[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Joel Sherrill
joel at rtems.org
Thu Jul 21 16:46:20 UTC 2022
This looks generally ok but is all this visible to any application that
includes bsp.h?
It might all need to be moved into a separate header to avoid contaminating
everyone's namespace.
On Thu, Jul 21, 2022, 10:56 AM Noor Aman <nooraman5718 at gmail.com> wrote:
> A brief gist of what i found compatible with the older code
> ---COMPATIBLE HEADER---
> - BCM2835 timer
> - GPIO
> - AUX
> - GPU timer
> ---DIDNT CHECK---
> - SPI
> - I2C
> ---MINOR CHNAGE---
> - IRQ
> - FIQ
> ---NOT SURE ABOUT---
> - Watchdog
> - Power management
> - Mailbox register
> I didnt get any info about power management or watchdog or mailboxes. (It
> isnt in the BCM2835 Documention too I think??)
> And to answer your question Alan about if the Aarch64 would require a DTB
> or not which you asked me quite earlier. I can say now, you dont, because
> every address is defined here already so no need for the DTB.
> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> index eeb48c42f1..a4ed2a01d1 100644
> --- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> @@ -52,15 +52,23 @@
> -#if (BSP_IS_RPI2 == 1)
> - #define RPI_PERIPHERAL_BASE 0x3F000000
> +#if (RPI_BSP == RPI2)
> + #define RPI_PERIPHERAL_BASE 0X3F000000
> #define BASE_OFFSET 0X3F000000
> +#elif (RPI_BSP == RPI4)
> + #define RPI_PERIPHERAL_BASE 0xFE000000
> + #define BASE_OFFSET 0xFE000000
> + #define RPI_PERIPHERAL_SIZE 0x01800000
> #else
> #define RPI_PERIPHERAL_BASE 0x20000000
> #define BASE_OFFSET 0X5E000000
> #endif
> -#define RPI_PERIPHERAL_SIZE 0x01000000
> +#ifndef RPI_PERIPHERAL_SIZE
> +#define RPI_PERIPHERAL_SIZE 0x01000000
> * @name Bus to Physical address translation
> @@ -543,6 +551,188 @@
> #define BCM2836_IRQ_SOURCE_PMU 0x00000200
> #define BCM2836_IRQ_SOURCE_LOCAL_TIMER 0x00000800
> + * @name Raspberry Pi 4 ARM_LOCAL registers
> +#define BCM2711_LOCAL_REGS_BASE 0x4C0000000
> +#define BCM2711_LOCAL_ARM_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x00)
> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c)
> +#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10)
> +#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14)
> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24)
> +#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30)
> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x34)
> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ (BCM2711_LOCAL_REGS_BASE +
> 0x38)
> +#define BCM2711_LOCAL_TIMER_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x40)
> +#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44)
> +#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48)
> +#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c)
> +#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50)
> +#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54)
> +#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58)
> +#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c)
> +#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60)
> +#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64)
> +#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68)
> +#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c)
> +#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70)
> +#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74)
> +#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78)
> +#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c)
> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
> +#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200)
> +#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00)
> +#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04)
> +#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08)
> +#define BCM2711_ARMC_IRQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x10)
> +#define BCM2711_ARMC_IRQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x14)
> +#define BCM2711_ARMC_IRQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x18)
> +#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20)
> +#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24)
> +#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28)
> +#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30)
> +#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34)
> +#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38)
> +#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40)
> +#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44)
> +#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48)
> +#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50)
> +#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54)
> +#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58)
> +#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60)
> +#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64)
> +#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68)
> +#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80)
> +#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84)
> +#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88)
> +#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90)
> +#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94)
> +#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98)
> +#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0)
> +#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4)
> +#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8)
> +#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0)
> +#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4)
> +#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8)
> +#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0)
> +#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4)
> +#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8)
> +#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0)
> +#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4)
> +#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8)
> +#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100)
> +#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104)
> +#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108)
> +#define BCM2711_ARMC_FIQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x110)
> +#define BCM2711_ARMC_FIQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x114)
> +#define BCM2711_ARMC_FIQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x118)
> +#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120)
> +#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124)
> +#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128)
> +#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140)
> +#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144)
> +#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148)
> +#define BCM2711_ARMC_FIQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x150)
> +#define BCM2711_ARMC_FIQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x154)
> +#define BCM2711_ARMC_FIQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x158)
> +#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160)
> +#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164)
> +#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168)
> +#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180)
> +#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184)
> +#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188)
> +#define BCM2711_ARMC_FIQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x190)
> +#define BCM2711_ARMC_FIQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x194)
> +#define BCM2711_ARMC_FIQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x198)
> +#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0)
> +#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4)
> +#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8)
> +#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0)
> +#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4)
> +#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8)
> +#define BCM2711_ARMC_FIQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1D0)
> +#define BCM2711_ARMC_FIQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1D4)
> +#define BCM2711_ARMC_FIQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1D8)
> +#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0)
> +#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4)
> +#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8)
> +#define BCM2711_ARMC_SWIRQ_SET (BCM2711_ARMC_REGS_BASE + 0x1F0)
> +#define BCM2711_ARMC_SWIRQ_CLEAR (BCM2711_ARMC_REGS_BASE + 0x1F4)
> + * @name Raspberry Pi 4 Mailbox registers
> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080
> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084
> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088
> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C
> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090
> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094
> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098
> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C
> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0
> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4
> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8
> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC
> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0
> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4
> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8
> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC
> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0
> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4
> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8
> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC
> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0
> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4
> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8
> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC
> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0
> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4
> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8
> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC
> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0
> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4
> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8
> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC
> #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220721/7cb63f86/attachment-0001.htm>
