[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Noor Aman nooraman5718 at gmail.com
Thu Jul 21 15:55:53 UTC 2022
A brief gist of what i found compatible with the older code
---COMPATIBLE HEADER---
- BCM2835 timer
- GPIO
- AUX
- GPU timer
---DIDNT CHECK---
- SPI
- I2C
---MINOR CHNAGE---
- IRQ
- FIQ
---NOT SURE ABOUT---
- Watchdog
- Power management
- Mailbox register
I didnt get any info about power management or watchdog or mailboxes. (It
isnt in the BCM2835 Documention too I think??)
And to answer your question Alan about if the Aarch64 would require a DTB
or not which you asked me quite earlier. I can say now, you dont, because
every address is defined here already so no need for the DTB.
diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
index eeb48c42f1..a4ed2a01d1 100644
--- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
+++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
@@ -52,15 +52,23 @@
-#if (BSP_IS_RPI2 == 1)
-  #define RPI_PERIPHERAL_BASE    0x3F000000
+#if (RPI_BSP == RPI2)
+  #define RPI_PERIPHERAL_BASE    0X3F000000
   #define BASE_OFFSET            0X3F000000
+#elif (RPI_BSP == RPI4)
+  #define RPI_PERIPHERAL_BASE 0xFE000000
+  #define BASE_OFFSET 0xFE000000
+  #define RPI_PERIPHERAL_SIZE    0x01800000
 #else
   #define RPI_PERIPHERAL_BASE    0x20000000
   #define BASE_OFFSET            0X5E000000
 #endif
-#define RPI_PERIPHERAL_SIZE      0x01000000
+#ifndef RPI_PERIPHERAL_SIZE
+#define RPI_PERIPHERAL_SIZE     0x01000000
  * @name Bus to Physical address translation
@@ -543,6 +551,188 @@
 #define BCM2836_IRQ_SOURCE_PMU            0x00000200
 #define BCM2836_IRQ_SOURCE_LOCAL_TIMER    0x00000800
+ * @name Raspberry Pi 4 ARM_LOCAL registers
+#define BCM2711_LOCAL_REGS_BASE   0x4C0000000
+#define BCM2711_LOCAL_ARM_CONTROL     (BCM2711_LOCAL_REGS_BASE + 0x00)
+#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c)
+#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10)
+#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14)
+#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24)
+#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30)
+#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x34)
+#define BCM2711_LOCAL_LOCAL_TIMER_IRQ       (BCM2711_LOCAL_REGS_BASE +
0x38)
+#define BCM2711_LOCAL_TIMER_CNTRL0       (BCM2711_LOCAL_REGS_BASE + 0x40)
+#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44)
+#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48)
+#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c)
+#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50)
+#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54)
+#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58)
+#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c)
+#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60)
+#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64)
+#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68)
+#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c)
+#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70)
+#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74)
+#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78)
+#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c)
+ * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
+#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200)
+#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00)
+#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04)
+#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08)
+#define BCM2711_ARMC_IRQ0_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x10)
+#define BCM2711_ARMC_IRQ0_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x14)
+#define BCM2711_ARMC_IRQ0_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x18)
+#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20)
+#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24)
+#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28)
+#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30)
+#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34)
+#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38)
+#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40)
+#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44)
+#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48)
+#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50)
+#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54)
+#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58)
+#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60)
+#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64)
+#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68)
+#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80)
+#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84)
+#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88)
+#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90)
+#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94)
+#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98)
+#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0)
+#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4)
+#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8)
+#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0)
+#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4)
+#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8)
+#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0)
+#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4)
+#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8)
+#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0)
+#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4)
+#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8)
+#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100)
+#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104)
+#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108)
+#define BCM2711_ARMC_FIQ0_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x110)
+#define BCM2711_ARMC_FIQ0_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x114)
+#define BCM2711_ARMC_FIQ0_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x118)
+#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120)
+#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124)
+#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128)
+#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140)
+#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144)
+#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148)
+#define BCM2711_ARMC_FIQ1_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x150)
+#define BCM2711_ARMC_FIQ1_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x154)
+#define BCM2711_ARMC_FIQ1_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x158)
+#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160)
+#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164)
+#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168)
+#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180)
+#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184)
+#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188)
+#define BCM2711_ARMC_FIQ2_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x190)
+#define BCM2711_ARMC_FIQ2_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x194)
+#define BCM2711_ARMC_FIQ2_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x198)
+#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0)
+#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4)
+#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8)
+#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0)
+#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4)
+#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8)
+#define BCM2711_ARMC_FIQ3_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x1D0)
+#define BCM2711_ARMC_FIQ3_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x1D4)
+#define BCM2711_ARMC_FIQ3_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x1D8)
+#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0)
+#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4)
+#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8)
+#define BCM2711_ARMC_SWIRQ_SET   (BCM2711_ARMC_REGS_BASE + 0x1F0)
+#define BCM2711_ARMC_SWIRQ_CLEAR   (BCM2711_ARMC_REGS_BASE + 0x1F4)
+ * @name Raspberry Pi 4 Mailbox registers
+#define BCM2711_MAILBOX_00_WRITE_SET_BASE   0x4C000080
+#define BCM2711_MAILBOX_01_WRITE_SET_BASE   0x4C000084
+#define BCM2711_MAILBOX_02_WRITE_SET_BASE   0x4C000088
+#define BCM2711_MAILBOX_03_WRITE_SET_BASE   0x4C00008C
+#define BCM2711_MAILBOX_04_WRITE_SET_BASE   0x4C000090
+#define BCM2711_MAILBOX_05_WRITE_SET_BASE   0x4C000094
+#define BCM2711_MAILBOX_06_WRITE_SET_BASE   0x4C000098
+#define BCM2711_MAILBOX_07_WRITE_SET_BASE   0x4C00009C
+#define BCM2711_MAILBOX_08_WRITE_SET_BASE   0x4C0000A0
+#define BCM2711_MAILBOX_09_WRITE_SET_BASE   0x4C0000A4
+#define BCM2711_MAILBOX_10_WRITE_SET_BASE   0x4C0000A8
+#define BCM2711_MAILBOX_11_WRITE_SET_BASE   0x4C0000AC
+#define BCM2711_MAILBOX_12_WRITE_SET_BASE   0x4C0000B0
+#define BCM2711_MAILBOX_13_WRITE_SET_BASE   0x4C0000B4
+#define BCM2711_MAILBOX_14_WRITE_SET_BASE   0x4C0000B8
+#define BCM2711_MAILBOX_15_WRITE_SET_BASE   0x4C0000BC
+#define BCM2711_MAILBOX_00_READ_CLEAR_BASE   0x4C0000C0
+#define BCM2711_MAILBOX_01_READ_CLEAR_BASE   0x4C0000C4
+#define BCM2711_MAILBOX_02_READ_CLEAR_BASE   0x4C0000C8
+#define BCM2711_MAILBOX_03_READ_CLEAR_BASE   0x4C0000CC
+#define BCM2711_MAILBOX_04_READ_CLEAR_BASE   0x4C0000D0
+#define BCM2711_MAILBOX_05_READ_CLEAR_BASE   0x4C0000D4
+#define BCM2711_MAILBOX_06_READ_CLEAR_BASE   0x4C0000D8
+#define BCM2711_MAILBOX_07_READ_CLEAR_BASE   0x4C0000DC
+#define BCM2711_MAILBOX_08_READ_CLEAR_BASE   0x4C0000E0
+#define BCM2711_MAILBOX_09_READ_CLEAR_BASE   0x4C0000E4
+#define BCM2711_MAILBOX_10_READ_CLEAR_BASE   0x4C0000E8
+#define BCM2711_MAILBOX_11_READ_CLEAR_BASE   0x4C0000EC
+#define BCM2711_MAILBOX_12_READ_CLEAR_BASE   0x4C0000F0
+#define BCM2711_MAILBOX_13_READ_CLEAR_BASE   0x4C0000F4
+#define BCM2711_MAILBOX_14_READ_CLEAR_BASE   0x4C0000F8
+#define BCM2711_MAILBOX_15_READ_CLEAR_BASE   0x4C0000FC
 #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220721/0bd13e7f/attachment.htm>
