[PATCH] cpukit/dev/can: Added CAN support
oss at c-mauderer.de oss at c-mauderer.de
Tue Jul 19 09:17:35 UTC 2022
Hello Prashanth,
first question: You also worked on a driver for beagle DCAN. Did you
already adapt that driver to this API? If yes, it would be usefull to
post that as a patch too so that the direction and the method how it
will be used is more clear.
Note that some of my comments might are a bit critical because you add a
general API. I would have a lot less problems if it would be only a
driver specific API. If you add a general API, it has to fit the needs
of not only your current driver but most future drivers too. Changing an
API later is allways tricky.
Am 15.07.22 um 20:11 schrieb Prashanth S:
>   cpukit/dev/can/can-queue.c        | 112 +++++++
>   cpukit/dev/can/can.c              | 480 ++++++++++++++++++++++++++++++
>   cpukit/include/dev/can/can.h      | 115 +++++++
>   spec/build/cpukit/librtemscpu.yml |   5 +
>   4 files changed, 712 insertions(+)
>   create mode 100644 cpukit/dev/can/can-queue.c
>   create mode 100644 cpukit/dev/can/can.c
>   create mode 100644 cpukit/include/dev/can/can.h
> diff --git a/cpukit/dev/can/can-queue.c b/cpukit/dev/can/can-queue.c
> new file mode 100644
> index 0000000000..1cebed2ca4
> --- /dev/null
> +++ b/cpukit/dev/can/can-queue.c
> @@ -0,0 +1,112 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup CANBus
> + * @brief Controller Area Network (CAN) Bus Implementation
> + * Copyright (C) 2022
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/imfs.h>
> +#include <rtems/thread.h>
> +#include <dev/can/can.h>
> +#include <string.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +rtems_status_code can_create_rx_buffers(struct can_bus *bus)
> +  static int init = 0;
> +  return rtems_message_queue_create(rtems_build_name('c', 'a', 'n', '0' + init++), CAN_RX_BUF_COUNT, sizeof(struct can_msg),
> +                                    RTEMS_FIFO | RTEMS_LOCAL, &bus->rx_queue_id);
Please make sure to stic to the RTEMS style and use a 80 character line
length.
You create a name with a "'0' + init++": Are you sure that a maximum of
10 buffers are created? Otherwise you will get names like "can:", "can;"
and - sooner or later: "can\xFF", "can\x00", ...
In the header you somewhere had a "destroy" function. Do you need some
way to de-initialize buffers only used by that bus?
> +rtems_status_code can_create_tx_buffers(struct can_bus *bus)
> +  if ((bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT * sizeof(struct can_msg))) == NULL) {
You seem to like writing a lot of code in one line. From my point of
view that makes code harder to read. If you write it into multiple lines
instead, someone else doesn't have to think that much about which
bracket closes where. For example in this case the following would be
simpler to read:
sizeof(struct can_msg));
if (bus->tx_fifo.pbuf == NULL) {
> +    printf("malloc failed\n");
Prints are nice for debugging but can be really annoying in
applications. Think about some kind of "debug_print" or similar that you
can enable / disable with a macro at the start of the file. You can also
use that to add a prefix or function name to all prints. If you search a
problem, a line like "mallof failed" is meaningless if you are not
currently working on specially this code. A line like
"can_create_tx_buffers: malloc failed" is a lot more usefull. There are
preprocessor macros like __FUNCTION__ that you can use for something
like that.
> +    return RTEMS_NO_MEMORY;
> +  bus->tx_fifo.head = bus->tx_fifo.tail = 0;
Same here: This is hard to read. I would suggest to split that into two
lines. Alternatively you might want to think about just using a memset
to have a clean start for a structure that you initialize.
> +  bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
> +  return 0;
> +bool can_tx_buf_isempty(struct can_bus *bus)
> +  if (bus->tx_fifo.empty_count <= 0) {
> +    /* tx_fifo.empty_count does not go below zero, incase if it goes update to zero */
> +    bus->tx_fifo.empty_count = 0;
empty_count is an unsigned type and therefore can never be smaller than
0. This line is not necessary at all.
> +    return false;
> +  return true;
> +struct can_msg *can_tx_get_data_buf(struct can_bus *bus)
> +  struct can_msg *msg = NULL;
> +  if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
> +    printf("can_tx_get_next_data_buf All buffers are empty\n");
> +    return NULL;
> +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
> +  bus->tx_fifo.empty_count++;
> +  bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
You want to return the pointer to the message (msg) to the caller,
right? In that case you must not marke it as empty here. Otherwise
someone else could already use that memory again while the application
is still processing it.
> +  return msg;
> +struct can_msg *can_tx_get_empty_buf(struct can_bus *bus)
> +  /* Check whether there is a empty CAN msg buffer */
> +  if (can_tx_buf_isempty(bus) == false) {
> +    printf("can_tx_get_empty_buf No empty buffer\n");
> +    return NULL;
> +  bus->tx_fifo.empty_count--;
> +  /* tx_fifo.head always points to a empty buffer if there is atleast one */
> +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
> +  bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
> +  return msg;
> diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
> index 0000000000..e8aa9d20ca
> --- /dev/null
> +++ b/cpukit/dev/can/can.c
> @@ -0,0 +1,480 @@
> + * @file
> + * @ingroup CANBus
> + * are met:
> +#include <fcntl.h>
> +static ssize_t can_bus_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
> +static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer, size_t count);
> +static ssize_t can_bus_write(rtems_libio_t *iop, const void *buffer, size_t count);
> +static ssize_t can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer);
> +static int can_xmit(struct can_bus *bus);
> +static void can_bus_obtain(can_bus *bus)
> +  rtems_recursive_mutex_lock(&bus->mutex);
> +static void can_bus_release(can_bus *bus)
> +  rtems_recursive_mutex_unlock(&bus->mutex);
> +  if (init == 1) {
> +    return 0;
> +  init = 1;
> +  can_bus *bus = IMFS_generic_get_context_by_iop(iop);
> +  if (bus == NULL) {
> +    return -RTEMS_NOT_DEFINED;
> +  can_create_sem(bus);
> +  return 0;
> +int can_receive(struct can_bus *bus, struct can_msg *msg)
> +  int32_t ret = 0;
> +  uint32_t count = 0;
> +  if ((ret = rtems_message_queue_broadcast(bus->rx_queue_id, msg, sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len), &count)) != RTEMS_SUCCESSFUL) {
> +    printf("rtems_message_queue_send failed\n");
> +  printf("rtems_message_queue_broadcast = %u\n", count);
> +  return ret;
> +/* count argument is not used here as struct can_msg has the dlc member */
> +  int32_t ret = 0;
> +  uint32_t flags = 0;
> +  if (bus == NULL || bus->can_dev_ops->dev_rx == NULL) {
> +  struct can_msg *msg = (struct can_msg *)buffer;
> +  if ((iop->flags & O_NONBLOCK) != 0) {
> +    flags = RTEMS_NO_WAIT;
> +  if ((ret = rtems_message_queue_receive(bus->rx_queue_id, (void *)msg, &count, flags, 0)) != RTEMS_SUCCESSFUL) {
> +    return ret;
> +  return count;
> +int can_create_sem(struct can_bus *bus)
Looks like a helper function that is only used in this file? Please make
it static and remove it from the header. Same is true for "take_sem" and
similar below.
> +  int ret = 0;
> +#ifndef _POSIX_SEM_
> +  //TODO: for test purpose
> +  ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n', '0' + init++), 1,
> +      RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | RTEMS_LOCAL, 0, &bus->tx_fifo_sem_id);
> +  if (ret != 0) {
> +    printf("rtems_semaphore_create failed %d\n", ret);
> +    return ret;
> +  ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> +  if (ret != 0) {
> +    printf("rtems_semaphore_obtain failed %d\n", ret);
> +    return ret;
> +#else
> +  ret = sem_init(&bus->tx_sem_id, 0, 1);
> +  if (ret != 0) {
> +    printf("sem_init failed %d\n", ret);
> +    return ret;
> +#endif /* _POSIX_SEM_ */
> +  return ret;
> +int take_sem(struct can_bus *bus)
> +  int ret = 0;
> +#else
> +  ret = sem_wait(&bus->tx_sem_id);
> +  return ret;
> +int give_sem(struct can_bus *bus)
> +  int ret = 0;
> +  ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
> +#else
> +  ret = sem_post(&bus->tx_sem_id);
> +  return ret;
> +  int ret = 0;
> +  rtems_interrupt_lock_context lock_context;
> +  while (1) {
> +    rtems_interrupt_lock_acquire(&bus->can_bus_lock, &lock_context);
Is an interrupt lock really necessary? Wouldn't a mutex or similar work
too to protect the relevant data? An interrupt lock is something that
should be used really carefull. You tell the system: Stop everything
else. This here is the most important task.
That means that for example a time critical data acquisition process can
be delayed by the time that you need in your interrupt lock. You have to
be really sure that the interrupt is the only solution to solve the
problem before you use one.
> +    ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
> +    if (ret != true) {
> +      goto return_with_lock_release;
> +    msg = can_tx_get_data_buf(bus);
> +    if (msg == NULL) {
> +    ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
You have an interrupt lock here. Is "dev_tx" a function that is
guaranteed to be fast enough not to make problems with that?
> +    if (ret != RTEMS_SUCCESSFUL) {
> +        printf("dev_send failed\n");
You have an interrupt lock here. You can't use a printf because that
uses interrupts.
> +    rtems_interrupt_lock_release(&bus->can_bus_lock, &lock_context);
> +    //can_tx_done(bus);
> +  return RTEMS_SUCCESSFUL;
> +return_with_lock_release:
> +void can_print_canmsg(struct can_msg const *msg)
I assume that's a debug only function. Otherwise I wouldn't be happy
with the output format.
> +  printf("\n----------------------------------------------------------------------------------------------------------------------\n");
> +  printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len, msg->flags);
> +  for (int i = 0; i < msg->len; i++) {
> +    printf("%02x ", msg->data[i]);
> +int can_tx_done(struct can_bus *bus)
> +  int ret = 0;
> +  if (bus->can_dev_ops->dev_tx_ready(bus) == true) {
> +    can_xmit(bus);
> +  if (bus->can_tx_buf_waiters > 0 && (can_tx_buf_isempty(bus) != 0)) {
> +    ret = give_sem(bus);
> +    if (ret != 0) {
> +      printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems_semaphore_release failed = %d\n", ret);
> +    } else {
> +  return ret;
> +  if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
> +  int32_t ret = 0;
> +  struct can_msg const *msg = buffer;
> +  struct can_msg *fifo_buf = NULL;
> +  while (1) {
> +    /* sleep is for debug purpose to test concurrency issues */
> +    sleep(1);
Same as above: Is an interrupt lock really necessary and the only solution?
> +    fifo_buf = can_tx_get_empty_buf(bus);
> +    if (fifo_buf != NULL) {
> +      uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
> +      if (msg_size > sizeof(struct can_msg)) {
> +        printf("can message len error msg_size = %u struct can_msg = %u\n", msg_size, sizeof(struct can_msg));
Again: Printf will not work during an interrupt lock.
> +        return -RTEMS_INVALID_SIZE;
> +      memcpy(fifo_buf, msg, msg_size); //sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len));
memcpy() in an interrupt lock is definitively takeing too much time. You
have to be really convincing that I agree that it's OK.
> +      ret = msg_size;
> +      //can_print_canmsg(msg);
> +    sleep(1);
> +      break;
> +    /* Enters if clause, if there are no empty tx fifo buffers. Based on the flags, sleep until buffer
> +     * is empty or return error status
> +    if (fifo_buf == NULL) {
> +        return -RTEMS_RESOURCE_IN_USE;
> +        can_xmit(bus);
> +      ret = can_tx_buf_isempty(bus);
If the "isempty" function needs an interupt_lock: Shouldn't it be part
of the function?
And again: Wouldn't a mutex work to protect the data instead of
interrupt locks?
> +      if (ret == true) {
> +        continue;
> +      bus->can_tx_buf_waiters++;
> +      printf("empty_count = %u\n", bus->tx_fifo.empty_count);
> +      ret = take_sem(bus);
> +      bus->can_tx_buf_waiters--;
> +        printf("cannot take semaphore\n");
> +        ret = -RTEMS_INTERNAL_ERROR;
> +        goto return_release_lock;
> +    can_xmit(bus);
> +return_release_lock:
Why is the label named "...release_lock"? It isn't releasing any lock.
> +  return ret;
> +  if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
> +  can_bus_obtain(bus);
> +  bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
> +  can_bus_release(bus);
> +static const rtems_filesystem_file_handlers_r can_bus_handler = {
> +  .open_h = can_bus_open,
> +  .close_h = rtems_filesystem_default_close,
> +  .read_h = can_bus_read,
> +  .write_h = can_bus_write,
> +  .ioctl_h = can_bus_ioctl,
> +  .lseek_h = rtems_filesystem_default_lseek,
> +  .fstat_h = IMFS_stat,
> +  .ftruncate_h = rtems_filesystem_default_ftruncate,
> +  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
> +  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
> +  .fcntl_h = rtems_filesystem_default_fcntl,
> +  .kqfilter_h = rtems_filesystem_default_kqfilter,
> +  .mmap_h = rtems_filesystem_default_mmap,
> +  .poll_h = rtems_filesystem_default_poll,
> +  .readv_h = rtems_filesystem_default_readv,
> +  .writev_h = rtems_filesystem_default_writev
> +static void can_bus_node_destroy(IMFS_jnode_t *node)
> +  can_bus *bus;
> +  bus = IMFS_generic_get_context_by_node(node);
> +  (*bus->destroy)(bus);
> +  IMFS_node_destroy_default(node);
> +static const IMFS_node_control can_bus_node_control = IMFS_GENERIC_INITIALIZER(&can_bus_handler,
> +                                                      IMFS_node_initialize_generic, can_bus_node_destroy);
> +rtems_status_code can_bus_register(can_bus *bus, const char *bus_path)
> +  int ret = RTEMS_SUCCESSFUL;
> +  ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO, &can_bus_node_control, bus);
> +    printf("Creating node failed: %d\n", ret);
> +    goto fail;
> +  RTEMS_INTERRUPT_LOCK_INITIALIZER(bus->can_bus_lock);
The RTEMS_INTERRUPT_LOCK_INITIALIZER is for a static initialization of
an interrupt lock. It won't work to initialize it dynamically here.
> +  if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
> +    printf("can_create_sem failed = %d\n", ret);
> +    goto fail;
> +  if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> +    printf("can_create_tx_buffers failed = %d\n", ret);
> +    goto fail;
> +  if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> +    printf("can_create_rx_buffers failed = %d\n", ret);
> +    goto fail;
> +  return ret;
> +fail:
> +  return ret;
> +static void can_bus_destroy(can_bus *bus)
> +  rtems_recursive_mutex_destroy(&bus->mutex);
> +static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus *bus))
> +  rtems_recursive_mutex_init(&bus->mutex, "CAN Bus");
> +  bus->destroy = can_bus_destroy;
> +static void can_bus_destroy_and_free(can_bus *bus)
> +  can_bus_destroy(bus);
> +  free(bus);
> +int can_bus_init(can_bus *bus)
> +  memset(bus, 0, sizeof(*bus));
> +  return can_bus_do_init(bus, can_bus_destroy);
> +can_bus *can_bus_alloc_and_init(size_t size)
> +  can_bus *bus = NULL;
> +  if (size >= sizeof(*bus)) {
> +    bus = calloc(1, size);
> +    if (bus != NULL) {
> +      int rv;
> +      rv = can_bus_do_init(bus, can_bus_destroy_and_free);
> +      if (rv != 0) {
> +        return NULL;
> +  return bus;
> diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
> index 0000000000..2210820504
> --- /dev/null
> +++ b/cpukit/include/dev/can/can.h
> @@ -0,0 +1,115 @@
> + * @file
> + * @ingroup CANBus
> + * are met:
> +#ifndef _DEV_CAN_CAN_H
> +#define _DEV_CAN_CAN_H
> +#include <semaphore.h>
> +#include <stdio.h>
A more or less general note for the header file: You want to introduce
it as a new general API. Please make sure to document that API enough.
Use doxygen-comments in the header file for that. For an example, take a
look at cpukit/include/linux/i2c.h or some other headers. Documentation
is often really annoying to write as a developer but at the same time
it's really convenient to have it for all other developers.
For me it's also not really clear whether you want to create a user
facing API with this file or a driver facing one.
> +#define CAN_MSG_MAX_SIZE  (8u)
> +#define CAN_TX_BUF_COUNT  (10u)
> +#define CAN_RX_BUF_COUNT  (10u)
Is that really a value that does match the needs of all drivers /
applications?
> +typedef struct can_dev_ops {
> +  int32_t (*dev_rx)(void *priv, void *buffer);
> +  int32_t (*dev_tx)(void *priv, void *buffer);
> +  bool (*dev_tx_ready)(void *priv);
> +  void (*dev_tx_int)(void *priv, bool);
> +  int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
> +} can_dev_ops;
> +struct ring_buf {
> +  struct can_msg *pbuf;
> +  uint32_t head;
> +  uint32_t tail;
> +  uint32_t empty_count;
> +typedef struct can_bus {
> +  void *priv;                               // CAN controller specific struct.
> +  struct can_dev_ops *can_dev_ops;          // CAN controller operations.
> +  struct ring_buf tx_fifo;                  // TX fifo
> +  rtems_id tx_fifo_sem_id;                  // TX fifo counting semaphore id
> +#else
> +  sem_t tx_sem_id;
> +  uint32_t tx_fifo_sem_name;                // TX fifo sem name
What's the advantage of implementing two types of semaphores depending
on the _POSIX_SEM_ macro instead of just using only one RTEMS-native type?
I haven't had a detailed look at the useage of the semaphores yet.
Personally I prefer the self-contained objects because they have the
advantage that the application-developers don't have to think about them
when configuring their application:
https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#
Not sure whether that would be an option here.
> +  uint32_t can_tx_buf_waiters;
> +  rtems_id rx_queue_id;
> +  uint32_t rx_queue_name;
> +  rtems_recursive_mutex mutex;              // For handling driver concurrency.
> +  RTEMS_INTERRUPT_LOCK_MEMBER(can_bus_lock);
> +  void (*destroy)(struct can_bus *bus);     // Clean the CAN controller specific resources.
> +} can_bus;
> +struct can_msg {
> +  uint32_t id;                              // 32 bits to support extended id (29 bits).
> +  uint32_t timestamp;
> +  uint16_t flags;                           // RTR | BRS | EXT ...
> +  uint16_t len;
> +  uint8_t data[CAN_MSG_MAX_SIZE];           // For supporting data transfer up to 64 bytes.
> +extern can_bus *can_bus_alloc_and_init(size_t size);
> +extern int can_bus_init(can_bus *bus);
> +extern rtems_status_code can_bus_register(can_bus *bus, const char *bus_path);
> +extern int can_tx_done(struct can_bus *);
> +extern int can_receive(struct can_bus *, struct can_msg *);
> +extern uint16_t can_len_to_dlc(uint16_t len);
> +extern uint16_t can_dlc_to_len(uint16_t dlc);
> +extern rtems_status_code can_create_tx_buffers(struct can_bus *bus);
> +extern rtems_status_code can_create_rx_buffers(struct can_bus *bus);
> +extern bool can_tx_buf_isempty(struct can_bus *bus);
> +extern struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
> +extern struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
> +extern int take_sem(struct can_bus *);
> +extern int give_sem(struct can_bus *);
> +extern int can_create_sem(struct can_bus *bus);
Some of the functions seem to be internal functions that are only used
in the framework (especially the ones with *_sem() but also the whole
create*buffers() stuff). You shouldn't expose them to the user. Make
them static or put them into some internal header.
Best regards
Christian
> +extern void can_print_canmsg(struct can_msg const *);
> +#endif /* _DEV_CAN_CAN_H */
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 31a68cf85a..b700935f82 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -50,6 +50,9 @@ install:
>   - destination: ${BSP_INCLUDEDIR}/dev/spi
>     source:
>     - cpukit/include/dev/spi/spi.h
> +- destination: ${BSP_INCLUDEDIR}/dev/can
> +  source:
> +  - cpukit/include/dev/can/can.h
>   - destination: ${BSP_INCLUDEDIR}/linux
>     source:
>     - cpukit/include/linux/i2c-dev.h
> @@ -530,6 +533,8 @@ source:
>   - cpukit/dev/serial/sc16is752-spi.c
>   - cpukit/dev/serial/sc16is752.c
>   - cpukit/dev/spi/spi-bus.c
> +- cpukit/dev/can/can.c
> +- cpukit/dev/can/can-queue.c
>   - cpukit/dtc/libfdt/fdt.c
>   - cpukit/dtc/libfdt/fdt_addresses.c
>   - cpukit/dtc/libfdt/fdt_empty_tree.c
