[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Noor Aman nooraman5718 at gmail.com
Thu Jul 21 17:31:51 UTC 2022
I dont think this would be visible to any other application until or unless
user explicitly include this header 'raspberrypi.h' in their application.
And as of now, this header is only placed in bsps/arm/raspberrypi/includes.
For my project I'm thinking of using this header with my project with
bcm2711 addresses included. For my project, this header will go under
bsps/aarch64/raspberrypi/includes. So I don't think this will create any
problem for other BSPs.
On Thu, Jul 21, 2022, 10:16 PM Joel Sherrill <joel at rtems.org> wrote:
> This looks generally ok but is all this visible to any application that
> includes bsp.h?
> It might all need to be moved into a separate header to avoid
> contaminating everyone's namespace.
> On Thu, Jul 21, 2022, 10:56 AM Noor Aman <nooraman5718 at gmail.com> wrote:
>> A brief gist of what i found compatible with the older code
>> ---COMPATIBLE HEADER---
>> - BCM2835 timer
>> - GPIO
>> - AUX
>> - GPU timer
>> ---DIDNT CHECK---
>> - SPI
>> - I2C
>> ---MINOR CHNAGE---
>> - IRQ
>> - FIQ
>> ---NOT SURE ABOUT---
>> - Watchdog
>> - Power management
>> - Mailbox register
>> I didnt get any info about power management or watchdog or mailboxes. (It
>> isnt in the BCM2835 Documention too I think??)
>> And to answer your question Alan about if the Aarch64 would require a DTB
>> or not which you asked me quite earlier. I can say now, you dont, because
>> every address is defined here already so no need for the DTB.
>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>> index eeb48c42f1..a4ed2a01d1 100644
>> --- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>> @@ -52,15 +52,23 @@
>> -#if (BSP_IS_RPI2 == 1)
>> -  #define RPI_PERIPHERAL_BASE    0x3F000000
>> +#if (RPI_BSP == RPI2)
>> +  #define RPI_PERIPHERAL_BASE    0X3F000000
>>    #define BASE_OFFSET            0X3F000000
>> +#elif (RPI_BSP == RPI4)
>> +  #define RPI_PERIPHERAL_BASE 0xFE000000
>> +  #define BASE_OFFSET 0xFE000000
>> +  #define RPI_PERIPHERAL_SIZE    0x01800000
>>  #else
>>    #define RPI_PERIPHERAL_BASE    0x20000000
>>    #define BASE_OFFSET            0X5E000000
>>  #endif
>> -#define RPI_PERIPHERAL_SIZE      0x01000000
>> +#ifndef RPI_PERIPHERAL_SIZE
>> +#define RPI_PERIPHERAL_SIZE     0x01000000
>>   * @name Bus to Physical address translation
>> @@ -543,6 +551,188 @@
>>  #define BCM2836_IRQ_SOURCE_PMU            0x00000200
>>  #define BCM2836_IRQ_SOURCE_LOCAL_TIMER    0x00000800
>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>> +#define BCM2711_LOCAL_REGS_BASE   0x4C0000000
>> +#define BCM2711_LOCAL_ARM_CONTROL     (BCM2711_LOCAL_REGS_BASE + 0x00)
>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c)
>> +#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10)
>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14)
>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24)
>> +#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30)
>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE +
>> 0x34)
>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ       (BCM2711_LOCAL_REGS_BASE +
>> 0x38)
>> +#define BCM2711_LOCAL_TIMER_CNTRL0       (BCM2711_LOCAL_REGS_BASE + 0x40)
>> +#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44)
>> +#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48)
>> +#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c)
>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50)
>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54)
>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58)
>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c)
>> +#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60)
>> +#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64)
>> +#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68)
>> +#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c)
>> +#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70)
>> +#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74)
>> +#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78)
>> +#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c)
>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>> +#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200)
>> +#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00)
>> +#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04)
>> +#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08)
>> +#define BCM2711_ARMC_IRQ0_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x10)
>> +#define BCM2711_ARMC_IRQ0_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x14)
>> +#define BCM2711_ARMC_IRQ0_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x18)
>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20)
>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24)
>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28)
>> +#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30)
>> +#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34)
>> +#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38)
>> +#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40)
>> +#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44)
>> +#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48)
>> +#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50)
>> +#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54)
>> +#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58)
>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60)
>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64)
>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68)
>> +#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80)
>> +#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84)
>> +#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88)
>> +#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90)
>> +#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94)
>> +#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98)
>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0)
>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4)
>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8)
>> +#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0)
>> +#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4)
>> +#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8)
>> +#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0)
>> +#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4)
>> +#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8)
>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0)
>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4)
>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8)
>> +#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100)
>> +#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104)
>> +#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108)
>> +#define BCM2711_ARMC_FIQ0_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x110)
>> +#define BCM2711_ARMC_FIQ0_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x114)
>> +#define BCM2711_ARMC_FIQ0_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x118)
>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120)
>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124)
>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128)
>> +#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140)
>> +#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144)
>> +#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148)
>> +#define BCM2711_ARMC_FIQ1_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x150)
>> +#define BCM2711_ARMC_FIQ1_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x154)
>> +#define BCM2711_ARMC_FIQ1_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x158)
>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160)
>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164)
>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168)
>> +#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180)
>> +#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184)
>> +#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188)
>> +#define BCM2711_ARMC_FIQ2_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x190)
>> +#define BCM2711_ARMC_FIQ2_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x194)
>> +#define BCM2711_ARMC_FIQ2_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x198)
>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0)
>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4)
>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8)
>> +#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0)
>> +#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4)
>> +#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8)
>> +#define BCM2711_ARMC_FIQ3_SET_EN_0   (BCM2711_ARMC_REGS_BASE + 0x1D0)
>> +#define BCM2711_ARMC_FIQ3_SET_EN_1   (BCM2711_ARMC_REGS_BASE + 0x1D4)
>> +#define BCM2711_ARMC_FIQ3_SET_EN_2   (BCM2711_ARMC_REGS_BASE + 0x1D8)
>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0)
>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4)
>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8)
>> +#define BCM2711_ARMC_SWIRQ_SET   (BCM2711_ARMC_REGS_BASE + 0x1F0)
>> +#define BCM2711_ARMC_SWIRQ_CLEAR   (BCM2711_ARMC_REGS_BASE + 0x1F4)
>> + * @name Raspberry Pi 4 Mailbox registers
>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE   0x4C000080
>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE   0x4C000084
>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE   0x4C000088
>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE   0x4C00008C
>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE   0x4C000090
>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE   0x4C000094
>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE   0x4C000098
>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE   0x4C00009C
>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE   0x4C0000A0
>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE   0x4C0000A4
>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE   0x4C0000A8
>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE   0x4C0000AC
>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE   0x4C0000B0
>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE   0x4C0000B4
>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE   0x4C0000B8
>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE   0x4C0000BC
>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE   0x4C0000C0
>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE   0x4C0000C4
>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE   0x4C0000C8
>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE   0x4C0000CC
>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE   0x4C0000D0
>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE   0x4C0000D4
>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE   0x4C0000D8
>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE   0x4C0000DC
>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE   0x4C0000E0
>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE   0x4C0000E4
>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE   0x4C0000E8
>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE   0x4C0000EC
>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE   0x4C0000F0
>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE   0x4C0000F4
>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE   0x4C0000F8
>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE   0x4C0000FC
>>  #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220721/aa3f1cd1/attachment-0001.htm>
