[PATCH] validation: Test thread free of FPU owner
Tue Jul 5 08:12:58 UTC 2022
 testsuites/validation/tc-score-thread.c | 74 +++++++++++++++++++++++++
 1 file changed, 74 insertions(+)
diff --git a/testsuites/validation/tc-score-thread.c b/testsuites/validation/tc-score-thread.c
index 53b939e3c5..88e86ca189 100644
--- a/testsuites/validation/tc-score-thread.c
+++ b/testsuites/validation/tc-score-thread.c
@@ -56,6 +56,7 @@
+#include "ts-config.h"
 #include "tx-support.h"
 #include <rtems/test.h>
@@ -86,6 +87,14 @@
  *   - Clean up all used resources.
+ * - Delete a thread which least recently used the floating point coprocessor.
+ *   - Start the worker thread.  Let it use the floating point coprocessor.
+ *   - Delete the worker thread and free the thread resources.
+ *   - Clean up all used resources.
@@ -102,6 +111,11 @@ typedef struct {
    * @brief This member contains the killer task identifier.
   rtems_id killer_id;
+   * @brief This member contains a floating-point object.
+  volatile double fp_obj;;
 } ScoreThreadValThread_Context;
 static ScoreThreadValThread_Context
@@ -126,6 +140,29 @@ static void WorkerTask( rtems_task_argument arg )
   SuspendSelf();
+static void GoBackToRunner( void *arg )
+  Context *ctx;
+  ctx = arg;
+  SetPriority( ctx->worker_id, PRIO_LOW );
+static void FloatingPointTask( rtems_task_argument arg )
+  Context *ctx;
+  ctx = (Context *) arg;
+  ctx->fp_obj *= 1.23;
+   * We use an interrupt to go back to the runner since on some
+   * architectures, the floating-point context is only saved during interrupt
+   * processing and not for synchronous thread switches.
+  CallWithinISR( GoBackToRunner, ctx );
 static void KillerTask( rtems_task_argument arg )
   Context *ctx;
@@ -216,6 +253,42 @@ static void ScoreThreadValThread_Action_0( ScoreThreadValThread_Context *ctx )
   T_rsc_success( sc );
+ * @brief Delete a thread which least recently used the floating point
+ *   coprocessor.
+static void ScoreThreadValThread_Action_1( ScoreThreadValThread_Context *ctx )
+  rtems_status_code sc;
+  SetSelfPriority( PRIO_NORMAL );
+  sc = rtems_task_create(
+    rtems_build_name( 'W', 'O', 'R', 'K'),
+    PRIO_HIGH,
+    TEST_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_FLOATING_POINT,
+    &ctx->worker_id
+  T_rsc_success( sc );
+   * Start the worker thread.  Let it use the floating point coprocessor.
+  StartTask( ctx->worker_id, FloatingPointTask, ctx );
+   * Delete the worker thread and free the thread resources.
+  DeleteTask( ctx->worker_id );
+  KillZombies();
+   * Clean up all used resources.
+  RestoreRunnerPriority();
  * @fn void T_case_body_ScoreThreadValThread( void )
@@ -226,6 +299,7 @@ T_TEST_CASE_FIXTURE( ScoreThreadValThread, &ScoreThreadValThread_Fixture )
   ctx = T_fixture_context();
   ScoreThreadValThread_Action_0( ctx );
+  ScoreThreadValThread_Action_1( ctx );
2.35.3
