[PATCH 16/23] bsps/m68k/mvf5235: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:43 UTC 2022
Updates #3053.
bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c | 25 ++++++++++++++++---
bsps/m68k/mcf5235/start/bspstart.c | 25 ++++++++++++++++---
bsps/m68k/mcf5235/start/linkcmds | 25 ++++++++++++++++---
bsps/m68k/mcf5235/start/linkcmdsflash | 25 ++++++++++++++++---
bsps/m68k/mcf5235/start/linkcmdsram | 25 ++++++++++++++++---
bsps/m68k/mcf5235/start/start.S | 25 ++++++++++++++++---
6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c b/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
index 548caaa9b8..d6331fa8aa 100644
--- a/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
+++ b/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/m68k/mcf5235/start/bspstart.c b/bsps/m68k/mcf5235/start/bspstart.c
index 744d4c9142..2d9a347dde 100644
--- a/bsps/m68k/mcf5235/start/bspstart.c
+++ b/bsps/m68k/mcf5235/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine does the bulk of the system initialization.
@@ -6,9 +8,26 @@
+ * are met:
#include <bsp.h>
diff --git a/bsps/m68k/mcf5235/start/linkcmds b/bsps/m68k/mcf5235/start/linkcmds
index fe2ebd26d2..9cdddcd38f 100644
--- a/bsps/m68k/mcf5235/start/linkcmds
+++ b/bsps/m68k/mcf5235/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Freescale ColdFire mcf5235
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/linkcmdsflash b/bsps/m68k/mcf5235/start/linkcmdsflash
index 2c25105134..7e796ceaff 100644
--- a/bsps/m68k/mcf5235/start/linkcmdsflash
+++ b/bsps/m68k/mcf5235/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/linkcmdsram b/bsps/m68k/mcf5235/start/linkcmdsram
index 25e0f9b093..057da6745f 100644
--- a/bsps/m68k/mcf5235/start/linkcmdsram
+++ b/bsps/m68k/mcf5235/start/linkcmdsram
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/start.S b/bsps/m68k/mcf5235/start/start.S
index cf33070d16..8ffcb78ecc 100644
--- a/bsps/m68k/mcf5235/start/start.S
+++ b/bsps/m68k/mcf5235/start/start.S
@@ -1,3 +1,5 @@
* mcf5235 startup code
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1998.
+ * are met:
#include <rtems/asm.h>
2.24.4
