[PATCH 22/23] bsps/m68k/shared: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:54 UTC 2022
Updates #3053.
bsps/m68k/shared/cache/cache-mcf5223x.c | 25 ++++++++++++++++++++++---
bsps/m68k/shared/cache/cache-mcf5235.c | 25 ++++++++++++++++++++++---
bsps/m68k/shared/m68kidle.c | 25 ++++++++++++++++++++++---
bsps/m68k/shared/start/linkcmds.base | 25 ++++++++++++++++++++++---
bsps/m68k/shared/start/start.S | 25 ++++++++++++++++++++++---
5 files changed, 110 insertions(+), 15 deletions(-)
diff --git a/bsps/m68k/shared/cache/cache-mcf5223x.c b/bsps/m68k/shared/cache/cache-mcf5223x.c
index 60b2f7f335..5f4b7cb075 100644
--- a/bsps/m68k/shared/cache/cache-mcf5223x.c
+++ b/bsps/m68k/shared/cache/cache-mcf5223x.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/bsps/m68k/shared/cache/cache-mcf5235.c b/bsps/m68k/shared/cache/cache-mcf5235.c
index 35390b02ef..9dbd4f63c6 100644
--- a/bsps/m68k/shared/cache/cache-mcf5235.c
+++ b/bsps/m68k/shared/cache/cache-mcf5235.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/bsps/m68k/shared/m68kidle.c b/bsps/m68k/shared/m68kidle.c
index 474437e3e7..54042d387e 100644
--- a/bsps/m68k/shared/m68kidle.c
+++ b/bsps/m68k/shared/m68kidle.c
@@ -1,3 +1,5 @@
* Motorola MC68xxx Dependent Idle Body Source
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2002.
+ * are met:
diff --git a/bsps/m68k/shared/start/linkcmds.base b/bsps/m68k/shared/start/linkcmds.base
index 9fa2d9662f..5626293874 100644
--- a/bsps/m68k/shared/start/linkcmds.base
+++ b/bsps/m68k/shared/start/linkcmds.base
@@ -1,9 +1,28 @@
* Copyright (c) 2008, 2018 embedded brains GmbH. All rights reserved.
+ * are met:
OUTPUT_FORMAT("elf32-m68k", "elf32-m68k", "elf32-m68k")
diff --git a/bsps/m68k/shared/start/start.S b/bsps/m68k/shared/start/start.S
index 3ee7917814..6389e278ea 100644
--- a/bsps/m68k/shared/start/start.S
+++ b/bsps/m68k/shared/start/start.S
@@ -1,3 +1,5 @@
/* entry.s
* This file contains the entry point for the application.
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
#include <rtems/asm.h>
2.24.4
