[PATCH rtems-docs] zynqmp: Add commentary about lwIP usage
Kinsey Moore kinsey.moore at oarcorp.com
Wed Jul 20 13:33:47 UTC 2022
On 7/19/2022 16:22, Chris Johns wrote:
> On 20/7/2022 5:42 am, Kinsey Moore wrote:
>>   user/bsps/aarch64/xilinx-zynqmp.rst | 9 +++++++++
>>   1 file changed, 9 insertions(+)
>> diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
>> index 78bff12..58954d6 100644
>> --- a/user/bsps/aarch64/xilinx-zynqmp.rst
>> +++ b/user/bsps/aarch64/xilinx-zynqmp.rst
>> @@ -244,6 +244,15 @@ Cadence GEM instances present on all ZynqMP hardware variants. All interfaces
>>   are enabled by default, but only interfaces with operational MII busses will be
>>   recognized and usable in RTEMS. Most ZynqMP dev boards use CGEM3.
>> +When used with lwIP from the rtems-lwip integration repository, these BSP
>> +variants support networking via the 0th and any one other of the Cadence GEM
>> +instances simultaneously.
> Is there a simpler way to word this? English may not be a user's first language.
>   variants support networking using the Cadence GEM interfaces labelled
>   ``CGEM0`` to ``CGEM3``. Multiple interfaces can be used at the same time.
> Chris
Unfortunately, it's not quite that simple, but I'll reword it in more
direct terms.
Thanks,
Kinsey
