Possible tls bug on arm / microblaze
Sam Price
thesamprice at gmail.com
Tue Jul 19 12:51:26 UTC 2022
On microblaze i was getting a
ESR: Unaligned data access exception
I narrowed this down to this "ti->offset;" being uninitialized in the
following two bsps
https://git.rtems.org/rtems/tree/cpukit/score/cpu/microblaze/__tls_get_addr.c
Also this file
cpukit/score/cpu/arm/__tls_get_addr.c
I tried recompiling with this on the microblaze build with offset being
renamed to offseta.
This only caused a compilation error in the __tls_get_addr function.
So I think this variable is being used without being initialized or ever
changed.
Is it safe to just remove the offset variable?
Thank you,
Sam Price
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220719/46e384a0/attachment.htm>
