[PATCH] cpukit/dev/can: Added CAN support
Christian Mauderer oss at c-mauderer.de
Tue Jul 19 13:35:08 UTC 2022
Hello Prashanth,
Am 19.07.22 um 15:09 schrieb Prashanth S:
> Hi Christian,
> This is to reply to review comments.
>> first question: You also worked on a driver for beagle DCAN. Did you
>> already adapt that driver to this API? If yes, it would be usefull to
>> post that as a patch too so that the direction and the method how it
>> will be used is more clear.
> Yes, Waiting for License confirmation.
If you didn't have to agree to some really odd license, you can post it
as a patch on the list. Make sure to make it _very_ clear that you are
not sure about the license and for what reason. Things like licensing
should be discussed with the community in public so that the discussion
is archived together with the list.
>> Note that some of my comments might are a bit critical because you add a
>> general API. I would have a lot less problems if it would be only a
>> driver specific API. If you add a general API, it has to fit the needs
>> of not only your current driver but most future drivers too. Changing an
>> API later is allways tricky.
> Ok
>> Please make sure to stic to the RTEMS style and use a 80 character line
>> length.
> OK
>> You create a name with a "'0' + init++": Are you sure that a maximum of
>> 10 buffers are created? Otherwise you will get names like "can:", "can;"
>> and - sooner or later: "can\xFF", "can\x00", ...
> Assuming we have less than 10 CAN controllers, I will update this to
> limit to 10 queues.
>> In the header you somewhere had a "destroy" function. Do you need some
>> way to de-initialize buffers only used by that bus?
> Yes, the can_bus structure holds data related only to a specific bus.
In that case the static variable will make trouble. You have a static
counter. If I register the bus, deregister it and register it again, the
counter will have odd values.
>>> +rtems_status_code can_create_tx_buffers(struct can_bus *bus)
>>> +  if ((bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT * sizeof(struct can_msg))) == NULL) {
>> You seem to like writing a lot of code in one line. From my point of
>> view that makes code harder to read. If you write it into multiple lines
>> instead, someone else doesn't have to think that much about which
>> bracket closes where. For example in this case the following would be
>> simpler to read:
> I will make changes to limit line length to 80.
>> sizeof(struct can_msg));
>> if (bus->tx_fifo.pbuf == NULL) {
>> +    printf("malloc failed\n");
>> Prints are nice for debugging but can be really annoying in
>> applications. Think about some kind of "debug_print" or similar that you
>> can enable / disable with a macro at the start of the file. You can also
>> use that to add a prefix or function name to all prints. If you search a
>> problem, a line like "mallof failed" is meaningless if you are not
>> currently working on specially this code. A line like
>> "can_create_tx_buffers: malloc failed" is a lot more usefull. There are
>> preprocessor macros like __FUNCTION__ that you can use for something
>> like that.
> Ok, I will update the prints with the function name in it.
Better: Use some macro to automate that and enable or disable all debug
messages at once. Also it's not the nicest solution, it's not uncommon
to have something like that. Examples are:
cpukit/libdrvmgr/drvmgr.c:44:#define DBG(x...) printk(x)
cpukit/include/rtems/posix/aio_misc.h:116:#define AIO_printf(_x) printf(_x)
cpukit/libfs/src/ftpfs/ftpfs.c:61:  #define DEBUG_PRINTF(...)
printf(__VA_ARGS__)
bsps/mips/malta/pci/pci.c:49:  #define JPRINTK(fmt, ...) printk("%s: "
fmt, __FUNCTION__, ##__VA_ARGS__)
>> +    return RTEMS_NO_MEMORY;
>> +  bus->tx_fifo.head = bus->tx_fifo.tail = 0;
>> Same here: This is hard to read. I would suggest to split that into two
>> lines. Alternatively you might want to think about just using a memset
>> to have a clean start for a structure that you initialize.
> Ok, memset is done in the can_bus_init or calloc is used in
> can_bus_alloc_and_init.
> Removing bus->tx_fifo.head = bus->tx_fifo.tail = 0;
>> +  bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
>> +  return 0;
>> +bool can_tx_buf_isempty(struct can_bus *bus)
>> +  if (bus->tx_fifo.empty_count <= 0) {
>> +    /* tx_fifo.empty_count does not go below zero, incase if it goes update to zero */
>> +    bus->tx_fifo.empty_count = 0;
> empty_count is an unsigned type and therefore can never be smaller than
> 0. This line is not necessary at all.
> Ok, removing it.
>> +    return false;
>> +  return true;
>> +struct can_msg *can_tx_get_data_buf(struct can_bus *bus)
>> +  struct can_msg *msg = NULL;
>> +  if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
>> +    printf("can_tx_get_next_data_buf All buffers are empty\n");
>> +    return NULL;
>> +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
>> +  bus->tx_fifo.empty_count++;
>> +  bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
>> You want to return the pointer to the message (msg) to the caller,
>> right? In that case you must not marke it as empty here. Otherwise
>> someone else could already use that memory again while the application
>> is still processing it.
> Here the application does not use this (driver buffer) buffer, we copy
> the message from this buffer (driver buffer)
> to the application passed buffer.
You put a pointer to the tx_fifo into msg:
and then return that pointer to the application:
   return msg;
The function is not static so it's clearly not internal use only. Even
if it would be internal only, I would suggest to split it into a get
buffer and mark buffer empty after it has been copied. Otherwise you
have to be _really_ carefull that the framework can't overwrite the
buffer while it is still used.
>> Looks like a helper function that is only used in this file? Please make
>> it  static and remove it from the header. Same is true for "take_sem" and
>> similar below.
> Functions in can-queue.c are used in can.c, Moving them to can-queue.h
> or can.h header file.
> I will add static to take_sem and give_sem.
Is the part in can-queue intendet to be used by an application?
Otherwise you should not install the headers so that a user can't use them.
>> Is an interrupt lock really necessary? Wouldn't a mutex or similar work
>> too to protect the relevant data? An interrupt lock is something that
>> should be used really carefull. You tell the system: Stop everything
>> else. This here is the most important task.
>> That means that for example a time critical data acquisition process can
>> be delayed by the time that you need in your interrupt lock. You have to
>> be really sure that the interrupt is the only solution to solve the
>> problem before you use one.
> Yes, We need to disable interrupts as the tx and rx buffers are used in
> the tx and rx interrupts handlers.
> Or could disable only CAN interrupts, as CAN messages being a higher
> priority so I added a Global interrupt disable.
> Shall I disable it locally or globally?
You should allways disable as few as possible. So if you can only
disable can interrupts instead of all interrupts, you should do that.
Otherwise you make assumptions about a user system. In that case you
assume that CAN is the most important thing in the system and therefore
it disables all other interrupts so that it can do it's work.
>>> +    ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
>>> +    if (ret != true) {
>>> +      goto return_with_lock_release;
>>> +    msg = can_tx_get_data_buf(bus);
>>> +    if (msg == NULL) {
>>> +    ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
>> You have an interrupt lock here. Is "dev_tx" a function that is
>> guaranteed to be fast enough not to make problems with that?
> This function copies drivers buffers to the controller's hardware
> buffer. Time taken is based on the
> message size.
Is it really necessary to copy the whole buffer in the interrupt lock or
could you prepare all data and then only copy one controll structure?
>>> +    if (ret != RTEMS_SUCCESSFUL) {
>>> +        printf("dev_send failed\n");
>> You have an interrupt lock here. You can't use a printf because that
>> uses interrupts.
> I will print after releasing the interrupt lock.
>>> +    rtems_interrupt_lock_release(&bus->can_bus_lock, &lock_context);
>>> +    //can_tx_done(bus);
>>> +  return RTEMS_SUCCESSFUL;
>>> +return_with_lock_release:
>>> +void can_print_canmsg(struct can_msg const *msg)
>> I assume that's a debug only function. Otherwise I wouldn't be happy
>> with the output format.
> Yes, can_print_message is for debug purposes only.
>> Same as above: Is an interrupt lock really necessary and the only solution?
Same as above: Don't make assumptions about what is critical in the
system. Disable only the CAN interrupt if that is possible.
>>> +    fifo_buf = can_tx_get_empty_buf(bus);
>>> +    if (fifo_buf != NULL) {
>>> +      uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
>>> +      if (msg_size > sizeof(struct can_msg)) {
>>> +        printf("can message len error msg_size = %u struct can_msg = %u\n", msg_size, sizeof(struct can_msg));
>> Again: Printf will not work during an interrupt lock.
> I will modify that.
>>> +        return -RTEMS_INVALID_SIZE;
>>> +      memcpy(fifo_buf, msg, msg_size); //sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len));
>> memcpy() in an interrupt lock is definitively takeing too much time. You
>> have to be really convincing that I agree that it's OK.If the "isempty" function needs an interupt_lock: Shouldn't it be part
>> of the function?
>> And again: Wouldn't a mutex work to protect the data instead of
>> interrupt locks?Why is the label named "...release_lock"? It isn't releasing any
> lock.The RTEMS_INTERRUPT_LOCK_INITIALIZER is for a static initialization of
>> an interrupt lock. It won't work to initialize it dynamically here.
Are the buffers used or only a small controll structure with a pointer
to the buffers?
> priority I added a Global interrupt disable.
> Changing RTEMS_INTERRUPT_LOCK_INITIALIZER to
> rtems_interrupt_lock_initialize.
>> A more or less general note for the header file: You want to introduce
>> it as a new general API. Please make sure to document that API enough.
>> Use doxygen-comments in the header file for that. For an example, take a
>> look at cpukit/include/linux/i2c.h or some other headers. Documentation
>> is often really annoying to write as a developer but at the same time
>> it's really convenient to have it for all other developers.
> Ok, I will add the doxygen style comments.
>> For me it's also not really clear whether you want to create a user
>> facing API with this file or a driver facing one.
>>> +#define CAN_MSG_MAX_SIZE  (8u)
>>> +#define CAN_TX_BUF_COUNT  (10u)
>>> +#define CAN_RX_BUF_COUNT  (10u)
>> Is that really a value that does match the needs of all drivers /
>> applications?
> Based on the suggestions, need to decide a suitable count.
Can it be some parameter that is passed for example during
initialization so that a user can decide how much he needs?
Best regards
Christian
>> What's the advantage of implementing two types of semaphores depending
>> on the _POSIX_SEM_ macro instead of just using only one RTEMS-native type?
> That I used for debug purposes, as at first rtems_semaphore_release was
> not working. So to test whether POSIX works I used that.
> Removing POSIX API.
>> I haven't had a detailed look at the useage of the semaphores yet.
>> Personally I prefer the self-contained objects because they have the
>> advantage that the application-developers don't have to think about them
>> when configuring their application:
>> https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#
> <https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#>
>> Not sure whether that would be an option here.
> Ok, I will look into the link.
>> Some of the functions seem to be internal functions that are only used
>> in the framework (especially the ones with *_sem() but also the whole
>> create*buffers() stuff). You shouldn't expose them to the user. Make
>> them static or put them into some internal header.
> Moving them to can-queue.h or can.h header file.
> Regards
> Prashanth S
> On Tue, 19 Jul 2022 at 14:47, <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Prashanth,
>     add a
>     Changing an
>     Am 15.07.22 um 20:11 schrieb Prashanth S:
>      >   cpukit/dev/can/can-queue.c        | 112 +++++++
>      >   cpukit/dev/can/can.c              | 480
>      >   cpukit/include/dev/can/can.h      | 115 +++++++
>      >   spec/build/cpukit/librtemscpu.yml |   5 +
>      >   4 files changed, 712 insertions(+)
>      >   create mode 100644 cpukit/dev/can/can-queue.c
>      >   create mode 100644 cpukit/dev/can/can.c
>      >   create mode 100644 cpukit/include/dev/can/can.h
>      > diff --git a/cpukit/dev/can/can-queue.c b/cpukit/dev/can/can-queue.c
>      > new file mode 100644
>      > index 0000000000..1cebed2ca4
>      > --- /dev/null
>      > +++ b/cpukit/dev/can/can-queue.c
>      > @@ -0,0 +1,112 @@
>      > +/* SPDX-License-Identifier: BSD-2-Clause */
>      > + * @file
>      > + * @ingroup CANBus
>      > + * @brief Controller Area Network (CAN) Bus Implementation
>      > + * Copyright (C) 2022
>      > + * Redistribution and use in source and binary forms, with or
>     without
>      > + * modification, are permitted provided that the following
>     conditions
>      > + * are met:
>      > + * 1. Redistributions of source code must retain the above copyright
>      > + * notice, this list of conditions and the following disclaimer.
>      > + * 2. Redistributions in binary form must reproduce the above
>     copyright
>     in the
>      > + * documentation and/or other materials provided with the
>     distribution.
>      > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>      > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>      > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>      > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>      > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>     EXEMPLARY, OR
>      > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>     PROCUREMENT OF
>      > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>     OR BUSINESS
>      > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>      > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>      > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>      > + * POSSIBILITY OF SUCH DAMAGE.
>      > +#include <rtems/imfs.h>
>      > +#include <rtems/thread.h>
>      > +#include <dev/can/can.h>
>      > +#include <string.h>
>      > +#include <stdlib.h>
>      > +#include <stdio.h>
>      > +rtems_status_code can_create_rx_buffers(struct can_bus *bus)
>      > +  static int init = 0;
>      > +  return rtems_message_queue_create(rtems_build_name('c', 'a',
>     'n', '0' + init++), CAN_RX_BUF_COUNT, sizeof(struct can_msg),
>      > +                                    RTEMS_FIFO | RTEMS_LOCAL,
>     &bus->rx_queue_id);
>     length.
>     "can;"
>     lines
>     simpler to read:
>     you
>     also
>     search a
>     like that.
>      > +  return 0;
>      > +    return false;
>      > +  return true;
>      > +    return NULL;
>      > +  return msg;
>      > +struct can_msg *can_tx_get_empty_buf(struct can_bus *bus)
>      > +  /* Check whether there is a empty CAN msg buffer */
>      > +  if (can_tx_buf_isempty(bus) == false) {
>      > +    printf("can_tx_get_empty_buf No empty buffer\n");
>      > +    return NULL;
>      > +  bus->tx_fifo.empty_count--;
>      > +  /* tx_fifo.head always points to a empty buffer if there is
>     atleast one */
>      > +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
>      > +  bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
>      > +  return msg;
>      > diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
>      > index 0000000000..e8aa9d20ca
>      > --- /dev/null
>      > +++ b/cpukit/dev/can/can.c
>      > @@ -0,0 +1,480 @@
>      > + * @file
>      > + * @ingroup CANBus
>     without
>     conditions
>      > + * are met:
>     copyright
>     in the
>     distribution.
>     LIMITED TO, THE
>     PARTICULAR PURPOSE
>     CONTRIBUTORS BE
>     EXEMPLARY, OR
>     PROCUREMENT OF
>     OR BUSINESS
>     WHETHER IN
>     OTHERWISE)
>     ADVISED OF THE
>      > +#include <fcntl.h>
>      > +static ssize_t can_bus_open(rtems_libio_t *iop, const char
>     *path, int oflag, mode_t mode);
>      > +static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer,
>     size_t count);
>      > +static ssize_t can_bus_write(rtems_libio_t *iop, const void
>     *buffer, size_t count);
>      > +static ssize_t can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t
>     request, void *buffer);
>      > +static int can_xmit(struct can_bus *bus);
>      > +static void can_bus_obtain(can_bus *bus)
>      > +  rtems_recursive_mutex_lock(&bus->mutex);
>      > +static void can_bus_release(can_bus *bus)
>      > +  rtems_recursive_mutex_unlock(&bus->mutex);
>      > +  if (init == 1) {
>      > +    return 0;
>      > +  init = 1;
>      > +  can_bus *bus = IMFS_generic_get_context_by_iop(iop);
>      > +  if (bus == NULL) {
>      > +    return -RTEMS_NOT_DEFINED;
>      > +  can_create_sem(bus);
>      > +  return 0;
>      > +int can_receive(struct can_bus *bus, struct can_msg *msg)
>      > +  int32_t ret = 0;
>      > +  uint32_t count = 0;
>      > +  if ((ret = rtems_message_queue_broadcast(bus->rx_queue_id,
>     msg, sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len),
>     &count)) != RTEMS_SUCCESSFUL) {
>      > +    printf("rtems_message_queue_send failed\n");
>      > +  printf("rtems_message_queue_broadcast = %u\n", count);
>      > +  return ret;
>      > +/* count argument is not used here as struct can_msg has the dlc
>     member */
>     size_t count)
>      > +  int32_t ret = 0;
>      > +  uint32_t flags = 0;
>      > +  if (bus == NULL || bus->can_dev_ops->dev_rx == NULL) {
>      > +  struct can_msg *msg = (struct can_msg *)buffer;
>      > +  if ((iop->flags & O_NONBLOCK) != 0) {
>      > +    flags = RTEMS_NO_WAIT;
>      > +  if ((ret = rtems_message_queue_receive(bus->rx_queue_id, (void
>     *)msg, &count, flags, 0)) != RTEMS_SUCCESSFUL) {
>      > +    return ret;
>      > +  return count;
>      > +int can_create_sem(struct can_bus *bus)
>     make
>     and
>     similar below.
>      > +  int ret = 0;
>      > +#ifndef _POSIX_SEM_
>      > +  //TODO: for test purpose
>      > +  ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n',
>     '0' + init++), 1,
>      > +      RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | RTEMS_LOCAL,
>     0, &bus->tx_fifo_sem_id);
>      > +  if (ret != 0) {
>      > +    printf("rtems_semaphore_create failed %d\n", ret);
>      > +    return ret;
>      > +  ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT,
>     RTEMS_NO_TIMEOUT);
>      > +  if (ret != 0) {
>      > +    printf("rtems_semaphore_obtain failed %d\n", ret);
>      > +    return ret;
>      > +#else
>      > +  ret = sem_init(&bus->tx_sem_id, 0, 1);
>      > +  if (ret != 0) {
>      > +    printf("sem_init failed %d\n", ret);
>      > +    return ret;
>      > +#endif /* _POSIX_SEM_ */
>      > +  return ret;
>      > +int take_sem(struct can_bus *bus)
>      > +  int ret = 0;
>     RTEMS_NO_TIMEOUT);
>      > +#else
>      > +  ret = sem_wait(&bus->tx_sem_id);
>      > +  return ret;
>      > +int give_sem(struct can_bus *bus)
>      > +  int ret = 0;
>      > +  ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
>      > +#else
>      > +  ret = sem_post(&bus->tx_sem_id);
>      > +  return ret;
>      > +  int ret = 0;
>      > +  rtems_interrupt_lock_context lock_context;
>      > +  while (1) {
>      > +    rtems_interrupt_lock_acquire(&bus->can_bus_lock, &lock_context);
>     can
>     have to
>     uses interrupts.
>     printf("\n----------------------------------------------------------------------------------------------------------------------\n");
>      > +  printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len,
>     msg->flags);
>      > +  for (int i = 0; i < msg->len; i++) {
>      > +    printf("%02x ", msg->data[i]);
>      > +int can_tx_done(struct can_bus *bus)
>      > +  int ret = 0;
>      > +  if (bus->can_dev_ops->dev_tx_ready(bus) == true) {
>      > +    can_xmit(bus);
>      > +  if (bus->can_tx_buf_waiters > 0 && (can_tx_buf_isempty(bus) !=
>     0)) {
>      > +    ret = give_sem(bus);
>      > +    if (ret != 0) {
>     printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
>     rtems_semaphore_release failed = %d\n", ret);
>      > +    } else {
>      > +  return ret;
>      > +  if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
>      > +  int32_t ret = 0;
>      > +  struct can_msg const *msg = buffer;
>      > +  struct can_msg *fifo_buf = NULL;
>      > +  while (1) {
>      > +    /* sleep is for debug purpose to test concurrency issues */
>      > +    sleep(1);
>     solution?
>     *)msg;
>     You
>      > +      ret = msg_size;
>      > +      //can_print_canmsg(msg);
>      > +    sleep(1);
>      > +      break;
>      > +    /* Enters if clause, if there are no empty tx fifo buffers.
>     Based on the flags, sleep until buffer
>      > +     * is empty or return error status
>      > +    if (fifo_buf == NULL) {
>      > +        return -RTEMS_RESOURCE_IN_USE;
>      > +        can_xmit(bus);
>     &lock_context);
>      > +      ret = can_tx_buf_isempty(bus);
>     &lock_context);
>     of the function?
>     interrupt locks?
>      > +      if (ret == true) {
>      > +        continue;
>     &lock_context);
>      > +      bus->can_tx_buf_waiters++;
>     &lock_context);
>      > +      printf("empty_count = %u\n", bus->tx_fifo.empty_count);
>      > +      ret = take_sem(bus);
>     &lock_context);
>      > +      bus->can_tx_buf_waiters--;
>     &lock_context);
>      > +        printf("cannot take semaphore\n");
>      > +        ret = -RTEMS_INTERNAL_ERROR;
>      > +        goto return_release_lock;
>      > +    can_xmit(bus);
>      > +return_release_lock:
>     Why is the label named "...release_lock"? It isn't releasing any lock.
>      > +  return ret;
>      > +  if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
>      > +  can_bus_obtain(bus);
>      > +  bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
>      > +  can_bus_release(bus);
>      > +static const rtems_filesystem_file_handlers_r can_bus_handler = {
>      > +  .open_h = can_bus_open,
>      > +  .close_h = rtems_filesystem_default_close,
>      > +  .read_h = can_bus_read,
>      > +  .write_h = can_bus_write,
>      > +  .ioctl_h = can_bus_ioctl,
>      > +  .lseek_h = rtems_filesystem_default_lseek,
>      > +  .fstat_h = IMFS_stat,
>      > +  .ftruncate_h = rtems_filesystem_default_ftruncate,
>      > +  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
>      > +  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
>      > +  .fcntl_h = rtems_filesystem_default_fcntl,
>      > +  .kqfilter_h = rtems_filesystem_default_kqfilter,
>      > +  .mmap_h = rtems_filesystem_default_mmap,
>      > +  .poll_h = rtems_filesystem_default_poll,
>      > +  .readv_h = rtems_filesystem_default_readv,
>      > +  .writev_h = rtems_filesystem_default_writev
>      > +static void can_bus_node_destroy(IMFS_jnode_t *node)
>      > +  can_bus *bus;
>      > +  bus = IMFS_generic_get_context_by_node(node);
>      > +  (*bus->destroy)(bus);
>      > +  IMFS_node_destroy_default(node);
>      > +static const IMFS_node_control can_bus_node_control =
>     IMFS_GENERIC_INITIALIZER(&can_bus_handler,
>     IMFS_node_initialize_generic, can_bus_node_destroy);
>      > +rtems_status_code can_bus_register(can_bus *bus, const char
>     *bus_path)
>      > +  int ret = RTEMS_SUCCESSFUL;
>      > +  ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU |
>     S_IRWXG | S_IRWXO, &can_bus_node_control, bus);
>      > +    printf("Creating node failed: %d\n", ret);
>      > +    goto fail;
>      > +  RTEMS_INTERRUPT_LOCK_INITIALIZER(bus->can_bus_lock);
>      > +  if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
>      > +    printf("can_create_sem failed = %d\n", ret);
>      > +    goto fail;
>      > +  if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
>      > +    printf("can_create_tx_buffers failed = %d\n", ret);
>      > +    goto fail;
>      > +  if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
>      > +    printf("can_create_rx_buffers failed = %d\n", ret);
>      > +    goto fail;
>      > +  return ret;
>      > +fail:
>      > +  return ret;
>      > +static void can_bus_destroy(can_bus *bus)
>      > +  rtems_recursive_mutex_destroy(&bus->mutex);
>      > +static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus
>     *bus))
>      > +  rtems_recursive_mutex_init(&bus->mutex, "CAN Bus");
>      > +  bus->destroy = can_bus_destroy;
>      > +static void can_bus_destroy_and_free(can_bus *bus)
>      > +  can_bus_destroy(bus);
>      > +  free(bus);
>      > +int can_bus_init(can_bus *bus)
>      > +  memset(bus, 0, sizeof(*bus));
>      > +  return can_bus_do_init(bus, can_bus_destroy);
>      > +can_bus *can_bus_alloc_and_init(size_t size)
>      > +  can_bus *bus = NULL;
>      > +  if (size >= sizeof(*bus)) {
>      > +    bus = calloc(1, size);
>      > +    if (bus != NULL) {
>      > +      int rv;
>      > +      rv = can_bus_do_init(bus, can_bus_destroy_and_free);
>      > +      if (rv != 0) {
>      > +        return NULL;
>      > +  return bus;
>      > diff --git a/cpukit/include/dev/can/can.h
>     b/cpukit/include/dev/can/can.h
>      > index 0000000000..2210820504
>      > --- /dev/null
>      > +++ b/cpukit/include/dev/can/can.h
>      > @@ -0,0 +1,115 @@
>      > + * @file
>      > + * @ingroup CANBus
>     without
>     conditions
>      > + * are met:
>     copyright
>     in the
>     distribution.
>     LIMITED TO, THE
>     PARTICULAR PURPOSE
>     CONTRIBUTORS BE
>     EXEMPLARY, OR
>     PROCUREMENT OF
>     OR BUSINESS
>     WHETHER IN
>     OTHERWISE)
>     ADVISED OF THE
>      > +#ifndef _DEV_CAN_CAN_H
>      > +#define _DEV_CAN_CAN_H
>      > +#include <semaphore.h>
>      > +#include <stdio.h>
>     take a
>     applications?
>      > +typedef struct can_dev_ops {
>      > +  int32_t (*dev_rx)(void *priv, void *buffer);
>      > +  int32_t (*dev_tx)(void *priv, void *buffer);
>      > +  bool (*dev_tx_ready)(void *priv);
>      > +  void (*dev_tx_int)(void *priv, bool);
>      > +  int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
>      > +} can_dev_ops;
>      > +struct ring_buf {
>      > +  struct can_msg *pbuf;
>      > +  uint32_t head;
>      > +  uint32_t tail;
>      > +  uint32_t empty_count;
>      > +typedef struct can_bus {
>      > +  void *priv;                               // CAN controller
>     specific struct.
>      > +  struct can_dev_ops *can_dev_ops;          // CAN controller
>     operations.
>      > +  struct ring_buf tx_fifo;                  // TX fifo
>      > +  rtems_id tx_fifo_sem_id;                  // TX fifo counting
>     semaphore id
>      > +#else
>      > +  sem_t tx_sem_id;
>      > +  uint32_t tx_fifo_sem_name;                // TX fifo sem name
>     type?
>     them
>      > +  uint32_t can_tx_buf_waiters;
>      > +  rtems_id rx_queue_id;
>      > +  uint32_t rx_queue_name;
>      > +  rtems_recursive_mutex mutex;              // For handling
>     driver concurrency.
>      > +  RTEMS_INTERRUPT_LOCK_MEMBER(can_bus_lock);
>      > +  void (*destroy)(struct can_bus *bus);     // Clean the CAN
>     controller specific resources.
>      > +} can_bus;
>      > +struct can_msg {
>      > +  uint32_t id;                              // 32 bits to
>     support extended id (29 bits).
>      > +  uint32_t timestamp;
>      > +  uint16_t flags;                           // RTR | BRS | EXT ...
>      > +  uint16_t len;
>      > +  uint8_t data[CAN_MSG_MAX_SIZE];           // For supporting
>     data transfer up to 64 bytes.
>      > +extern can_bus *can_bus_alloc_and_init(size_t size);
>      > +extern int can_bus_init(can_bus *bus);
>      > +extern rtems_status_code can_bus_register(can_bus *bus, const
>     char *bus_path);
>      > +extern int can_tx_done(struct can_bus *);
>      > +extern int can_receive(struct can_bus *, struct can_msg *);
>      > +extern uint16_t can_len_to_dlc(uint16_t len);
>      > +extern uint16_t can_dlc_to_len(uint16_t dlc);
>      > +extern rtems_status_code can_create_tx_buffers(struct can_bus *bus);
>      > +extern rtems_status_code can_create_rx_buffers(struct can_bus *bus);
>      > +extern bool can_tx_buf_isempty(struct can_bus *bus);
>      > +extern struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
>      > +extern struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
>      > +extern int take_sem(struct can_bus *);
>      > +extern int give_sem(struct can_bus *);
>      > +extern int can_create_sem(struct can_bus *bus);
>     Best regards
>     Christian
>      > +extern void can_print_canmsg(struct can_msg const *);
>      > +#endif /* _DEV_CAN_CAN_H */
>      > diff --git a/spec/build/cpukit/librtemscpu.yml
>     b/spec/build/cpukit/librtemscpu.yml
>      > index 31a68cf85a..b700935f82 100644
>      > --- a/spec/build/cpukit/librtemscpu.yml
>      > +++ b/spec/build/cpukit/librtemscpu.yml
>      > @@ -50,6 +50,9 @@ install:
>      >   - destination: ${BSP_INCLUDEDIR}/dev/spi
>      >     source:
>      >     - cpukit/include/dev/spi/spi.h
>      > +- destination: ${BSP_INCLUDEDIR}/dev/can
>      > +  source:
>      > +  - cpukit/include/dev/can/can.h
>      >   - destination: ${BSP_INCLUDEDIR}/linux
>      >     source:
>      >     - cpukit/include/linux/i2c-dev.h
>      > @@ -530,6 +533,8 @@ source:
>      >   - cpukit/dev/serial/sc16is752-spi.c
>      >   - cpukit/dev/serial/sc16is752.c
>      >   - cpukit/dev/spi/spi-bus.c
>      > +- cpukit/dev/can/can.c
>      > +- cpukit/dev/can/can-queue.c
>      >   - cpukit/dtc/libfdt/fdt.c
>      >   - cpukit/dtc/libfdt/fdt_addresses.c
>      >   - cpukit/dtc/libfdt/fdt_empty_tree.c
