[PATCH] score: Use priority inheritance for thread join
Sebastian Huber
Tue Jul 19 06:58:04 UTC 2022
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach is not
transitive, it does not account for priority adjustments of the calling task
while waiting for the join, clustered scheduling is not supported, and
deadlocks are not detected. All these problems are fixed by using a priority
inheritance thread queue for the join operation.
Update #4679.
cpukit/include/rtems/score/threadimpl.h | 81 ++-
cpukit/posix/src/cancel.c | 2 +-
cpukit/posix/src/pthreadjoin.c | 47 +-
cpukit/rtems/src/taskdelete.c | 17 +-
cpukit/score/src/threadinitialize.c | 2 +
cpukit/score/src/threadrestart.c | 124 ++--
testsuites/psxtests/psx08/init.c | 38 ++
testsuites/psxtests/psx12/init.c | 2 +
testsuites/smptests/smppsxmutex01/init.c | 33 +-
testsuites/validation/tc-task-delete.c | 705 +++++++++++------------
testsuites/validation/tc-task-exit.c | 44 +-
testsuites/validation/tc-task-restart.c | 6 +-
12 files changed, 567 insertions(+), 534 deletions(-)
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 37932b367d..e6e77b195c 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -380,39 +380,65 @@ RTEMS_NO_RETURN void _Thread_Exit(
- * @brief Joins the currently executing thread with the given thread to wait
- * for.
+ * @brief Joins the currently executing thread with the thread.
- * @param[in, out] the_thread The thread to wait for.
- * @param waiting_for_join The states control for the join.
- * @param[in, out] executing The currently executing thread.
- * @param queue_context The thread queue context.
+ * @param[in, out] the_thread is the thread to join.
+ * @param waiting_for_join is the thread state for the currently executing
+ * thread.
+ * @param[in, out] executing is the currently executing thread.
+ * @param queue_context[in, out] is the thread queue context. The caller shall
+ * have acquired the thread state lock using the thread queue context.
+ * @retval STATUS_SUCCESSFUL The operation was successful.
+ * @retval STATUS_DEADLOCK A deadlock occurred.
-void _Thread_Join(
+Status_Control _Thread_Join(
Thread_Control *the_thread,
States_Control waiting_for_join,
Thread_Control *executing,
Thread_queue_Context *queue_context
+ * @brief Indicates the resulting state of _Thread_Cancel().
+typedef enum {
+ * @brief Indicates that the thread cancel operation is done.
+ THREAD_CANCEL_DONE,
+ * @brief Indicates that the thread cancel operation is in progress.
+ * The cancelled thread is terminating. It may be joined.
+ THREAD_CANCEL_IN_PROGRESS
+} Thread_Cancel_state;
* @brief Cancels the thread.
- * @param[in, out] the_thread The thread to cancel.
- * @param executing The currently executing thread.
- * @param exit_value The exit value for the thread.
+ * @param[in, out] the_thread is the thread to cancel.
+ * @param[in, out] life_states_to_clear is the set of thread life states to
+ * clear for the thread to cancel.
+ * @param exit_value is the exit value for the thread to cancel.
-void _Thread_Cancel(
- Thread_Control *the_thread,
- Thread_Control *executing,
- void *exit_value
+Thread_Cancel_state _Thread_Cancel(
+ Thread_Control *the_thread,
+ Thread_Control *executing,
+ Thread_Life_state life_states_to_clear,
+ void *exit_value
-typedef struct {
- Thread_queue_Context Base;
- Thread_Control *cancel;
-} Thread_Close_context;
* @brief Closes the thread.
@@ -420,14 +446,21 @@ typedef struct {
* case the executing thread is not terminated, then this function waits until
* the terminating thread reached the zombie state.
- * @param the_thread The thread to close.
- * @param[in, out] context The thread close context.
+ * @param the_thread is the thread to close.
+ * @param[in, out] queue_context is the thread queue context. The caller shall
+ * have disabled interrupts using the thread queue context.
-void _Thread_Close(
+Status_Control _Thread_Close(
- Thread_Close_context *context
+ Thread_queue_Context *queue_context
diff --git a/cpukit/posix/src/cancel.c b/cpukit/posix/src/cancel.c
index 300055d68a..0fb2199f0a 100644
--- a/cpukit/posix/src/cancel.c
+++ b/cpukit/posix/src/cancel.c
@@ -75,7 +75,7 @@ int pthread_cancel( pthread_t thread )
} else {
_Thread_Dispatch_disable_with_CPU( cpu_self, &lock_context );
_ISR_lock_ISR_enable( &lock_context );
- _Thread_Cancel( the_thread, executing, PTHREAD_CANCELED );
+ (void) _Thread_Cancel( the_thread, executing, 0, PTHREAD_CANCELED );
_Thread_Dispatch_enable( cpu_self );
return 0;
diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
index 84ff15ceec..e4f978f6b4 100644
--- a/cpukit/posix/src/pthreadjoin.c
+++ b/cpukit/posix/src/pthreadjoin.c
@@ -54,26 +54,16 @@ static int _POSIX_Threads_Join( pthread_t thread, void **value_ptr )
Thread_Control *the_thread;
Thread_queue_Context queue_context;
- Per_CPU_Control *cpu_self;
Thread_Control *executing;
- void *value;
+ Status_Control status;
_Thread_queue_Context_initialize( &queue_context );
- _Thread_queue_Context_set_enqueue_do_nothing_extra( &queue_context );
the_thread = _Thread_Get( thread, &queue_context.Lock_context.Lock_context );
if ( the_thread == NULL ) {
return ESRCH;
- cpu_self = _Per_CPU_Get();
- executing = _Per_CPU_Get_executing( cpu_self );
- if ( executing == the_thread ) {
- _ISR_lock_ISR_enable( &queue_context.Lock_context.Lock_context );
- return EDEADLK;
_Thread_State_acquire_critical(
the_thread,
@@ -84,33 +74,20 @@ static int _POSIX_Threads_Join( pthread_t thread, void **value_ptr )
return EINVAL;
- if ( _States_Is_waiting_for_join_at_exit( the_thread->current_state ) ) {
- value = the_thread->Life.exit_value;
- _Thread_Clear_state_locked( the_thread, STATES_WAITING_FOR_JOIN_AT_EXIT );
- _Thread_Dispatch_disable_with_CPU(
- cpu_self,
- &queue_context.Lock_context.Lock_context
- _Thread_State_release( the_thread, &queue_context.Lock_context.Lock_context );
- _Thread_Dispatch_direct( cpu_self );
- } else {
- _Thread_Join(
- the_thread,
- STATES_INTERRUPTIBLE_BY_SIGNAL | STATES_WAITING_FOR_JOIN,
- executing,
- &queue_context
- if ( _POSIX_Get_error_after_wait( executing ) != 0 ) {
- _Assert( _POSIX_Get_error_after_wait( executing ) == EINTR );
- return EINTR;
- value = executing->Wait.return_argument;
+ executing = _Thread_Executing;
+ status = _Thread_Join(
+ the_thread,
+ STATES_INTERRUPTIBLE_BY_SIGNAL | STATES_WAITING_FOR_JOIN,
+ executing,
+ &queue_context
+ if ( status != STATUS_SUCCESSFUL ) {
+ return _POSIX_Get_error( status );
if ( value_ptr != NULL ) {
- *value_ptr = value;
+ *value_ptr = executing->Wait.return_argument;
return 0;
diff --git a/cpukit/rtems/src/taskdelete.c b/cpukit/rtems/src/taskdelete.c
index 2e3de0922e..410842f393 100644
--- a/cpukit/rtems/src/taskdelete.c
+++ b/cpukit/rtems/src/taskdelete.c
@@ -40,6 +40,7 @@
#endif
+#include <rtems/rtems/statusimpl.h>
rtems_status_code rtems_task_delete(
@@ -47,12 +48,13 @@ rtems_status_code rtems_task_delete(
- Thread_Close_context context;
+ Thread_queue_Context queue_context;
- _Thread_queue_Context_initialize( &context.Base );
- the_thread = _Thread_Get( id, &context.Base.Lock_context.Lock_context );
+ _Thread_queue_Context_initialize( &queue_context );
+ the_thread = _Thread_Get( id, &queue_context.Lock_context.Lock_context );
#if defined(RTEMS_MULTIPROCESSING)
@@ -67,23 +69,22 @@ rtems_status_code rtems_task_delete(
if ( _Per_CPU_Is_ISR_in_progress( cpu_self ) ) {
- _ISR_lock_ISR_enable( &context.Base.Lock_context.Lock_context );
+ _ISR_lock_ISR_enable( &queue_context.Lock_context.Lock_context );
return RTEMS_CALLED_FROM_ISR;
if ( the_thread == executing ) {
* The Classic tasks are neither detached nor joinable. In case of
* self deletion, they are detached, otherwise joinable by default.
_Thread_Exit( NULL, THREAD_LIFE_TERMINATING | THREAD_LIFE_DETACHED );
- } else {
- _Thread_Close( the_thread, executing, &context );
- return RTEMS_SUCCESSFUL;
+ status = _Thread_Close( the_thread, executing, &queue_context );
+ return _Status_Get( status );
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 457fdaa54a..5983675f7b 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -281,6 +281,8 @@ static bool _Thread_Try_initialize(
stack_end - stack_begin
+ the_thread->Join_queue.Queue.owner = the_thread;
* Get thread queue heads
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 25f57e2a40..e1911beb2b 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -55,7 +55,7 @@
#include <rtems/score/userextimpl.h>
-#define THREAD_JOIN_TQ_OPERATIONS &_Thread_queue_Operations_priority
+#define THREAD_JOIN_TQ_OPERATIONS &_Thread_queue_Operations_priority_inherit
static void _Thread_Life_action_handler(
@@ -70,31 +70,6 @@ Thread_Zombie_registry _Thread_Zombies = {
.Chain = CHAIN_INITIALIZER_EMPTY( _Thread_Zombies.Chain )
-static void _Thread_Raise_real_priority(
- Priority_Control priority
- Thread_queue_Context queue_context;
- _Thread_queue_Context_initialize( &queue_context );
- _Thread_queue_Context_clear_priority_updates( &queue_context );
- _Thread_Wait_acquire( the_thread, &queue_context );
- if ( priority < the_thread->Real_priority.priority ) {
- _Thread_Priority_change(
- the_thread,
- &the_thread->Real_priority,
- priority,
- PRIORITY_GROUP_LAST,
- &queue_context
- _Thread_Wait_release( the_thread, &queue_context );
- _Thread_Priority_update( &queue_context );
typedef struct {
void *exit_value;
@@ -388,18 +363,37 @@ static void _Thread_Remove_life_change_request( Thread_Control *the_thread )
_Thread_State_release( the_thread, &lock_context );
-void _Thread_Join(
+static void _Thread_Clear_waiting_for_join_at_exit(
+ Thread_queue_Queue *queue,
+ Per_CPU_Control *cpu_self,
+ (void) the_thread;
+ (void) cpu_self;
+ (void) queue_context;
+ _Thread_Clear_state( queue->owner, STATES_WAITING_FOR_JOIN_AT_EXIT );
- _Assert( the_thread != executing );
_Assert( _Thread_State_is_owner( the_thread ) );
executing->Wait.return_argument = NULL;
+ _Thread_queue_Context_set_enqueue_callout(
+ queue_context,
+ _Thread_Clear_waiting_for_join_at_exit
+ _Thread_queue_Context_set_deadlock_callout(
+ queue_context,
+ _Thread_queue_Deadlock_status
_Thread_queue_Context_set_thread_state( queue_context, waiting_for_join );
_Thread_queue_Enqueue(
&the_thread->Join_queue.Queue,
@@ -407,6 +401,7 @@ void _Thread_Join(
executing,
queue_context
+ return _Thread_Wait_get_status( executing );
static void _Thread_Set_exit_value(
@@ -435,15 +430,15 @@ static void _Thread_Try_life_change_request(
- void *exit_value
+ void *exit_value
- ISR_lock_Context lock_context;
- Thread_Life_state previous;
+ ISR_lock_Context lock_context;
+ Thread_Life_state previous;
@@ -452,60 +447,55 @@ void _Thread_Cancel(
_Thread_Set_exit_value( the_thread, exit_value );
previous = _Thread_Change_life_locked(
the_thread,
- 0,
+ life_states_to_clear,
THREAD_LIFE_TERMINATING,
0
- cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
if ( _States_Is_dormant( the_thread->current_state ) ) {
_Thread_Make_zombie( the_thread );
- } else {
- Priority_Control priority;
- _Thread_Try_life_change_request( the_thread, previous, &lock_context );
- priority = _Thread_Get_priority( executing );
- _Thread_Raise_real_priority( the_thread, priority );
+ return THREAD_CANCEL_DONE;
- _Thread_Dispatch_enable( cpu_self );
+ _Thread_Try_life_change_request( the_thread, previous, &lock_context );
+ return THREAD_CANCEL_IN_PROGRESS;
-static void _Thread_Close_enqueue_callout(
- Thread_queue_Queue *queue,
- Per_CPU_Control *cpu_self,
- Thread_Close_context *context;
- context = (Thread_Close_context *) queue_context;
- _Thread_Cancel( context->cancel, the_thread, NULL );
+ Per_CPU_Control *cpu_self;
+ Thread_Cancel_state cancel_state;
- context->cancel = the_thread;
- _Thread_queue_Context_set_enqueue_callout(
- &context->Base,
- _Thread_Close_enqueue_callout
+ cpu_self = _Thread_Dispatch_disable_critical(
+ &queue_context->Lock_context.Lock_context
+ _ISR_lock_ISR_enable( &queue_context->Lock_context.Lock_context );
+ cancel_state =
+ _Thread_Cancel( the_thread, executing, THREAD_LIFE_DETACHED, NULL );
+ if ( cancel_state == THREAD_CANCEL_DONE ) {
+ _Thread_Dispatch_enable( cpu_self );
+ return STATUS_SUCCESSFUL;
+ _ISR_lock_ISR_disable( &queue_context->Lock_context.Lock_context );
+ _Thread_Dispatch_unnest( cpu_self );
the_thread,
- &context->Base.Lock_context.Lock_context
- _Thread_Join(
+ return _Thread_Join(
the_thread,
executing,
- &context->Base
+ queue_context
diff --git a/testsuites/psxtests/psx08/init.c b/testsuites/psxtests/psx08/init.c
index b4b22a5338..f183b9acfc 100644
--- a/testsuites/psxtests/psx08/init.c
+++ b/testsuites/psxtests/psx08/init.c
@@ -36,6 +36,42 @@
const char rtems_test_name[] = "PSX 8";
+static void *join_thread( void *arg )
+ int eno;
+ (void) arg;
+ eno = pthread_setcanceltype( PTHREAD_CANCEL_ASYNCHRONOUS, NULL );
+ rtems_test_assert( eno == 0 );
+ (void) pthread_join( Init_id, NULL );
+ rtems_test_assert( 0 );
+static void test_join_deadlock( void )
+ pthread_t td;
+ int eno;
+ void *value;
+ eno = pthread_create( &td, NULL, join_thread, NULL );
+ sched_yield();
+ eno = pthread_join( td, NULL );
+ rtems_test_assert( eno == EDEADLK );
+ eno = pthread_cancel( td );
+ value = NULL;
+ eno = pthread_join( td, &value );
+ rtems_test_assert( value == PTHREAD_CANCELED );
void *POSIX_Init(
void *argument
@@ -54,6 +90,8 @@ void *POSIX_Init(
Init_id = pthread_self();
printf( "Init's ID is 0x%08" PRIxpthread_t "\n", Init_id );
+ test_join_deadlock();
puts( "Init: pthread_detach - ESRCH (invalid id)" );
status = pthread_detach( (pthread_t) -1 );
rtems_test_assert( status == ESRCH );
diff --git a/testsuites/psxtests/psx12/init.c b/testsuites/psxtests/psx12/init.c
index 76737b0c3b..6526805313 100644
--- a/testsuites/psxtests/psx12/init.c
+++ b/testsuites/psxtests/psx12/init.c
@@ -226,6 +226,8 @@ static void *POSIX_Init( void *argument )
puts( "Init: pthread_create - SUCCESSFUL" );
+ pthread_setschedprio( pthread_self(), SS_PRIO_LOW );
/* Align with clock tick */
sleep( 1 );
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index f5aacb42d8..0022e81b5f 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -55,25 +55,11 @@ static test_context test_instance;
static void *thread_b(void *arg)
test_context *ctx;
- rtems_id scheduler_b_id;
- rtems_status_code sc;
- rtems_task_priority prio;
int prio_ceiling;
int eno;
ctx = arg;
- rtems_test_assert(rtems_scheduler_get_processor() == 0);
- sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- sc = rtems_task_set_priority(pthread_self(), RTEMS_CURRENT_PRIORITY, &prio);
- sc = rtems_task_set_scheduler(pthread_self(), scheduler_b_id, prio);
rtems_test_assert(rtems_scheduler_get_processor() == 1);
eno = pthread_mutex_init(&ctx->mtx_b, &ctx->mtx_attr);
@@ -132,8 +118,24 @@ static void test(test_context *ctx)
rtems_test_assert(eno == 0);
if (cpu_count > 1) {
+ rtems_id scheduler_a_id;
+ rtems_id scheduler_b_id;
+ rtems_status_code sc;
+ rtems_task_priority prio;
void *exit_code;
+ sc = rtems_scheduler_ident(SCHED_A, &scheduler_a_id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
+ sc = rtems_task_set_priority(pthread_self(), RTEMS_CURRENT_PRIORITY, &prio);
+ sc = rtems_task_set_scheduler(pthread_self(), scheduler_b_id, prio);
eno = pthread_create(&ctx->thread_b, NULL, thread_b, ctx);
@@ -141,6 +143,9 @@ static void test(test_context *ctx)
eno = pthread_join(ctx->thread_b, &exit_code);
rtems_test_assert(exit_code == ctx);
+ sc = rtems_task_set_scheduler(pthread_self(), scheduler_a_id, prio);
eno = pthread_mutex_destroy(&ctx->mtx_a);
diff --git a/testsuites/validation/tc-task-delete.c b/testsuites/validation/tc-task-delete.c
index a12a060852..a9340b4f20 100644
--- a/testsuites/validation/tc-task-delete.c
+++ b/testsuites/validation/tc-task-delete.c
@@ -94,8 +94,8 @@ typedef enum {
} RtemsTaskReqDelete_Pre_ThreadDispatch;
typedef enum {
- RtemsTaskReqDelete_Pre_CallerPriority_Higher,
- RtemsTaskReqDelete_Pre_CallerPriority_LowerEqual,
+ RtemsTaskReqDelete_Pre_CallerPriority_Vital,
+ RtemsTaskReqDelete_Pre_CallerPriority_Dispensable,
RtemsTaskReqDelete_Pre_CallerPriority_NA
} RtemsTaskReqDelete_Pre_CallerPriority;
@@ -163,10 +163,10 @@ typedef enum {
} RtemsTaskReqDelete_Post_Zombie;
typedef enum {
- RtemsTaskReqDelete_Post_RealPriority_Raised,
- RtemsTaskReqDelete_Post_RealPriority_Nop,
- RtemsTaskReqDelete_Post_RealPriority_NA
-} RtemsTaskReqDelete_Post_RealPriority;
+ RtemsTaskReqDelete_Post_TaskPriority_Raise,
+ RtemsTaskReqDelete_Post_TaskPriority_Nop,
+ RtemsTaskReqDelete_Post_TaskPriority_NA
+} RtemsTaskReqDelete_Post_TaskPriority;
typedef enum {
RtemsTaskReqDelete_Post_RestartExtensions_Nop,
@@ -238,7 +238,7 @@ typedef struct {
uint64_t Post_Status : 3;
uint64_t Post_FatalError : 2;
uint64_t Post_Zombie : 2;
- uint64_t Post_RealPriority : 2;
+ uint64_t Post_TaskPriority : 2;
uint64_t Post_RestartExtensions : 1;
uint64_t Post_TerminateExtensions : 2;
uint64_t Post_Dormant : 2;
@@ -431,10 +431,10 @@ typedef struct {
bool timer_active;
- * @brief If this member is true, then the deleter shall have a higher
- * current priority than the real priority of the worker.
+ * @brief If this member is true, then the deleter shall have a vital
+ * priority for the worker.
- bool deleter_has_higher_priority;
+ bool vital_deleter_priority;
* @brief If this member is true, then thread dispatching is disabled by the
@@ -516,8 +516,8 @@ static const char * const RtemsTaskReqDelete_PreDesc_ThreadDispatch[] = {
static const char * const RtemsTaskReqDelete_PreDesc_CallerPriority[] = {
- "Higher",
- "LowerEqual",
+ "Vital",
+ "Dispensable",
"NA"
@@ -594,7 +594,7 @@ static void CaptureWorkerState( Context *ctx )
ctx->worker_state = ctx->worker_tcb->current_state;
ctx->worker_life_state = ctx->worker_tcb->Life.state;
ctx->worker_priority =
- SCHEDULER_PRIORITY_UNMAP( ctx->worker_tcb->Real_priority.priority );
+ SCHEDULER_PRIORITY_UNMAP( _Thread_Get_priority( ctx->worker_tcb ) );
CopyExtensionCalls( &ctx->calls, &ctx->calls_after_restart );
GetTaskTimerInfoByThread( ctx->worker_tcb, &ctx->worker_timer_info );
@@ -833,7 +833,7 @@ static void SecondDeleter( rtems_task_argument arg )
ctx = (Context *) arg;
if ( ctx != NULL ) {
- if ( !ctx->deleter_has_higher_priority ) {
+ if ( !ctx->vital_deleter_priority ) {
SetPriority( ctx->runner_id, PRIO_LOW );
SetSelfPriorityNoYield( PRIO_NORMAL );
@@ -1038,23 +1038,21 @@ static void RtemsTaskReqDelete_Pre_CallerPriority_Prepare(
switch ( state ) {
- case RtemsTaskReqDelete_Pre_CallerPriority_Higher: {
+ case RtemsTaskReqDelete_Pre_CallerPriority_Vital: {
- * While the current priority of the task calling rtems_task_delete() is
- * higher than the real priority of the task specified by the ``id``
- * parameter.
+ * While at least one priority of the calling task is higher than the
+ * highest priority of the task specified by the ``id`` parameter.
- ctx->deleter_has_higher_priority = true;
+ ctx->vital_deleter_priority = true;
break;
- case RtemsTaskReqDelete_Pre_CallerPriority_LowerEqual: {
+ case RtemsTaskReqDelete_Pre_CallerPriority_Dispensable: {
- * lower than or equal to the real priority of the task specified by the
- * ``id`` parameter.
+ * While all priorities of the calling task are lower than or equal to
+ * the highest priority of the task specified by the ``id`` parameter.
- ctx->deleter_has_higher_priority = false;
+ ctx->vital_deleter_priority = false;
break;
@@ -1369,32 +1367,32 @@ static void RtemsTaskReqDelete_Post_Zombie_Check(
-static void RtemsTaskReqDelete_Post_RealPriority_Check(
+static void RtemsTaskReqDelete_Post_TaskPriority_Check(
RtemsTaskReqDelete_Context *ctx,
- RtemsTaskReqDelete_Post_RealPriority state
+ RtemsTaskReqDelete_Post_TaskPriority state
switch ( state ) {
- case RtemsTaskReqDelete_Post_RealPriority_Raised: {
+ case RtemsTaskReqDelete_Post_TaskPriority_Raise: {
- * The real priority of the task specified by the ``id`` parameter shall
- * be raised to the current priority of the caller of
- * rtems_task_delete().
+ * Each priority of the calling task which is higher than the highest
+ * priority of the task specified by the ``id`` parameter shall be made
+ * the highest priority of the task.
T_eq_u32( ctx->worker_priority, PRIO_ULTRA_HIGH );
break;
- case RtemsTaskReqDelete_Post_RealPriority_Nop: {
+ case RtemsTaskReqDelete_Post_TaskPriority_Nop: {
- * not be changed by the rtems_task_delete() call.
+ * The priorities of the task specified by the ``id`` parameter shall not
+ * be changed by the rtems_task_delete() call.
T_eq_u32( ctx->worker_priority, PRIO_NORMAL );
break;
- case RtemsTaskReqDelete_Post_RealPriority_NA:
+ case RtemsTaskReqDelete_Post_TaskPriority_NA:
break;
@@ -1786,7 +1784,7 @@ static const RtemsTaskReqDelete_Entry
RtemsTaskReqDelete_Entries[] = {
{ 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, RtemsTaskReqDelete_Post_Status_NA,
RtemsTaskReqDelete_Post_FatalError_NA, RtemsTaskReqDelete_Post_Zombie_NA,
- RtemsTaskReqDelete_Post_RealPriority_NA,
+ RtemsTaskReqDelete_Post_TaskPriority_NA,
RtemsTaskReqDelete_Post_RestartExtensions_NA,
RtemsTaskReqDelete_Post_TerminateExtensions_NA,
RtemsTaskReqDelete_Post_Dormant_NA, RtemsTaskReqDelete_Post_Suspended_NA,
@@ -1796,7 +1794,7 @@ RtemsTaskReqDelete_Entries[] = {
RtemsTaskReqDelete_Post_Timer_NA },
{ 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, RtemsTaskReqDelete_Post_Status_InvId,
RtemsTaskReqDelete_Post_FatalError_Nop, RtemsTaskReqDelete_Post_Zombie_NA,
RtemsTaskReqDelete_Post_TerminateExtensions_Nop,
@@ -1806,7 +1804,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1816,7 +1814,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1826,7 +1824,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1834,31 +1832,9 @@ RtemsTaskReqDelete_Entries[] = {
RtemsTaskReqDelete_Post_Terminating_NA,
RtemsTaskReqDelete_Post_Protected_NA, RtemsTaskReqDelete_Post_State_NA,
- { 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1,
- RtemsTaskReqDelete_Post_Status_NoReturn,
- RtemsTaskReqDelete_Post_FatalError_Yes, RtemsTaskReqDelete_Post_Zombie_Yes,
- RtemsTaskReqDelete_Post_RestartExtensions_Nop,
- RtemsTaskReqDelete_Post_TerminateExtensions_Nop,
- RtemsTaskReqDelete_Post_Dormant_Yes, RtemsTaskReqDelete_Post_Suspended_Yes,
- RtemsTaskReqDelete_Post_Restarting_No,
- RtemsTaskReqDelete_Post_Terminating_Yes,
- RtemsTaskReqDelete_Post_Protected_No, RtemsTaskReqDelete_Post_State_Ready,
- RtemsTaskReqDelete_Post_Timer_Inactive },
- RtemsTaskReqDelete_Post_Dormant_Yes, RtemsTaskReqDelete_Post_Suspended_No,
{ 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, RtemsTaskReqDelete_Post_Status_Ok,
RtemsTaskReqDelete_Post_FatalError_Nop, RtemsTaskReqDelete_Post_Zombie_Yes,
@@ -1868,7 +1844,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1879,7 +1855,7 @@ RtemsTaskReqDelete_Entries[] = {
RtemsTaskReqDelete_Post_Status_CalledFromISR,
RtemsTaskReqDelete_Post_FatalError_Nop, RtemsTaskReqDelete_Post_Zombie_No,
@@ -1890,7 +1866,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1901,7 +1877,7 @@ RtemsTaskReqDelete_Entries[] = {
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
RtemsTaskReqDelete_Post_FatalError_Yes, RtemsTaskReqDelete_Post_Zombie_No,
RtemsTaskReqDelete_Post_Dormant_No, RtemsTaskReqDelete_Post_Suspended_No,
@@ -1912,7 +1888,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1923,7 +1899,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1934,7 +1910,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1944,7 +1920,7 @@ RtemsTaskReqDelete_Entries[] = {
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, RtemsTaskReqDelete_Post_Status_Ok,
@@ -1954,7 +1930,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1964,7 +1940,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1974,7 +1950,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -1985,7 +1961,7 @@ RtemsTaskReqDelete_Entries[] = {
{ 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0,
RtemsTaskReqDelete_Post_TerminateExtensions_Yes,
@@ -1996,7 +1972,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2007,7 +1983,7 @@ RtemsTaskReqDelete_Entries[] = {
RtemsTaskReqDelete_Post_Dormant_No, RtemsTaskReqDelete_Post_Suspended_Yes,
@@ -2018,7 +1994,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2029,7 +2005,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2040,7 +2016,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2051,7 +2027,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2062,7 +2038,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2073,7 +2049,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2084,7 +2060,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2095,7 +2071,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2106,7 +2082,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2117,7 +2093,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2128,7 +2104,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2139,7 +2115,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2151,7 +2127,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2163,7 +2139,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2174,7 +2150,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2186,7 +2162,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2197,7 +2173,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2209,7 +2185,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2221,7 +2197,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2232,7 +2208,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2244,7 +2220,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2255,7 +2231,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2267,7 +2243,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2279,7 +2255,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2290,7 +2266,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2302,7 +2278,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2313,7 +2289,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2325,7 +2301,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2337,7 +2313,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2348,7 +2324,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2360,7 +2336,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2370,7 +2346,7 @@ RtemsTaskReqDelete_Entries[] = {
RtemsTaskReqDelete_Post_State_Blocked, RtemsTaskReqDelete_Post_Timer_Active },
@@ -2381,7 +2357,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2392,7 +2368,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2402,7 +2378,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2413,7 +2389,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2423,7 +2399,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2434,7 +2410,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2445,7 +2421,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2455,7 +2431,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2466,7 +2442,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2476,7 +2452,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2487,7 +2463,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2498,7 +2474,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2508,7 +2484,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2519,7 +2495,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2529,7 +2505,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2540,7 +2516,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2551,7 +2527,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2561,7 +2537,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2572,7 +2548,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2583,7 +2559,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2595,7 +2571,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2607,7 +2583,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2618,7 +2594,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2630,7 +2606,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2641,7 +2617,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2653,7 +2629,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2665,7 +2641,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2676,7 +2652,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2688,7 +2664,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2699,7 +2675,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2711,7 +2687,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2723,7 +2699,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2734,7 +2710,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2746,7 +2722,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2757,7 +2733,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2769,7 +2745,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2781,7 +2757,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2792,7 +2768,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2804,7 +2780,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2815,7 +2791,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2827,7 +2803,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2839,7 +2815,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2850,7 +2826,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2862,7 +2838,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2873,7 +2849,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2885,7 +2861,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2897,7 +2873,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2908,7 +2884,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2920,7 +2896,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2931,7 +2907,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2943,7 +2919,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2955,7 +2931,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2966,7 +2942,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2978,7 +2954,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -2989,7 +2965,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3001,7 +2977,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3013,7 +2989,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3024,7 +3000,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3036,7 +3012,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3047,7 +3023,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3059,7 +3035,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3071,7 +3047,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3082,7 +3058,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3094,7 +3070,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3105,7 +3081,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3117,7 +3093,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3129,7 +3105,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3140,7 +3116,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3152,7 +3128,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3163,7 +3139,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3175,7 +3151,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3187,7 +3163,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3198,7 +3174,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3210,7 +3186,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3221,7 +3197,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3233,7 +3209,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3245,7 +3221,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3256,7 +3232,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3268,7 +3244,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3279,7 +3255,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3291,7 +3267,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3303,7 +3279,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3314,7 +3290,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3326,7 +3302,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3337,7 +3313,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3349,7 +3325,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3361,7 +3337,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3372,7 +3348,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3384,7 +3360,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3395,7 +3371,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3407,7 +3383,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3419,7 +3395,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3430,7 +3406,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3442,7 +3418,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3453,7 +3429,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3465,7 +3441,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3477,7 +3453,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3488,7 +3464,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3500,7 +3476,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3511,7 +3487,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3523,7 +3499,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3535,7 +3511,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3546,7 +3522,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3558,7 +3534,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3569,7 +3545,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3581,7 +3557,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3593,7 +3569,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3604,7 +3580,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3616,7 +3592,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3627,7 +3603,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3639,7 +3615,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3651,7 +3627,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3662,7 +3638,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3674,7 +3650,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3685,7 +3661,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3697,7 +3673,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3709,7 +3685,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3720,7 +3696,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3732,7 +3708,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3743,7 +3719,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3755,7 +3731,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3767,7 +3743,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3778,7 +3754,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3790,7 +3766,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3801,7 +3777,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3813,7 +3789,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3825,7 +3801,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3836,7 +3812,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3848,7 +3824,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3859,7 +3835,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3871,7 +3847,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3883,7 +3859,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3894,7 +3870,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3906,7 +3882,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3917,7 +3893,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3929,7 +3905,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3941,7 +3917,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3952,7 +3928,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3964,7 +3940,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3975,7 +3951,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3987,7 +3963,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -3999,7 +3975,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4010,7 +3986,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4022,7 +3998,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4033,7 +4009,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4045,7 +4021,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4057,7 +4033,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4068,7 +4044,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4080,7 +4056,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4091,7 +4067,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4103,7 +4079,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4115,7 +4091,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4126,7 +4102,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4138,7 +4114,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4149,7 +4125,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4161,7 +4137,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4173,7 +4149,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4184,7 +4160,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4196,7 +4172,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4207,7 +4183,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4219,7 +4195,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4231,7 +4207,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4242,7 +4218,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4254,7 +4230,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4265,7 +4241,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4277,7 +4253,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4289,7 +4265,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4300,7 +4276,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4312,7 +4288,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4323,7 +4299,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4335,7 +4311,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4347,7 +4323,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4358,7 +4334,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4370,7 +4346,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4381,7 +4357,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4393,7 +4369,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4405,7 +4381,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4416,7 +4392,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4428,7 +4404,7 @@ RtemsTaskReqDelete_Entries[] = {
@@ -4440,52 +4416,52 @@ RtemsTaskReqDelete_Entries[] = {
static const uint8_t
RtemsTaskReqDelete_Map[] = {
+ 3, 3, 19, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 20, 4, 3, 3,
3, 3, 21, 4, 3, 3, 3, 3, 22, 4, 3, 3, 3, 3, 21, 4, 3, 3, 3, 3, 22, 4, 3, 3,
3, 3, 23, 4, 3, 3, 3, 3, 24, 4, 3, 3, 3, 3, 23, 4, 3, 3, 3, 3, 24, 4, 3, 3,
3, 3, 25, 4, 3, 3, 3, 3, 26, 4, 3, 3, 3, 3, 25, 4, 3, 3, 3, 3, 26, 4, 3, 3,
- 3, 3, 27, 4, 3, 3, 3, 3, 28, 4, 3, 3, 3, 3, 27, 4, 3, 3, 3, 3, 28, 4, 3, 3,
2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
- 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 21, 4, 3, 3, 3,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 19, 4, 3, 3, 3,
+ 3, 20, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 21, 4, 3, 3, 3,
3, 22, 4, 3, 3, 3, 3, 21, 4, 3, 3, 3, 3, 22, 4, 3, 3, 3, 3, 23, 4, 3, 3, 3,
3, 24, 4, 3, 3, 3, 3, 23, 4, 3, 3, 3, 3, 24, 4, 3, 3, 3, 3, 25, 4, 3, 3, 3,
- 3, 26, 4, 3, 3, 3, 3, 25, 4, 3, 3, 3, 3, 26, 4, 3, 3, 3, 3, 27, 4, 3, 3, 3,
- 3, 28, 4, 3, 3, 3, 3, 27, 4, 3, 3, 3, 3, 28, 4, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2,
+ 3, 26, 4, 3, 3, 3, 3, 25, 4, 3, 3, 3, 3, 26, 4, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2,
- 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 29,
- 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 31, 4, 3, 3, 3, 3, 32, 4, 3, 3, 3, 3, 31,
- 4, 3, 3, 3, 3, 32, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 19,
- 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 20,
- 4, 3, 3, 3, 3, 20, 4, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 27, 4, 3, 3, 3, 3, 28, 4, 3, 3, 3, 3, 27,
+ 4, 3, 3, 3, 3, 28, 4, 3, 3, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 29,
+ 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 17,
+ 4, 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 18, 4, 3, 3, 3, 3, 18, 4, 3, 3, 3, 3, 18,
+ 4, 3, 3, 3, 3, 18, 4, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
- 2, 2, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4,
- 3, 3, 3, 3, 31, 4, 3, 3, 3, 3, 32, 4, 3, 3, 3, 3, 31, 4, 3, 3, 3, 3, 32, 4,
- 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 19, 4, 3, 3, 3, 3, 19, 4,
- 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 20, 4, 3, 3, 3, 3, 20, 4,
+ 2, 2, 3, 3, 27, 4, 3, 3, 3, 3, 28, 4, 3, 3, 3, 3, 27, 4, 3, 3, 3, 3, 28, 4,
+ 3, 3, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4, 3, 3, 3, 3, 29, 4, 3, 3, 3, 3, 30, 4,
+ 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 17, 4, 3, 3, 3, 3, 17, 4,
+ 3, 3, 3, 3, 18, 4, 3, 3, 3, 3, 18, 4, 3, 3, 3, 3, 18, 4, 3, 3, 3, 3, 18, 4,
3, 3, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
- 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 73, 74, 75, 4,
- 76, 77, 78, 79, 80, 4, 81, 82, 83, 84, 85, 4, 86, 87, 88, 89, 90, 4, 91, 92,
- 93, 94, 95, 4, 96, 97, 98, 99, 100, 4, 101, 102, 103, 104, 105, 4, 106, 107,
- 108, 109, 110, 4, 111, 112, 113, 114, 115, 4, 116, 117, 118, 119, 120, 4,
- 121, 122, 123, 124, 125, 4, 126, 127, 128, 129, 130, 4, 131, 132, 133, 134,
- 135, 4, 136, 137, 138, 139, 140, 4, 141, 142, 143, 144, 145, 4, 146, 147,
- 148, 149, 150, 4, 151, 152, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 71, 72, 73, 4,
+ 74, 75, 76, 77, 78, 4, 79, 80, 81, 82, 83, 4, 84, 85, 86, 87, 88, 4, 89, 90,
+ 91, 92, 93, 4, 94, 95, 96, 97, 98, 4, 99, 100, 101, 102, 103, 4, 104, 105,
+ 106, 107, 108, 4, 109, 110, 111, 112, 113, 4, 114, 115, 116, 117, 118, 4,
+ 119, 120, 121, 122, 123, 4, 124, 125, 126, 127, 128, 4, 129, 130, 131, 132,
+ 133, 4, 134, 135, 136, 137, 138, 4, 139, 140, 141, 142, 143, 4, 144, 145,
+ 146, 147, 148, 4, 149, 150, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
- 2, 2, 73, 74, 75, 4, 76, 77, 78, 79, 80, 4, 81, 82, 83, 84, 85, 4, 86, 87,
- 88, 89, 90, 4, 91, 92, 93, 94, 95, 4, 96, 97, 98, 99, 100, 4, 101, 102, 103,
- 104, 105, 4, 106, 107, 108, 109, 110, 4, 111, 112, 113, 114, 115, 4, 116,
- 117, 118, 119, 120, 4, 121, 122, 123, 124, 125, 4, 126, 127, 128, 129, 130,
- 4, 131, 132, 133, 134, 135, 4, 136, 137, 138, 139, 140, 4, 141, 142, 143,
- 144, 145, 4, 146, 147, 148, 149, 150, 4, 151, 152, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+ 2, 2, 71, 72, 73, 4, 74, 75, 76, 77, 78, 4, 79, 80, 81, 82, 83, 4, 84, 85,
+ 86, 87, 88, 4, 89, 90, 91, 92, 93, 4, 94, 95, 96, 97, 98, 4, 99, 100, 101,
+ 102, 103, 4, 104, 105, 106, 107, 108, 4, 109, 110, 111, 112, 113, 4, 114,
+ 115, 116, 117, 118, 4, 119, 120, 121, 122, 123, 4, 124, 125, 126, 127, 128,
+ 4, 129, 130, 131, 132, 133, 4, 134, 135, 136, 137, 138, 4, 139, 140, 141,
+ 142, 143, 4, 144, 145, 146, 147, 148, 4, 149, 150, 2, 2, 2, 2, 2, 2, 2, 2, 2,
@@ -4504,61 +4480,60 @@ RtemsTaskReqDelete_Map[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- 0, 0, 0, 33, 34, 35, 4, 36, 37, 11, 11, 11, 4, 11, 11, 33, 34, 35, 4, 36, 37,
- 11, 11, 11, 4, 11, 11, 38, 39, 40, 4, 41, 42, 12, 12, 12, 4, 12, 12, 38, 39,
- 40, 4, 41, 42, 12, 12, 12, 4, 12, 12, 33, 34, 35, 4, 36, 37, 11, 11, 11, 4,
- 11, 11, 33, 34, 35, 4, 36, 37, 11, 11, 11, 4, 11, 11, 38, 39, 40, 4, 41, 42,
- 12, 12, 12, 4, 12, 12, 38, 39, 40, 4, 41, 42, 12, 12, 12, 4, 12, 12, 5, 5, 5,
+ 0, 0, 0, 31, 32, 33, 4, 34, 35, 9, 9, 9, 4, 9, 9, 31, 32, 33, 4, 34, 35, 9,
+ 9, 9, 4, 9, 9, 36, 37, 38, 4, 39, 40, 10, 10, 10, 4, 10, 10, 36, 37, 38, 4,
+ 39, 40, 10, 10, 10, 4, 10, 10, 31, 32, 33, 4, 34, 35, 9, 9, 9, 4, 9, 9, 31,
+ 32, 33, 4, 34, 35, 9, 9, 9, 4, 9, 9, 36, 37, 38, 4, 39, 40, 10, 10, 10, 4,
+ 10, 10, 36, 37, 38, 4, 39, 40, 10, 10, 10, 4, 10, 10, 5, 5, 5, 5, 5, 5, 5, 5,
5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
- 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6,
+ 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6,
6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6,
- 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 43, 44, 45, 4, 46, 47, 13, 13,
- 13, 4, 13, 13, 43, 44, 45, 4, 46, 47, 13, 13, 13, 4, 13, 13, 48, 49, 50, 4,
- 51, 52, 14, 14, 14, 4, 14, 14, 48, 49, 50, 4, 51, 52, 14, 14, 14, 4, 14, 14,
- 43, 44, 45, 4, 46, 47, 13, 13, 13, 4, 13, 13, 43, 44, 45, 4, 46, 47, 13, 13,
- 13, 4, 13, 13, 48, 49, 50, 4, 51, 52, 14, 14, 14, 4, 14, 14, 48, 49, 50, 4,
- 51, 52, 14, 14, 14, 4, 14, 14, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 41, 42, 43, 4, 44, 45, 11, 11, 11, 4, 11, 11,
+ 41, 42, 43, 4, 44, 45, 11, 11, 11, 4, 11, 11, 46, 47, 48, 4, 49, 50, 12, 12,
+ 12, 4, 12, 12, 46, 47, 48, 4, 49, 50, 12, 12, 12, 4, 12, 12, 41, 42, 43, 4,
+ 44, 45, 11, 11, 11, 4, 11, 11, 41, 42, 43, 4, 44, 45, 11, 11, 11, 4, 11, 11,
+ 46, 47, 48, 4, 49, 50, 12, 12, 12, 4, 12, 12, 46, 47, 48, 4, 49, 50, 12, 12,
+ 12, 4, 12, 12, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 5, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 51, 52,
+ 53, 4, 54, 55, 13, 13, 13, 4, 13, 13, 51, 52, 53, 4, 54, 55, 13, 13, 13, 4,
+ 13, 13, 56, 57, 58, 4, 59, 60, 14, 14, 14, 4, 14, 14, 56, 57, 58, 4, 59, 60,
+ 14, 14, 14, 4, 14, 14, 51, 52, 53, 4, 54, 55, 13, 13, 13, 4, 13, 13, 51, 52,
+ 53, 4, 54, 55, 13, 13, 13, 4, 13, 13, 56, 57, 58, 4, 59, 60, 14, 14, 14, 4,
+ 14, 14, 56, 57, 58, 4, 59, 60, 14, 14, 14, 4, 14, 14, 5, 5, 5, 5, 5, 5, 5, 5,
- 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6,
- 6, 6, 6, 53, 54, 55, 4, 56, 57, 15, 15, 15, 4, 15, 15, 53, 54, 55, 4, 56, 57,
- 15, 15, 15, 4, 15, 15, 58, 59, 60, 4, 61, 62, 16, 16, 16, 4, 16, 16, 58, 59,
- 60, 4, 61, 62, 16, 16, 16, 4, 16, 16, 53, 54, 55, 4, 56, 57, 15, 15, 15, 4,
- 15, 15, 53, 54, 55, 4, 56, 57, 15, 15, 15, 4, 15, 15, 58, 59, 60, 4, 61, 62,
- 16, 16, 16, 4, 16, 16, 58, 59, 60, 4, 61, 62, 16, 16, 16, 4, 16, 16, 7, 7, 7,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 61, 62, 63, 4, 64, 65, 15, 15, 15, 4, 15, 15,
+ 61, 62, 63, 4, 64, 65, 15, 15, 15, 4, 15, 15, 66, 67, 68, 4, 69, 70, 16, 16,
+ 16, 4, 16, 16, 66, 67, 68, 4, 69, 70, 16, 16, 16, 4, 16, 16, 61, 62, 63, 4,
+ 64, 65, 15, 15, 15, 4, 15, 15, 61, 62, 63, 4, 64, 65, 15, 15, 15, 4, 15, 15,
+ 66, 67, 68, 4, 69, 70, 16, 16, 16, 4, 16, 16, 66, 67, 68, 4, 69, 70, 16, 16,
+ 16, 4, 16, 16, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5,
+ 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 151,
+ 152, 153, 4, 154, 155, 156, 157, 158, 4, 159, 160, 161, 162, 163, 4, 164,
+ 165, 166, 167, 168, 4, 169, 170, 171, 172, 173, 4, 174, 175, 176, 177, 178,
+ 4, 179, 180, 181, 182, 183, 4, 184, 185, 186, 187, 188, 4, 189, 190, 191,
+ 192, 193, 4, 194, 195, 196, 197, 198, 4, 199, 200, 201, 202, 203, 4, 204,
+ 205, 206, 207, 208, 4, 209, 210, 211, 212, 213, 4, 214, 215, 216, 217, 218,
+ 4, 219, 220, 221, 222, 223, 4, 224, 225, 226, 227, 228, 4, 229, 230, 7, 7, 7,
7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7,
7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8,
8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
- 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 63, 64, 65, 4, 66, 67, 17, 17,
- 17, 4, 17, 17, 63, 64, 65, 4, 66, 67, 17, 17, 17, 4, 17, 17, 68, 69, 70, 4,
- 71, 72, 18, 18, 18, 4, 18, 18, 68, 69, 70, 4, 71, 72, 18, 18, 18, 4, 18, 18,
- 63, 64, 65, 4, 66, 67, 17, 17, 17, 4, 17, 17, 63, 64, 65, 4, 66, 67, 17, 17,
- 17, 4, 17, 17, 68, 69, 70, 4, 71, 72, 18, 18, 18, 4, 18, 18, 68, 69, 70, 4,
- 71, 72, 18, 18, 18, 4, 18, 18, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7,
+ 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 151, 152, 153, 4, 154, 155, 156,
+ 157, 158, 4, 159, 160, 161, 162, 163, 4, 164, 165, 166, 167, 168, 4, 169,
+ 170, 171, 172, 173, 4, 174, 175, 176, 177, 178, 4, 179, 180, 181, 182, 183,
+ 4, 184, 185, 186, 187, 188, 4, 189, 190, 191, 192, 193, 4, 194, 195, 196,
+ 197, 198, 4, 199, 200, 201, 202, 203, 4, 204, 205, 206, 207, 208, 4, 209,
+ 210, 211, 212, 213, 4, 214, 215, 216, 217, 218, 4, 219, 220, 221, 222, 223,
+ 4, 224, 225, 226, 227, 228, 4, 229, 230, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 7,
- 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
+ 7, 7, 7, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
- 8, 8, 8, 153, 154, 155, 4, 156, 157, 158, 159, 160, 4, 161, 162, 163, 164,
- 165, 4, 166, 167, 168, 169, 170, 4, 171, 172, 173, 174, 175, 4, 176, 177,
- 178, 179, 180, 4, 181, 182, 183, 184, 185, 4, 186, 187, 188, 189, 190, 4,
- 191, 192, 193, 194, 195, 4, 196, 197, 198, 199, 200, 4, 201, 202, 203, 204,
- 205, 4, 206, 207, 208, 209, 210, 4, 211, 212, 213, 214, 215, 4, 216, 217,
- 218, 219, 220, 4, 221, 222, 223, 224, 225, 4, 226, 227, 228, 229, 230, 4,
- 231, 232, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9,
- 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9,
- 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10,
- 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 153, 154, 155, 4, 156, 157, 158, 159,
- 160, 4, 161, 162, 163, 164, 165, 4, 166, 167, 168, 169, 170, 4, 171, 172,
- 173, 174, 175, 4, 176, 177, 178, 179, 180, 4, 181, 182, 183, 184, 185, 4,
- 186, 187, 188, 189, 190, 4, 191, 192, 193, 194, 195, 4, 196, 197, 198, 199,
- 200, 4, 201, 202, 203, 204, 205, 4, 206, 207, 208, 209, 210, 4, 211, 212,
- 213, 214, 215, 4, 216, 217, 218, 219, 220, 4, 221, 222, 223, 224, 225, 4,
- 226, 227, 228, 229, 230, 4, 231, 232, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9,
- 9, 9, 9, 9, 9, 9, 9, 9, 9, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10,
- 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 10, 0, 0, 0,
+ 8, 8, 8, 8, 8, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
@@ -4573,7 +4548,6 @@ RtemsTaskReqDelete_Map[] = {
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
@@ -4617,7 +4591,8 @@ RtemsTaskReqDelete_Map[] = {
- 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0,
+ 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
+ 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
@@ -4632,7 +4607,7 @@ RtemsTaskReqDelete_Map[] = {
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
+ 0, 0
static size_t RtemsTaskReqDelete_Scope( void *arg, char *buf, size_t n )
@@ -4746,9 +4721,9 @@ static void RtemsTaskReqDelete_TestVariant( RtemsTaskReqDelete_Context *ctx )
ctx->Map.entry.Post_FatalError
RtemsTaskReqDelete_Post_Zombie_Check( ctx, ctx->Map.entry.Post_Zombie );
- RtemsTaskReqDelete_Post_RealPriority_Check(
+ RtemsTaskReqDelete_Post_TaskPriority_Check(
ctx,
- ctx->Map.entry.Post_RealPriority
+ ctx->Map.entry.Post_TaskPriority
RtemsTaskReqDelete_Post_RestartExtensions_Check(
ctx,
@@ -4806,7 +4781,7 @@ T_TEST_CASE_FIXTURE( RtemsTaskReqDelete, &RtemsTaskReqDelete_Fixture )
++ctx->Map.pci[ 2 ]
for (
- ctx->Map.pci[ 3 ] = RtemsTaskReqDelete_Pre_CallerPriority_Higher;
+ ctx->Map.pci[ 3 ] = RtemsTaskReqDelete_Pre_CallerPriority_Vital;
ctx->Map.pci[ 3 ] < RtemsTaskReqDelete_Pre_CallerPriority_NA;
++ctx->Map.pci[ 3 ]
diff --git a/testsuites/validation/tc-task-exit.c b/testsuites/validation/tc-task-exit.c
index 6ceaa06bd8..2f2733fe90 100644
--- a/testsuites/validation/tc-task-exit.c
+++ b/testsuites/validation/tc-task-exit.c
@@ -55,6 +55,7 @@
#include <rtems/test-scheduler.h>
#include <rtems/score/apimutex.h>
+#include <rtems/score/statesimpl.h>
#include "tx-support.h"
@@ -116,10 +117,10 @@ typedef enum {
} RtemsTaskReqExit_Post_TerminateExtensions;
typedef enum {
- RtemsTaskReqExit_Post_Block_Yes,
- RtemsTaskReqExit_Post_Block_Nop,
- RtemsTaskReqExit_Post_Block_NA
-} RtemsTaskReqExit_Post_Block;
+ RtemsTaskReqExit_Post_Zombie_Yes,
+ RtemsTaskReqExit_Post_Zombie_No,
+ RtemsTaskReqExit_Post_Zombie_NA
+} RtemsTaskReqExit_Post_Zombie;
typedef enum {
RtemsTaskReqExit_Post_ID_Valid,
@@ -143,7 +144,7 @@ typedef struct {
uint32_t Post_DeleteExtensions : 1;
uint32_t Post_RestartExtensions : 1;
uint32_t Post_TerminateExtensions : 2;
- uint32_t Post_Block : 2;
+ uint32_t Post_Zombie : 2;
uint32_t Post_ID : 2;
uint32_t Post_Delete : 2;
} RtemsTaskReqExit_Entry;
@@ -644,9 +645,9 @@ static void RtemsTaskReqExit_Post_TerminateExtensions_Check(
-static void RtemsTaskReqExit_Post_Block_Check(
- RtemsTaskReqExit_Context *ctx,
- RtemsTaskReqExit_Post_Block state
+static void RtemsTaskReqExit_Post_Zombie_Check(
+ RtemsTaskReqExit_Context *ctx,
+ RtemsTaskReqExit_Post_Zombie state
const T_scheduler_event *event;
@@ -655,20 +656,28 @@ static void RtemsTaskReqExit_Post_Block_Check(
index = 0;
switch ( state ) {
- case RtemsTaskReqExit_Post_Block_Yes: {
+ case RtemsTaskReqExit_Post_Zombie_Yes: {
- * The calling task shall be blocked exactly once by the
- * rtems_task_exit() call.
+ * The thread state of the calling task shall be set to the zombie state
+ * by the rtems_task_exit() call.
event = T_scheduler_next_any( &ctx->scheduler_log.header, &index );
T_eq_int( event->operation, T_SCHEDULER_BLOCK );
T_eq_u32( event->thread->Object.id, ctx->worker_id );
+ T_eq_u32( event->thread->current_state, STATES_ZOMBIE );
if ( ctx->terminating ) {
+ /* The thread waiting for the worker exit was unblocked */
T_eq_int( event->operation, T_SCHEDULER_UNBLOCK );
T_eq_u32( event->thread->Object.id, ctx->deleter_id );
+ /* Inherited priority was removed */
+ event = T_scheduler_next_any( &ctx->scheduler_log.header, &index );
+ T_eq_int( event->operation, T_SCHEDULER_UPDATE_PRIORITY );
+ T_eq_u32( event->thread->Object.id, ctx->worker_id );
+ /* The deleter task suspended itself */
@@ -679,15 +688,16 @@ static void RtemsTaskReqExit_Post_Block_Check(
break;
- case RtemsTaskReqExit_Post_Block_Nop: {
+ case RtemsTaskReqExit_Post_Zombie_No: {
- * No task shall be blocked by the rtems_task_exit() call.
+ * The thread state of the calling task shall be not modified by the
+ * rtems_task_exit() call.
T_eq_sz( ctx->scheduler_log.header.recorded, 0 );
break;
- case RtemsTaskReqExit_Post_Block_NA:
+ case RtemsTaskReqExit_Post_Zombie_NA:
break;
@@ -859,13 +869,13 @@ RtemsTaskReqExit_Entries[] = {
RtemsTaskReqExit_Post_DeleteExtensions_Nop,
RtemsTaskReqExit_Post_RestartExtensions_Nop,
RtemsTaskReqExit_Post_TerminateExtensions_Yes,
- RtemsTaskReqExit_Post_Block_Yes, RtemsTaskReqExit_Post_ID_Invalid,
+ RtemsTaskReqExit_Post_Zombie_Yes, RtemsTaskReqExit_Post_ID_Invalid,
RtemsTaskReqExit_Post_Delete_NextAllocate },
{ 0, 0, 0, 0, 0, RtemsTaskReqExit_Post_FatalError_Yes,
RtemsTaskReqExit_Post_TerminateExtensions_Nop,
- RtemsTaskReqExit_Post_Block_Nop, RtemsTaskReqExit_Post_ID_Valid,
+ RtemsTaskReqExit_Post_Zombie_No, RtemsTaskReqExit_Post_ID_Valid,
RtemsTaskReqExit_Post_Delete_Nop }
@@ -931,7 +941,7 @@ static void RtemsTaskReqExit_TestVariant( RtemsTaskReqExit_Context *ctx )
ctx,
ctx->Map.entry.Post_TerminateExtensions
- RtemsTaskReqExit_Post_Block_Check( ctx, ctx->Map.entry.Post_Block );
+ RtemsTaskReqExit_Post_Zombie_Check( ctx, ctx->Map.entry.Post_Zombie );
RtemsTaskReqExit_Post_ID_Check( ctx, ctx->Map.entry.Post_ID );
RtemsTaskReqExit_Post_Delete_Check( ctx, ctx->Map.entry.Post_Delete );
diff --git a/testsuites/validation/tc-task-restart.c b/testsuites/validation/tc-task-restart.c
index 1c7528e961..f6c3aabd33 100644
--- a/testsuites/validation/tc-task-restart.c
+++ b/testsuites/validation/tc-task-restart.c
@@ -1424,7 +1424,7 @@ static void RtemsTaskReqRestart_Post_State_Check(
T_eq_ptr( event->thread, ctx->worker_tcb );
- if ( !ctx->real_priority_is_initial ) {
+ if ( !ctx->real_priority_is_initial && !ctx->terminating ) {
@@ -1464,7 +1464,7 @@ static void RtemsTaskReqRestart_Post_State_Check(
@@ -1504,7 +1504,7 @@ static void RtemsTaskReqRestart_Post_State_Check(
2.35.3
