[PATCH] samples/cdtest: Test execeptions during system init
Chris Johns
chrisj at rtems.org
Thu Jul 14 08:39:41 UTC 2022
On 14/7/2022 4:02 pm, Sebastian Huber wrote:
> On 14/07/2022 02:31, Chris Johns wrote:
>> On 13/7/2022 6:42 pm, Sebastian Huber wrote:
>>> On 01/07/2022 12:02, Sebastian Huber wrote:
>>>> +static void early_exception()
>>>> + try
>>>> + throw "early exception";
>>>> + catch( const char *e )
>>>> + rtems_test_assert(strcmp(e, "early exception") == 0);
>>>> + throw "early exception 2";
>>>> +static void test_exceptions_during_system_init()
>>>> + TEST_BEGIN();
>>>> + try
>>>> + early_exception();
>>>> + rtems_test_assert(strcmp(e, "early exception 2") == 0);
>>>> +RTEMS_SYSINIT_ITEM(
>>>> + test_exceptions_during_system_init,
>>>> + RTEMS_SYSINIT_IDLE_THREADS,
>>>> + RTEMS_SYSINIT_ORDER_LAST
>>> Actually, on targets which use the DWARF2 unwinder (for example sparc), this
>>> doesn't work since the exception frames are no yet registered.
>> Is the result a terminate with an unknown type of exception of something else?
> It is a failed gcc_assert() in the unwinder code. Depending on the GCC options,
> this results in a __builtin_trap().
That is what Kinsey reported so it is the same issue. I will then see that on
the Versal which is good.
>> Kinsey is reporting an issue with aarch64 and cdtest on discord.
> Yes, it seems ARM changed the exception implementation for aarch64 to use what
> everyone else uses. So we essentially have:
> #if defined(__arm__)
> #define CAN_DO_EXCEPTIONS_DURING_SYSINIT
> #endif
OK
>> What mechanism is being used to initialise the unwinder support?
> It is the C runtime initialization done during global construction.
Is this then our problem?
>> With libdl the unwind tables are registered as part of the loading.
>>> They are
>>> registered during global construction. This also means that C++ exceptions can
>>> only be used once the global construction completed on these targets.
>> Has this always been the case?
> Yes, but there was no test which used the C++ exceptions during system
> initialization until recently.
Ah thanks.
>> It is part of the well documented RAII principle
>> so we need this to work.
> Probably the only thing we can do is to document this constraint somewhere.
An open ticket?
