Possible tls bug on arm / microblaze
Tue Jul 19 15:12:01 UTC 2022
On 19/07/2022 14:51, Sam Price wrote:
> On microblaze i was getting a
> ESR: Unaligned data access exception
> I narrowed this down to this "ti->offset;" being uninitialized in the
> following two bsps
> https://git.rtems.org/rtems/tree/cpukit/score/cpu/microblaze/__tls_get_addr.c
> <https://git.rtems.org/rtems/tree/cpukit/score/cpu/microblaze/__tls_get_addr.c>
> Also this file
> cpukit/score/cpu/arm/__tls_get_addr.c
> I tried recompiling with this on the microblaze build with offset being
> renamed to offseta.
> This only caused a compilation error in the __tls_get_addr function.
> So I think this variable is being used without being initialized or ever
> changed.
> Is it safe to just remove the offset variable?
No, it is not safe to remove the offset member. The offset member value
is provided by the caller of __tls_get_addr(). You have to check that
TLS_Index definition matches the GCC ABI. Do the sptls* tests run on
your system?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
