[PATCH v1 3/5] cpukit/libdl: Add support for AArch64
Ryan Long ryan.long at oarcorp.com
Thu Jul 21 15:11:17 UTC 2022
On 7/20/2022 11:39 PM, Chris Johns wrote:
> On 21/7/2022 7:36 am, Ryan Long wrote:
>> rtl-mdreloc-aarch64.c and elf_machdep.h came from NetBSD.
>> Updates #4682
>>   cpukit/libdl/rtl-mdreloc-aarch64.c            | 598 ++++++++++++++++++
>>   .../cpu/aarch64/include/machine/elf_machdep.h | 256 ++++++++
>>   spec/build/cpukit/objdl.yml                   |   2 +
>>   spec/build/cpukit/objdlaarch64.yml            |  15 +
>>   spec/build/cpukit/optlibdl.yml                |   1 +
>>   5 files changed, 872 insertions(+)
>>   create mode 100644 cpukit/libdl/rtl-mdreloc-aarch64.c
>>   create mode 100644 cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
>>   create mode 100644 spec/build/cpukit/objdlaarch64.yml
>> diff --git a/cpukit/libdl/rtl-mdreloc-aarch64.c b/cpukit/libdl/rtl-mdreloc-aarch64.c
>> new file mode 100644
>> index 0000000000..ded73ad46b
>> --- /dev/null
>> +++ b/cpukit/libdl/rtl-mdreloc-aarch64.c
>> @@ -0,0 +1,598 @@
>> + * Taken from NetBSD and stripped of the relocations not needed on RTEMS.
>> +/* $NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $ */
>> + * Copyright (c) 2014 The NetBSD Foundation, Inc.
>> + * All rights reserved.
>> + * This code is derived from software contributed to The NetBSD Foundation
>> + * by Matt Thomas of 3am Software Foundry.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
>> + * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> + * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> + * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
>> + * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> + * Copyright (c) 2014-2015 The FreeBSD Foundation
>> + * Portions of this software were developed by Andrew Turner
>> + * under sponsorship from the FreeBSD Foundation.
>> + * are met:
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#include <sys/cdefs.h>
>> +#ifndef lint
>> +__RCSID("$NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $");
>> +#endif /* not lint */
>> +#include <sys/types.h>
>> +#include <string.h>
>> +#include <errno.h>
>> +#include <inttypes.h>
>> +#include <sys/stat.h>
>> +#include <sys/endian.h>
>> +#include <unwind.h>
>> +#include <rtems/rtl/rtl.h>
>> +#include "rtl-elf.h"
>> +#include "rtl-error.h"
>> +#include <rtems/rtl/rtl-trace.h>
>> +#include "rtl-unwind.h"
>> +typedef unsigned _Unwind_Word __attribute__((__mode__(__word__)));
>> +typedef _Unwind_Word _uw;
>> +struct tls_data {
>> +	size_t		td_tlsindex;
>> +	Elf_Addr	td_tlsoffs;
>> +rtems_rtl_elf_rel_status
>> +rtems_rtl_elf_reloc_rela (
>> +  rtems_rtl_obj*            obj,
>> +  const Elf_Rela*           rela,
>> +  const rtems_rtl_obj_sect* sect,
>> +  const char*               symname,
>> +  const Elf_Byte            syminfo,
>> +  const Elf_Word            symvalue,
>> +  const bool                parsing
>> +#define __BITS(hi,lo)    ((~((~(Elf_Addr)0)<<((hi)+1)))&((~(Elf_Addr)0)<<(lo)))
>> +#define WIDTHMASK(w)  (0xffffffffffffffffUL >> (64 - (w)))
>> +static inline bool
>> +checkoverflow(Elf_Addr addr, int bitwidth, Elf_Addr targetaddr,
>> +    const char *bitscale, void *where, Elf64_Addr off)
>> +  const Elf_Addr mask = ~__BITS(bitwidth - 1, 0);
>> +  if (((addr & mask) != 0) && ((addr & mask) != mask)) {
>> +    printf("kobj_reloc: Relocation 0x%jx too far from %p"
>> +        " (base+0x%jx) for %dbit%s\n",
>> +        (uintptr_t)targetaddr, where, off, bitwidth, bitscale);
>> +    return true;
>> +  return false;
>> +static inline bool
>> +checkalign(Elf_Addr addr, int alignbyte, void *where, Elf64_Addr off)
>> +  if ((addr & (alignbyte - 1)) != 0) {
>> +    printf("kobj_reloc: Relocation 0x%jx unaligned at %p"
>> +        " (base+0x%jx). must be aligned %d\n",
>> +        (uintptr_t)addr, where, off, alignbyte);
>> +    return true;
>> +  return false;
>> + * Set to 1 to allow untested relocations. If you tested one and it
>> + * works or you fixed the relocation please remove the guard.
>> +#define ALLOW_UNTESTED_RELOCS 1
>> +static void*
>> +set_veneer(void* tramopline, Elf_Addr target)
>> +   * http://shell-storm.org/online/Online-Assembler-and-Disassembler/
>> +   * ldr x9, #8
>> +   * br x9
>> +  uint64_t* tramp = (uint64_t*) tramopline;
>> + #if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
>> +  *tramp++ = 0xd61f012058000049;
>> + #else
>> +  *tramp++ = 0xd61f012058000049; /* not tested */
>> + #endif
>> +  *tramp++ = (uint64_t) target;
>> +  return tramp;
>> +static size_t
>> +get_veneer_size(int type)
>> +  (void) type;
>> +  return 16;
>> +size_t
>> +rtems_rtl_elf_relocate_tramp_max_size (void)
>> +  return 16;
>> +uint32_t
>> +rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
>> +                             const Elf_Shdr*      shdr)
>> +  return 0;
>> +uint32_t
>> +rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj* obj,
>> +                                  int                  section,
>> +                                  const char*          name,
>> +                                  const Elf_Shdr*      shdr,
>> +                                  const uint32_t       flags)
>> +  (void) obj;
>> +  (void) section;
>> +  (void) name;
>> +  (void) shdr;
>> +  return flags;
>> +bool
>> +rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj* obj,
>> +                                  rtems_rtl_obj_sect*  sect)
>> +  (void) obj;
>> +  (void) sect;
>> +  return false;
>> +bool
>> +rtems_rtl_elf_arch_section_free (const rtems_rtl_obj* obj,
>> +  (void) obj;
>> +  (void) sect;
>> +  return false;
>> +bool
>> +rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
>> +  return true;
>> +rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
>> +                          const bool                parsing)
>> +	Elf64_Addr    *where;
>> +	Elf32_Addr    *where32;
>> +	Elf_Addr      off = rela->r_offset;
>> +	Elf_Addr     	target;
>> +	Elf_Addr     	raddr;
>> +  uint32_t      *insn, immhi, immlo, shift;
>> +	where = (Elf_Addr *)(sect->base + rela->r_offset);
>> +  where32 = (void *)where;
> Mixed tabs and spaces? We copy this code into our repo so I suggest you convert
> all tabs to spaces.
Will do.
>> +  insn = (uint32_t *)where;
>> +   * S - the address of the symbol
>> +   * A - the addend of the reolcation
>> +   * P - the address of the place being relocated (derived from r_offset)
>> +   * Page(expr) - the page address of the expression expr, defined as (expr & ~0xFFF).
>> +	switch (ELF_R_TYPE(rela->r_info)) {
>> +	case R_TYPE(NONE):
>> +    if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC)) {
>> +      printf ("rtl: NONE %p in %s\n", where, rtems_rtl_obj_oname (obj));
>> +		break;
>> +	case R_TYPE(ABS64):	/* word S + A */
>> +	case R_TYPE(GLOB_DAT):	/* word S + A */
>> +    if (!parsing) {
>> +      target = (Elf_Addr)symvalue + rela->r_addend;
>> +      if (*where != target)
>> +        *where = target;
>> +        printf ("rtl: reloc 64/GLOB_DAT in %s --> %p in %s\n",
>> +                sect->name, (void *)*where,
>> +                rtems_rtl_obj_oname (obj));
>> +		break;
>> +   * If S is a normal symbol, resolves to the difference between the static
>> +   * link address of S and the execution address of S. If S is the null symbol
>> +   * (ELF symbol index 0), resolves to the difference between the static link
>> +   * address of P and the execution address of P.
>> +	case R_TYPE(RELATIVE):	/* Delta(S) + A */
>> +    if (!parsing) {
>> +      *where = (Elf_Addr)(sect->base + rela->r_addend);
>> +        printf ("rtl: reloc RELATIVE in %s --> %p in %s\n",
>> +		break;
>> +	case R_TYPE(COPY):
>> +		 * These are deferred until all other relocations have
>> +		 * been done.  All we do here is make sure that the
>> +		 * COPY relocation is not in a shared library.  They
>> +		 * are allowed only in executable files.
>> +		printf("rtl: reloc COPY (please report)\n");
>> +		break;
>> +  case R_AARCH64_ADD_ABS_LO12_NC: /* S + A */
>> +  case R_AARCH64_LDST8_ABS_LO12_NC:
>> +  case R_AARCH_LDST16_ABS_LO12_NC:
>> +  case R_AARCH_LDST32_ABS_LO12_NC:
>> +  case R_AARCH_LDST64_ABS_LO12_NC:
>> +        shift = 0;
>> +        break;
>> +        shift = 1;
>> +        break;
>> +        shift = 2;
>> +        break;
>> +        shift = 3;
>> +        break;
>> +      default:
>> +        printf("illegal rtype: %ld\n", ELF_R_TYPE(rela->r_info));
>> +        break;
>> +     * S + A
>> +     *  e.g.) add  x0,x0,#:lo12:<sym>+<addend>
>> +     *        ldrb w0,[x0,#:lo12:<sym>+<addend>]
>> +     *        ldrh w0,[x0,#:lo12:<sym>+<addend>]
>> +     *        ldr  w0,[x0,#:lo12:<sym>+<addend>]
>> +     *        ldr  x0,[x0,#:lo12:<sym>+<addend>]
>> +    if (!parsing) {
>> +      if (checkalign(target, 1 << shift, where, off)) {
>> +        printf ("rtl: reloc checkalign failed in %s --> %p in %s\n",
>> +        printf("ELF_R_TYPE is : %ld\n", ELF_R_TYPE(rela->r_info));
>> +        break;
>> +      target &= WIDTHMASK(12);
>> +      target >>= shift;
>> +      *insn = htole32(
>> +          (le32toh(*insn) & ~__BITS(21,10)) | (target << 10));
>> +    break;
>> +  case R_AARCH64_ADR_PREL_PG_HI21:
>> +     * Page(S + A) - Page(P)
>> +     *  e.g.) adrp x0,<sym>+<addend>
>> +    if (!parsing) {
>> +      target = target >> 12;
>> +      raddr = target << 12;
>> +      target -= (uintptr_t)where >> 12;
>> +      if (checkoverflow(target, 21, raddr, " x 4k", where, off)) {
>> +        return rtems_rtl_elf_rel_failure;
>> +      immlo = target & WIDTHMASK(2);
>> +      immhi = (target >> 2) & WIDTHMASK(19);
>> +      *insn = htole32((le32toh(*insn) &
>> +          ~(__BITS(30,29) | __BITS(23,5))) |
>> +          (immlo << 29) | (immhi << 5));
>> +    break;
>> +  case R_AARCH_JUMP26:
>> +  case R_AARCH_CALL26:
>> +     * S + A - P
>> +     *  e.g.) b <sym>+<addend>
>> +     *        bl <sym>+<addend>
>> +    if (parsing && sect->base == 0) {
>> +        printf ("rtl: JUMP26/PC26/CALL tramp cache\n");
>> +      return rtems_rtl_elf_rel_tramp_cache;
>> +    raddr = (Elf_Addr)symvalue + rela->r_addend;
>> +    target = raddr - (uintptr_t)where;
>> +    if (checkalign(target, 4, where, off)) {
>> +    target = (intptr_t)target >> 2;
>> +    if (((Elf_Sword)target > 0x1FFFFFF) || ((Elf_Sword)target < -0x2000000)) {
>> +      Elf_Word tramp_addr;
>> +      size_t   tramp_size = get_veneer_size(ELF_R_TYPE(rela->r_info));
>> +      if (parsing) {
>> +          printf ("rtl: JUMP26/PC26/CALL tramp add\n");
>> +        return rtems_rtl_elf_rel_tramp_add;
>> +      if (!rtems_rtl_obj_has_tramp_space (obj, tramp_size)) {
>> +        rtems_rtl_set_error (EINVAL,
>> +                             "%s: CALL/JUMP26: overflow: no tramp memory",
>> +                             sect->name);
>> +      tramp_addr = ((Elf_Addr) obj->tramp_brk) | (symvalue & 1);
>> +      obj->tramp_brk = set_veneer(obj->tramp_brk, symvalue);
>> +      target = tramp_addr + rela->r_addend - (uintptr_t)where;
>> +      target = (uintptr_t)target >> 2;
>> +    if (checkoverflow(target, 26, raddr, " word", where, off)) {
>> +    if (!parsing) {
>> +      target &= WIDTHMASK(26);
>> +      *insn = htole32((le32toh(*insn) & ~__BITS(25,0)) | target);
>> +    break;
>> +  case R_AARCH64_PREL32:
>> +     * S + A - P
>> +     *  e.g.) 1: .word <sym>+<addend>-1b
>> +    if (!parsing) {
>> +      if (checkoverflow(target, 32, raddr, "", where, off)) {
>> +      *where32 = target;
>> +    break;
>> +	case R_TYPE(TLSDESC):
>> +    printf ("rtl: reloc TLSDESC in %s --> %p in %s\n",
>> +		break;
>> +	case R_TLS_TYPE(TLS_DTPREL):
>> +    printf ("rtl: reloc TLS_DTPREL in %s --> %p in %s\n",
>> +		break;
>> +	case R_TLS_TYPE(TLS_DTPMOD):
>> +    printf ("rtl: reloc TLS_DTPMOD in %s --> %p in %s\n",
>> +		break;
>> +	case R_TLS_TYPE(TLS_TPREL):
>> +    printf ("rtl: reloc TLS_TPREL in %s --> %p in %s\n",
>> +		break;
>> +	default:
>> +    printf ("rtl: Unsupported relocation type in %s --> %p in %s\n",
>> +            sect->name, (void *)where,
>> +	return rtems_rtl_elf_rel_no_error;
>> +rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj*            obj,
>> +                                   const Elf_Word            symvalue)
>> +  return rtems_rtl_elf_reloc_rela (obj,
>> +                                   rela,
>> +                                   sect,
>> +                                   symname,
>> +                                   syminfo,
>> +                                   symvalue,
>> +                                   true);
>> +rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
>> +                                   rela,
>> +                                   sect,
>> +                                   symname,
>> +                                   syminfo,
>> +                                   symvalue,
>> +                                   false);
>> +rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj*            obj,
>> +                                  const Elf_Rel*            rel,
>> +  rtems_rtl_set_error (EINVAL, "rela type record not supported");
>> +rtems_rtl_elf_relocate_rel (rtems_rtl_obj*            obj,
>> +bool
>> +rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
>> +                            const char*          name,
>> +                            uint32_t             flags)
>> +   * We location the EH sections in section flags.
>> +  return false;
>> +bool
>> +rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj)
>> +  return true;
>> +bool
>> +rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj)
>> +  obj->loader = NULL;
> You cannot touch this field. It belongs to the format loader.
I copied this method from rtl-mdreloc-arm.c, and it's the same way there.
>> +  return true;
>> +/* An exception index table entry.  */
>> +typedef struct __EIT_entry
>> +  _uw fnoffset;
>> +  _uw content;
>> +} __EIT_entry;
>> +/* The exception index table location in the base module */
>> +extern __EIT_entry __exidx_start;
>> +extern __EIT_entry __exidx_end;
>> + * A weak reference is in libgcc, provide a real version and provide a way to
>> + * manage loaded modules.
>> + * Passed in the return address and a reference to the number of records
>> + * found. We set the start of the exidx data and the number of records.
>> +_Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
>> +                                     int*        nrec) __attribute__ ((__noinline__,
>> +        __used__,
>> +        __noclone__));
>> +                                     int*        nrec)
>> +  rtems_rtl_data*   rtl;
>> +  rtems_chain_node* node;
>> +  __EIT_entry*      exidx_start = &__exidx_start;
>> +  __EIT_entry*      exidx_end = &__exidx_end;
>> +  rtl = rtems_rtl_lock ();
>> +  node = rtems_chain_first (&rtl->objects);
>> +  while (!rtems_chain_is_tail (&rtl->objects, node)) {
>> +    rtems_rtl_obj* obj = (rtems_rtl_obj*) node;
>> +    if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
>> +      exidx_start = (__EIT_entry*) obj->eh_base;
>> +      exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
>> +      break;
>> +    node = rtems_chain_next (node);
> Can the RTL chain iterator be used here?
I got this from rtl-mdreloc-arm.c.
>> +  rtems_rtl_unlock ();
>> +  *nrec = exidx_end - exidx_start;
>> +  return (_Unwind_Ptr) exidx_start;
> Can this exception unwind support be placed in rtl-unwind-arm.[ch]?
> I suppose you will need to reference the call from here to bring the symbol into
> the link and override the weak version in gcc?
> Chris
Is it alright if I implement this and take it out of
rtl-mdreloc-aarch64.c and rtl-mdreloc-arm.c in a follow up patch?
>> diff --git a/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h b/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
>> index 0000000000..c1d219d715
>> --- /dev/null
>> +++ b/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
>> @@ -0,0 +1,256 @@
>> +/* $NetBSD: elf_machdep.h,v 1.4 2018/10/12 01:28:58 ryo Exp $ */
>> + * are met:
>> +#ifndef _AARCH64_ELF_MACHDEP_H_
>> +#define _AARCH64_ELF_MACHDEP_H_
>> +#ifdef __aarch64__
>> +#if defined(__AARCH64EB__)
>> +#define ELF64_MACHDEP_ENDIANNESS	ELFDATA2MSB
>> +#define ELF32_MACHDEP_ENDIANNESS	ELFDATA2MSB
>> +#else
>> +#define ELF64_MACHDEP_ENDIANNESS	ELFDATA2LSB
>> +#define ELF32_MACHDEP_ENDIANNESS	ELFDATA2LSB
>> +#endif
>> +/* Processor specific flags for the ELF header e_flags field.  */
>> +#define EF_ARM_RELEXEC		0x00000001
>> +#define EF_ARM_HASENTRY		0x00000002
>> +#define EF_ARM_INTERWORK	0x00000004 /* GNU binutils 000413 */
>> +#define EF_ARM_SYMSARESORTED	0x00000004 /* ARM ELF A08 */
>> +#define EF_ARM_APCS_26		0x00000008 /* GNU binutils 000413 */
>> +#define EF_ARM_DYNSYMSUSESEGIDX	0x00000008 /* ARM ELF B01 */
>> +#define EF_ARM_APCS_FLOAT	0x00000010 /* GNU binutils 000413 */
>> +#define EF_ARM_MAPSYMSFIRST	0x00000010 /* ARM ELF B01 */
>> +#define EF_ARM_PIC		0x00000020
>> +#define EF_ARM_ALIGN8		0x00000040 /* 8-bit structure alignment.  */
>> +#define EF_ARM_NEW_ABI		0x00000080
>> +#define EF_ARM_OLD_ABI		0x00000100
>> +#define EF_ARM_SOFT_FLOAT	0x00000200
>> +#define EF_ARM_BE8		0x00800000
>> +#define EF_ARM_EABIMASK		0xff000000
>> +#define	EF_ARM_EABI_VER1	0x01000000
>> +#define	EF_ARM_EABI_VER2	0x02000000
>> +#define	EF_ARM_EABI_VER3	0x03000000
>> +#define	EF_ARM_EABI_VER4	0x04000000
>> +#define	EF_ARM_EABI_VER5	0x05000000
>> +#define ELF32_MACHDEP_ID_CASES						\
>> +		case EM_ARM:						\
>> +			break;
>> +#define	ELF64_MACHDEP_ID_CASES						\
>> +		case EM_AARCH64:					\
>> +			break;
>> +#define	ELF64_MACHDEP_ID	EM_AARCH64
>> +#define ELF32_MACHDEP_ID	EM_ARM
>> +#define	KERN_ELFSIZE		64
>> +#define ARCH_ELFSIZE		64	/* MD native binary size */
>> +/* Processor specific relocation types */
>> +#define R_AARCH64_NONE			0
>> +#define R_AARCH64_NONE2			256
>> +#define	R_AARCH64_ABS64			257	/* S + A */
>> +#define	R_AARCH64_ABS32			258	/* S + A */
>> +#define	R_AARCH64_ABS16			259	/* S + A */
>> +#define	R_AARCH64_PREL64		260	/* S + A - P */
>> +#define	R_AARCH64_PREL32		261	/* S + A - P */
>> +#define	R_AARCH64_PREL16		262	/* S + A - P */
>> +#define R_AARCH64_MOVW_UABS_G0		263	/* S + A [bits 0..15] */
>> +#define R_AARCH64_MOVW_UABS_G0_NC	264	/* S + A [bits 0..15] */
>> +#define R_AARCH64_MOVW_UABS_G1		265	/* S + A [bits 16..31] */
>> +#define R_AARCH64_MOVW_UABS_G1_NC	266	/* S + A [bits 16..31] */
>> +#define R_AARCH64_MOVW_UABS_G2		267	/* S + A [bits 32..47] */
>> +#define R_AARCH64_MOVW_UABS_G2_NC	268	/* S + A [bits 32..47] */
>> +#define R_AARCH64_MOVW_UABS_G3		269	/* S + A [bits 48..63] */
>> +#define R_AARCH64_MOVW_SABS_G0		270	/* S + A [bits 0..15] */
>> +#define R_AARCH64_MOVW_SABS_G1		271	/* S + A [bits 16..31] */
>> +#define R_AARCH64_MOVW_SABS_G2		272	/* S + A [bits 32..47] */
>> +#define	R_AARCH64_LD_PREL_LO19		273	/* S + A - P */
>> +#define	R_AARCH64_ADR_PREL_LO21		274	/* S + A - P */
>> +#define	R_AARCH64_ADR_PREL_PG_HI21	275	/* Page(S + A) - Page(P) */
>> +#define	R_AARCH64_ADR_PREL_PG_HI21_NC	276	/* Page(S + A) - Page(P) */
>> +#define R_AARCH64_ADD_ABS_LO12_NC	277	/* S + A */
>> +#define	R_AARCH64_LDST8_ABS_LO12_NC	278	/* S + A */
>> +#define R_AARCH_TSTBR14			279	/* S + A - P */
>> +#define R_AARCH_CONDBR19		281	/* S + A - P */
>> +#define R_AARCH_JUMP26			282	/* S + A - P */
>> +#define R_AARCH_CALL26			283	/* S + A - P */
>> +#define R_AARCH_LDST16_ABS_LO12_NC	284	/* S + A */
>> +#define R_AARCH_LDST32_ABS_LO12_NC	285	/* S + A */
>> +#define R_AARCH_LDST64_ABS_LO12_NC	286	/* S + A */
>> +#define R_AARCH64_MOVW_PREL_G0		287	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G0_NC	288	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G1		289	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G1_NC	290	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G2		291	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G2_NC	292	/* S + A - P */
>> +#define R_AARCH64_MOVW_PREL_G3		293	/* S + A - P */
>> +#define R_AARCH64_LDST128_ABS_LO12_NC	299	/* S + A */
>> +#define R_AARCH64_MOVW_GOTOFF_G0	300	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G0_NC	301	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G1	302	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G1_NC	303	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G2	304	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G2_NC	305	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_MOVW_GOTOFF_G3	306	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_GOTREL64		307	/* S + A - GOT */
>> +#define R_AARCH64_GOTREL32		308	/* S + A - GOT */
>> +#define R_AARCH64_GOT_LD_PREL19		309	/* G(GDAT(S + A)) - P */
>> +#define R_AARCH64_LD64_GOTOFF_LO15	310	/* G(GDAT(S + A)) - GOT */
>> +#define R_AARCH64_ADR_GOT_PAGE		311	/* Page(G(GDAT(S + A))) - Page(GOT) */
>> +#define R_AARCH64_LD64_GOT_LO12_NC	312	/* G(GDAT(S + A)) */
>> +#define R_AARCH64_LD64_GOTPAGE_LO15	313	/* G(GDAT(S + A)) - Page(GOT) */
>> +#define R_AARCH64_TLSGD_ADR_PREL21		512	/* G(GTLSIDX(S,A)) - P */
>> +#define R_AARCH64_TLSGD_ADR_PAGE21		513	/* Page(G(GTLSIDX(S,A))) - Page(P) */
>> +#define R_AARCH64_TLSGD_ADD_LO12_NC		514	/* G(GTLSIDX(S,A)) */
>> +#define R_AARCH64_TLSGD_MOVW_G1			515	/* G(GTLSIDX(S,A)) - GOT */
>> +#define R_AARCH64_TLSGD_MOVW_G0_NV		516	/* G(GTLSIDX(S,A)) - GOT */
>> +#define R_AARCH64_TLSLD_ADR_PREL21		517	/* G(GLDM(S,A)) - P */
>> +#define R_AARCH64_TLSLD_ADR_PAGE21		518	/* Page(G(GLDM(S))) - Page(P) */
>> +#define R_AARCH64_TLSLD_ADD_LO12_NC		519	/* G(GLDM(S)) */
>> +#define R_AARCH64_TLSLD_MOVW_G1			520	/* G(GLDM(S)) - GOT */
>> +#define R_AARCH64_TLSLD_MOVW_G0_NC		521	/* G(GLDM(S)) - GOT */
>> +#define R_AARCH64_TLSLD_LD_PREL21		522	/* G(GLDM(S)) - P */
>> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G2		523	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G1		524	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G1_NC	525	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G0		526	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G0_NC	528	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_ADD_DTPREL_HI12		528	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_ADD_DTPREL_LO12		529	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_ADD_DTPREL_LO12_NC	530	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST8_DTPREL_LO12	531	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST8_DTPREL_LO12_NC	532	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST16_DTPREL_LO12	533	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST16_DTPREL_LO12_NC	534	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST32_DTPREL_LO12	535	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST32_DTPREL_LO12_NC	536	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST64_DTPREL_LO12	537	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST64_DTPREL_LO12_NC	538	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSIE_MOVW_GOTTPREL_G1	539	/* G(GTPREL(S+A)) - GOT */
>> +#define R_AARCH64_TLSIE_MOVW_GOTTPREL_G0_NC	540	/* G(GTPREL(S+A)) - GOT */
>> +#define R_AARCH64_TLSIE_ADR_GOTTPREL_PAGE21	541	/* Page(G(GTPREL(S+A))) - Page(P) */
>> +#define R_AARCH64_TLSIE_LD64_GOTTPREL_LO12_NC	542	/* G(GTPREL(S+A)) */
>> +#define R_AARCH64_TLSIE_LD_GOTTPREL_PREL19	543	/* G(GTPREL(S+A)) - P */
>> +#define R_AARCH64_TLSLE_MOVW_TPREL_G2	544	/* TPREL(S+A) */
>> +#define R_AARCH64_MOVW_TPREL_G1		545	/* TPREL(S+A) */
>> +#define R_AARCH64_MOVW_TPREL_G1_NC	546	/* TPREL(S+A) */
>> +#define R_AARCH64_MOVW_TPREL_G0		547	/* TPREL(S+A) */
>> +#define R_AARCH64_MOVW_TPREL_G0_NC	548	/* TPREL(S+A) */
>> +#define R_AARCH64_ADD_TPREL_HI12	549	/* TPREL(S+A) */
>> +#define R_AARCH64_ADD_TPREL_LO12	550	/* TPREL(S+A) */
>> +#define R_AARCH64_ADD_TPREL_LO12_NC	551	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST8_TPREL_LO12	552	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST8_TPREL_LO12_NC	553	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST16_TPREL_LO12	554	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST16_TPREL_LO12_NC	555	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST32_TPREL_LO12	556	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST32_TPREL_LO12_NC	557	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST64_TPREL_LO12	558	/* TPREL(S+A) */
>> +#define R_AARCH64_LDST64_TPREL_LO12_NC	559	/* TPREL(S+A) */
>> +#define R_AARCH64_TLSDESC_LD_PREL19	560	/* G(GTLSDESC(S+A)) - P */
>> +#define R_AARCH64_TLSDESC_LD_PREL21	561	/* G(GTLSDESC(S+A)) - P */
>> +#define R_AARCH64_TLSDESC_LD_PAGE21	562	/* Page(G(GTLSDESC(S+A))) - Page(P) */
>> +#define R_AARCH64_TLSDESC_LD64_LO12	563	/* G(GTLSDESC(S+A)) */
>> +#define R_AARCH64_TLSDESC_ADD_LO12	564	/* G(GTLSDESC(S+A)) */
>> +#define R_AARCH64_TLSDESC_OFF_G1	565	/* G(GTLSDESC(S+A)) - GOT */
>> +#define R_AARCH64_TLSDESC_OFF_G0_NC	566	/* G(GTLSDESC(S+A)) - GOT */
>> +#define R_AARCH64_TLSDESC_LDR		567	/* */
>> +#define R_AARCH64_TLSDESC_ADD		568	/* */
>> +#define R_AARCH64_TLSDESC_CALL		569	/* */
>> +#define R_AARCH64_TLSLE_LDST128_TPREL_LO12	570	/* TPREL(S+A) */
>> +#define R_AARCH64_TLSLE_LDST128_TPREL_LO12_NC	571	/* TPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST128_DTPREL_LO12	572	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLSLD_LDST128_DTPREL_LO12_NC	572	/* DTPREL(S+A) */
>> +/* Dynamic Relocations */
>> +#define R_AARCH64_P32_COPY		180
>> +#define R_AARCH64_P32_GLOB_DAT		181	/* S + A */
>> +#define R_AARCH64_P32_JUMP_SLOT		182	/* S + A */
>> +#define R_AARCH64_P32_RELATIVE		183	/* Delta(S) + A */
>> +#define R_AARCH64_P32_TLS_DTPREL	184	/* DTPREL(S+A) */
>> +#define R_AARCH64_P32_TLS_DTPMOD	185	/* LBM(S) */
>> +#define R_AARCH64_P32_TLS_TPREL		186	/* TPREL(S+A) */
>> +#define R_AARCH64_P32_TLSDESC		187	/* TLSDESC(S+A) */
>> +#define R_AARCH64_P32_IRELATIVE		188	/* Indirect(Delta(S) + A) */
>> +#define R_AARCH64_COPY			1024
>> +#define R_AARCH64_GLOB_DAT		1025	/* S + A */
>> +#define R_AARCH64_JUMP_SLOT		1026	/* S + A */
>> +#define R_AARCH64_RELATIVE		1027	/* Delta(S) + A */
>> +#define R_AARCH64_TLS_DTPREL64		1028	/* DTPREL(S+A) */
>> +#define R_AARCH64_TLS_DTPMOD64		1029	/* LBM(S) */
>> +#define R_AARCH64_TLS_TPREL64		1030	/* TPREL(S+A) */
>> +#define R_AARCH64_TLSDESC		1031	/* TLSDESC(S+A) */
>> +#define R_AARCH64_IRELATIVE		1032	/* Indirect(Delta(S) + A) */
>> +#define R_TYPE(name)		R_AARCH64_ ## name
>> +#define R_TLS_TYPE(name)	R_AARCH64_ ## name ## 64
>> +/* Processor specific program header types */
>> +#define PT_AARCH64_ARCHEXT	(PT_LOPROC + 0)
>> +#define PT_AARCH64_UNWIND	(PT_LOPROC + 1)
>> +/* Processor specific section header flags */
>> +#define SHF_ENTRYSECT		0x10000000
>> +#define SHF_COMDEF		0x80000000
>> +#define SHT_AARCH64_ATTRIBUTES	(SHT_LOPROC + 3)
>> +#ifdef _KERNEL
>> +#ifdef ELFSIZE
>> +#define	ELF_MD_PROBE_FUNC	ELFNAME2(aarch64_netbsd,probe)
>> +#endif
>> +struct exec_package;
>> +int aarch64_netbsd_elf64_probe(struct lwp *, struct exec_package *, void *,
>> +	char *, vaddr_t *);
>> +int aarch64_netbsd_elf32_probe(struct lwp *, struct exec_package *, void *,
>> +#endif
>> +#elif defined(__arm__)
>> +#include <arm/elf_machdep.h>
>> +#endif
>> +#endif /* _AARCH64_ELF_MACHDEP_H_ */
>> diff --git a/spec/build/cpukit/objdl.yml b/spec/build/cpukit/objdl.yml
>> index 05de6ca882..c312e04eb7 100644
>> --- a/spec/build/cpukit/objdl.yml
>> +++ b/spec/build/cpukit/objdl.yml
>> @@ -28,6 +28,8 @@ install:
>>     - cpukit/include/rtems/rtl/rtl-unresolved.h
>>     - cpukit/include/rtems/rtl/rtl.h
>>   links:
>> +- role: build-dependency
>> +  uid: objdlaarch64
>>     uid: objdlarm
>> diff --git a/spec/build/cpukit/objdlaarch64.yml b/spec/build/cpukit/objdlaarch64.yml
>> index 0000000000..2909a902f2
>> --- /dev/null
>> +++ b/spec/build/cpukit/objdlaarch64.yml
>> @@ -0,0 +1,15 @@
>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> +build-type: objects
>> +cflags: []
>> +copyrights:
>> +- Copyright (C) 2022 On-Line Applications Research (OAR)
>> +cppflags: []
>> +cxxflags: []
>> +enabled-by:
>> +- aarch64
>> +includes: []
>> +install: []
>> +links: []
>> +source:
>> +- cpukit/libdl/rtl-mdreloc-aarch64.c
>> +type: build
>> diff --git a/spec/build/cpukit/optlibdl.yml b/spec/build/cpukit/optlibdl.yml
>> index 8b9f5e1209..a3269c68ea 100644
>> --- a/spec/build/cpukit/optlibdl.yml
>> +++ b/spec/build/cpukit/optlibdl.yml
>> @@ -9,6 +9,7 @@ default: null
>>   default-by-variant: []
>>   description: ''
>>   enabled-by:
>> +- aarch64
>>   - arm
>>   - i386
>>   - m68k
