[PATCH] sptls04: Test an external TLS object
Sebastian Huber
Wed Jul 20 09:06:10 UTC 2022
spec/build/testsuites/sptests/sptls04.yml | 1 +
testsuites/sptests/sptls04/init.c | 9 +++--
testsuites/sptests/sptls04/sptls04.h | 41 +++++++++++++++++++++++
testsuites/sptests/sptls04/tls.c | 34 +++++++++++++++++++
4 files changed, 82 insertions(+), 3 deletions(-)
create mode 100644 testsuites/sptests/sptls04/sptls04.h
create mode 100644 testsuites/sptests/sptls04/tls.c
diff --git a/spec/build/testsuites/sptests/sptls04.yml b/spec/build/testsuites/sptests/sptls04.yml
index 8243fb81b9..ed2cf1c3e1 100644
--- a/spec/build/testsuites/sptests/sptls04.yml
+++ b/spec/build/testsuites/sptests/sptls04.yml
@@ -12,6 +12,7 @@ ldflags: []
links: []
source:
- testsuites/sptests/sptls04/init.c
+- testsuites/sptests/sptls04/tls.c
stlib: []
target: testsuites/sptests/sptls04.exe
type: build
diff --git a/testsuites/sptests/sptls04/init.c b/testsuites/sptests/sptls04/init.c
index fad919f8ac..79ab5a5a9a 100644
--- a/testsuites/sptests/sptls04/init.c
+++ b/testsuites/sptests/sptls04/init.c
@@ -9,7 +9,7 @@
* This test program runs also on GNU/Linux and FreeBSD. Use
- * cc init.c && ./a.out
+ * cc init.c tls.c && ./a.out
* to run it.
@@ -18,6 +18,8 @@
#include "config.h"
#endif
+#include "sptls04.h"
#ifdef __rtems__
#include <tmacros.h>
@@ -30,9 +32,9 @@
#endif /* __rtems__ */
-static __thread int i;
+static _Thread_local int i;
-static __thread int j;
+static _Thread_local int j;
static __attribute__((__constructor__)) void con(void)
@@ -43,6 +45,7 @@ static void test(void)
rtems_test_assert(i == 1);
rtems_test_assert(j == 0);
+ rtems_test_assert(k == 2);
#ifdef __rtems__
diff --git a/testsuites/sptests/sptls04/sptls04.h b/testsuites/sptests/sptls04/sptls04.h
new file mode 100644
index 0000000000..9aa737ecb0
--- /dev/null
+++ b/testsuites/sptests/sptls04/sptls04.h
@@ -0,0 +1,41 @@
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _SPTLS01_H
+#define _SPTLS01_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+extern _Thread_local int k;
+#ifdef __cplusplus
+#endif
+#endif /* _SPTLS01_H */
diff --git a/testsuites/sptests/sptls04/tls.c b/testsuites/sptests/sptls04/tls.c
index 0000000000..ce91518fd0
--- /dev/null
+++ b/testsuites/sptests/sptls04/tls.c
@@ -0,0 +1,34 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+_Thread_local int k = 2;
2.35.3
