[RTEMS 5 2/2] score: Fix unlimited objects support
Sebastian Huber
Mon Jul 18 07:37:40 UTC 2022
Commit 21275b58a5a69c3c838082ffc8a7a3641f32ea9a ("score: Static
Objects_Information initialization") introduced an off-by-one error in the
maintenance of inactive objects.
Close #4676.
cpukit/include/rtems/score/objectimpl.h | 29 +++++++++++++++++++++----
cpukit/score/src/objectfree.c | 12 +++++-----
2 files changed, 32 insertions(+), 9 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index c540f90166..ed0ce2aa10 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -937,6 +937,25 @@ RTEMS_INLINE_ROUTINE void _Objects_Free(
( *information->deallocate )( information, the_object );
+ * @brief Returns true, if the object associated with the zero-based index is
+ * contained in an allocated block of objects, otherwise false.
+ * @param index is the zero-based object index.
+ * @param objects_per_block is the object count per block.
+ * @retval true The object associated with the zero-based index is in an
+ * allocated block of objects.
+ * @retval false Otherwise.
+RTEMS_INLINE_ROUTINE bool _Objects_Is_in_allocated_block(
+ Objects_Maximum index,
+ Objects_Maximum objects_per_block
+ return index >= objects_per_block;
* @brief Activate the object.
@@ -952,15 +971,17 @@ RTEMS_INLINE_ROUTINE void _Objects_Activate_unlimited(
Objects_Maximum objects_per_block;
- Objects_Maximum block;
+ Objects_Maximum index;
_Assert( _Objects_Is_auto_extend( information ) );
objects_per_block = information->objects_per_block;
- block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
+ index = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
+ if ( _Objects_Is_in_allocated_block( index, objects_per_block ) ) {
+ Objects_Maximum block;
- if ( block > objects_per_block ) {
- block /= objects_per_block;
+ block = index / objects_per_block;
information->inactive_per_block[ block ]--;
information->inactive--;
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index 1f7aa37e3f..964adbc62a 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -30,14 +30,16 @@ void _Objects_Free_unlimited(
if ( _Objects_Is_auto_extend( information ) ) {
- Objects_Maximum inactive;
+ Objects_Maximum inactive;
++information->inactive_per_block[ block ];
2.35.3
