[PATCH] cpukit/dev/can: Added CAN support
Prashanth S
fishesprashanth at gmail.com
Fri Jul 15 18:11:32 UTC 2022
cpukit/dev/can/can-queue.c | 112 +++++++
cpukit/dev/can/can.c | 480 ++++++++++++++++++++++++++++++
cpukit/include/dev/can/can.h | 115 +++++++
spec/build/cpukit/librtemscpu.yml | 5 +
4 files changed, 712 insertions(+)
create mode 100644 cpukit/dev/can/can-queue.c
create mode 100644 cpukit/dev/can/can.c
create mode 100644 cpukit/include/dev/can/can.h
diff --git a/cpukit/dev/can/can-queue.c b/cpukit/dev/can/can-queue.c
new file mode 100644
index 0000000000..1cebed2ca4
--- /dev/null
+++ b/cpukit/dev/can/can-queue.c
@@ -0,0 +1,112 @@
+ * @file
+ * @ingroup CANBus
+ * @brief Controller Area Network (CAN) Bus Implementation
+ * Copyright (C) 2022
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/imfs.h>
+#include <rtems/thread.h>
+#include <dev/can/can.h>
+#include <string.h>
+#include <stdlib.h>
+#include <stdio.h>
+rtems_status_code can_create_rx_buffers(struct can_bus *bus)
+ static int init = 0;
+ return rtems_message_queue_create(rtems_build_name('c', 'a', 'n', '0' + init++), CAN_RX_BUF_COUNT, sizeof(struct can_msg),
+ RTEMS_FIFO | RTEMS_LOCAL, &bus->rx_queue_id);
+rtems_status_code can_create_tx_buffers(struct can_bus *bus)
+ if ((bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT * sizeof(struct can_msg))) == NULL) {
+ printf("malloc failed\n");
+ return RTEMS_NO_MEMORY;
+ bus->tx_fifo.head = bus->tx_fifo.tail = 0;
+ bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
+ return 0;
+bool can_tx_buf_isempty(struct can_bus *bus)
+ if (bus->tx_fifo.empty_count <= 0) {
+ /* tx_fifo.empty_count does not go below zero, incase if it goes update to zero */
+ bus->tx_fifo.empty_count = 0;
+ return false;
+ return true;
+struct can_msg *can_tx_get_data_buf(struct can_bus *bus)
+ struct can_msg *msg = NULL;
+ if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
+ printf("can_tx_get_next_data_buf All buffers are empty\n");
+ return NULL;
+ msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
+ bus->tx_fifo.empty_count++;
+ bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
+ return msg;
+struct can_msg *can_tx_get_empty_buf(struct can_bus *bus)
+ /* Check whether there is a empty CAN msg buffer */
+ if (can_tx_buf_isempty(bus) == false) {
+ printf("can_tx_get_empty_buf No empty buffer\n");
+ return NULL;
+ bus->tx_fifo.empty_count--;
+ /* tx_fifo.head always points to a empty buffer if there is atleast one */
+ msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
+ bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
+ return msg;
diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
index 0000000000..e8aa9d20ca
--- /dev/null
+++ b/cpukit/dev/can/can.c
@@ -0,0 +1,480 @@
+ * @file
+ * @ingroup CANBus
+ * are met:
+#include <fcntl.h>
+static ssize_t can_bus_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
+static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer, size_t count);
+static ssize_t can_bus_write(rtems_libio_t *iop, const void *buffer, size_t count);
+static ssize_t can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer);
+static int can_xmit(struct can_bus *bus);
+static void can_bus_obtain(can_bus *bus)
+ rtems_recursive_mutex_lock(&bus->mutex);
+static void can_bus_release(can_bus *bus)
+ rtems_recursive_mutex_unlock(&bus->mutex);
+ if (init == 1) {
+ return 0;
+ init = 1;
+ can_bus *bus = IMFS_generic_get_context_by_iop(iop);
+ if (bus == NULL) {
+ return -RTEMS_NOT_DEFINED;
+ can_create_sem(bus);
+ return 0;
+int can_receive(struct can_bus *bus, struct can_msg *msg)
+ int32_t ret = 0;
+ uint32_t count = 0;
+ if ((ret = rtems_message_queue_broadcast(bus->rx_queue_id, msg, sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len), &count)) != RTEMS_SUCCESSFUL) {
+ printf("rtems_message_queue_send failed\n");
+ printf("rtems_message_queue_broadcast = %u\n", count);
+ return ret;
+/* count argument is not used here as struct can_msg has the dlc member */
+ int32_t ret = 0;
+ uint32_t flags = 0;
+ if (bus == NULL || bus->can_dev_ops->dev_rx == NULL) {
+ struct can_msg *msg = (struct can_msg *)buffer;
+ if ((iop->flags & O_NONBLOCK) != 0) {
+ flags = RTEMS_NO_WAIT;
+ if ((ret = rtems_message_queue_receive(bus->rx_queue_id, (void *)msg, &count, flags, 0)) != RTEMS_SUCCESSFUL) {
+ return ret;
+ return count;
+int can_create_sem(struct can_bus *bus)
+ int ret = 0;
+#ifndef _POSIX_SEM_
+ //TODO: for test purpose
+ ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n', '0' + init++), 1,
+ RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | RTEMS_LOCAL, 0, &bus->tx_fifo_sem_id);
+ if (ret != 0) {
+ printf("rtems_semaphore_create failed %d\n", ret);
+ return ret;
+ ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ if (ret != 0) {
+ printf("rtems_semaphore_obtain failed %d\n", ret);
+ return ret;
+#else
+ ret = sem_init(&bus->tx_sem_id, 0, 1);
+ if (ret != 0) {
+ printf("sem_init failed %d\n", ret);
+ return ret;
+#endif /* _POSIX_SEM_ */
+ return ret;
+int take_sem(struct can_bus *bus)
+ int ret = 0;
+#else
+ ret = sem_wait(&bus->tx_sem_id);
+ return ret;
+int give_sem(struct can_bus *bus)
+ int ret = 0;
+ ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
+#else
+ ret = sem_post(&bus->tx_sem_id);
+ return ret;
+ int ret = 0;
+ rtems_interrupt_lock_context lock_context;
+ while (1) {
+ rtems_interrupt_lock_acquire(&bus->can_bus_lock, &lock_context);
+ ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
+ if (ret != true) {
+ goto return_with_lock_release;
+ msg = can_tx_get_data_buf(bus);
+ if (msg == NULL) {
+ ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
+ if (ret != RTEMS_SUCCESSFUL) {
+ printf("dev_send failed\n");
+ rtems_interrupt_lock_release(&bus->can_bus_lock, &lock_context);
+ //can_tx_done(bus);
+ return RTEMS_SUCCESSFUL;
+return_with_lock_release:
+void can_print_canmsg(struct can_msg const *msg)
+ printf("\n----------------------------------------------------------------------------------------------------------------------\n");
+ printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len, msg->flags);
+ for (int i = 0; i < msg->len; i++) {
+ printf("%02x ", msg->data[i]);
+int can_tx_done(struct can_bus *bus)
+ int ret = 0;
+ if (bus->can_dev_ops->dev_tx_ready(bus) == true) {
+ can_xmit(bus);
+ if (bus->can_tx_buf_waiters > 0 && (can_tx_buf_isempty(bus) != 0)) {
+ ret = give_sem(bus);
+ if (ret != 0) {
+ printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems_semaphore_release failed = %d\n", ret);
+ } else {
+ return ret;
+ if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
+ int32_t ret = 0;
+ struct can_msg const *msg = buffer;
+ struct can_msg *fifo_buf = NULL;
+ while (1) {
+ /* sleep is for debug purpose to test concurrency issues */
+ sleep(1);
+ fifo_buf = can_tx_get_empty_buf(bus);
+ if (fifo_buf != NULL) {
+ uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
+ if (msg_size > sizeof(struct can_msg)) {
+ printf("can message len error msg_size = %u struct can_msg = %u\n", msg_size, sizeof(struct can_msg));
+ return -RTEMS_INVALID_SIZE;
+ memcpy(fifo_buf, msg, msg_size); //sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len));
+ ret = msg_size;
+ //can_print_canmsg(msg);
+ sleep(1);
+ break;
+ /* Enters if clause, if there are no empty tx fifo buffers. Based on the flags, sleep until buffer
+ * is empty or return error status
+ if (fifo_buf == NULL) {
+ return -RTEMS_RESOURCE_IN_USE;
+ can_xmit(bus);
+ ret = can_tx_buf_isempty(bus);
+ if (ret == true) {
+ continue;
+ bus->can_tx_buf_waiters++;
+ printf("empty_count = %u\n", bus->tx_fifo.empty_count);
+ ret = take_sem(bus);
+ bus->can_tx_buf_waiters--;
+ printf("cannot take semaphore\n");
+ ret = -RTEMS_INTERNAL_ERROR;
+ goto return_release_lock;
+ can_xmit(bus);
+return_release_lock:
+ return ret;
+ if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
+ can_bus_obtain(bus);
+ bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
+ can_bus_release(bus);
+static const rtems_filesystem_file_handlers_r can_bus_handler = {
+ .open_h = can_bus_open,
+ .close_h = rtems_filesystem_default_close,
+ .read_h = can_bus_read,
+ .write_h = can_bus_write,
+ .ioctl_h = can_bus_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .mmap_h = rtems_filesystem_default_mmap,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev
+static void can_bus_node_destroy(IMFS_jnode_t *node)
+ can_bus *bus;
+ bus = IMFS_generic_get_context_by_node(node);
+ (*bus->destroy)(bus);
+ IMFS_node_destroy_default(node);
+static const IMFS_node_control can_bus_node_control = IMFS_GENERIC_INITIALIZER(&can_bus_handler,
+ IMFS_node_initialize_generic, can_bus_node_destroy);
+rtems_status_code can_bus_register(can_bus *bus, const char *bus_path)
+ int ret = RTEMS_SUCCESSFUL;
+ ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO, &can_bus_node_control, bus);
+ printf("Creating node failed: %d\n", ret);
+ goto fail;
+ RTEMS_INTERRUPT_LOCK_INITIALIZER(bus->can_bus_lock);
+ if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
+ printf("can_create_sem failed = %d\n", ret);
+ goto fail;
+ if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
+ printf("can_create_tx_buffers failed = %d\n", ret);
+ goto fail;
+ if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
+ printf("can_create_rx_buffers failed = %d\n", ret);
+ goto fail;
+ return ret;
+fail:
+ return ret;
+static void can_bus_destroy(can_bus *bus)
+ rtems_recursive_mutex_destroy(&bus->mutex);
+static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus *bus))
+ rtems_recursive_mutex_init(&bus->mutex, "CAN Bus");
+ bus->destroy = can_bus_destroy;
+static void can_bus_destroy_and_free(can_bus *bus)
+ can_bus_destroy(bus);
+ free(bus);
+int can_bus_init(can_bus *bus)
+ memset(bus, 0, sizeof(*bus));
+ return can_bus_do_init(bus, can_bus_destroy);
+can_bus *can_bus_alloc_and_init(size_t size)
+ can_bus *bus = NULL;
+ if (size >= sizeof(*bus)) {
+ bus = calloc(1, size);
+ if (bus != NULL) {
+ int rv;
+ rv = can_bus_do_init(bus, can_bus_destroy_and_free);
+ if (rv != 0) {
+ return NULL;
+ return bus;
diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
index 0000000000..2210820504
--- /dev/null
+++ b/cpukit/include/dev/can/can.h
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup CANBus
+ * are met:
+#ifndef _DEV_CAN_CAN_H
+#define _DEV_CAN_CAN_H
+#include <semaphore.h>
+#include <stdio.h>
+#define CAN_MSG_MAX_SIZE (8u)
+#define CAN_TX_BUF_COUNT (10u)
+#define CAN_RX_BUF_COUNT (10u)
+typedef struct can_dev_ops {
+ int32_t (*dev_rx)(void *priv, void *buffer);
+ int32_t (*dev_tx)(void *priv, void *buffer);
+ bool (*dev_tx_ready)(void *priv);
+ void (*dev_tx_int)(void *priv, bool);
+ int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
+} can_dev_ops;
+struct ring_buf {
+ struct can_msg *pbuf;
+ uint32_t head;
+ uint32_t tail;
+ uint32_t empty_count;
+typedef struct can_bus {
+ void *priv; // CAN controller specific struct.
+ struct can_dev_ops *can_dev_ops; // CAN controller operations.
+ struct ring_buf tx_fifo; // TX fifo
+ rtems_id tx_fifo_sem_id; // TX fifo counting semaphore id
+#else
+ sem_t tx_sem_id;
+ uint32_t tx_fifo_sem_name; // TX fifo sem name
+ uint32_t can_tx_buf_waiters;
+ rtems_id rx_queue_id;
+ uint32_t rx_queue_name;
+ rtems_recursive_mutex mutex; // For handling driver concurrency.
+ RTEMS_INTERRUPT_LOCK_MEMBER(can_bus_lock);
+ void (*destroy)(struct can_bus *bus); // Clean the CAN controller specific resources.
+} can_bus;
+struct can_msg {
+ uint32_t id; // 32 bits to support extended id (29 bits).
+ uint32_t timestamp;
+ uint16_t flags; // RTR | BRS | EXT ...
+ uint16_t len;
+ uint8_t data[CAN_MSG_MAX_SIZE]; // For supporting data transfer up to 64 bytes.
+extern can_bus *can_bus_alloc_and_init(size_t size);
+extern int can_bus_init(can_bus *bus);
+extern rtems_status_code can_bus_register(can_bus *bus, const char *bus_path);
+extern int can_tx_done(struct can_bus *);
+extern int can_receive(struct can_bus *, struct can_msg *);
+extern uint16_t can_len_to_dlc(uint16_t len);
+extern uint16_t can_dlc_to_len(uint16_t dlc);
+extern rtems_status_code can_create_tx_buffers(struct can_bus *bus);
+extern rtems_status_code can_create_rx_buffers(struct can_bus *bus);
+extern bool can_tx_buf_isempty(struct can_bus *bus);
+extern struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
+extern struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
+extern int take_sem(struct can_bus *);
+extern int give_sem(struct can_bus *);
+extern int can_create_sem(struct can_bus *bus);
+extern void can_print_canmsg(struct can_msg const *);
+#endif /* _DEV_CAN_CAN_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 31a68cf85a..b700935f82 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -50,6 +50,9 @@ install:
- destination: ${BSP_INCLUDEDIR}/dev/spi
source:
- cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/can
+ source:
+ - cpukit/include/dev/can/can.h
- destination: ${BSP_INCLUDEDIR}/linux
source:
- cpukit/include/linux/i2c-dev.h
@@ -530,6 +533,8 @@ source:
- cpukit/dev/serial/sc16is752-spi.c
- cpukit/dev/serial/sc16is752.c
- cpukit/dev/spi/spi-bus.c
+- cpukit/dev/can/can.c
+- cpukit/dev/can/can-queue.c
- cpukit/dtc/libfdt/fdt.c
- cpukit/dtc/libfdt/fdt_addresses.c
- cpukit/dtc/libfdt/fdt_empty_tree.c
2.25.1
