[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Fri Jul 22 02:44:23 UTC 2022
On 22/7/2022 12:42 pm, Chris Johns wrote:
> On 22/7/2022 1:55 am, Noor Aman wrote:
>> A brief gist of what i found compatible with the older code
>> ---COMPATIBLE HEADER---
>> - BCM2835 timer
>> - GPIO
>> - AUX
>> - GPU timer
>> ---DIDNT CHECK---
>> - SPI
>> - I2C
>> ---MINOR CHNAGE---
>> - IRQ
>> - FIQ
>> ---NOT SURE ABOUT---
>> - Watchdog
>> - Power management
>> - Mailbox register
>> I didnt get any info about power management or watchdog or mailboxes. (It isnt
>> in the BCM2835 Documention too I think??)
>> And to answer your question Alan about if the Aarch64 would require a DTB or not
>> which you asked me quite earlier. I can say now, you dont, because every address
>> is defined here already so no need for the DTB.
> Is this a commit message?
> Is not think a conversation suites a commit message.
Sorry, that should read "I do not think ..."
