[PATCH 3/3] score: Fix unlimited objects support
Wed Jul 13 13:17:24 UTC 2022
Commit 21275b58a5a69c3c838082ffc8a7a3641f32ea9a ("score: Static
Objects_Information initialization") introduced an off-by-one error in the
maintenance of inactive objects.
Close #4677.
 cpukit/include/rtems/score/objectimpl.h | 29 +++++++++++++++++++++----
 cpukit/score/src/objectfree.c           | 12 +++++-----
 2 files changed, 32 insertions(+), 9 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 72a5f6b126..7938996df8 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -911,6 +911,25 @@ RTEMS_INLINE_ROUTINE void _Objects_Free(
   ( *information->deallocate )( information, the_object );
+ * @brief Returns true, if the object associated with the zero-based index is
+ *   contained in an allocated block of objects, otherwise false.
+ * @param index is the zero-based object index.
+ * @param objects_per_block is the object count per block.
+ * @retval true The object associated with the zero-based index is in an
+ *   allocated block of objects.
+ * @retval false Otherwise.
+RTEMS_INLINE_ROUTINE bool _Objects_Is_in_allocated_block(
+  Objects_Maximum index,
+  Objects_Maximum objects_per_block
+  return index >= objects_per_block;
  * @brief Activate the object.
@@ -926,15 +945,17 @@ RTEMS_INLINE_ROUTINE void _Objects_Activate_unlimited(
   Objects_Maximum objects_per_block;
-  Objects_Maximum block;
+  Objects_Maximum index;
   _Assert( _Objects_Is_auto_extend( information ) );
   objects_per_block = information->objects_per_block;
-  block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
+  index = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
+  if ( _Objects_Is_in_allocated_block( index, objects_per_block ) ) {
+    Objects_Maximum block;
-  if ( block > objects_per_block ) {
-    block /= objects_per_block;
+    block = index / objects_per_block;
     information->inactive_per_block[ block ]--;
     information->inactive--;
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index 45b2ba2c86..06d7d82672 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -51,14 +51,16 @@ void _Objects_Free_unlimited(
   if ( _Objects_Is_auto_extend( information ) ) {
-    Objects_Maximum inactive;
+      Objects_Maximum inactive;
       ++information->inactive_per_block[ block ];
2.35.3
