[PATCH 19/23] bsps/m68k/mvme147: Change license to BSD-2
Fri Jul 8 14:02:46 UTC 2022
Updates #3053.
 bsps/m68k/mvme147/btimer/btimer.c   | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/clock/ckinit.c    | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/console/console.c | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/include/bsp.h     | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/start/bspclean.c  | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/start/bspstart.c  | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147/start/linkcmds    | 25 ++++++++++++++++++++++---
 7 files changed, 154 insertions(+), 21 deletions(-)
diff --git a/bsps/m68k/mvme147/btimer/btimer.c b/bsps/m68k/mvme147/btimer/btimer.c
index 9d48fa7075..72955f8119 100644
--- a/bsps/m68k/mvme147/btimer/btimer.c
+++ b/bsps/m68k/mvme147/btimer/btimer.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
  *  MVME147 port for TNI - Telecom Bretagne
  *  by Dominique LE CAMPION (Dominique.LECAMPION at enst-bretagne.fr)
diff --git a/bsps/m68k/mvme147/clock/ckinit.c b/bsps/m68k/mvme147/clock/ckinit.c
index bf5dba2160..39a0ef29a0 100644
--- a/bsps/m68k/mvme147/clock/ckinit.c
+++ b/bsps/m68k/mvme147/clock/ckinit.c
@@ -1,3 +1,5 @@
  *  This routine initializes the Tick Timer 2 on the MVME147 board.
  *  The tick frequency is 1 millisecond.
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147/console/console.c b/bsps/m68k/mvme147/console/console.c
index f26ca6485a..615c264621 100644
--- a/bsps/m68k/mvme147/console/console.c
+++ b/bsps/m68k/mvme147/console/console.c
@@ -1,3 +1,5 @@
  *  This file contains the MVME147 console IO package.
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147/include/bsp.h b/bsps/m68k/mvme147/include/bsp.h
index 612b2b183d..041129decc 100644
--- a/bsps/m68k/mvme147/include/bsp.h
+++ b/bsps/m68k/mvme147/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147/start/bspclean.c b/bsps/m68k/mvme147/start/bspclean.c
index 6606b9a249..dc08532e42 100644
--- a/bsps/m68k/mvme147/start/bspclean.c
+++ b/bsps/m68k/mvme147/start/bspclean.c
@@ -1,3 +1,5 @@
  *  This routine returns control to 147Bug.
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-2014.
+ * are met:
diff --git a/bsps/m68k/mvme147/start/bspstart.c b/bsps/m68k/mvme147/start/bspstart.c
index cb5f84a075..f5dcf2afee 100644
--- a/bsps/m68k/mvme147/start/bspstart.c
+++ b/bsps/m68k/mvme147/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialization.
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147/start/linkcmds b/bsps/m68k/mvme147/start/linkcmds
index 6603a438f1..375e9e8d54 100644
--- a/bsps/m68k/mvme147/start/linkcmds
+++ b/bsps/m68k/mvme147/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Motorola MVME147 boards.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2007,2016.
+ * are met:
2.24.4
