[PATCH v1 3/5] cpukit/libdl: Add support for AArch64
Chris Johns
chrisj at rtems.org
Thu Jul 21 04:39:32 UTC 2022
On 21/7/2022 7:36 am, Ryan Long wrote:
> rtl-mdreloc-aarch64.c and elf_machdep.h came from NetBSD.
> Updates #4682
> cpukit/libdl/rtl-mdreloc-aarch64.c | 598 ++++++++++++++++++
> .../cpu/aarch64/include/machine/elf_machdep.h | 256 ++++++++
> spec/build/cpukit/objdl.yml | 2 +
> spec/build/cpukit/objdlaarch64.yml | 15 +
> spec/build/cpukit/optlibdl.yml | 1 +
> 5 files changed, 872 insertions(+)
> create mode 100644 cpukit/libdl/rtl-mdreloc-aarch64.c
> create mode 100644 cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
> create mode 100644 spec/build/cpukit/objdlaarch64.yml
> diff --git a/cpukit/libdl/rtl-mdreloc-aarch64.c b/cpukit/libdl/rtl-mdreloc-aarch64.c
> new file mode 100644
> index 0000000000..ded73ad46b
> --- /dev/null
> +++ b/cpukit/libdl/rtl-mdreloc-aarch64.c
> @@ -0,0 +1,598 @@
> + * Taken from NetBSD and stripped of the relocations not needed on RTEMS.
> +/* $NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $ */
> + * Copyright (c) 2014 The NetBSD Foundation, Inc.
> + * All rights reserved.
> + * This code is derived from software contributed to The NetBSD Foundation
> + * by Matt Thomas of 3am Software Foundry.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
> + * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> + * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> + * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
> + * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * Copyright (c) 2014-2015 The FreeBSD Foundation
> + * Portions of this software were developed by Andrew Turner
> + * under sponsorship from the FreeBSD Foundation.
> + * are met:
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#include <sys/cdefs.h>
> +#ifndef lint
> +__RCSID("$NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $");
> +#endif /* not lint */
> +#include <sys/types.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <inttypes.h>
> +#include <sys/stat.h>
> +#include <sys/endian.h>
> +#include <unwind.h>
> +#include <rtems/rtl/rtl.h>
> +#include "rtl-elf.h"
> +#include "rtl-error.h"
> +#include <rtems/rtl/rtl-trace.h>
> +#include "rtl-unwind.h"
> +typedef unsigned _Unwind_Word __attribute__((__mode__(__word__)));
> +typedef _Unwind_Word _uw;
> +struct tls_data {
> + size_t td_tlsindex;
> + Elf_Addr td_tlsoffs;
> +rtems_rtl_elf_rel_status
> +rtems_rtl_elf_reloc_rela (
> + rtems_rtl_obj* obj,
> + const Elf_Rela* rela,
> + const rtems_rtl_obj_sect* sect,
> + const char* symname,
> + const Elf_Byte syminfo,
> + const Elf_Word symvalue,
> + const bool parsing
> +#define __BITS(hi,lo) ((~((~(Elf_Addr)0)<<((hi)+1)))&((~(Elf_Addr)0)<<(lo)))
> +#define WIDTHMASK(w) (0xffffffffffffffffUL >> (64 - (w)))
> +static inline bool
> +checkoverflow(Elf_Addr addr, int bitwidth, Elf_Addr targetaddr,
> + const char *bitscale, void *where, Elf64_Addr off)
> + const Elf_Addr mask = ~__BITS(bitwidth - 1, 0);
> + if (((addr & mask) != 0) && ((addr & mask) != mask)) {
> + printf("kobj_reloc: Relocation 0x%jx too far from %p"
> + " (base+0x%jx) for %dbit%s\n",
> + (uintptr_t)targetaddr, where, off, bitwidth, bitscale);
> + return true;
> + return false;
> +static inline bool
> +checkalign(Elf_Addr addr, int alignbyte, void *where, Elf64_Addr off)
> + if ((addr & (alignbyte - 1)) != 0) {
> + printf("kobj_reloc: Relocation 0x%jx unaligned at %p"
> + " (base+0x%jx). must be aligned %d\n",
> + (uintptr_t)addr, where, off, alignbyte);
> + return true;
> + return false;
> + * Set to 1 to allow untested relocations. If you tested one and it
> + * works or you fixed the relocation please remove the guard.
> +#define ALLOW_UNTESTED_RELOCS 1
> +static void*
> +set_veneer(void* tramopline, Elf_Addr target)
> + * http://shell-storm.org/online/Online-Assembler-and-Disassembler/
> + * ldr x9, #8
> + * br x9
> + uint64_t* tramp = (uint64_t*) tramopline;
> + #if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
> + *tramp++ = 0xd61f012058000049;
> + #else
> + *tramp++ = 0xd61f012058000049; /* not tested */
> + #endif
> + *tramp++ = (uint64_t) target;
> + return tramp;
> +static size_t
> +get_veneer_size(int type)
> + (void) type;
> + return 16;
> +size_t
> +rtems_rtl_elf_relocate_tramp_max_size (void)
> + return 16;
> +uint32_t
> +rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
> + const Elf_Shdr* shdr)
> + return 0;
> +uint32_t
> +rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj* obj,
> + int section,
> + const char* name,
> + const Elf_Shdr* shdr,
> + const uint32_t flags)
> + (void) obj;
> + (void) section;
> + (void) name;
> + (void) shdr;
> + return flags;
> +bool
> +rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj* obj,
> + rtems_rtl_obj_sect* sect)
> + (void) obj;
> + (void) sect;
> + return false;
> +bool
> +rtems_rtl_elf_arch_section_free (const rtems_rtl_obj* obj,
> + (void) obj;
> + (void) sect;
> + return false;
> +bool
> +rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
> + return true;
> +rtems_rtl_elf_reloc_rela (rtems_rtl_obj* obj,
> + const bool parsing)
> + Elf64_Addr *where;
> + Elf32_Addr *where32;
> + Elf_Addr off = rela->r_offset;
> + Elf_Addr target;
> + Elf_Addr raddr;
> + uint32_t *insn, immhi, immlo, shift;
> + where = (Elf_Addr *)(sect->base + rela->r_offset);
> + where32 = (void *)where;
Mixed tabs and spaces? We copy this code into our repo so I suggest you convert
all tabs to spaces.
> + insn = (uint32_t *)where;
> + * S - the address of the symbol
> + * A - the addend of the reolcation
> + * P - the address of the place being relocated (derived from r_offset)
> + * Page(expr) - the page address of the expression expr, defined as (expr & ~0xFFF).
> + switch (ELF_R_TYPE(rela->r_info)) {
> + case R_TYPE(NONE):
> + if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC)) {
> + printf ("rtl: NONE %p in %s\n", where, rtems_rtl_obj_oname (obj));
> + break;
> + case R_TYPE(ABS64): /* word S + A */
> + case R_TYPE(GLOB_DAT): /* word S + A */
> + if (!parsing) {
> + target = (Elf_Addr)symvalue + rela->r_addend;
> + if (*where != target)
> + *where = target;
> + printf ("rtl: reloc 64/GLOB_DAT in %s --> %p in %s\n",
> + sect->name, (void *)*where,
> + rtems_rtl_obj_oname (obj));
> + break;
> + * If S is a normal symbol, resolves to the difference between the static
> + * link address of S and the execution address of S. If S is the null symbol
> + * (ELF symbol index 0), resolves to the difference between the static link
> + * address of P and the execution address of P.
> + case R_TYPE(RELATIVE): /* Delta(S) + A */
> + if (!parsing) {
> + *where = (Elf_Addr)(sect->base + rela->r_addend);
> + printf ("rtl: reloc RELATIVE in %s --> %p in %s\n",
> + break;
> + case R_TYPE(COPY):
> + * These are deferred until all other relocations have
> + * been done. All we do here is make sure that the
> + * COPY relocation is not in a shared library. They
> + * are allowed only in executable files.
> + printf("rtl: reloc COPY (please report)\n");
> + break;
> + case R_AARCH64_ADD_ABS_LO12_NC: /* S + A */
> + case R_AARCH64_LDST8_ABS_LO12_NC:
> + case R_AARCH_LDST16_ABS_LO12_NC:
> + case R_AARCH_LDST32_ABS_LO12_NC:
> + case R_AARCH_LDST64_ABS_LO12_NC:
> + shift = 0;
> + break;
> + shift = 1;
> + break;
> + shift = 2;
> + break;
> + shift = 3;
> + break;
> + default:
> + printf("illegal rtype: %ld\n", ELF_R_TYPE(rela->r_info));
> + break;
> + * S + A
> + * e.g.) add x0,x0,#:lo12:<sym>+<addend>
> + * ldrb w0,[x0,#:lo12:<sym>+<addend>]
> + * ldrh w0,[x0,#:lo12:<sym>+<addend>]
> + * ldr w0,[x0,#:lo12:<sym>+<addend>]
> + * ldr x0,[x0,#:lo12:<sym>+<addend>]
> + if (!parsing) {
> + if (checkalign(target, 1 << shift, where, off)) {
> + printf ("rtl: reloc checkalign failed in %s --> %p in %s\n",
> + printf("ELF_R_TYPE is : %ld\n", ELF_R_TYPE(rela->r_info));
> + break;
> + target &= WIDTHMASK(12);
> + target >>= shift;
> + *insn = htole32(
> + (le32toh(*insn) & ~__BITS(21,10)) | (target << 10));
> + break;
> + case R_AARCH64_ADR_PREL_PG_HI21:
> + * Page(S + A) - Page(P)
> + * e.g.) adrp x0,<sym>+<addend>
> + if (!parsing) {
> + target = target >> 12;
> + raddr = target << 12;
> + target -= (uintptr_t)where >> 12;
> + if (checkoverflow(target, 21, raddr, " x 4k", where, off)) {
> + return rtems_rtl_elf_rel_failure;
> + immlo = target & WIDTHMASK(2);
> + immhi = (target >> 2) & WIDTHMASK(19);
> + *insn = htole32((le32toh(*insn) &
> + ~(__BITS(30,29) | __BITS(23,5))) |
> + (immlo << 29) | (immhi << 5));
> + break;
> + case R_AARCH_JUMP26:
> + case R_AARCH_CALL26:
> + * S + A - P
> + * e.g.) b <sym>+<addend>
> + * bl <sym>+<addend>
> + if (parsing && sect->base == 0) {
> + printf ("rtl: JUMP26/PC26/CALL tramp cache\n");
> + return rtems_rtl_elf_rel_tramp_cache;
> + raddr = (Elf_Addr)symvalue + rela->r_addend;
> + target = raddr - (uintptr_t)where;
> + if (checkalign(target, 4, where, off)) {
> + target = (intptr_t)target >> 2;
> + if (((Elf_Sword)target > 0x1FFFFFF) || ((Elf_Sword)target < -0x2000000)) {
> + Elf_Word tramp_addr;
> + size_t tramp_size = get_veneer_size(ELF_R_TYPE(rela->r_info));
> + if (parsing) {
> + printf ("rtl: JUMP26/PC26/CALL tramp add\n");
> + return rtems_rtl_elf_rel_tramp_add;
> + if (!rtems_rtl_obj_has_tramp_space (obj, tramp_size)) {
> + rtems_rtl_set_error (EINVAL,
> + "%s: CALL/JUMP26: overflow: no tramp memory",
> + sect->name);
> + tramp_addr = ((Elf_Addr) obj->tramp_brk) | (symvalue & 1);
> + obj->tramp_brk = set_veneer(obj->tramp_brk, symvalue);
> + target = tramp_addr + rela->r_addend - (uintptr_t)where;
> + target = (uintptr_t)target >> 2;
> + if (checkoverflow(target, 26, raddr, " word", where, off)) {
> + if (!parsing) {
> + target &= WIDTHMASK(26);
> + *insn = htole32((le32toh(*insn) & ~__BITS(25,0)) | target);
> + break;
> + case R_AARCH64_PREL32:
> + * S + A - P
> + * e.g.) 1: .word <sym>+<addend>-1b
> + if (!parsing) {
> + if (checkoverflow(target, 32, raddr, "", where, off)) {
> + *where32 = target;
> + break;
> + case R_TYPE(TLSDESC):
> + printf ("rtl: reloc TLSDESC in %s --> %p in %s\n",
> + break;
> + case R_TLS_TYPE(TLS_DTPREL):
> + printf ("rtl: reloc TLS_DTPREL in %s --> %p in %s\n",
> + break;
> + case R_TLS_TYPE(TLS_DTPMOD):
> + printf ("rtl: reloc TLS_DTPMOD in %s --> %p in %s\n",
> + break;
> + case R_TLS_TYPE(TLS_TPREL):
> + printf ("rtl: reloc TLS_TPREL in %s --> %p in %s\n",
> + break;
> + default:
> + printf ("rtl: Unsupported relocation type in %s --> %p in %s\n",
> + sect->name, (void *)where,
> + return rtems_rtl_elf_rel_no_error;
> +rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj* obj,
> + const Elf_Word symvalue)
> + return rtems_rtl_elf_reloc_rela (obj,
> + rela,
> + sect,
> + symname,
> + syminfo,
> + symvalue,
> + true);
> +rtems_rtl_elf_relocate_rela (rtems_rtl_obj* obj,
> + rela,
> + sect,
> + symname,
> + syminfo,
> + symvalue,
> + false);
> +rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj* obj,
> + const Elf_Rel* rel,
> + rtems_rtl_set_error (EINVAL, "rela type record not supported");
> +rtems_rtl_elf_relocate_rel (rtems_rtl_obj* obj,
> +bool
> +rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
> + const char* name,
> + uint32_t flags)
> + * We location the EH sections in section flags.
> + return false;
> +bool
> +rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj)
> + return true;
> +bool
> +rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj)
> + obj->loader = NULL;
You cannot touch this field. It belongs to the format loader.
> + return true;
> +/* An exception index table entry. */
> +typedef struct __EIT_entry
> + _uw fnoffset;
> + _uw content;
> +} __EIT_entry;
> +/* The exception index table location in the base module */
> +extern __EIT_entry __exidx_start;
> +extern __EIT_entry __exidx_end;
> + * A weak reference is in libgcc, provide a real version and provide a way to
> + * manage loaded modules.
> + * Passed in the return address and a reference to the number of records
> + * found. We set the start of the exidx data and the number of records.
> +_Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
> + int* nrec) __attribute__ ((__noinline__,
> + __used__,
> + __noclone__));
> + int* nrec)
> + rtems_rtl_data* rtl;
> + rtems_chain_node* node;
> + __EIT_entry* exidx_start = &__exidx_start;
> + __EIT_entry* exidx_end = &__exidx_end;
> + rtl = rtems_rtl_lock ();
> + node = rtems_chain_first (&rtl->objects);
> + while (!rtems_chain_is_tail (&rtl->objects, node)) {
> + rtems_rtl_obj* obj = (rtems_rtl_obj*) node;
> + if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
> + exidx_start = (__EIT_entry*) obj->eh_base;
> + exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
> + break;
> + node = rtems_chain_next (node);
Can the RTL chain iterator be used here?
> + rtems_rtl_unlock ();
> + *nrec = exidx_end - exidx_start;
> + return (_Unwind_Ptr) exidx_start;
Can this exception unwind support be placed in rtl-unwind-arm.[ch]?
I suppose you will need to reference the call from here to bring the symbol into
the link and override the weak version in gcc?
> diff --git a/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h b/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
> index 0000000000..c1d219d715
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/include/machine/elf_machdep.h
> @@ -0,0 +1,256 @@
> +/* $NetBSD: elf_machdep.h,v 1.4 2018/10/12 01:28:58 ryo Exp $ */
> + * are met:
> +#ifndef _AARCH64_ELF_MACHDEP_H_
> +#define _AARCH64_ELF_MACHDEP_H_
> +#ifdef __aarch64__
> +#if defined(__AARCH64EB__)
> +#define ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB
> +#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
> +#else
> +#define ELF64_MACHDEP_ENDIANNESS ELFDATA2LSB
> +#define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
> +#endif
> +/* Processor specific flags for the ELF header e_flags field. */
> +#define EF_ARM_RELEXEC 0x00000001
> +#define EF_ARM_HASENTRY 0x00000002
> +#define EF_ARM_INTERWORK 0x00000004 /* GNU binutils 000413 */
> +#define EF_ARM_SYMSARESORTED 0x00000004 /* ARM ELF A08 */
> +#define EF_ARM_APCS_26 0x00000008 /* GNU binutils 000413 */
> +#define EF_ARM_DYNSYMSUSESEGIDX 0x00000008 /* ARM ELF B01 */
> +#define EF_ARM_APCS_FLOAT 0x00000010 /* GNU binutils 000413 */
> +#define EF_ARM_MAPSYMSFIRST 0x00000010 /* ARM ELF B01 */
> +#define EF_ARM_PIC 0x00000020
> +#define EF_ARM_ALIGN8 0x00000040 /* 8-bit structure alignment. */
> +#define EF_ARM_NEW_ABI 0x00000080
> +#define EF_ARM_OLD_ABI 0x00000100
> +#define EF_ARM_SOFT_FLOAT 0x00000200
> +#define EF_ARM_BE8 0x00800000
> +#define EF_ARM_EABIMASK 0xff000000
> +#define EF_ARM_EABI_VER1 0x01000000
> +#define EF_ARM_EABI_VER2 0x02000000
> +#define EF_ARM_EABI_VER3 0x03000000
> +#define EF_ARM_EABI_VER4 0x04000000
> +#define EF_ARM_EABI_VER5 0x05000000
> +#define ELF32_MACHDEP_ID_CASES \
> + case EM_ARM: \
> + break;
> +#define ELF64_MACHDEP_ID_CASES \
> + case EM_AARCH64: \
> + break;
> +#define ELF64_MACHDEP_ID EM_AARCH64
> +#define ELF32_MACHDEP_ID EM_ARM
> +#define KERN_ELFSIZE 64
> +#define ARCH_ELFSIZE 64 /* MD native binary size */
> +/* Processor specific relocation types */
> +#define R_AARCH64_NONE 0
> +#define R_AARCH64_NONE2 256
> +#define R_AARCH64_ABS64 257 /* S + A */
> +#define R_AARCH64_ABS32 258 /* S + A */
> +#define R_AARCH64_ABS16 259 /* S + A */
> +#define R_AARCH64_PREL64 260 /* S + A - P */
> +#define R_AARCH64_PREL32 261 /* S + A - P */
> +#define R_AARCH64_PREL16 262 /* S + A - P */
> +#define R_AARCH64_MOVW_UABS_G0 263 /* S + A [bits 0..15] */
> +#define R_AARCH64_MOVW_UABS_G0_NC 264 /* S + A [bits 0..15] */
> +#define R_AARCH64_MOVW_UABS_G1 265 /* S + A [bits 16..31] */
> +#define R_AARCH64_MOVW_UABS_G1_NC 266 /* S + A [bits 16..31] */
> +#define R_AARCH64_MOVW_UABS_G2 267 /* S + A [bits 32..47] */
> +#define R_AARCH64_MOVW_UABS_G2_NC 268 /* S + A [bits 32..47] */
> +#define R_AARCH64_MOVW_UABS_G3 269 /* S + A [bits 48..63] */
> +#define R_AARCH64_MOVW_SABS_G0 270 /* S + A [bits 0..15] */
> +#define R_AARCH64_MOVW_SABS_G1 271 /* S + A [bits 16..31] */
> +#define R_AARCH64_MOVW_SABS_G2 272 /* S + A [bits 32..47] */
> +#define R_AARCH64_LD_PREL_LO19 273 /* S + A - P */
> +#define R_AARCH64_ADR_PREL_LO21 274 /* S + A - P */
> +#define R_AARCH64_ADR_PREL_PG_HI21 275 /* Page(S + A) - Page(P) */
> +#define R_AARCH64_ADR_PREL_PG_HI21_NC 276 /* Page(S + A) - Page(P) */
> +#define R_AARCH64_ADD_ABS_LO12_NC 277 /* S + A */
> +#define R_AARCH64_LDST8_ABS_LO12_NC 278 /* S + A */
> +#define R_AARCH_TSTBR14 279 /* S + A - P */
> +#define R_AARCH_CONDBR19 281 /* S + A - P */
> +#define R_AARCH_JUMP26 282 /* S + A - P */
> +#define R_AARCH_CALL26 283 /* S + A - P */
> +#define R_AARCH_LDST16_ABS_LO12_NC 284 /* S + A */
> +#define R_AARCH_LDST32_ABS_LO12_NC 285 /* S + A */
> +#define R_AARCH_LDST64_ABS_LO12_NC 286 /* S + A */
> +#define R_AARCH64_MOVW_PREL_G0 287 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G0_NC 288 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G1 289 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G1_NC 290 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G2 291 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G2_NC 292 /* S + A - P */
> +#define R_AARCH64_MOVW_PREL_G3 293 /* S + A - P */
> +#define R_AARCH64_LDST128_ABS_LO12_NC 299 /* S + A */
> +#define R_AARCH64_MOVW_GOTOFF_G0 300 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G0_NC 301 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G1 302 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G1_NC 303 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G2 304 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G2_NC 305 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_MOVW_GOTOFF_G3 306 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_GOTREL64 307 /* S + A - GOT */
> +#define R_AARCH64_GOTREL32 308 /* S + A - GOT */
> +#define R_AARCH64_GOT_LD_PREL19 309 /* G(GDAT(S + A)) - P */
> +#define R_AARCH64_LD64_GOTOFF_LO15 310 /* G(GDAT(S + A)) - GOT */
> +#define R_AARCH64_ADR_GOT_PAGE 311 /* Page(G(GDAT(S + A))) - Page(GOT) */
> +#define R_AARCH64_LD64_GOT_LO12_NC 312 /* G(GDAT(S + A)) */
> +#define R_AARCH64_LD64_GOTPAGE_LO15 313 /* G(GDAT(S + A)) - Page(GOT) */
> +#define R_AARCH64_TLSGD_ADR_PREL21 512 /* G(GTLSIDX(S,A)) - P */
> +#define R_AARCH64_TLSGD_ADR_PAGE21 513 /* Page(G(GTLSIDX(S,A))) - Page(P) */
> +#define R_AARCH64_TLSGD_ADD_LO12_NC 514 /* G(GTLSIDX(S,A)) */
> +#define R_AARCH64_TLSGD_MOVW_G1 515 /* G(GTLSIDX(S,A)) - GOT */
> +#define R_AARCH64_TLSGD_MOVW_G0_NV 516 /* G(GTLSIDX(S,A)) - GOT */
> +#define R_AARCH64_TLSLD_ADR_PREL21 517 /* G(GLDM(S,A)) - P */
> +#define R_AARCH64_TLSLD_ADR_PAGE21 518 /* Page(G(GLDM(S))) - Page(P) */
> +#define R_AARCH64_TLSLD_ADD_LO12_NC 519 /* G(GLDM(S)) */
> +#define R_AARCH64_TLSLD_MOVW_G1 520 /* G(GLDM(S)) - GOT */
> +#define R_AARCH64_TLSLD_MOVW_G0_NC 521 /* G(GLDM(S)) - GOT */
> +#define R_AARCH64_TLSLD_LD_PREL21 522 /* G(GLDM(S)) - P */
> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G2 523 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G1 524 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G1_NC 525 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G0 526 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_MOVW_DTPREL_G0_NC 528 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_ADD_DTPREL_HI12 528 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_ADD_DTPREL_LO12 529 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_ADD_DTPREL_LO12_NC 530 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST8_DTPREL_LO12 531 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST8_DTPREL_LO12_NC 532 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST16_DTPREL_LO12 533 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST16_DTPREL_LO12_NC 534 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST32_DTPREL_LO12 535 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST32_DTPREL_LO12_NC 536 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST64_DTPREL_LO12 537 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST64_DTPREL_LO12_NC 538 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSIE_MOVW_GOTTPREL_G1 539 /* G(GTPREL(S+A)) - GOT */
> +#define R_AARCH64_TLSIE_MOVW_GOTTPREL_G0_NC 540 /* G(GTPREL(S+A)) - GOT */
> +#define R_AARCH64_TLSIE_ADR_GOTTPREL_PAGE21 541 /* Page(G(GTPREL(S+A))) - Page(P) */
> +#define R_AARCH64_TLSIE_LD64_GOTTPREL_LO12_NC 542 /* G(GTPREL(S+A)) */
> +#define R_AARCH64_TLSIE_LD_GOTTPREL_PREL19 543 /* G(GTPREL(S+A)) - P */
> +#define R_AARCH64_TLSLE_MOVW_TPREL_G2 544 /* TPREL(S+A) */
> +#define R_AARCH64_MOVW_TPREL_G1 545 /* TPREL(S+A) */
> +#define R_AARCH64_MOVW_TPREL_G1_NC 546 /* TPREL(S+A) */
> +#define R_AARCH64_MOVW_TPREL_G0 547 /* TPREL(S+A) */
> +#define R_AARCH64_MOVW_TPREL_G0_NC 548 /* TPREL(S+A) */
> +#define R_AARCH64_ADD_TPREL_HI12 549 /* TPREL(S+A) */
> +#define R_AARCH64_ADD_TPREL_LO12 550 /* TPREL(S+A) */
> +#define R_AARCH64_ADD_TPREL_LO12_NC 551 /* TPREL(S+A) */
> +#define R_AARCH64_LDST8_TPREL_LO12 552 /* TPREL(S+A) */
> +#define R_AARCH64_LDST8_TPREL_LO12_NC 553 /* TPREL(S+A) */
> +#define R_AARCH64_LDST16_TPREL_LO12 554 /* TPREL(S+A) */
> +#define R_AARCH64_LDST16_TPREL_LO12_NC 555 /* TPREL(S+A) */
> +#define R_AARCH64_LDST32_TPREL_LO12 556 /* TPREL(S+A) */
> +#define R_AARCH64_LDST32_TPREL_LO12_NC 557 /* TPREL(S+A) */
> +#define R_AARCH64_LDST64_TPREL_LO12 558 /* TPREL(S+A) */
> +#define R_AARCH64_LDST64_TPREL_LO12_NC 559 /* TPREL(S+A) */
> +#define R_AARCH64_TLSDESC_LD_PREL19 560 /* G(GTLSDESC(S+A)) - P */
> +#define R_AARCH64_TLSDESC_LD_PREL21 561 /* G(GTLSDESC(S+A)) - P */
> +#define R_AARCH64_TLSDESC_LD_PAGE21 562 /* Page(G(GTLSDESC(S+A))) - Page(P) */
> +#define R_AARCH64_TLSDESC_LD64_LO12 563 /* G(GTLSDESC(S+A)) */
> +#define R_AARCH64_TLSDESC_ADD_LO12 564 /* G(GTLSDESC(S+A)) */
> +#define R_AARCH64_TLSDESC_OFF_G1 565 /* G(GTLSDESC(S+A)) - GOT */
> +#define R_AARCH64_TLSDESC_OFF_G0_NC 566 /* G(GTLSDESC(S+A)) - GOT */
> +#define R_AARCH64_TLSDESC_LDR 567 /* */
> +#define R_AARCH64_TLSDESC_ADD 568 /* */
> +#define R_AARCH64_TLSDESC_CALL 569 /* */
> +#define R_AARCH64_TLSLE_LDST128_TPREL_LO12 570 /* TPREL(S+A) */
> +#define R_AARCH64_TLSLE_LDST128_TPREL_LO12_NC 571 /* TPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST128_DTPREL_LO12 572 /* DTPREL(S+A) */
> +#define R_AARCH64_TLSLD_LDST128_DTPREL_LO12_NC 572 /* DTPREL(S+A) */
> +/* Dynamic Relocations */
> +#define R_AARCH64_P32_COPY 180
> +#define R_AARCH64_P32_GLOB_DAT 181 /* S + A */
> +#define R_AARCH64_P32_JUMP_SLOT 182 /* S + A */
> +#define R_AARCH64_P32_RELATIVE 183 /* Delta(S) + A */
> +#define R_AARCH64_P32_TLS_DTPREL 184 /* DTPREL(S+A) */
> +#define R_AARCH64_P32_TLS_DTPMOD 185 /* LBM(S) */
> +#define R_AARCH64_P32_TLS_TPREL 186 /* TPREL(S+A) */
> +#define R_AARCH64_P32_TLSDESC 187 /* TLSDESC(S+A) */
> +#define R_AARCH64_P32_IRELATIVE 188 /* Indirect(Delta(S) + A) */
> +#define R_AARCH64_COPY 1024
> +#define R_AARCH64_GLOB_DAT 1025 /* S + A */
> +#define R_AARCH64_JUMP_SLOT 1026 /* S + A */
> +#define R_AARCH64_RELATIVE 1027 /* Delta(S) + A */
> +#define R_AARCH64_TLS_DTPREL64 1028 /* DTPREL(S+A) */
> +#define R_AARCH64_TLS_DTPMOD64 1029 /* LBM(S) */
> +#define R_AARCH64_TLS_TPREL64 1030 /* TPREL(S+A) */
> +#define R_AARCH64_TLSDESC 1031 /* TLSDESC(S+A) */
> +#define R_AARCH64_IRELATIVE 1032 /* Indirect(Delta(S) + A) */
> +#define R_TYPE(name) R_AARCH64_ ## name
> +#define R_TLS_TYPE(name) R_AARCH64_ ## name ## 64
> +/* Processor specific program header types */
> +#define PT_AARCH64_ARCHEXT (PT_LOPROC + 0)
> +#define PT_AARCH64_UNWIND (PT_LOPROC + 1)
> +/* Processor specific section header flags */
> +#define SHF_ENTRYSECT 0x10000000
> +#define SHF_COMDEF 0x80000000
> +#define SHT_AARCH64_ATTRIBUTES (SHT_LOPROC + 3)
> +#ifdef _KERNEL
> +#ifdef ELFSIZE
> +#define ELF_MD_PROBE_FUNC ELFNAME2(aarch64_netbsd,probe)
> +#endif
> +struct exec_package;
> +int aarch64_netbsd_elf64_probe(struct lwp *, struct exec_package *, void *,
> + char *, vaddr_t *);
> +int aarch64_netbsd_elf32_probe(struct lwp *, struct exec_package *, void *,
> +#endif
> +#elif defined(__arm__)
> +#include <arm/elf_machdep.h>
> +#endif
> +#endif /* _AARCH64_ELF_MACHDEP_H_ */
> diff --git a/spec/build/cpukit/objdl.yml b/spec/build/cpukit/objdl.yml
> index 05de6ca882..c312e04eb7 100644
> --- a/spec/build/cpukit/objdl.yml
> +++ b/spec/build/cpukit/objdl.yml
> @@ -28,6 +28,8 @@ install:
> - cpukit/include/rtems/rtl/rtl-unresolved.h
> - cpukit/include/rtems/rtl/rtl.h
> links:
> +- role: build-dependency
> + uid: objdlaarch64
> uid: objdlarm
> diff --git a/spec/build/cpukit/objdlaarch64.yml b/spec/build/cpukit/objdlaarch64.yml
> index 0000000000..2909a902f2
> --- /dev/null
> +++ b/spec/build/cpukit/objdlaarch64.yml
> @@ -0,0 +1,15 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2022 On-Line Applications Research (OAR)
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +- aarch64
> +includes: []
> +install: []
> +links: []
> +source:
> +- cpukit/libdl/rtl-mdreloc-aarch64.c
> +type: build
> diff --git a/spec/build/cpukit/optlibdl.yml b/spec/build/cpukit/optlibdl.yml
> index 8b9f5e1209..a3269c68ea 100644
> --- a/spec/build/cpukit/optlibdl.yml
> +++ b/spec/build/cpukit/optlibdl.yml
> @@ -9,6 +9,7 @@ default: null
> default-by-variant: []
> description: ''
> enabled-by:
> +- aarch64
> - arm
> - i386
> - m68k
