[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Fri Jul 22 02:42:52 UTC 2022
On 22/7/2022 1:55 am, Noor Aman wrote:
> A brief gist of what i found compatible with the older code
> ---COMPATIBLE HEADER---
> - BCM2835 timer
> - GPIO
> - AUX
> - GPU timer
> ---DIDNT CHECK---
> - SPI
> - I2C
> ---MINOR CHNAGE---
> - IRQ
> - FIQ
> ---NOT SURE ABOUT---
> - Watchdog
> - Power management
> - Mailbox register
> I didnt get any info about power management or watchdog or mailboxes. (It isnt
> in the BCM2835 Documention too I think??)
> And to answer your question Alan about if the Aarch64 would require a DTB or not
> which you asked me quite earlier. I can say now, you dont, because every address
> is defined here already so no need for the DTB.
Is this a commit message?
Is not think a conversation suites a commit message.
