[PATCH 21/35] bsps/powerpc/shared: Change license to BSD-2
Mon Jul 11 22:36:53 UTC 2022
Updates #3053.
 bsps/powerpc/shared/btimer/btimer-ppc-dec.c   | 25 ++++++++++++++++---
 bsps/powerpc/shared/clock/clock.c             | 25 ++++++++++++++++---
 .../powerpc/shared/exceptions/ppc-code-copy.c | 25 ++++++++++++++++---
 .../shared/exceptions/ppc-exc-handler-table.c | 25 ++++++++++++++++---
 .../shared/exceptions/ppc_exc_alignment.c     | 25 ++++++++++++++++---
 .../shared/exceptions/ppc_exc_async_normal.S  | 25 ++++++++++++++++---
 .../powerpc/shared/exceptions/ppc_exc_fatal.S | 25 ++++++++++++++++---
 .../powerpc/shared/exceptions/ppc_exc_naked.S | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/bsp-start-zero.S    | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/bspidle.c           | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/linkcmds.base       | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/memcpy.c            | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/rtems_crti.S        | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/rtems_crtn.S        | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/showbats.c          | 25 ++++++++++++++++---
 bsps/powerpc/shared/start/tictac.c            | 25 ++++++++++++++++---
 .../powerpc/shared/u-boot/uboot_dump_bdinfo.c | 25 ++++++++++++++++---
 bsps/powerpc/shared/u-boot/uboot_getenv.c     | 25 ++++++++++++++++---
 18 files changed, 396 insertions(+), 54 deletions(-)
diff --git a/bsps/powerpc/shared/btimer/btimer-ppc-dec.c b/bsps/powerpc/shared/btimer/btimer-ppc-dec.c
index 1e65d49c6e..4b3cac31ec 100644
--- a/bsps/powerpc/shared/btimer/btimer-ppc-dec.c
+++ b/bsps/powerpc/shared/btimer/btimer-ppc-dec.c
@@ -1,3 +1,5 @@
  *  @file
  *  @brief
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/powerpc/shared/clock/clock.c b/bsps/powerpc/shared/clock/clock.c
index 545636e195..6e8cc52ee5 100644
--- a/bsps/powerpc/shared/clock/clock.c
+++ b/bsps/powerpc/shared/clock/clock.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008-2015 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
+ * are met:
diff --git a/bsps/powerpc/shared/exceptions/ppc-code-copy.c b/bsps/powerpc/shared/exceptions/ppc-code-copy.c
index b324c49503..1c4d99a8d1 100644
--- a/bsps/powerpc/shared/exceptions/ppc-code-copy.c
+++ b/bsps/powerpc/shared/exceptions/ppc-code-copy.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c b/bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c
index a52191ab80..ca0760ad30 100644
--- a/bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c
+++ b/bsps/powerpc/shared/exceptions/ppc-exc-handler-table.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp/vectors.h>
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_alignment.c b/bsps/powerpc/shared/exceptions/ppc_exc_alignment.c
index fd36551a14..e0b7f0a435 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_alignment.c
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_alignment.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2011 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_async_normal.S b/bsps/powerpc/shared/exceptions/ppc_exc_async_normal.S
index 87d7d2e028..de4621ef55 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_async_normal.S
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_async_normal.S
@@ -1,9 +1,28 @@
  * Copyright (c) 2011, 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bspopts.h>
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_fatal.S b/bsps/powerpc/shared/exceptions/ppc_exc_fatal.S
index afd516dff3..46e1e373b7 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_fatal.S
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_fatal.S
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_naked.S b/bsps/powerpc/shared/exceptions/ppc_exc_naked.S
index b5762eef6c..95c9e7bf8e 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_naked.S
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_naked.S
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include "ppc_exc_asm_macros.h"
diff --git a/bsps/powerpc/shared/start/bsp-start-zero.S b/bsps/powerpc/shared/start/bsp-start-zero.S
index 9347963a27..5242b01c13 100644
--- a/bsps/powerpc/shared/start/bsp-start-zero.S
+++ b/bsps/powerpc/shared/start/bsp-start-zero.S
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2010-2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <rtems/asm.h>
diff --git a/bsps/powerpc/shared/start/bspidle.c b/bsps/powerpc/shared/start/bspidle.c
index de37fa1ced..f4b62442ae 100644
--- a/bsps/powerpc/shared/start/bspidle.c
+++ b/bsps/powerpc/shared/start/bspidle.c
@@ -1,3 +1,5 @@
  *  Moved to libbsp/powerpc/shared by Joel Sherrill (9 Sept 09).
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2009.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/powerpc/shared/start/linkcmds.base b/bsps/powerpc/shared/start/linkcmds.base
index e24f5cf823..a3a1b1108a 100644
--- a/bsps/powerpc/shared/start/linkcmds.base
+++ b/bsps/powerpc/shared/start/linkcmds.base
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011, 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
 ENTRY (_start)
diff --git a/bsps/powerpc/shared/start/memcpy.c b/bsps/powerpc/shared/start/memcpy.c
index 2eaefa1799..eb91e90f72 100644
--- a/bsps/powerpc/shared/start/memcpy.c
+++ b/bsps/powerpc/shared/start/memcpy.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/powerpc/shared/start/rtems_crti.S b/bsps/powerpc/shared/start/rtems_crti.S
index 34c245d9fa..132a0473f4 100644
--- a/bsps/powerpc/shared/start/rtems_crti.S
+++ b/bsps/powerpc/shared/start/rtems_crti.S
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
 /* rtems_crti.S */
diff --git a/bsps/powerpc/shared/start/rtems_crtn.S b/bsps/powerpc/shared/start/rtems_crtn.S
index 70b60f68ff..fe9c48d6ea 100644
--- a/bsps/powerpc/shared/start/rtems_crtn.S
+++ b/bsps/powerpc/shared/start/rtems_crtn.S
@@ -1,9 +1,28 @@
+ * are met:
 #if defined(__powerpc64__)
diff --git a/bsps/powerpc/shared/start/showbats.c b/bsps/powerpc/shared/start/showbats.c
index 3978b53152..92e81c4689 100644
--- a/bsps/powerpc/shared/start/showbats.c
+++ b/bsps/powerpc/shared/start/showbats.c
@@ -1,12 +1,31 @@
  *  Display the PowerPC BAT Registers
  *  COPYRIGHT (c) 1989-2007.
+ * are met:
 #include <inttypes.h>
diff --git a/bsps/powerpc/shared/start/tictac.c b/bsps/powerpc/shared/start/tictac.c
index 6163a01f60..fdf97ae20f 100644
--- a/bsps/powerpc/shared/start/tictac.c
+++ b/bsps/powerpc/shared/start/tictac.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
  * Copyright (c) 2008 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <stdint.h>
diff --git a/bsps/powerpc/shared/u-boot/uboot_dump_bdinfo.c b/bsps/powerpc/shared/u-boot/uboot_dump_bdinfo.c
index deec8124f6..1776f8c41d 100644
--- a/bsps/powerpc/shared/u-boot/uboot_dump_bdinfo.c
+++ b/bsps/powerpc/shared/u-boot/uboot_dump_bdinfo.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/bsps/powerpc/shared/u-boot/uboot_getenv.c b/bsps/powerpc/shared/u-boot/uboot_getenv.c
index 43ef4af81b..14af74da92 100644
--- a/bsps/powerpc/shared/u-boot/uboot_getenv.c
+++ b/bsps/powerpc/shared/u-boot/uboot_getenv.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
 #include <bsp.h>
2.24.4
