[PATCH v3] irq/arm-gicv3.h: Customize CPU Interface init
Mon Jul 11 09:16:54 UTC 2022
Use the existing WRITE_SR() abstraction to access the interrupt group 0 and 1
enable registers.  This fixes the build for the AArch32 target.
Add BSP options which define the initial values of CPU Interface registers.
v3:
* Fix variant-specific default values.
* Add BSP options for ICC_BPR0, ICC_BPR1, ICC_CTRL, ICC_PMR, and ICC_SRE.
 bsps/include/dev/irq/arm-gicv3.h              | 58 ++++++++++++-------
 spec/build/bsps/aarch64/a53/grp.yml           |  2 +
 spec/build/bsps/aarch64/a53/obj.yml           |  1 -
 spec/build/bsps/aarch64/a72/grp.yml           |  2 +
 spec/build/bsps/aarch64/a72/obj.yml           |  1 -
 spec/build/bsps/aarch64/grp.yml               |  1 -
 spec/build/bsps/aarch64/xilinx-versal/grp.yml |  2 +
 spec/build/bsps/aarch64/xilinx-versal/obj.yml |  1 -
 spec/build/bsps/arm/fvp/grp.yml               |  2 +
 spec/build/bsps/arm/fvp/obj.yml               |  1 -
 spec/build/bsps/arm/grp.yml                   |  1 -
 spec/build/bsps/dev/irq/objarmgicv3.yml       | 31 ++++++++++
 .../build/bsps/dev/irq/optarmgic-icc-bpr0.yml | 21 +++++++
 .../build/bsps/dev/irq/optarmgic-icc-bpr1.yml | 18 ++++++
 .../build/bsps/dev/irq/optarmgic-icc-ctrl.yml | 18 ++++++
 .../bsps/dev/irq/optarmgic-icc-igrpen0.yml    | 21 +++++++
 .../bsps/dev/irq/optarmgic-icc-igrpen1.yml    | 18 ++++++
 spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml | 18 ++++++
 spec/build/bsps/dev/irq/optarmgic-icc-sre.yml | 18 ++++++
 19 files changed, 208 insertions(+), 27 deletions(-)
 create mode 100644 spec/build/bsps/dev/irq/objarmgicv3.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-bpr1.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-ctrl.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-igrpen1.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml
 create mode 100644 spec/build/bsps/dev/irq/optarmgic-icc-sre.yml
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index a79368ebdf..a716ffbca5 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -116,13 +116,16 @@ extern "C" {
 #else /* ARM_MULTILIB_ARCH_V4 */
 /* AArch64 GICv3 registers are not named in GCC */
-#define ICC_IGRPEN0 "S3_0_C12_C12_6, %0"
-#define ICC_IGRPEN1 "S3_0_C12_C12_7, %0"
+#define ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0"
+#define ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0"
 #define ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0"
+#define ICC_IGRPEN0 ICC_IGRPEN0_EL1
+#define ICC_IGRPEN1 ICC_IGRPEN1_EL1
 #define ICC_PMR     "S3_0_C4_C6_0, %0"
 #define ICC_EOIR1   "S3_0_C12_C12_1, %0"
 #define ICC_SRE     "S3_0_C12_C12_5, %0"
 #define ICC_BPR0    "S3_0_C12_C8_3, %0"
+#define ICC_BPR1    "S3_0_C12_C12_3, %0"
 #define ICC_CTLR    "S3_0_C12_C12_4, %0"
 #define ICC_IAR1    "%0, S3_0_C12_C12_0"
 #define MPIDR       "%0, mpidr_el1"
@@ -300,25 +303,27 @@ static void gicv3_init_dist(volatile gic_dist *dist)
- * A better way to access these registers than special opcodes
-#define isb() __asm __volatile("isb" : : : "memory")
+static void gicv3_init_cpu_interface(uint32_t cpu_index)
+  /* Initialize Interrupt Controller System Register Enable Register */
+#ifdef BSP_ARM_GIC_ICC_SRE
+  WRITE_SR(ICC_SRE, BSP_ARM_GIC_ICC_SRE);
+#endif
-#define  WRITE_SPECIALREG(reg, _val)                                    \
-  __asm __volatile("msr  " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
+  /* Initialize Interrupt Controller Interrupt Priority Mask Register */
+#ifdef BSP_ARM_GIC_ICC_PMR
+  WRITE_SR(ICC_PMR, BSP_ARM_GIC_ICC_PMR);
+#endif
-#define  gic_icc_write(reg, val)            \
-do {                                        \
-  WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
-  isb();                                    \
-} while (0)
+  /* Initialize Interrupt Controller Binary Point Register 0 */
+#ifdef BSP_ARM_GIC_ICC_BPR0
+  WRITE_SR(ICC_BPR0, BSP_ARM_GIC_ICC_BPR0);
+#endif
-static void gicv3_init_cpu_interface(uint32_t cpu_index)
-  uint32_t sre_value = 0x7;
-  WRITE_SR(ICC_SRE, sre_value);
-  WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
+  /* Initialize Interrupt Controller Binary Point Register 1 */
+#ifdef BSP_ARM_GIC_ICC_BPR1
+  WRITE_SR(ICC_BPR1, BSP_ARM_GIC_ICC_BPR1);
+#endif
   volatile gic_redist *redist = gicv3_get_redist(cpu_index);
   uint32_t waker = redist->icrwaker;
@@ -334,9 +339,20 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
     sgi_ppi->icspiprior[id] = PRIORITY_DEFAULT;
-  /* Enable interrupt groups 0 and 1 */
-  gic_icc_write(IGRPEN1, 1);
-  WRITE_SR(ICC_CTLR, 0x0);
+  /* Initialize Interrupt Controller Interrupt Group Enable 0 Register */
+#ifdef BSP_ARM_GIC_ICC_IGRPEN0
+  WRITE_SR(ICC_IGRPEN0, BSP_ARM_GIC_ICC_IGRPEN0);
+#endif
+  /* Initialize Interrupt Controller Interrupt Group Enable 1 Register */
+#ifdef BSP_ARM_GIC_ICC_IGRPEN1
+  WRITE_SR(ICC_IGRPEN1, BSP_ARM_GIC_ICC_IGRPEN1);
+#endif
+  /* Initialize Interrupt Controller Control Register */
+#ifdef BSP_ARM_GIC_ICC_CTRL
+  WRITE_SR(ICC_CTLR, BSP_ARM_GIC_ICC_CTRL);
+#endif
 static inline void gicv3_get_attributes(
diff --git a/spec/build/bsps/aarch64/a53/grp.yml b/spec/build/bsps/aarch64/a53/grp.yml
index 091f18d6f5..9ab10d643d 100644
--- a/spec/build/bsps/aarch64/a53/grp.yml
+++ b/spec/build/bsps/aarch64/a53/grp.yml
@@ -32,6 +32,8 @@ links:
   uid: ../../obj
 - role: build-dependency
   uid: ../../objirq
+- role: build-dependency
+  uid: ../../dev/irq/objarmgicv3
   uid: ../../objmem
diff --git a/spec/build/bsps/aarch64/a53/obj.yml b/spec/build/bsps/aarch64/a53/obj.yml
index 242631fba2..33c0884b85 100644
--- a/spec/build/bsps/aarch64/a53/obj.yml
+++ b/spec/build/bsps/aarch64/a53/obj.yml
@@ -26,7 +26,6 @@ source:
 - bsps/shared/dev/btimer/btimer-cpucounter.c
 - bsps/shared/dev/clock/arm-generic-timer.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
-- bsps/shared/dev/irq/arm-gicv3.c
 - bsps/shared/dev/serial/console-termios-init.c
 - bsps/shared/dev/serial/console-termios.c
 - bsps/shared/irq/irq-default-handler.c
diff --git a/spec/build/bsps/aarch64/a72/grp.yml b/spec/build/bsps/aarch64/a72/grp.yml
index 341f832a61..a8d09d108c 100644
--- a/spec/build/bsps/aarch64/a72/grp.yml
+++ b/spec/build/bsps/aarch64/a72/grp.yml
   uid: ../../obj
   uid: ../../objirq
   uid: ../../objmem
diff --git a/spec/build/bsps/aarch64/a72/obj.yml b/spec/build/bsps/aarch64/a72/obj.yml
index f797762b41..4fb5e59ba3 100644
--- a/spec/build/bsps/aarch64/a72/obj.yml
+++ b/spec/build/bsps/aarch64/a72/obj.yml
diff --git a/spec/build/bsps/aarch64/grp.yml b/spec/build/bsps/aarch64/grp.yml
index ba4ec6c6cf..9428fb9435 100644
--- a/spec/build/bsps/aarch64/grp.yml
+++ b/spec/build/bsps/aarch64/grp.yml
@@ -22,7 +22,6 @@ install:
   - bsps/include/dev/irq/arm-gic-regs.h
   - bsps/include/dev/irq/arm-gic-tm27.h
   - bsps/include/dev/irq/arm-gic.h
-  - bsps/include/dev/irq/arm-gicv3.h
 - destination: ${BSP_LIBDIR}
   source:
   - bsps/aarch64/shared/start/linkcmds.base
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
index 0f23e20950..27a77e9e6f 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
@@ -40,6 +40,8 @@ links:
   uid: ../../obj
   uid: ../../objirq
   uid: ../../objdevspizynq
diff --git a/spec/build/bsps/aarch64/xilinx-versal/obj.yml b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
index d5748aca9a..04ac3761f9 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
@@ -33,7 +33,6 @@ source:
diff --git a/spec/build/bsps/arm/fvp/grp.yml b/spec/build/bsps/arm/fvp/grp.yml
index 8de7d10917..eecbd9efd9 100644
--- a/spec/build/bsps/arm/fvp/grp.yml
+++ b/spec/build/bsps/arm/fvp/grp.yml
@@ -24,6 +24,8 @@ links:
   uid: ../../obj
   uid: ../../objirq
   uid: ../../objmem
diff --git a/spec/build/bsps/arm/fvp/obj.yml b/spec/build/bsps/arm/fvp/obj.yml
index 3db46c6ccc..05fa6dc368 100644
--- a/spec/build/bsps/arm/fvp/obj.yml
+++ b/spec/build/bsps/arm/fvp/obj.yml
@@ -34,7 +34,6 @@ source:
 - bsps/shared/start/bspfatal-default.c
diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
index bb51734b3c..37229fddc2 100644
--- a/spec/build/bsps/arm/grp.yml
+++ b/spec/build/bsps/arm/grp.yml
@@ -46,7 +46,6 @@ install:
 - destination: ${BSP_INCLUDEDIR}/libcpu
   source:
   - bsps/arm/include/libcpu/am335x.h
diff --git a/spec/build/bsps/dev/irq/objarmgicv3.yml b/spec/build/bsps/dev/irq/objarmgicv3.yml
new file mode 100644
index 0000000000..aa84ae5416
--- /dev/null
+++ b/spec/build/bsps/dev/irq/objarmgicv3.yml
@@ -0,0 +1,31 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/dev/irq
+  source:
+  - bsps/include/dev/irq/arm-gicv3.h
+links:
+  uid: optarmgic-icc-bpr0
+  uid: optarmgic-icc-bpr1
+  uid: optarmgic-icc-ctrl
+  uid: optarmgic-icc-igrpen0
+  uid: optarmgic-icc-igrpen1
+  uid: optarmgic-icc-pmr
+  uid: optarmgic-icc-sre
+source:
+- bsps/shared/dev/irq/arm-gicv3.c
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
index 0000000000..01933d00ca
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
@@ -0,0 +1,21 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+default: 2
+default-by-variant:
+- value: null
+  variants:
+  - aarch64/.*
+description: |
+  Defines the initial value of the ICC_BPR0 register of the ARM GIC CPU
+  Interface.  The value is optional.  If it is not defined, then the register
+  is not initialized.
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_BPR0
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr1.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr1.yml
index 0000000000..c9c99dfc63
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr1.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 3
+default-by-variant: []
+description: |
+  Defines the initial value of the ICC_BPR1 register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_BPR1
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-ctrl.yml b/spec/build/bsps/dev/irq/optarmgic-icc-ctrl.yml
index 0000000000..1f9ae33e0f
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-ctrl.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 0
+description: |
+  Defines the initial value of the ICC_CTRL register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_CTRL
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
index 0000000000..aea536d7d1
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
@@ -0,0 +1,21 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 1
+- value: null
+  variants:
+  - aarch64/.*
+description: |
+  Defines the initial value of the ICC_IGRPEN0 register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_IGRPEN0
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen1.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen1.yml
index 0000000000..1c18db63b7
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen1.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 1
+description: |
+  Defines the initial value of the ICC_IGRPEN1 register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_IGRPEN1
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml b/spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml
index 0000000000..d0fbda520a
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-pmr.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 255
+description: |
+  Defines the initial value of the ICC_PMR register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_PMR
+type: build
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-sre.yml b/spec/build/bsps/dev/irq/optarmgic-icc-sre.yml
index 0000000000..aca2f2720b
--- /dev/null
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-sre.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 3
+description: |
+  Defines the initial value of the ICC_SRE register of the ARM GIC CPU
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_ARM_GIC_ICC_SRE
+type: build
2.35.3
