[PATCH 20/23] bsps/m68k/mvme147s: Change license to BSD-2
Fri Jul 8 14:02:47 UTC 2022
Updates #3053.
 bsps/m68k/mvme147s/include/bsp.h    | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/mpci/addrconv.c  | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/mpci/getcfg.c    | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/mpci/lock.c      | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/mpci/mpisr.c     | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/start/bspstart.c | 25 ++++++++++++++++++++++---
 bsps/m68k/mvme147s/start/linkcmds   | 25 ++++++++++++++++++++++---
 7 files changed, 154 insertions(+), 21 deletions(-)
diff --git a/bsps/m68k/mvme147s/include/bsp.h b/bsps/m68k/mvme147s/include/bsp.h
index 6c285f9e6c..a5eb48982f 100644
--- a/bsps/m68k/mvme147s/include/bsp.h
+++ b/bsps/m68k/mvme147s/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
  *  MVME147 port for TNI - Telecom Bretagne
  *  by Dominique LE CAMPION (Dominique.LECAMPION at enst-bretagne.fr)
diff --git a/bsps/m68k/mvme147s/mpci/addrconv.c b/bsps/m68k/mvme147s/mpci/addrconv.c
index 0ed0fdbed1..2e3c3a216e 100644
--- a/bsps/m68k/mvme147s/mpci/addrconv.c
+++ b/bsps/m68k/mvme147s/mpci/addrconv.c
@@ -1,3 +1,5 @@
 /*  Shm_Convert_address
  *  This MVME147 has a "normal" view of the VME address space.
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/getcfg.c b/bsps/m68k/mvme147s/mpci/getcfg.c
index c549a9fcea..40c4910582 100644
--- a/bsps/m68k/mvme147s/mpci/getcfg.c
+++ b/bsps/m68k/mvme147s/mpci/getcfg.c
@@ -1,3 +1,5 @@
 /*  void Shm_Get_configuration( localnode, &shmcfg )
  *  This routine initializes, if necessary, and returns a pointer
@@ -16,9 +18,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/lock.c b/bsps/m68k/mvme147s/mpci/lock.c
index 129de01fd0..1301ef0581 100644
--- a/bsps/m68k/mvme147s/mpci/lock.c
+++ b/bsps/m68k/mvme147s/mpci/lock.c
@@ -1,3 +1,5 @@
 /*  Shared Memory Lock Routines
  *  This shared memory locked queue support routine need to be
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/mpisr.c b/bsps/m68k/mvme147s/mpci/mpisr.c
index 0669538e1b..8f7b8c2a4f 100644
--- a/bsps/m68k/mvme147s/mpci/mpisr.c
+++ b/bsps/m68k/mvme147s/mpci/mpisr.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-1999, 2016.
+ * are met:
diff --git a/bsps/m68k/mvme147s/start/bspstart.c b/bsps/m68k/mvme147s/start/bspstart.c
index 497b644150..dd007b70d6 100644
--- a/bsps/m68k/mvme147s/start/bspstart.c
+++ b/bsps/m68k/mvme147s/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialization.
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/start/linkcmds b/bsps/m68k/mvme147s/start/linkcmds
index 01be6d93b2..dee9593f97 100644
--- a/bsps/m68k/mvme147s/start/linkcmds
+++ b/bsps/m68k/mvme147s/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Motorola MVME147s boards.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2007,2016.
+ * are met:
2.24.4
