[PATCH] score: Use RTEMS_SMP in _Thread_Create_idle()
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jul 15 16:35:18 UTC 2022
On 7/6/2022 13:21, Sebastian Huber wrote:
> On 06/07/2022 20:19, Gedare Bloom wrote:
>> ok, this changes slightly the order of events in the system state
>> (idle threads are now created in the preceding state,
>> SYSTEM_STATE_BEFORE_INITIALIZATION) but without thinking too hard
>> about it, I think it should be fine.
> Yes, it doesn't really matter. Logically, setting the new state after
> the work is done is slightly better.
This seems to have broken spextensions01 on AArch64 (both QEMU and on
hardware) and likely elsewhere:
assertion "_Thread_Dispatch_is_enabled() || before_multitasking()"
failed: file "../../../testsuites/sptests/spextensions01/init.c", line
64, function: assert_allocator_protected_thread_context
Kinsey
