[PATCH 21/23] bsps/m68k/mvme162: Change license to BSD-2
Mon Jul 11 22:36:52 UTC 2022
Updates #3053.
 bsps/m68k/mvme162/start/linkcmds | 25 ++++++++++++++++++++++---
 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/bsps/m68k/mvme162/start/linkcmds b/bsps/m68k/mvme162/start/linkcmds
index 26c85007a4..656aa56e71 100644
--- a/bsps/m68k/mvme162/start/linkcmds
+++ b/bsps/m68k/mvme162/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Motorola MVME162 boards.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2007,2016.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
  *  MVME147 port for TNI - Telecom Bretagne
  *  by Dominique LE CAMPION (Dominique.LECAMPION at enst-bretagne.fr)
2.24.4
