[PATCH 17/23] bsps/m68k/mcf5329: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:44 UTC 2022
Updates #3053.
bsps/m68k/mcf5329/start/bspstart.c | 25 ++++++++++++++++++++++---
bsps/m68k/mcf5329/start/linkcmds | 25 ++++++++++++++++++++++---
bsps/m68k/mcf5329/start/linkcmdsflash | 25 ++++++++++++++++++++++---
bsps/m68k/mcf5329/start/start.S | 25 ++++++++++++++++++++++---
4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/bsps/m68k/mcf5329/start/bspstart.c b/bsps/m68k/mcf5329/start/bspstart.c
index d5a258da47..7684af0589 100644
--- a/bsps/m68k/mcf5329/start/bspstart.c
+++ b/bsps/m68k/mcf5329/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine does the bulk of the system initialisation.
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-1998.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/m68k/mcf5329/start/linkcmds b/bsps/m68k/mcf5329/start/linkcmds
index 8b017c06a8..1578dc6c60 100644
--- a/bsps/m68k/mcf5329/start/linkcmds
+++ b/bsps/m68k/mcf5329/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Freescale ColdFire mcf52235
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1999.
- * http://www.rtems.org/license/LICENSE.e
+ * are met:
+ * POSSIBILITY OF SUCH DAMAGE.e
diff --git a/bsps/m68k/mcf5329/start/linkcmdsflash b/bsps/m68k/mcf5329/start/linkcmdsflash
index aacaca7b47..437852b7e4 100644
--- a/bsps/m68k/mcf5329/start/linkcmdsflash
+++ b/bsps/m68k/mcf5329/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5329/start/start.S b/bsps/m68k/mcf5329/start/start.S
index 7a61ffc998..102a88beae 100644
--- a/bsps/m68k/mcf5329/start/start.S
+++ b/bsps/m68k/mcf5329/start/start.S
@@ -1,3 +1,5 @@
* mcf52235 startup code
@@ -9,9 +11,26 @@
+ * are met:
#include <rtems/asm.h>
2.24.4
