[GCC 12 v3] RTEMS: Enable some features in libstdc++
Wed Jul 20 06:38:20 UTC 2022
Remove RTEMS support from crossconfig.m4 since this code is not used due to
"with_newlib" being "yes".
libstdc++-v3/ChangeLog:
	* configure: Regnerate.
	* configure.ac (newlib, *-rtems*): Enable TLS support for all RTEMS
	targets except bfin, lm32, mips, moxie, or1k, and v850.
	For all RTEMS targets, define HAVE_ALIGNED_ALLOC, HAVE_AT_QUICK_EXIT,
	HAVE_LINK, HAVE_QUICK_EXIT, HAVE_READLINK, HAVE_SETENV, HAVE_SLEEP,
	HAVE_SOCKATMARK, HAVE_STRERROR_L, HAVE_SYMLINK, HAVE_TRUNCATE, and HAVE_USLEEP.
	* crossconfig.m4 (*-rtems*): Remove.
v3:
Remove HAVE_POLL since this function is not always available.
 libstdc++-v3/configure      | 6010 +----------------------------------
 libstdc++-v3/configure.ac   |   24 +
 libstdc++-v3/crossconfig.m4 |    6 -
 3 files changed, 61 insertions(+), 5979 deletions(-)
diff --git a/libstdc++-v3/configure b/libstdc++-v3/configure
index 9b94fd71e42..1039c8addec 100755
--- a/libstdc++-v3/configure
+++ b/libstdc++-v3/configure
@@ -29237,6 +29237,43 @@ else
     $as_echo "#define HAVE_MEMALIGN 1" >>confdefs.h
+    case "${target}" in
+      *-rtems*)
+          bfin* | lm32* | mips* | moxie* | or1k* | v850*)
+            $as_echo "#define HAVE_TLS 1" >>confdefs.h
+        esac
+        $as_echo "#define HAVE_ALIGNED_ALLOC 1" >>confdefs.h
+        $as_echo "#define HAVE_AT_QUICK_EXIT 1" >>confdefs.h
+        $as_echo "#define HAVE_LINK 1" >>confdefs.h
+        $as_echo "#define HAVE_QUICK_EXIT 1" >>confdefs.h
+        $as_echo "#define HAVE_READLINK 1" >>confdefs.h
+        $as_echo "#define HAVE_SETENV 1" >>confdefs.h
+        $as_echo "#define HAVE_SLEEP 1" >>confdefs.h
+        $as_echo "#define HAVE_SOCKATMARK 1" >>confdefs.h
+        $as_echo "#define HAVE_STRERROR_L 1" >>confdefs.h
+        $as_echo "#define HAVE_SYMLINK 1" >>confdefs.h
+        $as_echo "#define HAVE_TRUNCATE 1" >>confdefs.h
+        $as_echo "#define HAVE_USLEEP 1" >>confdefs.h
+    esac
   elif test "x$with_headers" != "xno"; then
 # Base decisions on target environment.
@@ -60919,5979 +60956,6 @@ $as_echo "$ac_ld_relro" >&6; }
     $as_echo "#define HAVE_SINHL 1" >>confdefs.h
-  *-rtems*)
-  # All these tests are for C++; save the language and the compiler flags.
-  # The CXXFLAGS thing is suspicious, but based on similar bits previously
-  # found in GLIBCXX_CONFIGURE.
-  ac_ext=cpp
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-  ac_test_CXXFLAGS="${CXXFLAGS+set}"
-  ac_save_CXXFLAGS="$CXXFLAGS"
-  # Check for -ffunction-sections -fdata-sections
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for g++ that supports -ffunction-sections -fdata-sections" >&5
-$as_echo_n "checking for g++ that supports -ffunction-sections -fdata-sections... " >&6; }
-  CXXFLAGS='-g -Werror -ffunction-sections -fdata-sections'
-  cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h.  */
-int foo; void bar() { };
-int
-main ()
-  return 0;
-_ACEOF
-if ac_fn_cxx_try_compile "$LINENO"; then :
-  ac_fdsections=yes
-else
-  ac_fdsections=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-  if test "$ac_test_CXXFLAGS" = set; then
-    CXXFLAGS="$ac_save_CXXFLAGS"
-  else
-    # this is the suspicious part
-    CXXFLAGS=''
-  fi
-  if test x"$ac_fdsections" = x"yes"; then
-    SECTION_FLAGS='-ffunction-sections -fdata-sections'
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_fdsections" >&5
-$as_echo "$ac_fdsections" >&6; }
-  ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-  # If we're not using GNU ld, then there's no point in even trying these
-  # tests.  Check for that first.  We should have already tested for gld
-  # by now (in libtool), but require it now just to be safe...
-  test -z "$SECTION_LDFLAGS" && SECTION_LDFLAGS=''
-  test -z "$OPT_LDFLAGS" && OPT_LDFLAGS=''
-  # The name set by libtool depends on the version of libtool.  Shame on us
-  # for depending on an impl detail, but c'est la vie.  Older versions used
-  # ac_cv_prog_gnu_ld, but now it's lt_cv_prog_gnu_ld, and is copied back on
-  # top of with_gnu_ld (which is also set by --with-gnu-ld, so that actually
-  # makes sense).  We'll test with_gnu_ld everywhere else, so if that isn't
-  # set (hence we're using an older libtool), then set it.
-  if test x${with_gnu_ld+set} != xset; then
-    if test x${ac_cv_prog_gnu_ld+set} != xset; then
-      # We got through "ac_require(ac_prog_ld)" and still not set?  Huh?
-      with_gnu_ld=no
-    else
-      with_gnu_ld=$ac_cv_prog_gnu_ld
-    fi
-  fi
-  # Start by getting the version number.  I think the libtool test already
-  # does some of this, but throws away the result.
-  glibcxx_ld_is_gold=no
-  glibcxx_ld_is_mold=no
-  if test x"$with_gnu_ld" = x"yes"; then
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld version" >&5
-$as_echo_n "checking for ld version... " >&6; }
-    if $LD --version 2>/dev/null | grep 'GNU gold' >/dev/null 2>&1; then
-      glibcxx_ld_is_gold=yes
-    elif $LD --version 2>/dev/null | grep 'mold' >/dev/null 2>&1; then
-      glibcxx_ld_is_mold=yes
-    fi
-    ldver=`$LD --version 2>/dev/null |
-	   sed -e 's/[. ][0-9]\{8\}$//;s/.* \([^ ]\{1,\}\)$/\1/; q'`
-    glibcxx_gnu_ld_version=`echo $ldver | \
-	   $AWK -F. '{ if (NF<3) $3=0; print ($1*100+$2)*100+$3 }'`
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_gnu_ld_version" >&5
-$as_echo "$glibcxx_gnu_ld_version" >&6; }
-  fi
-  # Set --gc-sections.
-  glibcxx_have_gc_sections=no
-  if test "$glibcxx_ld_is_gold" = "yes" || test "$glibcxx_ld_is_mold" = "yes" ; then
-    if $LD --help 2>/dev/null | grep gc-sections >/dev/null 2>&1; then
-      glibcxx_have_gc_sections=yes
-    fi
-  else
-    glibcxx_gcsections_min_ld=21602
-    if test x"$with_gnu_ld" = x"yes" &&
-	test $glibcxx_gnu_ld_version -gt $glibcxx_gcsections_min_ld ; then
-    fi
-  fi
-  if test "$glibcxx_have_gc_sections" = "yes"; then
-    # Sufficiently young GNU ld it is!  Joy and bunny rabbits!
-    # NB: This flag only works reliably after 2.16.1. Configure tests
-    # for this are difficult, so hard wire a value that should work.
-    ac_test_CFLAGS="${CFLAGS+set}"
-    ac_save_CFLAGS="$CFLAGS"
-    CFLAGS='-Wl,--gc-sections'
-    # Check for -Wl,--gc-sections
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld that supports -Wl,--gc-sections" >&5
-$as_echo_n "checking for ld that supports -Wl,--gc-sections... " >&6; }
-    if test x$gcc_no_link = xyes; then
-  as_fn_error $? "Link tests are not allowed after GCC_NO_EXECUTABLES." "$LINENO" 5
-fi
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
- int one(void) { return 1; }
-     int two(void) { return 2; }
-int
-main ()
- two();
-  return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
-  ac_gcsections=yes
-else
-  ac_gcsections=no
-fi
-rm -f core conftest.err conftest.$ac_objext \
-    conftest$ac_exeext conftest.$ac_ext
-    if test "$ac_gcsections" = "yes"; then
-      rm -f conftest.c
-      touch conftest.c
-      if $CC -c conftest.c; then
-	if $LD --gc-sections -o conftest conftest.o 2>&1 | \
-	   grep "Warning: gc-sections option ignored" > /dev/null; then
-	  ac_gcsections=no
-	fi
-      fi
-      rm -f conftest.c conftest.o conftest
-    fi
-      SECTION_LDFLAGS="-Wl,--gc-sections $SECTION_LDFLAGS"
-    fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_gcsections" >&5
-$as_echo "$ac_gcsections" >&6; }
-    if test "$ac_test_CFLAGS" = set; then
-      CFLAGS="$ac_save_CFLAGS"
-    else
-      CFLAGS=''
-    fi
-  fi
-  # Set -z,relro.
-  # Note this is only for shared objects.
-  ac_ld_relro=no
-    # cygwin and mingw uses PE, which has no ELF relro support,
-    # multi target ld may confuse configure machinery
-    case "$host" in
-    *-*-cygwin*)
-    *-*-mingw*)
-      { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld that supports -Wl,-z,relro" >&5
-$as_echo_n "checking for ld that supports -Wl,-z,relro... " >&6; }
-      cxx_z_relo=`$LD -v --help 2>/dev/null | grep "z relro"`
-      if test -n "$cxx_z_relo"; then
-        OPT_LDFLAGS="-Wl,-z,relro"
-        ac_ld_relro=yes
-      fi
-      { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ld_relro" >&5
-$as_echo "$ac_ld_relro" >&6; }
-    esac
-  fi
-  # Set linker optimization flags.
-    OPT_LDFLAGS="-Wl,-O1 $OPT_LDFLAGS"
-  fi
-  CXXFLAGS='-fno-builtin -D_GNU_SOURCE'
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sin in -lm" >&5
-$as_echo_n "checking for sin in -lm... " >&6; }
-if ${ac_cv_lib_m_sin+:} false; then :
-  $as_echo_n "(cached) " >&6
-else
-  ac_check_lib_save_LIBS=$LIBS
-LIBS="-lm  $LIBS"
-if test x$gcc_no_link = xyes; then
-fi
-/* Override any GCC internal prototype to avoid an error.
-   Use char because int might match the return type of a GCC
-   builtin and then its argument prototype would still apply.  */
-#ifdef __cplusplus
-extern "C"
-#endif
-char sin ();
-int
-main ()
-return sin ();
-  return 0;
-_ACEOF
-  ac_cv_lib_m_sin=yes
-else
-  ac_cv_lib_m_sin=no
-fi
-LIBS=$ac_check_lib_save_LIBS
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_m_sin" >&5
-$as_echo "$ac_cv_lib_m_sin" >&6; }
-if test "x$ac_cv_lib_m_sin" = xyes; then :
-  libm="-lm"
-fi
-  ac_save_LIBS="$LIBS"
-  LIBS="$LIBS $libm"
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isinf declaration" >&5
-$as_echo_n "checking for isinf declaration... " >&6; }
-  if test x${glibcxx_cv_func_isinf_use+set} != xset; then
-    if ${glibcxx_cv_func_isinf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #ifdef HAVE_IEEEFP_H
-		      #include <ieeefp.h>
-		      #endif
-int
-main ()
- isinf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isinf_use=yes
-else
-  glibcxx_cv_func_isinf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isinf_use" >&5
-$as_echo "$glibcxx_cv_func_isinf_use" >&6; }
-  if test x$glibcxx_cv_func_isinf_use = x"yes"; then
-    for ac_func in isinf
-do :
-  ac_fn_c_check_func "$LINENO" "isinf" "ac_cv_func_isinf"
-if test "x$ac_cv_func_isinf" = xyes; then :
-  cat >>confdefs.h <<_ACEOF
-#define HAVE_ISINF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isinf declaration" >&5
-$as_echo_n "checking for _isinf declaration... " >&6; }
-  if test x${glibcxx_cv_func__isinf_use+set} != xset; then
-    if ${glibcxx_cv_func__isinf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isinf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isinf_use=yes
-else
-  glibcxx_cv_func__isinf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isinf_use" >&5
-$as_echo "$glibcxx_cv_func__isinf_use" >&6; }
-    if test x$glibcxx_cv_func__isinf_use = x"yes"; then
-      for ac_func in _isinf
-do :
-  ac_fn_c_check_func "$LINENO" "_isinf" "ac_cv_func__isinf"
-if test "x$ac_cv_func__isinf" = xyes; then :
-#define HAVE__ISINF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isnan declaration" >&5
-$as_echo_n "checking for isnan declaration... " >&6; }
-  if test x${glibcxx_cv_func_isnan_use+set} != xset; then
-    if ${glibcxx_cv_func_isnan_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- isnan(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isnan_use=yes
-else
-  glibcxx_cv_func_isnan_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isnan_use" >&5
-$as_echo "$glibcxx_cv_func_isnan_use" >&6; }
-  if test x$glibcxx_cv_func_isnan_use = x"yes"; then
-    for ac_func in isnan
-do :
-  ac_fn_c_check_func "$LINENO" "isnan" "ac_cv_func_isnan"
-if test "x$ac_cv_func_isnan" = xyes; then :
-#define HAVE_ISNAN 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isnan declaration" >&5
-$as_echo_n "checking for _isnan declaration... " >&6; }
-  if test x${glibcxx_cv_func__isnan_use+set} != xset; then
-    if ${glibcxx_cv_func__isnan_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isnan(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isnan_use=yes
-else
-  glibcxx_cv_func__isnan_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isnan_use" >&5
-$as_echo "$glibcxx_cv_func__isnan_use" >&6; }
-    if test x$glibcxx_cv_func__isnan_use = x"yes"; then
-      for ac_func in _isnan
-do :
-  ac_fn_c_check_func "$LINENO" "_isnan" "ac_cv_func__isnan"
-if test "x$ac_cv_func__isnan" = xyes; then :
-#define HAVE__ISNAN 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for finite declaration" >&5
-$as_echo_n "checking for finite declaration... " >&6; }
-  if test x${glibcxx_cv_func_finite_use+set} != xset; then
-    if ${glibcxx_cv_func_finite_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- finite(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_finite_use=yes
-else
-  glibcxx_cv_func_finite_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_finite_use" >&5
-$as_echo "$glibcxx_cv_func_finite_use" >&6; }
-  if test x$glibcxx_cv_func_finite_use = x"yes"; then
-    for ac_func in finite
-do :
-  ac_fn_c_check_func "$LINENO" "finite" "ac_cv_func_finite"
-if test "x$ac_cv_func_finite" = xyes; then :
-#define HAVE_FINITE 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _finite declaration" >&5
-$as_echo_n "checking for _finite declaration... " >&6; }
-  if test x${glibcxx_cv_func__finite_use+set} != xset; then
-    if ${glibcxx_cv_func__finite_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _finite(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__finite_use=yes
-else
-  glibcxx_cv_func__finite_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__finite_use" >&5
-$as_echo "$glibcxx_cv_func__finite_use" >&6; }
-    if test x$glibcxx_cv_func__finite_use = x"yes"; then
-      for ac_func in _finite
-do :
-  ac_fn_c_check_func "$LINENO" "_finite" "ac_cv_func__finite"
-if test "x$ac_cv_func__finite" = xyes; then :
-#define HAVE__FINITE 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sincos declaration" >&5
-$as_echo_n "checking for sincos declaration... " >&6; }
-  if test x${glibcxx_cv_func_sincos_use+set} != xset; then
-    if ${glibcxx_cv_func_sincos_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- sincos(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_sincos_use=yes
-else
-  glibcxx_cv_func_sincos_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_sincos_use" >&5
-$as_echo "$glibcxx_cv_func_sincos_use" >&6; }
-  if test x$glibcxx_cv_func_sincos_use = x"yes"; then
-    for ac_func in sincos
-do :
-  ac_fn_c_check_func "$LINENO" "sincos" "ac_cv_func_sincos"
-if test "x$ac_cv_func_sincos" = xyes; then :
-#define HAVE_SINCOS 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _sincos declaration" >&5
-$as_echo_n "checking for _sincos declaration... " >&6; }
-  if test x${glibcxx_cv_func__sincos_use+set} != xset; then
-    if ${glibcxx_cv_func__sincos_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _sincos(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__sincos_use=yes
-else
-  glibcxx_cv_func__sincos_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__sincos_use" >&5
-$as_echo "$glibcxx_cv_func__sincos_use" >&6; }
-    if test x$glibcxx_cv_func__sincos_use = x"yes"; then
-      for ac_func in _sincos
-do :
-  ac_fn_c_check_func "$LINENO" "_sincos" "ac_cv_func__sincos"
-if test "x$ac_cv_func__sincos" = xyes; then :
-#define HAVE__SINCOS 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for fpclass declaration" >&5
-$as_echo_n "checking for fpclass declaration... " >&6; }
-  if test x${glibcxx_cv_func_fpclass_use+set} != xset; then
-    if ${glibcxx_cv_func_fpclass_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- fpclass(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_fpclass_use=yes
-else
-  glibcxx_cv_func_fpclass_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_fpclass_use" >&5
-$as_echo "$glibcxx_cv_func_fpclass_use" >&6; }
-  if test x$glibcxx_cv_func_fpclass_use = x"yes"; then
-    for ac_func in fpclass
-do :
-  ac_fn_c_check_func "$LINENO" "fpclass" "ac_cv_func_fpclass"
-if test "x$ac_cv_func_fpclass" = xyes; then :
-#define HAVE_FPCLASS 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _fpclass declaration" >&5
-$as_echo_n "checking for _fpclass declaration... " >&6; }
-  if test x${glibcxx_cv_func__fpclass_use+set} != xset; then
-    if ${glibcxx_cv_func__fpclass_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _fpclass(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__fpclass_use=yes
-else
-  glibcxx_cv_func__fpclass_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__fpclass_use" >&5
-$as_echo "$glibcxx_cv_func__fpclass_use" >&6; }
-    if test x$glibcxx_cv_func__fpclass_use = x"yes"; then
-      for ac_func in _fpclass
-do :
-  ac_fn_c_check_func "$LINENO" "_fpclass" "ac_cv_func__fpclass"
-if test "x$ac_cv_func__fpclass" = xyes; then :
-#define HAVE__FPCLASS 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for qfpclass declaration" >&5
-$as_echo_n "checking for qfpclass declaration... " >&6; }
-  if test x${glibcxx_cv_func_qfpclass_use+set} != xset; then
-    if ${glibcxx_cv_func_qfpclass_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- qfpclass(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_qfpclass_use=yes
-else
-  glibcxx_cv_func_qfpclass_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_qfpclass_use" >&5
-$as_echo "$glibcxx_cv_func_qfpclass_use" >&6; }
-  if test x$glibcxx_cv_func_qfpclass_use = x"yes"; then
-    for ac_func in qfpclass
-do :
-  ac_fn_c_check_func "$LINENO" "qfpclass" "ac_cv_func_qfpclass"
-if test "x$ac_cv_func_qfpclass" = xyes; then :
-#define HAVE_QFPCLASS 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _qfpclass declaration" >&5
-$as_echo_n "checking for _qfpclass declaration... " >&6; }
-  if test x${glibcxx_cv_func__qfpclass_use+set} != xset; then
-    if ${glibcxx_cv_func__qfpclass_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _qfpclass(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__qfpclass_use=yes
-else
-  glibcxx_cv_func__qfpclass_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__qfpclass_use" >&5
-$as_echo "$glibcxx_cv_func__qfpclass_use" >&6; }
-    if test x$glibcxx_cv_func__qfpclass_use = x"yes"; then
-      for ac_func in _qfpclass
-do :
-  ac_fn_c_check_func "$LINENO" "_qfpclass" "ac_cv_func__qfpclass"
-if test "x$ac_cv_func__qfpclass" = xyes; then :
-#define HAVE__QFPCLASS 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for hypot declaration" >&5
-$as_echo_n "checking for hypot declaration... " >&6; }
-  if test x${glibcxx_cv_func_hypot_use+set} != xset; then
-    if ${glibcxx_cv_func_hypot_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- hypot(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_hypot_use=yes
-else
-  glibcxx_cv_func_hypot_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_hypot_use" >&5
-$as_echo "$glibcxx_cv_func_hypot_use" >&6; }
-  if test x$glibcxx_cv_func_hypot_use = x"yes"; then
-    for ac_func in hypot
-do :
-  ac_fn_c_check_func "$LINENO" "hypot" "ac_cv_func_hypot"
-if test "x$ac_cv_func_hypot" = xyes; then :
-#define HAVE_HYPOT 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _hypot declaration" >&5
-$as_echo_n "checking for _hypot declaration... " >&6; }
-  if test x${glibcxx_cv_func__hypot_use+set} != xset; then
-    if ${glibcxx_cv_func__hypot_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _hypot(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__hypot_use=yes
-else
-  glibcxx_cv_func__hypot_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__hypot_use" >&5
-$as_echo "$glibcxx_cv_func__hypot_use" >&6; }
-    if test x$glibcxx_cv_func__hypot_use = x"yes"; then
-      for ac_func in _hypot
-do :
-  ac_fn_c_check_func "$LINENO" "_hypot" "ac_cv_func__hypot"
-if test "x$ac_cv_func__hypot" = xyes; then :
-#define HAVE__HYPOT 1
-_ACEOF
-fi
-done
-    fi
-  fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for float trig functions" >&5
-$as_echo_n "checking for float trig functions... " >&6; }
-  if ${glibcxx_cv_func_float_trig_use+:} false; then :
-else
-    ac_ext=cpp
-#include <math.h>
-int
-main ()
-acosf (0); asinf (0); atanf (0); cosf (0); sinf (0); tanf (0); coshf (0); sinhf (0); tanhf (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_float_trig_use=yes
-else
-  glibcxx_cv_func_float_trig_use=no
-fi
-    ac_ext=c
-fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_float_trig_use" >&5
-$as_echo "$glibcxx_cv_func_float_trig_use" >&6; }
-  if test x$glibcxx_cv_func_float_trig_use = x"yes"; then
-    for ac_func in acosf asinf atanf cosf sinf tanf coshf sinhf tanhf
-do :
-  as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
-ac_fn_c_check_func "$LINENO" "$ac_func" "$as_ac_var"
-if eval test \"x\$"$as_ac_var"\" = x"yes"; then :
-#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-  else
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _float trig functions" >&5
-$as_echo_n "checking for _float trig functions... " >&6; }
-    if ${glibcxx_cv_func__float_trig_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
-_acosf (0); _asinf (0); _atanf (0); _cosf (0); _sinf (0); _tanf (0); _coshf (0); _sinhf (0); _tanhf (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__float_trig_use=yes
-else
-  glibcxx_cv_func__float_trig_use=no
-fi
-      ac_ext=c
-fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__float_trig_use" >&5
-$as_echo "$glibcxx_cv_func__float_trig_use" >&6; }
-    if test x$glibcxx_cv_func__float_trig_use = x"yes"; then
-      for ac_func in _acosf _asinf _atanf _cosf _sinf _tanf _coshf _sinhf _tanhf
-do :
-_ACEOF
-fi
-done
-    fi
-  fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for float round functions" >&5
-$as_echo_n "checking for float round functions... " >&6; }
-  if ${glibcxx_cv_func_float_round_use+:} false; then :
-else
-    ac_ext=cpp
-#include <math.h>
-int
-main ()
-ceilf (0); floorf (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_float_round_use=yes
-else
-  glibcxx_cv_func_float_round_use=no
-fi
-    ac_ext=c
-fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_float_round_use" >&5
-$as_echo "$glibcxx_cv_func_float_round_use" >&6; }
-  if test x$glibcxx_cv_func_float_round_use = x"yes"; then
-    for ac_func in ceilf floorf
-do :
-_ACEOF
-fi
-done
-  else
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _float round functions" >&5
-$as_echo_n "checking for _float round functions... " >&6; }
-    if ${glibcxx_cv_func__float_round_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
-_ceilf (0); _floorf (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__float_round_use=yes
-else
-  glibcxx_cv_func__float_round_use=no
-fi
-      ac_ext=c
-fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__float_round_use" >&5
-$as_echo "$glibcxx_cv_func__float_round_use" >&6; }
-    if test x$glibcxx_cv_func__float_round_use = x"yes"; then
-      for ac_func in _ceilf _floorf
-do :
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for expf declaration" >&5
-$as_echo_n "checking for expf declaration... " >&6; }
-  if test x${glibcxx_cv_func_expf_use+set} != xset; then
-    if ${glibcxx_cv_func_expf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- expf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_expf_use=yes
-else
-  glibcxx_cv_func_expf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_expf_use" >&5
-$as_echo "$glibcxx_cv_func_expf_use" >&6; }
-  if test x$glibcxx_cv_func_expf_use = x"yes"; then
-    for ac_func in expf
-do :
-  ac_fn_c_check_func "$LINENO" "expf" "ac_cv_func_expf"
-if test "x$ac_cv_func_expf" = xyes; then :
-#define HAVE_EXPF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _expf declaration" >&5
-$as_echo_n "checking for _expf declaration... " >&6; }
-  if test x${glibcxx_cv_func__expf_use+set} != xset; then
-    if ${glibcxx_cv_func__expf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _expf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__expf_use=yes
-else
-  glibcxx_cv_func__expf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__expf_use" >&5
-$as_echo "$glibcxx_cv_func__expf_use" >&6; }
-    if test x$glibcxx_cv_func__expf_use = x"yes"; then
-      for ac_func in _expf
-do :
-  ac_fn_c_check_func "$LINENO" "_expf" "ac_cv_func__expf"
-if test "x$ac_cv_func__expf" = xyes; then :
-#define HAVE__EXPF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isnanf declaration" >&5
-$as_echo_n "checking for isnanf declaration... " >&6; }
-  if test x${glibcxx_cv_func_isnanf_use+set} != xset; then
-    if ${glibcxx_cv_func_isnanf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- isnanf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isnanf_use=yes
-else
-  glibcxx_cv_func_isnanf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isnanf_use" >&5
-$as_echo "$glibcxx_cv_func_isnanf_use" >&6; }
-  if test x$glibcxx_cv_func_isnanf_use = x"yes"; then
-    for ac_func in isnanf
-do :
-  ac_fn_c_check_func "$LINENO" "isnanf" "ac_cv_func_isnanf"
-if test "x$ac_cv_func_isnanf" = xyes; then :
-#define HAVE_ISNANF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isnanf declaration" >&5
-$as_echo_n "checking for _isnanf declaration... " >&6; }
-  if test x${glibcxx_cv_func__isnanf_use+set} != xset; then
-    if ${glibcxx_cv_func__isnanf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isnanf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isnanf_use=yes
-else
-  glibcxx_cv_func__isnanf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isnanf_use" >&5
-$as_echo "$glibcxx_cv_func__isnanf_use" >&6; }
-    if test x$glibcxx_cv_func__isnanf_use = x"yes"; then
-      for ac_func in _isnanf
-do :
-  ac_fn_c_check_func "$LINENO" "_isnanf" "ac_cv_func__isnanf"
-if test "x$ac_cv_func__isnanf" = xyes; then :
-#define HAVE__ISNANF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isinff declaration" >&5
-$as_echo_n "checking for isinff declaration... " >&6; }
-  if test x${glibcxx_cv_func_isinff_use+set} != xset; then
-    if ${glibcxx_cv_func_isinff_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- isinff(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isinff_use=yes
-else
-  glibcxx_cv_func_isinff_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isinff_use" >&5
-$as_echo "$glibcxx_cv_func_isinff_use" >&6; }
-  if test x$glibcxx_cv_func_isinff_use = x"yes"; then
-    for ac_func in isinff
-do :
-  ac_fn_c_check_func "$LINENO" "isinff" "ac_cv_func_isinff"
-if test "x$ac_cv_func_isinff" = xyes; then :
-#define HAVE_ISINFF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isinff declaration" >&5
-$as_echo_n "checking for _isinff declaration... " >&6; }
-  if test x${glibcxx_cv_func__isinff_use+set} != xset; then
-    if ${glibcxx_cv_func__isinff_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isinff(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isinff_use=yes
-else
-  glibcxx_cv_func__isinff_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isinff_use" >&5
-$as_echo "$glibcxx_cv_func__isinff_use" >&6; }
-    if test x$glibcxx_cv_func__isinff_use = x"yes"; then
-      for ac_func in _isinff
-do :
-  ac_fn_c_check_func "$LINENO" "_isinff" "ac_cv_func__isinff"
-if test "x$ac_cv_func__isinff" = xyes; then :
-#define HAVE__ISINFF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for atan2f declaration" >&5
-$as_echo_n "checking for atan2f declaration... " >&6; }
-  if test x${glibcxx_cv_func_atan2f_use+set} != xset; then
-    if ${glibcxx_cv_func_atan2f_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- atan2f(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_atan2f_use=yes
-else
-  glibcxx_cv_func_atan2f_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_atan2f_use" >&5
-$as_echo "$glibcxx_cv_func_atan2f_use" >&6; }
-  if test x$glibcxx_cv_func_atan2f_use = x"yes"; then
-    for ac_func in atan2f
-do :
-  ac_fn_c_check_func "$LINENO" "atan2f" "ac_cv_func_atan2f"
-if test "x$ac_cv_func_atan2f" = xyes; then :
-#define HAVE_ATAN2F 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _atan2f declaration" >&5
-$as_echo_n "checking for _atan2f declaration... " >&6; }
-  if test x${glibcxx_cv_func__atan2f_use+set} != xset; then
-    if ${glibcxx_cv_func__atan2f_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _atan2f(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__atan2f_use=yes
-else
-  glibcxx_cv_func__atan2f_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__atan2f_use" >&5
-$as_echo "$glibcxx_cv_func__atan2f_use" >&6; }
-    if test x$glibcxx_cv_func__atan2f_use = x"yes"; then
-      for ac_func in _atan2f
-do :
-  ac_fn_c_check_func "$LINENO" "_atan2f" "ac_cv_func__atan2f"
-if test "x$ac_cv_func__atan2f" = xyes; then :
-#define HAVE__ATAN2F 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for fabsf declaration" >&5
-$as_echo_n "checking for fabsf declaration... " >&6; }
-  if test x${glibcxx_cv_func_fabsf_use+set} != xset; then
-    if ${glibcxx_cv_func_fabsf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- fabsf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_fabsf_use=yes
-else
-  glibcxx_cv_func_fabsf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_fabsf_use" >&5
-$as_echo "$glibcxx_cv_func_fabsf_use" >&6; }
-  if test x$glibcxx_cv_func_fabsf_use = x"yes"; then
-    for ac_func in fabsf
-do :
-  ac_fn_c_check_func "$LINENO" "fabsf" "ac_cv_func_fabsf"
-if test "x$ac_cv_func_fabsf" = xyes; then :
-#define HAVE_FABSF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _fabsf declaration" >&5
-$as_echo_n "checking for _fabsf declaration... " >&6; }
-  if test x${glibcxx_cv_func__fabsf_use+set} != xset; then
-    if ${glibcxx_cv_func__fabsf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _fabsf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__fabsf_use=yes
-else
-  glibcxx_cv_func__fabsf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__fabsf_use" >&5
-$as_echo "$glibcxx_cv_func__fabsf_use" >&6; }
-    if test x$glibcxx_cv_func__fabsf_use = x"yes"; then
-      for ac_func in _fabsf
-do :
-  ac_fn_c_check_func "$LINENO" "_fabsf" "ac_cv_func__fabsf"
-if test "x$ac_cv_func__fabsf" = xyes; then :
-#define HAVE__FABSF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for fmodf declaration" >&5
-$as_echo_n "checking for fmodf declaration... " >&6; }
-  if test x${glibcxx_cv_func_fmodf_use+set} != xset; then
-    if ${glibcxx_cv_func_fmodf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- fmodf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_fmodf_use=yes
-else
-  glibcxx_cv_func_fmodf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_fmodf_use" >&5
-$as_echo "$glibcxx_cv_func_fmodf_use" >&6; }
-  if test x$glibcxx_cv_func_fmodf_use = x"yes"; then
-    for ac_func in fmodf
-do :
-  ac_fn_c_check_func "$LINENO" "fmodf" "ac_cv_func_fmodf"
-if test "x$ac_cv_func_fmodf" = xyes; then :
-#define HAVE_FMODF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _fmodf declaration" >&5
-$as_echo_n "checking for _fmodf declaration... " >&6; }
-  if test x${glibcxx_cv_func__fmodf_use+set} != xset; then
-    if ${glibcxx_cv_func__fmodf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _fmodf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__fmodf_use=yes
-else
-  glibcxx_cv_func__fmodf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__fmodf_use" >&5
-$as_echo "$glibcxx_cv_func__fmodf_use" >&6; }
-    if test x$glibcxx_cv_func__fmodf_use = x"yes"; then
-      for ac_func in _fmodf
-do :
-  ac_fn_c_check_func "$LINENO" "_fmodf" "ac_cv_func__fmodf"
-if test "x$ac_cv_func__fmodf" = xyes; then :
-#define HAVE__FMODF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for frexpf declaration" >&5
-$as_echo_n "checking for frexpf declaration... " >&6; }
-  if test x${glibcxx_cv_func_frexpf_use+set} != xset; then
-    if ${glibcxx_cv_func_frexpf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- frexpf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_frexpf_use=yes
-else
-  glibcxx_cv_func_frexpf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_frexpf_use" >&5
-$as_echo "$glibcxx_cv_func_frexpf_use" >&6; }
-  if test x$glibcxx_cv_func_frexpf_use = x"yes"; then
-    for ac_func in frexpf
-do :
-  ac_fn_c_check_func "$LINENO" "frexpf" "ac_cv_func_frexpf"
-if test "x$ac_cv_func_frexpf" = xyes; then :
-#define HAVE_FREXPF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _frexpf declaration" >&5
-$as_echo_n "checking for _frexpf declaration... " >&6; }
-  if test x${glibcxx_cv_func__frexpf_use+set} != xset; then
-    if ${glibcxx_cv_func__frexpf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _frexpf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__frexpf_use=yes
-else
-  glibcxx_cv_func__frexpf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__frexpf_use" >&5
-$as_echo "$glibcxx_cv_func__frexpf_use" >&6; }
-    if test x$glibcxx_cv_func__frexpf_use = x"yes"; then
-      for ac_func in _frexpf
-do :
-  ac_fn_c_check_func "$LINENO" "_frexpf" "ac_cv_func__frexpf"
-if test "x$ac_cv_func__frexpf" = xyes; then :
-#define HAVE__FREXPF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for hypotf declaration" >&5
-$as_echo_n "checking for hypotf declaration... " >&6; }
-  if test x${glibcxx_cv_func_hypotf_use+set} != xset; then
-    if ${glibcxx_cv_func_hypotf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- hypotf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_hypotf_use=yes
-else
-  glibcxx_cv_func_hypotf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_hypotf_use" >&5
-$as_echo "$glibcxx_cv_func_hypotf_use" >&6; }
-  if test x$glibcxx_cv_func_hypotf_use = x"yes"; then
-    for ac_func in hypotf
-do :
-  ac_fn_c_check_func "$LINENO" "hypotf" "ac_cv_func_hypotf"
-if test "x$ac_cv_func_hypotf" = xyes; then :
-#define HAVE_HYPOTF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _hypotf declaration" >&5
-$as_echo_n "checking for _hypotf declaration... " >&6; }
-  if test x${glibcxx_cv_func__hypotf_use+set} != xset; then
-    if ${glibcxx_cv_func__hypotf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _hypotf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__hypotf_use=yes
-else
-  glibcxx_cv_func__hypotf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__hypotf_use" >&5
-$as_echo "$glibcxx_cv_func__hypotf_use" >&6; }
-    if test x$glibcxx_cv_func__hypotf_use = x"yes"; then
-      for ac_func in _hypotf
-do :
-  ac_fn_c_check_func "$LINENO" "_hypotf" "ac_cv_func__hypotf"
-if test "x$ac_cv_func__hypotf" = xyes; then :
-#define HAVE__HYPOTF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ldexpf declaration" >&5
-$as_echo_n "checking for ldexpf declaration... " >&6; }
-  if test x${glibcxx_cv_func_ldexpf_use+set} != xset; then
-    if ${glibcxx_cv_func_ldexpf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- ldexpf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_ldexpf_use=yes
-else
-  glibcxx_cv_func_ldexpf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_ldexpf_use" >&5
-$as_echo "$glibcxx_cv_func_ldexpf_use" >&6; }
-  if test x$glibcxx_cv_func_ldexpf_use = x"yes"; then
-    for ac_func in ldexpf
-do :
-  ac_fn_c_check_func "$LINENO" "ldexpf" "ac_cv_func_ldexpf"
-if test "x$ac_cv_func_ldexpf" = xyes; then :
-#define HAVE_LDEXPF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _ldexpf declaration" >&5
-$as_echo_n "checking for _ldexpf declaration... " >&6; }
-  if test x${glibcxx_cv_func__ldexpf_use+set} != xset; then
-    if ${glibcxx_cv_func__ldexpf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _ldexpf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__ldexpf_use=yes
-else
-  glibcxx_cv_func__ldexpf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__ldexpf_use" >&5
-$as_echo "$glibcxx_cv_func__ldexpf_use" >&6; }
-    if test x$glibcxx_cv_func__ldexpf_use = x"yes"; then
-      for ac_func in _ldexpf
-do :
-  ac_fn_c_check_func "$LINENO" "_ldexpf" "ac_cv_func__ldexpf"
-if test "x$ac_cv_func__ldexpf" = xyes; then :
-#define HAVE__LDEXPF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for logf declaration" >&5
-$as_echo_n "checking for logf declaration... " >&6; }
-  if test x${glibcxx_cv_func_logf_use+set} != xset; then
-    if ${glibcxx_cv_func_logf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- logf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_logf_use=yes
-else
-  glibcxx_cv_func_logf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_logf_use" >&5
-$as_echo "$glibcxx_cv_func_logf_use" >&6; }
-  if test x$glibcxx_cv_func_logf_use = x"yes"; then
-    for ac_func in logf
-do :
-  ac_fn_c_check_func "$LINENO" "logf" "ac_cv_func_logf"
-if test "x$ac_cv_func_logf" = xyes; then :
-#define HAVE_LOGF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _logf declaration" >&5
-$as_echo_n "checking for _logf declaration... " >&6; }
-  if test x${glibcxx_cv_func__logf_use+set} != xset; then
-    if ${glibcxx_cv_func__logf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _logf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__logf_use=yes
-else
-  glibcxx_cv_func__logf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__logf_use" >&5
-$as_echo "$glibcxx_cv_func__logf_use" >&6; }
-    if test x$glibcxx_cv_func__logf_use = x"yes"; then
-      for ac_func in _logf
-do :
-  ac_fn_c_check_func "$LINENO" "_logf" "ac_cv_func__logf"
-if test "x$ac_cv_func__logf" = xyes; then :
-#define HAVE__LOGF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for log10f declaration" >&5
-$as_echo_n "checking for log10f declaration... " >&6; }
-  if test x${glibcxx_cv_func_log10f_use+set} != xset; then
-    if ${glibcxx_cv_func_log10f_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- log10f(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_log10f_use=yes
-else
-  glibcxx_cv_func_log10f_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_log10f_use" >&5
-$as_echo "$glibcxx_cv_func_log10f_use" >&6; }
-  if test x$glibcxx_cv_func_log10f_use = x"yes"; then
-    for ac_func in log10f
-do :
-  ac_fn_c_check_func "$LINENO" "log10f" "ac_cv_func_log10f"
-if test "x$ac_cv_func_log10f" = xyes; then :
-#define HAVE_LOG10F 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _log10f declaration" >&5
-$as_echo_n "checking for _log10f declaration... " >&6; }
-  if test x${glibcxx_cv_func__log10f_use+set} != xset; then
-    if ${glibcxx_cv_func__log10f_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _log10f(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__log10f_use=yes
-else
-  glibcxx_cv_func__log10f_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__log10f_use" >&5
-$as_echo "$glibcxx_cv_func__log10f_use" >&6; }
-    if test x$glibcxx_cv_func__log10f_use = x"yes"; then
-      for ac_func in _log10f
-do :
-  ac_fn_c_check_func "$LINENO" "_log10f" "ac_cv_func__log10f"
-if test "x$ac_cv_func__log10f" = xyes; then :
-#define HAVE__LOG10F 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for modff declaration" >&5
-$as_echo_n "checking for modff declaration... " >&6; }
-  if test x${glibcxx_cv_func_modff_use+set} != xset; then
-    if ${glibcxx_cv_func_modff_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- modff(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_modff_use=yes
-else
-  glibcxx_cv_func_modff_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_modff_use" >&5
-$as_echo "$glibcxx_cv_func_modff_use" >&6; }
-  if test x$glibcxx_cv_func_modff_use = x"yes"; then
-    for ac_func in modff
-do :
-  ac_fn_c_check_func "$LINENO" "modff" "ac_cv_func_modff"
-if test "x$ac_cv_func_modff" = xyes; then :
-#define HAVE_MODFF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _modff declaration" >&5
-$as_echo_n "checking for _modff declaration... " >&6; }
-  if test x${glibcxx_cv_func__modff_use+set} != xset; then
-    if ${glibcxx_cv_func__modff_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _modff(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__modff_use=yes
-else
-  glibcxx_cv_func__modff_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__modff_use" >&5
-$as_echo "$glibcxx_cv_func__modff_use" >&6; }
-    if test x$glibcxx_cv_func__modff_use = x"yes"; then
-      for ac_func in _modff
-do :
-  ac_fn_c_check_func "$LINENO" "_modff" "ac_cv_func__modff"
-if test "x$ac_cv_func__modff" = xyes; then :
-#define HAVE__MODFF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for modf declaration" >&5
-$as_echo_n "checking for modf declaration... " >&6; }
-  if test x${glibcxx_cv_func_modf_use+set} != xset; then
-    if ${glibcxx_cv_func_modf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- modf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_modf_use=yes
-else
-  glibcxx_cv_func_modf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_modf_use" >&5
-$as_echo "$glibcxx_cv_func_modf_use" >&6; }
-  if test x$glibcxx_cv_func_modf_use = x"yes"; then
-do :
-  ac_fn_c_check_func "$LINENO" "modf" "ac_cv_func_modf"
-if test "x$ac_cv_func_modf" = xyes; then :
-#define HAVE_MODF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _modf declaration" >&5
-$as_echo_n "checking for _modf declaration... " >&6; }
-  if test x${glibcxx_cv_func__modf_use+set} != xset; then
-    if ${glibcxx_cv_func__modf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _modf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__modf_use=yes
-else
-  glibcxx_cv_func__modf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__modf_use" >&5
-$as_echo "$glibcxx_cv_func__modf_use" >&6; }
-    if test x$glibcxx_cv_func__modf_use = x"yes"; then
-do :
-  ac_fn_c_check_func "$LINENO" "_modf" "ac_cv_func__modf"
-if test "x$ac_cv_func__modf" = xyes; then :
-#define HAVE__MODF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for powf declaration" >&5
-$as_echo_n "checking for powf declaration... " >&6; }
-  if test x${glibcxx_cv_func_powf_use+set} != xset; then
-    if ${glibcxx_cv_func_powf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- powf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_powf_use=yes
-else
-  glibcxx_cv_func_powf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_powf_use" >&5
-$as_echo "$glibcxx_cv_func_powf_use" >&6; }
-  if test x$glibcxx_cv_func_powf_use = x"yes"; then
-    for ac_func in powf
-do :
-  ac_fn_c_check_func "$LINENO" "powf" "ac_cv_func_powf"
-if test "x$ac_cv_func_powf" = xyes; then :
-#define HAVE_POWF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _powf declaration" >&5
-$as_echo_n "checking for _powf declaration... " >&6; }
-  if test x${glibcxx_cv_func__powf_use+set} != xset; then
-    if ${glibcxx_cv_func__powf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _powf(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__powf_use=yes
-else
-  glibcxx_cv_func__powf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__powf_use" >&5
-$as_echo "$glibcxx_cv_func__powf_use" >&6; }
-    if test x$glibcxx_cv_func__powf_use = x"yes"; then
-      for ac_func in _powf
-do :
-  ac_fn_c_check_func "$LINENO" "_powf" "ac_cv_func__powf"
-if test "x$ac_cv_func__powf" = xyes; then :
-#define HAVE__POWF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sqrtf declaration" >&5
-$as_echo_n "checking for sqrtf declaration... " >&6; }
-  if test x${glibcxx_cv_func_sqrtf_use+set} != xset; then
-    if ${glibcxx_cv_func_sqrtf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- sqrtf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_sqrtf_use=yes
-else
-  glibcxx_cv_func_sqrtf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_sqrtf_use" >&5
-$as_echo "$glibcxx_cv_func_sqrtf_use" >&6; }
-  if test x$glibcxx_cv_func_sqrtf_use = x"yes"; then
-    for ac_func in sqrtf
-do :
-  ac_fn_c_check_func "$LINENO" "sqrtf" "ac_cv_func_sqrtf"
-if test "x$ac_cv_func_sqrtf" = xyes; then :
-#define HAVE_SQRTF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _sqrtf declaration" >&5
-$as_echo_n "checking for _sqrtf declaration... " >&6; }
-  if test x${glibcxx_cv_func__sqrtf_use+set} != xset; then
-    if ${glibcxx_cv_func__sqrtf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _sqrtf(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__sqrtf_use=yes
-else
-  glibcxx_cv_func__sqrtf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__sqrtf_use" >&5
-$as_echo "$glibcxx_cv_func__sqrtf_use" >&6; }
-    if test x$glibcxx_cv_func__sqrtf_use = x"yes"; then
-      for ac_func in _sqrtf
-do :
-  ac_fn_c_check_func "$LINENO" "_sqrtf" "ac_cv_func__sqrtf"
-if test "x$ac_cv_func__sqrtf" = xyes; then :
-#define HAVE__SQRTF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sincosf declaration" >&5
-$as_echo_n "checking for sincosf declaration... " >&6; }
-  if test x${glibcxx_cv_func_sincosf_use+set} != xset; then
-    if ${glibcxx_cv_func_sincosf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- sincosf(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_sincosf_use=yes
-else
-  glibcxx_cv_func_sincosf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_sincosf_use" >&5
-$as_echo "$glibcxx_cv_func_sincosf_use" >&6; }
-  if test x$glibcxx_cv_func_sincosf_use = x"yes"; then
-    for ac_func in sincosf
-do :
-  ac_fn_c_check_func "$LINENO" "sincosf" "ac_cv_func_sincosf"
-if test "x$ac_cv_func_sincosf" = xyes; then :
-#define HAVE_SINCOSF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _sincosf declaration" >&5
-$as_echo_n "checking for _sincosf declaration... " >&6; }
-  if test x${glibcxx_cv_func__sincosf_use+set} != xset; then
-    if ${glibcxx_cv_func__sincosf_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _sincosf(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__sincosf_use=yes
-else
-  glibcxx_cv_func__sincosf_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__sincosf_use" >&5
-$as_echo "$glibcxx_cv_func__sincosf_use" >&6; }
-    if test x$glibcxx_cv_func__sincosf_use = x"yes"; then
-      for ac_func in _sincosf
-do :
-  ac_fn_c_check_func "$LINENO" "_sincosf" "ac_cv_func__sincosf"
-if test "x$ac_cv_func__sincosf" = xyes; then :
-#define HAVE__SINCOSF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for finitef declaration" >&5
-$as_echo_n "checking for finitef declaration... " >&6; }
-  if test x${glibcxx_cv_func_finitef_use+set} != xset; then
-    if ${glibcxx_cv_func_finitef_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- finitef(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_finitef_use=yes
-else
-  glibcxx_cv_func_finitef_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_finitef_use" >&5
-$as_echo "$glibcxx_cv_func_finitef_use" >&6; }
-  if test x$glibcxx_cv_func_finitef_use = x"yes"; then
-    for ac_func in finitef
-do :
-  ac_fn_c_check_func "$LINENO" "finitef" "ac_cv_func_finitef"
-if test "x$ac_cv_func_finitef" = xyes; then :
-#define HAVE_FINITEF 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _finitef declaration" >&5
-$as_echo_n "checking for _finitef declaration... " >&6; }
-  if test x${glibcxx_cv_func__finitef_use+set} != xset; then
-    if ${glibcxx_cv_func__finitef_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _finitef(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__finitef_use=yes
-else
-  glibcxx_cv_func__finitef_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__finitef_use" >&5
-$as_echo "$glibcxx_cv_func__finitef_use" >&6; }
-    if test x$glibcxx_cv_func__finitef_use = x"yes"; then
-      for ac_func in _finitef
-do :
-  ac_fn_c_check_func "$LINENO" "_finitef" "ac_cv_func__finitef"
-if test "x$ac_cv_func__finitef" = xyes; then :
-#define HAVE__FINITEF 1
-_ACEOF
-fi
-done
-    fi
-  fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for long double trig functions" >&5
-$as_echo_n "checking for long double trig functions... " >&6; }
-  if ${glibcxx_cv_func_long_double_trig_use+:} false; then :
-else
-    ac_ext=cpp
-#include <math.h>
-int
-main ()
-acosl (0); asinl (0); atanl (0); cosl (0); sinl (0); tanl (0); coshl (0); sinhl (0); tanhl (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_long_double_trig_use=yes
-else
-  glibcxx_cv_func_long_double_trig_use=no
-fi
-    ac_ext=c
-fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_long_double_trig_use" >&5
-$as_echo "$glibcxx_cv_func_long_double_trig_use" >&6; }
-  if test x$glibcxx_cv_func_long_double_trig_use = x"yes"; then
-    for ac_func in acosl asinl atanl cosl sinl tanl coshl sinhl tanhl
-do :
-_ACEOF
-fi
-done
-  else
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _long double trig functions" >&5
-$as_echo_n "checking for _long double trig functions... " >&6; }
-    if ${glibcxx_cv_func__long_double_trig_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
-_acosl (0); _asinl (0); _atanl (0); _cosl (0); _sinl (0); _tanl (0); _coshl (0); _sinhl (0); _tanhl (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__long_double_trig_use=yes
-else
-  glibcxx_cv_func__long_double_trig_use=no
-fi
-      ac_ext=c
-fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__long_double_trig_use" >&5
-$as_echo "$glibcxx_cv_func__long_double_trig_use" >&6; }
-    if test x$glibcxx_cv_func__long_double_trig_use = x"yes"; then
-      for ac_func in _acosl _asinl _atanl _cosl _sinl _tanl _coshl _sinhl _tanhl
-do :
-_ACEOF
-fi
-done
-    fi
-  fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for long double round functions" >&5
-$as_echo_n "checking for long double round functions... " >&6; }
-  if ${glibcxx_cv_func_long_double_round_use+:} false; then :
-else
-    ac_ext=cpp
-#include <math.h>
-int
-main ()
-ceill (0); floorl (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_long_double_round_use=yes
-else
-  glibcxx_cv_func_long_double_round_use=no
-fi
-    ac_ext=c
-fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_long_double_round_use" >&5
-$as_echo "$glibcxx_cv_func_long_double_round_use" >&6; }
-  if test x$glibcxx_cv_func_long_double_round_use = x"yes"; then
-    for ac_func in ceill floorl
-do :
-_ACEOF
-fi
-done
-  else
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _long double round functions" >&5
-$as_echo_n "checking for _long double round functions... " >&6; }
-    if ${glibcxx_cv_func__long_double_round_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
-_ceill (0); _floorl (0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__long_double_round_use=yes
-else
-  glibcxx_cv_func__long_double_round_use=no
-fi
-      ac_ext=c
-fi
-    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__long_double_round_use" >&5
-$as_echo "$glibcxx_cv_func__long_double_round_use" >&6; }
-    if test x$glibcxx_cv_func__long_double_round_use = x"yes"; then
-      for ac_func in _ceill _floorl
-do :
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isnanl declaration" >&5
-$as_echo_n "checking for isnanl declaration... " >&6; }
-  if test x${glibcxx_cv_func_isnanl_use+set} != xset; then
-    if ${glibcxx_cv_func_isnanl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- isnanl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isnanl_use=yes
-else
-  glibcxx_cv_func_isnanl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isnanl_use" >&5
-$as_echo "$glibcxx_cv_func_isnanl_use" >&6; }
-  if test x$glibcxx_cv_func_isnanl_use = x"yes"; then
-    for ac_func in isnanl
-do :
-  ac_fn_c_check_func "$LINENO" "isnanl" "ac_cv_func_isnanl"
-if test "x$ac_cv_func_isnanl" = xyes; then :
-#define HAVE_ISNANL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isnanl declaration" >&5
-$as_echo_n "checking for _isnanl declaration... " >&6; }
-  if test x${glibcxx_cv_func__isnanl_use+set} != xset; then
-    if ${glibcxx_cv_func__isnanl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isnanl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isnanl_use=yes
-else
-  glibcxx_cv_func__isnanl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isnanl_use" >&5
-$as_echo "$glibcxx_cv_func__isnanl_use" >&6; }
-    if test x$glibcxx_cv_func__isnanl_use = x"yes"; then
-      for ac_func in _isnanl
-do :
-  ac_fn_c_check_func "$LINENO" "_isnanl" "ac_cv_func__isnanl"
-if test "x$ac_cv_func__isnanl" = xyes; then :
-#define HAVE__ISNANL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for isinfl declaration" >&5
-$as_echo_n "checking for isinfl declaration... " >&6; }
-  if test x${glibcxx_cv_func_isinfl_use+set} != xset; then
-    if ${glibcxx_cv_func_isinfl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- isinfl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_isinfl_use=yes
-else
-  glibcxx_cv_func_isinfl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_isinfl_use" >&5
-$as_echo "$glibcxx_cv_func_isinfl_use" >&6; }
-  if test x$glibcxx_cv_func_isinfl_use = x"yes"; then
-    for ac_func in isinfl
-do :
-  ac_fn_c_check_func "$LINENO" "isinfl" "ac_cv_func_isinfl"
-if test "x$ac_cv_func_isinfl" = xyes; then :
-#define HAVE_ISINFL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _isinfl declaration" >&5
-$as_echo_n "checking for _isinfl declaration... " >&6; }
-  if test x${glibcxx_cv_func__isinfl_use+set} != xset; then
-    if ${glibcxx_cv_func__isinfl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _isinfl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__isinfl_use=yes
-else
-  glibcxx_cv_func__isinfl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__isinfl_use" >&5
-$as_echo "$glibcxx_cv_func__isinfl_use" >&6; }
-    if test x$glibcxx_cv_func__isinfl_use = x"yes"; then
-      for ac_func in _isinfl
-do :
-  ac_fn_c_check_func "$LINENO" "_isinfl" "ac_cv_func__isinfl"
-if test "x$ac_cv_func__isinfl" = xyes; then :
-#define HAVE__ISINFL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for atan2l declaration" >&5
-$as_echo_n "checking for atan2l declaration... " >&6; }
-  if test x${glibcxx_cv_func_atan2l_use+set} != xset; then
-    if ${glibcxx_cv_func_atan2l_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- atan2l(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_atan2l_use=yes
-else
-  glibcxx_cv_func_atan2l_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_atan2l_use" >&5
-$as_echo "$glibcxx_cv_func_atan2l_use" >&6; }
-  if test x$glibcxx_cv_func_atan2l_use = x"yes"; then
-    for ac_func in atan2l
-do :
-  ac_fn_c_check_func "$LINENO" "atan2l" "ac_cv_func_atan2l"
-if test "x$ac_cv_func_atan2l" = xyes; then :
-#define HAVE_ATAN2L 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _atan2l declaration" >&5
-$as_echo_n "checking for _atan2l declaration... " >&6; }
-  if test x${glibcxx_cv_func__atan2l_use+set} != xset; then
-    if ${glibcxx_cv_func__atan2l_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _atan2l(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__atan2l_use=yes
-else
-  glibcxx_cv_func__atan2l_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__atan2l_use" >&5
-$as_echo "$glibcxx_cv_func__atan2l_use" >&6; }
-    if test x$glibcxx_cv_func__atan2l_use = x"yes"; then
-      for ac_func in _atan2l
-do :
-  ac_fn_c_check_func "$LINENO" "_atan2l" "ac_cv_func__atan2l"
-if test "x$ac_cv_func__atan2l" = xyes; then :
-#define HAVE__ATAN2L 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for expl declaration" >&5
-$as_echo_n "checking for expl declaration... " >&6; }
-  if test x${glibcxx_cv_func_expl_use+set} != xset; then
-    if ${glibcxx_cv_func_expl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- expl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_expl_use=yes
-else
-  glibcxx_cv_func_expl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_expl_use" >&5
-$as_echo "$glibcxx_cv_func_expl_use" >&6; }
-  if test x$glibcxx_cv_func_expl_use = x"yes"; then
-    for ac_func in expl
-do :
-  ac_fn_c_check_func "$LINENO" "expl" "ac_cv_func_expl"
-if test "x$ac_cv_func_expl" = xyes; then :
-#define HAVE_EXPL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _expl declaration" >&5
-$as_echo_n "checking for _expl declaration... " >&6; }
-  if test x${glibcxx_cv_func__expl_use+set} != xset; then
-    if ${glibcxx_cv_func__expl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _expl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__expl_use=yes
-else
-  glibcxx_cv_func__expl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__expl_use" >&5
-$as_echo "$glibcxx_cv_func__expl_use" >&6; }
-    if test x$glibcxx_cv_func__expl_use = x"yes"; then
-      for ac_func in _expl
-do :
-  ac_fn_c_check_func "$LINENO" "_expl" "ac_cv_func__expl"
-if test "x$ac_cv_func__expl" = xyes; then :
-#define HAVE__EXPL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for fabsl declaration" >&5
-$as_echo_n "checking for fabsl declaration... " >&6; }
-  if test x${glibcxx_cv_func_fabsl_use+set} != xset; then
-    if ${glibcxx_cv_func_fabsl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- fabsl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_fabsl_use=yes
-else
-  glibcxx_cv_func_fabsl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_fabsl_use" >&5
-$as_echo "$glibcxx_cv_func_fabsl_use" >&6; }
-  if test x$glibcxx_cv_func_fabsl_use = x"yes"; then
-    for ac_func in fabsl
-do :
-  ac_fn_c_check_func "$LINENO" "fabsl" "ac_cv_func_fabsl"
-if test "x$ac_cv_func_fabsl" = xyes; then :
-#define HAVE_FABSL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _fabsl declaration" >&5
-$as_echo_n "checking for _fabsl declaration... " >&6; }
-  if test x${glibcxx_cv_func__fabsl_use+set} != xset; then
-    if ${glibcxx_cv_func__fabsl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _fabsl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__fabsl_use=yes
-else
-  glibcxx_cv_func__fabsl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__fabsl_use" >&5
-$as_echo "$glibcxx_cv_func__fabsl_use" >&6; }
-    if test x$glibcxx_cv_func__fabsl_use = x"yes"; then
-      for ac_func in _fabsl
-do :
-  ac_fn_c_check_func "$LINENO" "_fabsl" "ac_cv_func__fabsl"
-if test "x$ac_cv_func__fabsl" = xyes; then :
-#define HAVE__FABSL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for fmodl declaration" >&5
-$as_echo_n "checking for fmodl declaration... " >&6; }
-  if test x${glibcxx_cv_func_fmodl_use+set} != xset; then
-    if ${glibcxx_cv_func_fmodl_use+:} false; then :
-else
-      ac_ext=cpp
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-#include <math.h>
-int
-main ()
- fmodl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_fmodl_use=yes
-else
-  glibcxx_cv_func_fmodl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_fmodl_use" >&5
-$as_echo "$glibcxx_cv_func_fmodl_use" >&6; }
-  if test x$glibcxx_cv_func_fmodl_use = x"yes"; then
-    for ac_func in fmodl
-do :
-  ac_fn_c_check_func "$LINENO" "fmodl" "ac_cv_func_fmodl"
-if test "x$ac_cv_func_fmodl" = xyes; then :
-#define HAVE_FMODL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _fmodl declaration" >&5
-$as_echo_n "checking for _fmodl declaration... " >&6; }
-  if test x${glibcxx_cv_func__fmodl_use+set} != xset; then
-    if ${glibcxx_cv_func__fmodl_use+:} false; then :
-else
-      ac_ext=cpp
-      cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h.  */
-#include <math.h>
-int
-main ()
- _fmodl(0, 0);
-  return 0;
-_ACEOF
-if ac_fn_cxx_try_compile "$LINENO"; then :
-  glibcxx_cv_func__fmodl_use=yes
-else
-  glibcxx_cv_func__fmodl_use=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-      ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__fmodl_use" >&5
-$as_echo "$glibcxx_cv_func__fmodl_use" >&6; }
-    if test x$glibcxx_cv_func__fmodl_use = x"yes"; then
-      for ac_func in _fmodl
-do :
-  ac_fn_c_check_func "$LINENO" "_fmodl" "ac_cv_func__fmodl"
-if test "x$ac_cv_func__fmodl" = xyes; then :
-#define HAVE__FMODL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for frexpl declaration" >&5
-$as_echo_n "checking for frexpl declaration... " >&6; }
-  if test x${glibcxx_cv_func_frexpl_use+set} != xset; then
-    if ${glibcxx_cv_func_frexpl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- frexpl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_frexpl_use=yes
-else
-  glibcxx_cv_func_frexpl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_frexpl_use" >&5
-$as_echo "$glibcxx_cv_func_frexpl_use" >&6; }
-  if test x$glibcxx_cv_func_frexpl_use = x"yes"; then
-    for ac_func in frexpl
-do :
-  ac_fn_c_check_func "$LINENO" "frexpl" "ac_cv_func_frexpl"
-if test "x$ac_cv_func_frexpl" = xyes; then :
-#define HAVE_FREXPL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _frexpl declaration" >&5
-$as_echo_n "checking for _frexpl declaration... " >&6; }
-  if test x${glibcxx_cv_func__frexpl_use+set} != xset; then
-    if ${glibcxx_cv_func__frexpl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _frexpl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__frexpl_use=yes
-else
-  glibcxx_cv_func__frexpl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__frexpl_use" >&5
-$as_echo "$glibcxx_cv_func__frexpl_use" >&6; }
-    if test x$glibcxx_cv_func__frexpl_use = x"yes"; then
-      for ac_func in _frexpl
-do :
-  ac_fn_c_check_func "$LINENO" "_frexpl" "ac_cv_func__frexpl"
-if test "x$ac_cv_func__frexpl" = xyes; then :
-#define HAVE__FREXPL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for hypotl declaration" >&5
-$as_echo_n "checking for hypotl declaration... " >&6; }
-  if test x${glibcxx_cv_func_hypotl_use+set} != xset; then
-    if ${glibcxx_cv_func_hypotl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- hypotl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_hypotl_use=yes
-else
-  glibcxx_cv_func_hypotl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_hypotl_use" >&5
-$as_echo "$glibcxx_cv_func_hypotl_use" >&6; }
-  if test x$glibcxx_cv_func_hypotl_use = x"yes"; then
-    for ac_func in hypotl
-do :
-  ac_fn_c_check_func "$LINENO" "hypotl" "ac_cv_func_hypotl"
-if test "x$ac_cv_func_hypotl" = xyes; then :
-#define HAVE_HYPOTL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _hypotl declaration" >&5
-$as_echo_n "checking for _hypotl declaration... " >&6; }
-  if test x${glibcxx_cv_func__hypotl_use+set} != xset; then
-    if ${glibcxx_cv_func__hypotl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _hypotl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__hypotl_use=yes
-else
-  glibcxx_cv_func__hypotl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__hypotl_use" >&5
-$as_echo "$glibcxx_cv_func__hypotl_use" >&6; }
-    if test x$glibcxx_cv_func__hypotl_use = x"yes"; then
-      for ac_func in _hypotl
-do :
-  ac_fn_c_check_func "$LINENO" "_hypotl" "ac_cv_func__hypotl"
-if test "x$ac_cv_func__hypotl" = xyes; then :
-#define HAVE__HYPOTL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ldexpl declaration" >&5
-$as_echo_n "checking for ldexpl declaration... " >&6; }
-  if test x${glibcxx_cv_func_ldexpl_use+set} != xset; then
-    if ${glibcxx_cv_func_ldexpl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- ldexpl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_ldexpl_use=yes
-else
-  glibcxx_cv_func_ldexpl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_ldexpl_use" >&5
-$as_echo "$glibcxx_cv_func_ldexpl_use" >&6; }
-  if test x$glibcxx_cv_func_ldexpl_use = x"yes"; then
-    for ac_func in ldexpl
-do :
-  ac_fn_c_check_func "$LINENO" "ldexpl" "ac_cv_func_ldexpl"
-if test "x$ac_cv_func_ldexpl" = xyes; then :
-#define HAVE_LDEXPL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _ldexpl declaration" >&5
-$as_echo_n "checking for _ldexpl declaration... " >&6; }
-  if test x${glibcxx_cv_func__ldexpl_use+set} != xset; then
-    if ${glibcxx_cv_func__ldexpl_use+:} false; then :
-  $as_echo_n "(cached) " >&6
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _ldexpl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__ldexpl_use=yes
-else
-  glibcxx_cv_func__ldexpl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__ldexpl_use" >&5
-$as_echo "$glibcxx_cv_func__ldexpl_use" >&6; }
-    if test x$glibcxx_cv_func__ldexpl_use = x"yes"; then
-      for ac_func in _ldexpl
-do :
-  ac_fn_c_check_func "$LINENO" "_ldexpl" "ac_cv_func__ldexpl"
-if test "x$ac_cv_func__ldexpl" = xyes; then :
-#define HAVE__LDEXPL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for logl declaration" >&5
-$as_echo_n "checking for logl declaration... " >&6; }
-  if test x${glibcxx_cv_func_logl_use+set} != xset; then
-    if ${glibcxx_cv_func_logl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- logl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_logl_use=yes
-else
-  glibcxx_cv_func_logl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_logl_use" >&5
-$as_echo "$glibcxx_cv_func_logl_use" >&6; }
-  if test x$glibcxx_cv_func_logl_use = x"yes"; then
-    for ac_func in logl
-do :
-  ac_fn_c_check_func "$LINENO" "logl" "ac_cv_func_logl"
-if test "x$ac_cv_func_logl" = xyes; then :
-#define HAVE_LOGL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _logl declaration" >&5
-$as_echo_n "checking for _logl declaration... " >&6; }
-  if test x${glibcxx_cv_func__logl_use+set} != xset; then
-    if ${glibcxx_cv_func__logl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #ifdef HAVE_IEEEFP_H
-		      #include <ieeefp.h>
-		      #endif
-int
-main ()
- _logl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__logl_use=yes
-else
-  glibcxx_cv_func__logl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__logl_use" >&5
-$as_echo "$glibcxx_cv_func__logl_use" >&6; }
-    if test x$glibcxx_cv_func__logl_use = x"yes"; then
-      for ac_func in _logl
-do :
-  ac_fn_c_check_func "$LINENO" "_logl" "ac_cv_func__logl"
-if test "x$ac_cv_func__logl" = xyes; then :
-  cat >>confdefs.h <<_ACEOF
-#define HAVE__LOGL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for log10l declaration" >&5
-$as_echo_n "checking for log10l declaration... " >&6; }
-  if test x${glibcxx_cv_func_log10l_use+set} != xset; then
-    if ${glibcxx_cv_func_log10l_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- log10l(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_log10l_use=yes
-else
-  glibcxx_cv_func_log10l_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_log10l_use" >&5
-$as_echo "$glibcxx_cv_func_log10l_use" >&6; }
-  if test x$glibcxx_cv_func_log10l_use = x"yes"; then
-    for ac_func in log10l
-do :
-  ac_fn_c_check_func "$LINENO" "log10l" "ac_cv_func_log10l"
-if test "x$ac_cv_func_log10l" = xyes; then :
-#define HAVE_LOG10L 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _log10l declaration" >&5
-$as_echo_n "checking for _log10l declaration... " >&6; }
-  if test x${glibcxx_cv_func__log10l_use+set} != xset; then
-    if ${glibcxx_cv_func__log10l_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _log10l(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__log10l_use=yes
-else
-  glibcxx_cv_func__log10l_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__log10l_use" >&5
-$as_echo "$glibcxx_cv_func__log10l_use" >&6; }
-    if test x$glibcxx_cv_func__log10l_use = x"yes"; then
-      for ac_func in _log10l
-do :
-  ac_fn_c_check_func "$LINENO" "_log10l" "ac_cv_func__log10l"
-if test "x$ac_cv_func__log10l" = xyes; then :
-#define HAVE__LOG10L 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for modfl declaration" >&5
-$as_echo_n "checking for modfl declaration... " >&6; }
-  if test x${glibcxx_cv_func_modfl_use+set} != xset; then
-    if ${glibcxx_cv_func_modfl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- modfl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_modfl_use=yes
-else
-  glibcxx_cv_func_modfl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_modfl_use" >&5
-$as_echo "$glibcxx_cv_func_modfl_use" >&6; }
-  if test x$glibcxx_cv_func_modfl_use = x"yes"; then
-    for ac_func in modfl
-do :
-  ac_fn_c_check_func "$LINENO" "modfl" "ac_cv_func_modfl"
-if test "x$ac_cv_func_modfl" = xyes; then :
-#define HAVE_MODFL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _modfl declaration" >&5
-$as_echo_n "checking for _modfl declaration... " >&6; }
-  if test x${glibcxx_cv_func__modfl_use+set} != xset; then
-    if ${glibcxx_cv_func__modfl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _modfl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__modfl_use=yes
-else
-  glibcxx_cv_func__modfl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__modfl_use" >&5
-$as_echo "$glibcxx_cv_func__modfl_use" >&6; }
-    if test x$glibcxx_cv_func__modfl_use = x"yes"; then
-      for ac_func in _modfl
-do :
-  ac_fn_c_check_func "$LINENO" "_modfl" "ac_cv_func__modfl"
-if test "x$ac_cv_func__modfl" = xyes; then :
-#define HAVE__MODFL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for powl declaration" >&5
-$as_echo_n "checking for powl declaration... " >&6; }
-  if test x${glibcxx_cv_func_powl_use+set} != xset; then
-    if ${glibcxx_cv_func_powl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- powl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_powl_use=yes
-else
-  glibcxx_cv_func_powl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_powl_use" >&5
-$as_echo "$glibcxx_cv_func_powl_use" >&6; }
-  if test x$glibcxx_cv_func_powl_use = x"yes"; then
-    for ac_func in powl
-do :
-  ac_fn_c_check_func "$LINENO" "powl" "ac_cv_func_powl"
-if test "x$ac_cv_func_powl" = xyes; then :
-#define HAVE_POWL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _powl declaration" >&5
-$as_echo_n "checking for _powl declaration... " >&6; }
-  if test x${glibcxx_cv_func__powl_use+set} != xset; then
-    if ${glibcxx_cv_func__powl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _powl(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__powl_use=yes
-else
-  glibcxx_cv_func__powl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__powl_use" >&5
-$as_echo "$glibcxx_cv_func__powl_use" >&6; }
-    if test x$glibcxx_cv_func__powl_use = x"yes"; then
-      for ac_func in _powl
-do :
-  ac_fn_c_check_func "$LINENO" "_powl" "ac_cv_func__powl"
-if test "x$ac_cv_func__powl" = xyes; then :
-#define HAVE__POWL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sqrtl declaration" >&5
-$as_echo_n "checking for sqrtl declaration... " >&6; }
-  if test x${glibcxx_cv_func_sqrtl_use+set} != xset; then
-    if ${glibcxx_cv_func_sqrtl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- sqrtl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_sqrtl_use=yes
-else
-  glibcxx_cv_func_sqrtl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_sqrtl_use" >&5
-$as_echo "$glibcxx_cv_func_sqrtl_use" >&6; }
-  if test x$glibcxx_cv_func_sqrtl_use = x"yes"; then
-    for ac_func in sqrtl
-do :
-  ac_fn_c_check_func "$LINENO" "sqrtl" "ac_cv_func_sqrtl"
-if test "x$ac_cv_func_sqrtl" = xyes; then :
-#define HAVE_SQRTL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _sqrtl declaration" >&5
-$as_echo_n "checking for _sqrtl declaration... " >&6; }
-  if test x${glibcxx_cv_func__sqrtl_use+set} != xset; then
-    if ${glibcxx_cv_func__sqrtl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _sqrtl(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__sqrtl_use=yes
-else
-  glibcxx_cv_func__sqrtl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__sqrtl_use" >&5
-$as_echo "$glibcxx_cv_func__sqrtl_use" >&6; }
-    if test x$glibcxx_cv_func__sqrtl_use = x"yes"; then
-      for ac_func in _sqrtl
-do :
-  ac_fn_c_check_func "$LINENO" "_sqrtl" "ac_cv_func__sqrtl"
-if test "x$ac_cv_func__sqrtl" = xyes; then :
-#define HAVE__SQRTL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for sincosl declaration" >&5
-$as_echo_n "checking for sincosl declaration... " >&6; }
-  if test x${glibcxx_cv_func_sincosl_use+set} != xset; then
-    if ${glibcxx_cv_func_sincosl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- sincosl(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_sincosl_use=yes
-else
-  glibcxx_cv_func_sincosl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_sincosl_use" >&5
-$as_echo "$glibcxx_cv_func_sincosl_use" >&6; }
-  if test x$glibcxx_cv_func_sincosl_use = x"yes"; then
-    for ac_func in sincosl
-do :
-  ac_fn_c_check_func "$LINENO" "sincosl" "ac_cv_func_sincosl"
-if test "x$ac_cv_func_sincosl" = xyes; then :
-#define HAVE_SINCOSL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _sincosl declaration" >&5
-$as_echo_n "checking for _sincosl declaration... " >&6; }
-  if test x${glibcxx_cv_func__sincosl_use+set} != xset; then
-    if ${glibcxx_cv_func__sincosl_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-int
-main ()
- _sincosl(0, 0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__sincosl_use=yes
-else
-  glibcxx_cv_func__sincosl_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__sincosl_use" >&5
-$as_echo "$glibcxx_cv_func__sincosl_use" >&6; }
-    if test x$glibcxx_cv_func__sincosl_use = x"yes"; then
-      for ac_func in _sincosl
-do :
-  ac_fn_c_check_func "$LINENO" "_sincosl" "ac_cv_func__sincosl"
-if test "x$ac_cv_func__sincosl" = xyes; then :
-#define HAVE__SINCOSL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for finitel declaration" >&5
-$as_echo_n "checking for finitel declaration... " >&6; }
-  if test x${glibcxx_cv_func_finitel_use+set} != xset; then
-    if ${glibcxx_cv_func_finitel_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- finitel(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_finitel_use=yes
-else
-  glibcxx_cv_func_finitel_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_finitel_use" >&5
-$as_echo "$glibcxx_cv_func_finitel_use" >&6; }
-  if test x$glibcxx_cv_func_finitel_use = x"yes"; then
-    for ac_func in finitel
-do :
-  ac_fn_c_check_func "$LINENO" "finitel" "ac_cv_func_finitel"
-if test "x$ac_cv_func_finitel" = xyes; then :
-#define HAVE_FINITEL 1
-_ACEOF
-fi
-done
-  else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for _finitel declaration" >&5
-$as_echo_n "checking for _finitel declaration... " >&6; }
-  if test x${glibcxx_cv_func__finitel_use+set} != xset; then
-    if ${glibcxx_cv_func__finitel_use+:} false; then :
-else
-      ac_ext=cpp
-#include <math.h>
-		      #endif
-int
-main ()
- _finitel(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func__finitel_use=yes
-else
-  glibcxx_cv_func__finitel_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func__finitel_use" >&5
-$as_echo "$glibcxx_cv_func__finitel_use" >&6; }
-    if test x$glibcxx_cv_func__finitel_use = x"yes"; then
-      for ac_func in _finitel
-do :
-  ac_fn_c_check_func "$LINENO" "_finitel" "ac_cv_func__finitel"
-if test "x$ac_cv_func__finitel" = xyes; then :
-#define HAVE__FINITEL 1
-_ACEOF
-fi
-done
-    fi
-  fi
-  LIBS="$ac_save_LIBS"
-  CXXFLAGS="$ac_save_CXXFLAGS"
-  ac_test_CXXFLAGS="${CXXFLAGS+set}"
-  ac_save_CXXFLAGS="$CXXFLAGS"
-  CXXFLAGS='-fno-builtin -D_GNU_SOURCE'
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for at_quick_exit declaration" >&5
-$as_echo_n "checking for at_quick_exit declaration... " >&6; }
-  if test x${glibcxx_cv_func_at_quick_exit_use+set} != xset; then
-    if ${glibcxx_cv_func_at_quick_exit_use+:} false; then :
-else
-      ac_ext=cpp
-#include <stdlib.h>
-int
-main ()
- at_quick_exit(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_at_quick_exit_use=yes
-else
-  glibcxx_cv_func_at_quick_exit_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_at_quick_exit_use" >&5
-$as_echo "$glibcxx_cv_func_at_quick_exit_use" >&6; }
-  if test x$glibcxx_cv_func_at_quick_exit_use = x"yes"; then
-    for ac_func in at_quick_exit
-do :
-  ac_fn_c_check_func "$LINENO" "at_quick_exit" "ac_cv_func_at_quick_exit"
-if test "x$ac_cv_func_at_quick_exit" = xyes; then :
-#define HAVE_AT_QUICK_EXIT 1
-_ACEOF
-fi
-done
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for quick_exit declaration" >&5
-$as_echo_n "checking for quick_exit declaration... " >&6; }
-  if test x${glibcxx_cv_func_quick_exit_use+set} != xset; then
-    if ${glibcxx_cv_func_quick_exit_use+:} false; then :
-else
-      ac_ext=cpp
-int
-main ()
- quick_exit(0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_quick_exit_use=yes
-else
-  glibcxx_cv_func_quick_exit_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_quick_exit_use" >&5
-$as_echo "$glibcxx_cv_func_quick_exit_use" >&6; }
-  if test x$glibcxx_cv_func_quick_exit_use = x"yes"; then
-    for ac_func in quick_exit
-do :
-  ac_fn_c_check_func "$LINENO" "quick_exit" "ac_cv_func_quick_exit"
-if test "x$ac_cv_func_quick_exit" = xyes; then :
-#define HAVE_QUICK_EXIT 1
-_ACEOF
-fi
-done
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for strtold declaration" >&5
-$as_echo_n "checking for strtold declaration... " >&6; }
-  if test x${glibcxx_cv_func_strtold_use+set} != xset; then
-    if ${glibcxx_cv_func_strtold_use+:} false; then :
-else
-      ac_ext=cpp
-int
-main ()
- strtold(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_strtold_use=yes
-else
-  glibcxx_cv_func_strtold_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_strtold_use" >&5
-$as_echo "$glibcxx_cv_func_strtold_use" >&6; }
-  if test x$glibcxx_cv_func_strtold_use = x"yes"; then
-    for ac_func in strtold
-do :
-  ac_fn_c_check_func "$LINENO" "strtold" "ac_cv_func_strtold"
-if test "x$ac_cv_func_strtold" = xyes; then :
-#define HAVE_STRTOLD 1
-_ACEOF
-fi
-done
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for strtof declaration" >&5
-$as_echo_n "checking for strtof declaration... " >&6; }
-  if test x${glibcxx_cv_func_strtof_use+set} != xset; then
-    if ${glibcxx_cv_func_strtof_use+:} false; then :
-else
-      ac_ext=cpp
-int
-main ()
- strtof(0, 0);
-  return 0;
-_ACEOF
-  glibcxx_cv_func_strtof_use=yes
-else
-  glibcxx_cv_func_strtof_use=no
-fi
-      ac_ext=c
-fi
-  fi
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $glibcxx_cv_func_strtof_use" >&5
-$as_echo "$glibcxx_cv_func_strtof_use" >&6; }
-  if test x$glibcxx_cv_func_strtof_use = x"yes"; then
-    for ac_func in strtof
-do :
-  ac_fn_c_check_func "$LINENO" "strtof" "ac_cv_func_strtof"
-if test "x$ac_cv_func_strtof" = xyes; then :
-#define HAVE_STRTOF 1
-_ACEOF
-fi
-done
-  fi
   *-tpf)
     SECTION_FLAGS='-ffunction-sections -fdata-sections'
diff --git a/libstdc++-v3/configure.ac b/libstdc++-v3/configure.ac
index e59bcdb2944..b351622bf46 100644
--- a/libstdc++-v3/configure.ac
+++ b/libstdc++-v3/configure.ac
@@ -353,6 +353,30 @@ else
     AC_DEFINE(HAVE_ICONV)
     AC_DEFINE(HAVE_MEMALIGN)
+    case "${target}" in
+      *-rtems*)
+          bfin* | lm32* | mips* | moxie* | or1k* | v850*)
+            AC_DEFINE(HAVE_TLS)
+        esac
+        AC_DEFINE(HAVE_ALIGNED_ALLOC)
+        AC_DEFINE(HAVE_AT_QUICK_EXIT)
+        AC_DEFINE(HAVE_LINK)
+        AC_DEFINE(HAVE_QUICK_EXIT)
+        AC_DEFINE(HAVE_READLINK)
+        AC_DEFINE(HAVE_SETENV)
+        AC_DEFINE(HAVE_SLEEP)
+        AC_DEFINE(HAVE_SOCKATMARK)
+        AC_DEFINE(HAVE_STRERROR_L)
+        AC_DEFINE(HAVE_SYMLINK)
+        AC_DEFINE(HAVE_TRUNCATE)
+        AC_DEFINE(HAVE_USLEEP)
+    esac
   elif test "x$with_headers" != "xno"; then
     GLIBCXX_CROSSCONFIG
   fi
diff --git a/libstdc++-v3/crossconfig.m4 b/libstdc++-v3/crossconfig.m4
index ae5283b7ad3..e8ff89fe658 100644
--- a/libstdc++-v3/crossconfig.m4
+++ b/libstdc++-v3/crossconfig.m4
@@ -244,12 +244,6 @@ case "${host}" in
     AC_DEFINE(HAVE_SINHF)
     AC_DEFINE(HAVE_SINHL)
-  *-rtems*)
-    GLIBCXX_CHECK_COMPILER_FEATURES
-    GLIBCXX_CHECK_LINKER_FEATURES
-    GLIBCXX_CHECK_MATH_SUPPORT
-    GLIBCXX_CHECK_STDLIB_SUPPORT
   *-tpf)
     SECTION_LDFLAGS='-Wl,--gc-sections $SECTION_LDFLAGS'
2.35.3
