[PATCH 21/23] bsps/m68k/mvme162: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:48 UTC 2022
Updates #3053.
bsps/m68k/mvme162/start/linkcmds | 25 ++++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/bsps/m68k/mvme162/start/linkcmds b/bsps/m68k/mvme162/start/linkcmds
index 26c85007a4..656aa56e71 100644
--- a/bsps/m68k/mvme162/start/linkcmds
+++ b/bsps/m68k/mvme162/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Motorola MVME162 boards.
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2007,2016.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* MVME147 port for TNI - Telecom Bretagne
* by Dominique LE CAMPION (Dominique.LECAMPION at enst-bretagne.fr)
2.24.4
