[PATCH] cpukit/dev/can: Added CAN support
Prashanth S fishesprashanth at gmail.com
Tue Jul 19 14:59:02 UTC 2022
Hi Christian,
> If you didn't have to agree to some really odd license, you can post it
> as a patch on the list. Make sure to make it _very_ clear that you are
> not sure about the license and for what reason. Things like licensing
> should be discussed with the community in public so that the discussion
> is archived together with the list.
Ok, Need to make a few more changes and send them to review.
> In that case the static variable will make trouble. You have a static
> counter. If I register the bus, deregister it and register it again, the
> counter will have odd values. Better: Use some macro to automate that and
enable or disable all debug
> messages at once. Also it's not the nicest solution, it's not uncommon
> to have something like that. Examples are:
> cpukit/libdrvmgr/drvmgr.c:44:#define DBG(x...) printk(x)
> cpukit/include/rtems/posix/aio_misc.h:116:#define AIO_printf(_x)
printf(_x)
> cpukit/libfs/src/ftpfs/ftpfs.c:61:  #define DEBUG_PRINTF(...)
> printf(__VA_ARGS__)
> bsps/mips/malta/pci/pci.c:49:  #define JPRINTK(fmt, ...) printk("%s: "
> fmt, __FUNCTION__, ##__VA_ARGS__) You put a pointer to the tx_fifo into
msg:
Ok
>   msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
> and then return that pointer to the application:
>    return msg;
> The function is not static so it's clearly not internal use only. Even
> if it would be internal only, I would suggest to split it into a get
> buffer and mark buffer empty after it has been copied. Otherwise you
> have to be _really_ carefull that the framework can't overwrite the
> buffer while it is still used.
Ok, I added as a single API, as we can change the type of
data structure used (now ring buffer is used, maybe later a priority queue
or red black tree).
> Is the part in can-queue intendet to be used by an application?
> Otherwise you should not install the headers so that a user can't use
them.
functions in can-queue.c are only for driver purpose, Moving them to
can-queue.h
> You should allways disable as few as possible. So if you can only
> disable can interrupts instead of all interrupts, you should do that.
> Otherwise you make assumptions about a user system. In that case you
> assume that CAN is the most important thing in the system and therefore
> it disables all other interrupts so that it can do it's work.
Ok, I will disable interrupts locally and make changes accordingly.
> Is it really necessary to copy the whole buffer in the interrupt lock or
> could you prepare all data and then only copy one controll structure?
Yes, Moving, copying buffers out of interrupt lock (As we already got the
buffer from can_tx_get_empty_buf).
> Same as above: Don't make assumptions about what is critical in the
> system. Disable only the CAN interrupt if that is possible.
Ok
>>> +    fifo_buf = can_tx_get_empty_buf(bus);
>>> +    if (fifo_buf != NULL) {
>>> +      uint32_t msg_size = (char *)&msg->data[msg->len] - (char *)msg;
>>> +      if (msg_size > sizeof(struct can_msg)) {
>>> +        printf("can message len error msg_size = %u struct can_msg =
%u\n", msg_size, sizeof(struct can_msg));
>> Again: Printf will not work during an interrupt lock.
> I will modify that.
>>> +        return -RTEMS_INVALID_SIZE;
>>> +      memcpy(fifo_buf, msg, msg_size); //sizeof(struct can_msg) -
(CAN_MSG_MAX_SIZE - msg->len));
>> memcpy() in an interrupt lock is definitively takeing too much time. You
>> have to be really convincing that I agree that it's OK.If the "isempty"
function needs an interupt_lock: Shouldn't it be part
>> of the function?
>> And again: Wouldn't a mutex work to protect the data instead of
>> interrupt locks?Why is the label named "...release_lock"? It isn't
releasing any
> lock.The RTEMS_INTERRUPT_LOCK_INITIALIZER is for a static initialization
of
>> an interrupt lock. It won't work to initialize it dynamically here.
> Yes, We need to disable interrupts as the tx and rx buffers are used in
> the tx and rx interrupts handlers.
> Are the buffers used or only a small controll structure with a pointer
> to the buffers?
Yes the buffers are used to identify the type of message based on the flags.
> Or could disable only CAN interrupts, as CAN messages being a higher
> priority I added a Global interrupt disable.
> Shall I disable it locally or globally?
> Changing RTEMS_INTERRUPT_LOCK_INITIALIZER to
> rtems_interrupt_lock_initialize.
>> A more or less general note for the header file: You want to introduce
>> it as a new general API. Please make sure to document that API enough.
>> Use doxygen-comments in the header file for that. For an example, take a
>> look at cpukit/include/linux/i2c.h or some other headers. Documentation
>> is often really annoying to write as a developer but at the same time
>> it's really convenient to have it for all other developers.
> Ok, I will add the doxygen style comments.
>> For me it's also not really clear whether you want to create a user
>> facing API with this file or a driver facing one.
>>> +#define CAN_MSG_MAX_SIZE  (8u)
>>> +#define CAN_TX_BUF_COUNT  (10u)
>>> +#define CAN_RX_BUF_COUNT  (10u)
>> Is that really a value that does match the needs of all drivers /
>> applications?
> Based on the suggestions, need to decide a suitable count.
> Can it be some parameter that is passed for example during
> initialization so that a user can decide how much he needs?
Yes, I think that can be done as a #define to be configured by the
application, As the driver is initialized before the application starts.
And can be changed dynamically also by using an ioctl.
Regards
Prashanth S
On Tue, 19 Jul 2022 at 19:05, Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Prashanth,
> Am 19.07.22 um 15:09 schrieb Prashanth S:
> > Hi Christian,
> > This is to reply to review comments.
> >> first question: You also worked on a driver for beagle DCAN. Did you
> >> already adapt that driver to this API? If yes, it would be usefull to
> >> post that as a patch too so that the direction and the method how it
> >> will be used is more clear.
> > Yes, Waiting for License confirmation.
> >> Note that some of my comments might are a bit critical because you add
> a
> >> general API. I would have a lot less problems if it would be only a
> >> driver specific API. If you add a general API, it has to fit the needs
> >> of not only your current driver but most future drivers too. Changing
> an
> >> API later is allways tricky.
> > Ok
> >> Please make sure to stic to the RTEMS style and use a 80 character line
> >> length.
> > OK
> >> You create a name with a "'0' + init++": Are you sure that a maximum of
> >> 10 buffers are created? Otherwise you will get names like "can:",
> "can;"
> >> and - sooner or later: "can\xFF", "can\x00", ...
> > Assuming we have less than 10 CAN controllers, I will update this to
> > limit to 10 queues.
> >> In the header you somewhere had a "destroy" function. Do you need some
> >> way to de-initialize buffers only used by that bus?
> > Yes, the can_bus structure holds data related only to a specific bus.
> >>> +rtems_status_code can_create_tx_buffers(struct can_bus *bus)
> >>> +  if ((bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT
> * sizeof(struct can_msg))) == NULL) {
> >> You seem to like writing a lot of code in one line. From my point of
> >> view that makes code harder to read. If you write it into multiple
> lines
> >> instead, someone else doesn't have to think that much about which
> >> bracket closes where. For example in this case the following would be
> >> simpler to read:
> > I will make changes to limit line length to 80.
> >> bus->tx_fifo.pbuf = (struct can_msg *)malloc(CAN_TX_BUF_COUNT *
> >> if (bus->tx_fifo.pbuf == NULL) {
> >> +    printf("malloc failed\n");
> >> Prints are nice for debugging but can be really annoying in
> >> applications. Think about some kind of "debug_print" or similar that
> you
> >> can enable / disable with a macro at the start of the file. You can
> also
> >> use that to add a prefix or function name to all prints. If you search
> a
> >> problem, a line like "mallof failed" is meaningless if you are not
> >> currently working on specially this code. A line like
> >> "can_create_tx_buffers: malloc failed" is a lot more usefull. There are
> >> preprocessor macros like __FUNCTION__ that you can use for something
> >> like that.
> > Ok, I will update the prints with the function name in it.
> Better: Use some macro to automate that and enable or disable all debug
> cpukit/include/rtems/posix/aio_misc.h:116:#define AIO_printf(_x) printf(_x)
> printf(__VA_ARGS__)
> >> +    return RTEMS_NO_MEMORY;
> >> +  bus->tx_fifo.head = bus->tx_fifo.tail = 0;
> >> Same here: This is hard to read. I would suggest to split that into two
> >> lines. Alternatively you might want to think about just using a memset
> >> to have a clean start for a structure that you initialize.
> > Ok, memset is done in the can_bus_init or calloc is used in
> > can_bus_alloc_and_init.
> > Removing bus->tx_fifo.head = bus->tx_fifo.tail = 0;
> >> +  bus->tx_fifo.empty_count = CAN_TX_BUF_COUNT;
> >> +  return 0;
> >> +bool can_tx_buf_isempty(struct can_bus *bus)
> >> +  if (bus->tx_fifo.empty_count <= 0) {
> >> +    /* tx_fifo.empty_count does not go below zero, incase if it goes
> update to zero */
> >> +    bus->tx_fifo.empty_count = 0;
> > empty_count is an unsigned type and therefore can never be smaller than
> > 0. This line is not necessary at all.
> > Ok, removing it.
> >> +    return false;
> >> +  return true;
> >> +struct can_msg *can_tx_get_data_buf(struct can_bus *bus)
> >> +  struct can_msg *msg = NULL;
> >> +  if (bus->tx_fifo.empty_count == CAN_TX_BUF_COUNT) {
> >> +    printf("can_tx_get_next_data_buf All buffers are empty\n");
> >> +    return NULL;
> >> +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.tail];
> >> +  bus->tx_fifo.empty_count++;
> >> +  bus->tx_fifo.tail = (bus->tx_fifo.tail + 1) % CAN_TX_BUF_COUNT;
> >> You want to return the pointer to the message (msg) to the caller,
> >> right? In that case you must not marke it as empty here. Otherwise
> >> someone else could already use that memory again while the application
> >> is still processing it.
> > Here the application does not use this (driver buffer) buffer, we copy
> > the message from this buffer (driver buffer)
> > to the application passed buffer.
> You put a pointer to the tx_fifo into msg:
>    return msg;
> >> Looks like a helper function that is only used in this file? Please
> make
> >> it  static and remove it from the header. Same is true for "take_sem"
> and
> >> similar below.
> > Functions in can-queue.c are used in can.c, Moving them to can-queue.h
> > or can.h header file.
> > I will add static to take_sem and give_sem.
> Otherwise you should not install the headers so that a user can't use them.
> >> Is an interrupt lock really necessary? Wouldn't a mutex or similar work
> >> too to protect the relevant data? An interrupt lock is something that
> >> should be used really carefull. You tell the system: Stop everything
> >> else. This here is the most important task.
> >> That means that for example a time critical data acquisition process
> can
> >> be delayed by the time that you need in your interrupt lock. You have
> to
> >> be really sure that the interrupt is the only solution to solve the
> >> problem before you use one.
> > priority so I added a Global interrupt disable.
> >>> +    ret = bus->can_dev_ops->dev_tx_ready(bus->priv);
> >>> +    if (ret != true) {
> >>> +      goto return_with_lock_release;
> >>> +    msg = can_tx_get_data_buf(bus);
> >>> +    if (msg == NULL) {
> >>> +    ret = bus->can_dev_ops->dev_tx(bus->priv, msg);
> >> You have an interrupt lock here. Is "dev_tx" a function that is
> >> guaranteed to be fast enough not to make problems with that?
> > This function copies drivers buffers to the controller's hardware
> > buffer. Time taken is based on the
> > message size.
> >>> +    if (ret != RTEMS_SUCCESSFUL) {
> >>> +        printf("dev_send failed\n");
> >> You have an interrupt lock here. You can't use a printf because that
> >> uses interrupts.
> > I will print after releasing the interrupt lock.
> >>> +    rtems_interrupt_lock_release(&bus->can_bus_lock, &lock_context);
> >>> +    //can_tx_done(bus);
> >>> +  return RTEMS_SUCCESSFUL;
> >>> +return_with_lock_release:
> >>> +void can_print_canmsg(struct can_msg const *msg)
> >> I assume that's a debug only function. Otherwise I wouldn't be happy
> >> with the output format.
> > Yes, can_print_message is for debug purposes only.
> >> Same as above: Is an interrupt lock really necessary and the only
> solution?
> > I will modify that.
> You
> >> of the function?
> releasing any
> of
> to the buffers?
> a
> >> applications?
> Best regards
> Christian
> >> What's the advantage of implementing two types of semaphores depending
> >> on the _POSIX_SEM_ macro instead of just using only one RTEMS-native
> type?
> > That I used for debug purposes, as at first rtems_semaphore_release was
> > not working. So to test whether POSIX works I used that.
> > Removing POSIX API.
> >> I haven't had a detailed look at the useage of the semaphores yet.
> >> Personally I prefer the self-contained objects because they have the
> >> advantage that the application-developers don't have to think about them
> >> when configuring their application:
> https://docs.rtems.org/branches/master/c-user/self_contained_objects.html#
> >> Not sure whether that would be an option here.
> > Ok, I will look into the link.
> >> Some of the functions seem to be internal functions that are only used
> >> in the framework (especially the ones with *_sem() but also the whole
> >> create*buffers() stuff). You shouldn't expose them to the user. Make
> >> them static or put them into some internal header.
> > Moving them to can-queue.h or can.h header file.
> > Regards
> > Prashanth S
> > On Tue, 19 Jul 2022 at 14:47, <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> >     Hello Prashanth,
> >     add a
> needs
> >     Changing an
> >     Am 15.07.22 um 20:11 schrieb Prashanth S:
> >      >   cpukit/dev/can/can-queue.c        | 112 +++++++
> >      >   cpukit/dev/can/can.c              | 480
> >      >   cpukit/include/dev/can/can.h      | 115 +++++++
> >      >   spec/build/cpukit/librtemscpu.yml |   5 +
> >      >   4 files changed, 712 insertions(+)
> >      >   create mode 100644 cpukit/dev/can/can-queue.c
> >      >   create mode 100644 cpukit/dev/can/can.c
> >      >   create mode 100644 cpukit/include/dev/can/can.h
> >      > diff --git a/cpukit/dev/can/can-queue.c
> b/cpukit/dev/can/can-queue.c
> >      > new file mode 100644
> >      > index 0000000000..1cebed2ca4
> >      > --- /dev/null
> >      > +++ b/cpukit/dev/can/can-queue.c
> >      > @@ -0,0 +1,112 @@
> >      > +/* SPDX-License-Identifier: BSD-2-Clause */
> >      > + * @file
> >      > + * @ingroup CANBus
> >      > + * @brief Controller Area Network (CAN) Bus Implementation
> >      > + * Copyright (C) 2022
> >      > + * Redistribution and use in source and binary forms, with or
> >     without
> >      > + * modification, are permitted provided that the following
> >     conditions
> >      > + * are met:
> >      > + * 1. Redistributions of source code must retain the above
> copyright
> >      > + * notice, this list of conditions and the following disclaimer.
> >      > + * 2. Redistributions in binary form must reproduce the above
> >     copyright
> >     in the
> >      > + * documentation and/or other materials provided with the
> >     distribution.
> >      > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> >     CONTRIBUTORS "AS IS"
> >      > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> >     LIMITED TO, THE
> >      > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> >     PARTICULAR PURPOSE
> >      > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> >     CONTRIBUTORS BE
> >      > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> >     EXEMPLARY, OR
> >      > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> >     PROCUREMENT OF
> >      > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
> >     OR BUSINESS
> >      > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> >     WHETHER IN
> >      > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> >     OTHERWISE)
> >      > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> >     ADVISED OF THE
> >      > + * POSSIBILITY OF SUCH DAMAGE.
> >      > +#include <rtems/imfs.h>
> >      > +#include <rtems/thread.h>
> >      > +#include <dev/can/can.h>
> >      > +#include <string.h>
> >      > +#include <stdlib.h>
> >      > +#include <stdio.h>
> >      > +rtems_status_code can_create_rx_buffers(struct can_bus *bus)
> >      > +  static int init = 0;
> >      > +  return rtems_message_queue_create(rtems_build_name('c', 'a',
> >     'n', '0' + init++), CAN_RX_BUF_COUNT, sizeof(struct can_msg),
> >      > +                                    RTEMS_FIFO | RTEMS_LOCAL,
> >     &bus->rx_queue_id);
> line
> >     length.
> of
> >     "can;"
> some
> >     *)malloc(CAN_TX_BUF_COUNT * sizeof(struct can_msg))) == NULL) {
> >     lines
> >     simpler to read:
> >     you
> >     also
> >     search a
> are
> >     like that.
> two
> memset
> >      > +  return 0;
> >     goes update to zero */
> than
> >      > +    return false;
> >      > +  return true;
> >      > +    return NULL;
> application
> >      > +  return msg;
> >      > +struct can_msg *can_tx_get_empty_buf(struct can_bus *bus)
> >      > +  /* Check whether there is a empty CAN msg buffer */
> >      > +  if (can_tx_buf_isempty(bus) == false) {
> >      > +    printf("can_tx_get_empty_buf No empty buffer\n");
> >      > +    return NULL;
> >      > +  bus->tx_fifo.empty_count--;
> >      > +  /* tx_fifo.head always points to a empty buffer if there is
> >     atleast one */
> >      > +  msg = &bus->tx_fifo.pbuf[bus->tx_fifo.head];
> >      > +  bus->tx_fifo.head = (bus->tx_fifo.head + 1) % CAN_TX_BUF_COUNT;
> >      > +  return msg;
> >      > diff --git a/cpukit/dev/can/can.c b/cpukit/dev/can/can.c
> >      > index 0000000000..e8aa9d20ca
> >      > --- /dev/null
> >      > +++ b/cpukit/dev/can/can.c
> >      > @@ -0,0 +1,480 @@
> >      > + * @file
> >      > + * @ingroup CANBus
> >     without
> >     conditions
> >      > + * are met:
> copyright
> >     copyright
> >     in the
> >     distribution.
> >     LIMITED TO, THE
> >     PARTICULAR PURPOSE
> >     CONTRIBUTORS BE
> >     EXEMPLARY, OR
> >     PROCUREMENT OF
> >     OR BUSINESS
> >     WHETHER IN
> >     OTHERWISE)
> >     ADVISED OF THE
> >      > +#include <fcntl.h>
> >      > +static ssize_t can_bus_open(rtems_libio_t *iop, const char
> >     *path, int oflag, mode_t mode);
> >      > +static ssize_t can_bus_read(rtems_libio_t *iop, void *buffer,
> >     size_t count);
> >      > +static ssize_t can_bus_write(rtems_libio_t *iop, const void
> >     *buffer, size_t count);
> >      > +static ssize_t can_bus_ioctl(rtems_libio_t *iop, ioctl_command_t
> >     request, void *buffer);
> >      > +static int can_xmit(struct can_bus *bus);
> >      > +static void can_bus_obtain(can_bus *bus)
> >      > +  rtems_recursive_mutex_lock(&bus->mutex);
> >      > +static void can_bus_release(can_bus *bus)
> >      > +  rtems_recursive_mutex_unlock(&bus->mutex);
> >      > +  if (init == 1) {
> >      > +    return 0;
> >      > +  init = 1;
> >      > +  can_bus *bus = IMFS_generic_get_context_by_iop(iop);
> >      > +  if (bus == NULL) {
> >      > +    return -RTEMS_NOT_DEFINED;
> >      > +  can_create_sem(bus);
> >      > +  return 0;
> >      > +int can_receive(struct can_bus *bus, struct can_msg *msg)
> >      > +  int32_t ret = 0;
> >      > +  uint32_t count = 0;
> >      > +  if ((ret = rtems_message_queue_broadcast(bus->rx_queue_id,
> >     msg, sizeof(struct can_msg) - (CAN_MSG_MAX_SIZE - msg->len),
> >     &count)) != RTEMS_SUCCESSFUL) {
> >      > +    printf("rtems_message_queue_send failed\n");
> >      > +  printf("rtems_message_queue_broadcast = %u\n", count);
> >      > +  return ret;
> >      > +/* count argument is not used here as struct can_msg has the dlc
> >     member */
> >     size_t count)
> >      > +  int32_t ret = 0;
> >      > +  uint32_t flags = 0;
> >      > +  if (bus == NULL || bus->can_dev_ops->dev_rx == NULL) {
> >      > +  struct can_msg *msg = (struct can_msg *)buffer;
> >      > +  if ((iop->flags & O_NONBLOCK) != 0) {
> >      > +    flags = RTEMS_NO_WAIT;
> >      > +  if ((ret = rtems_message_queue_receive(bus->rx_queue_id, (void
> >     *)msg, &count, flags, 0)) != RTEMS_SUCCESSFUL) {
> >      > +    return ret;
> >      > +  return count;
> >      > +int can_create_sem(struct can_bus *bus)
> >     make
> >     and
> >     similar below.
> >      > +  int ret = 0;
> >      > +#ifndef _POSIX_SEM_
> >      > +  //TODO: for test purpose
> >      > +  ret = rtems_semaphore_create(rtems_build_name('c', 'a', 'n',
> >     '0' + init++), 1,
> >      > +      RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | RTEMS_LOCAL,
> >     0, &bus->tx_fifo_sem_id);
> >      > +  if (ret != 0) {
> >      > +    printf("rtems_semaphore_create failed %d\n", ret);
> >      > +    return ret;
> >      > +  ret = rtems_semaphore_obtain(bus->tx_fifo_sem_id, RTEMS_WAIT,
> >     RTEMS_NO_TIMEOUT);
> >      > +  if (ret != 0) {
> >      > +    printf("rtems_semaphore_obtain failed %d\n", ret);
> >      > +    return ret;
> >      > +#else
> >      > +  ret = sem_init(&bus->tx_sem_id, 0, 1);
> >      > +  if (ret != 0) {
> >      > +    printf("sem_init failed %d\n", ret);
> >      > +    return ret;
> >      > +#endif /* _POSIX_SEM_ */
> >      > +  return ret;
> >      > +int take_sem(struct can_bus *bus)
> >      > +  int ret = 0;
> >     RTEMS_NO_TIMEOUT);
> >      > +#else
> >      > +  ret = sem_wait(&bus->tx_sem_id);
> >      > +  return ret;
> >      > +int give_sem(struct can_bus *bus)
> >      > +  int ret = 0;
> >      > +  ret = rtems_semaphore_release(bus->tx_fifo_sem_id);
> >      > +#else
> >      > +  ret = sem_post(&bus->tx_sem_id);
> >      > +  return ret;
> >      > +  int ret = 0;
> >      > +  rtems_interrupt_lock_context lock_context;
> >      > +  while (1) {
> >      > +    rtems_interrupt_lock_acquire(&bus->can_bus_lock,
> &lock_context);
> work
> >     can
> >     have to
> >     uses interrupts.
> &lock_context);
> &lock_context);
>  printf("\n----------------------------------------------------------------------------------------------------------------------\n");
> >      > +  printf("id = %d len = %d flags = 0x%08X\n", msg->id, msg->len,
> >     msg->flags);
> >      > +  for (int i = 0; i < msg->len; i++) {
> >      > +    printf("%02x ", msg->data[i]);
> >      > +int can_tx_done(struct can_bus *bus)
> >      > +  int ret = 0;
> >      > +  if (bus->can_dev_ops->dev_tx_ready(bus) == true) {
> >      > +    can_xmit(bus);
> >      > +  if (bus->can_tx_buf_waiters > 0 && (can_tx_buf_isempty(bus) !=
> >     0)) {
> >      > +    ret = give_sem(bus);
> >      > +    if (ret != 0) {
>  printf(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
> >     rtems_semaphore_release failed = %d\n", ret);
> >      > +    } else {
> >      > +  return ret;
> >      > +  if (bus == NULL || bus->can_dev_ops->dev_tx == NULL) {
> >      > +  int32_t ret = 0;
> >      > +  struct can_msg const *msg = buffer;
> >      > +  struct can_msg *fifo_buf = NULL;
> >      > +  while (1) {
> >      > +    /* sleep is for debug purpose to test concurrency issues */
> >      > +    sleep(1);
> &lock_context);
> >     solution?
> >     *)msg;
> >     can_msg = %u\n", msg_size, sizeof(struct can_msg));
> >     - (CAN_MSG_MAX_SIZE - msg->len));
> >     You
> >      > +      ret = msg_size;
> >      > +      //can_print_canmsg(msg);
> &lock_context);
> >      > +    sleep(1);
> >      > +      break;
> >      > +    /* Enters if clause, if there are no empty tx fifo buffers.
> >     Based on the flags, sleep until buffer
> >      > +     * is empty or return error status
> >      > +    if (fifo_buf == NULL) {
> >      > +        return -RTEMS_RESOURCE_IN_USE;
> >      > +        can_xmit(bus);
> >     &lock_context);
> >      > +      ret = can_tx_buf_isempty(bus);
> >     &lock_context);
> >     If the "isempty" function needs an interupt_lock: Shouldn't it be
> part
> >     of the function?
> >     interrupt locks?
> >      > +      if (ret == true) {
> >      > +        continue;
> >     &lock_context);
> >      > +      bus->can_tx_buf_waiters++;
> >     &lock_context);
> >      > +      printf("empty_count = %u\n", bus->tx_fifo.empty_count);
> >      > +      ret = take_sem(bus);
> >     &lock_context);
> >      > +      bus->can_tx_buf_waiters--;
> >     &lock_context);
> >      > +        printf("cannot take semaphore\n");
> >      > +        ret = -RTEMS_INTERNAL_ERROR;
> >      > +        goto return_release_lock;
> >      > +    can_xmit(bus);
> >      > +return_release_lock:
> >     Why is the label named "...release_lock"? It isn't releasing any
> lock.
> >      > +  return ret;
> >      > +  if (bus == NULL || bus->can_dev_ops->dev_ioctl == NULL) {
> >      > +  can_bus_obtain(bus);
> >      > +  bus->can_dev_ops->dev_ioctl(bus->priv, NULL, 0);
> >      > +  can_bus_release(bus);
> >      > +static const rtems_filesystem_file_handlers_r can_bus_handler = {
> >      > +  .open_h = can_bus_open,
> >      > +  .close_h = rtems_filesystem_default_close,
> >      > +  .read_h = can_bus_read,
> >      > +  .write_h = can_bus_write,
> >      > +  .ioctl_h = can_bus_ioctl,
> >      > +  .lseek_h = rtems_filesystem_default_lseek,
> >      > +  .fstat_h = IMFS_stat,
> >      > +  .ftruncate_h = rtems_filesystem_default_ftruncate,
> >      > +  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
> >      > +  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
> >      > +  .fcntl_h = rtems_filesystem_default_fcntl,
> >      > +  .kqfilter_h = rtems_filesystem_default_kqfilter,
> >      > +  .mmap_h = rtems_filesystem_default_mmap,
> >      > +  .poll_h = rtems_filesystem_default_poll,
> >      > +  .readv_h = rtems_filesystem_default_readv,
> >      > +  .writev_h = rtems_filesystem_default_writev
> >      > +static void can_bus_node_destroy(IMFS_jnode_t *node)
> >      > +  can_bus *bus;
> >      > +  bus = IMFS_generic_get_context_by_node(node);
> >      > +  (*bus->destroy)(bus);
> >      > +  IMFS_node_destroy_default(node);
> >      > +static const IMFS_node_control can_bus_node_control =
> >     IMFS_GENERIC_INITIALIZER(&can_bus_handler,
> >     IMFS_node_initialize_generic, can_bus_node_destroy);
> >      > +rtems_status_code can_bus_register(can_bus *bus, const char
> >     *bus_path)
> >      > +  int ret = RTEMS_SUCCESSFUL;
> >      > +  ret = IMFS_make_generic_node(bus_path, S_IFCHR | S_IRWXU |
> >     S_IRWXG | S_IRWXO, &can_bus_node_control, bus);
> >      > +    printf("Creating node failed: %d\n", ret);
> >      > +    goto fail;
> >      > +  RTEMS_INTERRUPT_LOCK_INITIALIZER(bus->can_bus_lock);
> of
> >      > +  if ((ret = can_create_sem(bus)) != RTEMS_SUCCESSFUL) {
> >      > +    printf("can_create_sem failed = %d\n", ret);
> >      > +    goto fail;
> >      > +  if ((ret = can_create_tx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> >      > +    printf("can_create_tx_buffers failed = %d\n", ret);
> >      > +    goto fail;
> >      > +  if ((ret = can_create_rx_buffers(bus)) != RTEMS_SUCCESSFUL) {
> >      > +    printf("can_create_rx_buffers failed = %d\n", ret);
> >      > +    goto fail;
> >      > +  return ret;
> >      > +fail:
> >      > +  return ret;
> >      > +static void can_bus_destroy(can_bus *bus)
> >      > +  rtems_recursive_mutex_destroy(&bus->mutex);
> >      > +static int can_bus_do_init(can_bus *bus, void (*destroy)(can_bus
> >     *bus))
> >      > +  rtems_recursive_mutex_init(&bus->mutex, "CAN Bus");
> >      > +  bus->destroy = can_bus_destroy;
> >      > +static void can_bus_destroy_and_free(can_bus *bus)
> >      > +  can_bus_destroy(bus);
> >      > +  free(bus);
> >      > +int can_bus_init(can_bus *bus)
> >      > +  memset(bus, 0, sizeof(*bus));
> >      > +  return can_bus_do_init(bus, can_bus_destroy);
> >      > +can_bus *can_bus_alloc_and_init(size_t size)
> >      > +  can_bus *bus = NULL;
> >      > +  if (size >= sizeof(*bus)) {
> >      > +    bus = calloc(1, size);
> >      > +    if (bus != NULL) {
> >      > +      int rv;
> >      > +      rv = can_bus_do_init(bus, can_bus_destroy_and_free);
> >      > +      if (rv != 0) {
> >      > +        return NULL;
> >      > +  return bus;
> >      > diff --git a/cpukit/include/dev/can/can.h
> >     b/cpukit/include/dev/can/can.h
> >      > index 0000000000..2210820504
> >      > --- /dev/null
> >      > +++ b/cpukit/include/dev/can/can.h
> >      > @@ -0,0 +1,115 @@
> >      > + * @file
> >      > + * @ingroup CANBus
> >     without
> >     conditions
> >      > + * are met:
> copyright
> >     copyright
> >     in the
> >     distribution.
> >     LIMITED TO, THE
> >     PARTICULAR PURPOSE
> >     CONTRIBUTORS BE
> >     EXEMPLARY, OR
> >     PROCUREMENT OF
> >     OR BUSINESS
> >     WHETHER IN
> >     OTHERWISE)
> >     ADVISED OF THE
> >      > +#ifndef _DEV_CAN_CAN_H
> >      > +#define _DEV_CAN_CAN_H
> >      > +#include <semaphore.h>
> >      > +#include <stdio.h>
> introduce
> enough.
> >     take a
> Documentation
> >     applications?
> >      > +typedef struct can_dev_ops {
> >      > +  int32_t (*dev_rx)(void *priv, void *buffer);
> >      > +  int32_t (*dev_tx)(void *priv, void *buffer);
> >      > +  bool (*dev_tx_ready)(void *priv);
> >      > +  void (*dev_tx_int)(void *priv, bool);
> >      > +  int32_t (*dev_ioctl)(void *priv, void *buffer, size_t cmd);
> >      > +} can_dev_ops;
> >      > +struct ring_buf {
> >      > +  struct can_msg *pbuf;
> >      > +  uint32_t head;
> >      > +  uint32_t tail;
> >      > +  uint32_t empty_count;
> >      > +typedef struct can_bus {
> >      > +  void *priv;                               // CAN controller
> >     specific struct.
> >      > +  struct can_dev_ops *can_dev_ops;          // CAN controller
> >     operations.
> >      > +  struct ring_buf tx_fifo;                  // TX fifo
> >      > +  rtems_id tx_fifo_sem_id;                  // TX fifo counting
> >     semaphore id
> >      > +#else
> >      > +  sem_t tx_sem_id;
> >      > +  uint32_t tx_fifo_sem_name;                // TX fifo sem name
> depending
> >     type?
> >     them
> >      > +  uint32_t can_tx_buf_waiters;
> >      > +  rtems_id rx_queue_id;
> >      > +  uint32_t rx_queue_name;
> >      > +  rtems_recursive_mutex mutex;              // For handling
> >     driver concurrency.
> >      > +  RTEMS_INTERRUPT_LOCK_MEMBER(can_bus_lock);
> >      > +  void (*destroy)(struct can_bus *bus);     // Clean the CAN
> >     controller specific resources.
> >      > +} can_bus;
> >      > +struct can_msg {
> >      > +  uint32_t id;                              // 32 bits to
> >     support extended id (29 bits).
> >      > +  uint32_t timestamp;
> >      > +  uint16_t flags;                           // RTR | BRS | EXT
> >      > +  uint16_t len;
> >      > +  uint8_t data[CAN_MSG_MAX_SIZE];           // For supporting
> >     data transfer up to 64 bytes.
> >      > +extern can_bus *can_bus_alloc_and_init(size_t size);
> >      > +extern int can_bus_init(can_bus *bus);
> >      > +extern rtems_status_code can_bus_register(can_bus *bus, const
> >     char *bus_path);
> >      > +extern int can_tx_done(struct can_bus *);
> >      > +extern int can_receive(struct can_bus *, struct can_msg *);
> >      > +extern uint16_t can_len_to_dlc(uint16_t len);
> >      > +extern uint16_t can_dlc_to_len(uint16_t dlc);
> >      > +extern rtems_status_code can_create_tx_buffers(struct can_bus
> *bus);
> >      > +extern rtems_status_code can_create_rx_buffers(struct can_bus
> *bus);
> >      > +extern bool can_tx_buf_isempty(struct can_bus *bus);
> >      > +extern struct can_msg *can_tx_get_data_buf(struct can_bus *bus);
> >      > +extern struct can_msg *can_tx_get_empty_buf(struct can_bus *bus);
> >      > +extern int take_sem(struct can_bus *);
> >      > +extern int give_sem(struct can_bus *);
> >      > +extern int can_create_sem(struct can_bus *bus);
> used
> >     Best regards
> >     Christian
> >      > +extern void can_print_canmsg(struct can_msg const *);
> >      > +#endif /* _DEV_CAN_CAN_H */
> >      > diff --git a/spec/build/cpukit/librtemscpu.yml
> >     b/spec/build/cpukit/librtemscpu.yml
> >      > index 31a68cf85a..b700935f82 100644
> >      > --- a/spec/build/cpukit/librtemscpu.yml
> >      > +++ b/spec/build/cpukit/librtemscpu.yml
> >      > @@ -50,6 +50,9 @@ install:
> >      >   - destination: ${BSP_INCLUDEDIR}/dev/spi
> >      >     source:
> >      >     - cpukit/include/dev/spi/spi.h
> >      > +- destination: ${BSP_INCLUDEDIR}/dev/can
> >      > +  source:
> >      > +  - cpukit/include/dev/can/can.h
> >      >   - destination: ${BSP_INCLUDEDIR}/linux
> >      >     source:
> >      >     - cpukit/include/linux/i2c-dev.h
> >      > @@ -530,6 +533,8 @@ source:
> >      >   - cpukit/dev/serial/sc16is752-spi.c
> >      >   - cpukit/dev/serial/sc16is752.c
> >      >   - cpukit/dev/spi/spi-bus.c
> >      > +- cpukit/dev/can/can.c
> >      > +- cpukit/dev/can/can-queue.c
> >      >   - cpukit/dtc/libfdt/fdt.c
> >      >   - cpukit/dtc/libfdt/fdt_addresses.c
> >      >   - cpukit/dtc/libfdt/fdt_empty_tree.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220719/2c993223/attachment-0001.htm>
