsps/m68k/mcf5225x/start/linkcmds
index ae9800dcc4..fc1aa1a107 100644
--- a/bsps/m68k/mcf5225x/start/linkcmds
+++ b/bsps/m68k/mcf5225x/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Freescale ColdFire mcf52258
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1999.
- *  http://www.rtems.org/license/LICENSE.e
+ * are met:
+ * POSSIBILITY OF SUCH DAMAGE.e
diff --git a/bsps/m68k/mcf5225x/start/start.S b/bsps/m68k/mcf5225x/start/start.S
index 4513f663c0..f62e53f590 100644
--- a/bsps/m68k/mcf5225x/start/start.S
+++ b/bsps/m68k/mcf5225x/start/start.S
@@ -1,3 +1,5 @@
  *  dpu-mcf52258 startup code
@@ -9,9 +11,26 @@
+ * are met:
 #include <rtems/asm.h>
2.24.4
