[PATCH 2/3] spunlimited01: New test
Wed Jul 13 13:17:23 UTC 2022
Update #4677.
 spec/build/testsuites/sptests/grp.yml         |   2 +
 .../testsuites/sptests/spunlimited01.yml      |  20 +++
 testsuites/sptests/spunlimited01/init.c       | 125 ++++++++++++++++++
 .../sptests/spunlimited01/spunlimited01.doc   |  14 ++
 4 files changed, 161 insertions(+)
 create mode 100644 spec/build/testsuites/sptests/spunlimited01.yml
 create mode 100644 testsuites/sptests/spunlimited01/init.c
 create mode 100644 testsuites/sptests/spunlimited01/spunlimited01.doc
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index c6d07b07fd..891a78eb86 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -448,6 +448,8 @@ links:
   uid: sptls03
 - role: build-dependency
   uid: sptls04
+- role: build-dependency
+  uid: spunlimited01
   uid: spversion01
diff --git a/spec/build/testsuites/sptests/spunlimited01.yml b/spec/build/testsuites/sptests/spunlimited01.yml
new file mode 100644
index 0000000000..e0f530da74
--- /dev/null
+++ b/spec/build/testsuites/sptests/spunlimited01.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags:
+- -Wl,--wrap=_Workspace_Free
+links: []
+source:
+- testsuites/sptests/spunlimited01/init.c
+stlib: []
+target: testsuites/sptests/spunlimited01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spunlimited01/init.c b/testsuites/sptests/spunlimited01/init.c
index 0000000000..ce64324768
--- /dev/null
+++ b/testsuites/sptests/spunlimited01/init.c
@@ -0,0 +1,125 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/heapimpl.h>
+#include <string.h>
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+const char rtems_test_name[] = "SPUNLIMITED 1";
+void __real__Workspace_Free( void * );
+void __wrap__Workspace_Free( void * );
+void __wrap__Workspace_Free( void *ptr )
+  uintptr_t alloc_begin;
+  uintptr_t block_size;
+  uintptr_t block_end;
+  Heap_Block *block;
+  if ( ptr == NULL ) {
+    return;
+  alloc_begin = (uintptr_t) ptr;
+  block = _Heap_Block_of_alloc_area( alloc_begin, CPU_HEAP_ALIGNMENT );
+  block_size = _Heap_Block_size( block );
+  block_end = (uintptr_t) block + block_size;
+  memset( ptr, 0, block_end - alloc_begin );
+  __real__Workspace_Free( ptr );
+static void delete_mutex( rtems_id id )
+  rtems_status_code sc;
+  sc = rtems_semaphore_delete( id );
+  T_rsc_success( sc );
+T_TEST_CASE( UnlimitedShrink )
+  rtems_id ids[ 6 ];
+  size_t i;
+  for ( i = 0; i < RTEMS_ARRAY_SIZE( ids ); ++i ) {
+    sc = rtems_semaphore_create(
+      rtems_build_name( 'M', 'U', 'T', 'X' ),
+      1,
+      RTEMS_BINARY_SEMAPHORE,
+      0,
+      &ids[ i ]
+    T_assert_rsc_success( sc );
+  sc = rtems_semaphore_obtain( ids[ 2 ], RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+  delete_mutex( ids[ 5 ] );
+  delete_mutex( ids[ 4 ] );
+  delete_mutex( ids[ 3 ] );
+  sc = rtems_semaphore_release( ids[ 2 ] );
+  delete_mutex( ids[ 2 ] );
+  delete_mutex( ids[ 1 ] );
+  delete_mutex( ids[ 0 ] );
+static rtems_task Init( rtems_task_argument argument )
+  rtems_test_run( argument, TEST_STATE );
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES rtems_resource_unlimited( 2 )
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spunlimited01/spunlimited01.doc b/testsuites/sptests/spunlimited01/spunlimited01.doc
index 0000000000..43d3ec1646
--- /dev/null
+++ b/testsuites/sptests/spunlimited01/spunlimited01.doc
@@ -0,0 +1,14 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spunlimited01
+directives:
+  - _Objects_Activate_unlimited()
+  - _Objects_Free_unlimited()
+concepts:
+  - Create and delete objects with the unlimited objects support in a certain
+    order.  Ensure that only blocks with free objects are reclaimed during a
+    shrink operation.
2.35.3
