[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Noor Aman
nooraman5718 at gmail.com
Fri Jul 22 02:49:49 UTC 2022
Sorry for that. I wanted a review for this so that's why included the gist
too. I think instead of writing as a patch, I'll be using review. Thank you
for the info.
On Fri, Jul 22, 2022, 8:14 AM Chris Johns <chrisj at rtems.org> wrote:
> On 22/7/2022 12:42 pm, Chris Johns wrote:
> > On 22/7/2022 1:55 am, Noor Aman wrote:
> >> A brief gist of what i found compatible with the older code
> >> ---COMPATIBLE HEADER---
> >> - BCM2835 timer
> >> - GPIO
> >> - AUX
> >> - GPU timer
> >> ---DIDNT CHECK---
> >> - SPI
> >> - I2C
> >> ---MINOR CHNAGE---
> >> - IRQ
> >> - FIQ
> >> ---NOT SURE ABOUT---
> >> - Watchdog
> >> - Power management
> >> - Mailbox register
> >> I didnt get any info about power management or watchdog or mailboxes.
> (It isnt
> >> in the BCM2835 Documention too I think??)
> >> And to answer your question Alan about if the Aarch64 would require a
> DTB or not
> >> which you asked me quite earlier. I can say now, you dont, because
> every address
> >> is defined here already so no need for the DTB.
> > Is this a commit message?
> > Is not think a conversation suites a commit message.
> Sorry, that should read "I do not think ..."
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220722/eda0c4ea/attachment-0001.htm>
