[PATCH v4 1/7] bsps/stm32f4 Include STM32F4 HAL
Duc Doan
dtbpkmte at gmail.com
Sat Jul 23 09:31:20 UTC 2022
Hello Christian,
On Sat, 2022-07-23 at 10:31 +0200, oss at c-mauderer.de wrote:
> Hello Duc,
> Am 23.07.22 um 09:37 schrieb Duc Doan:
> > Hello Karel,
> > On Sat, 2022-07-23 at 09:09 +0200, Karel Gardas wrote:
> > > Duc,
> > > where have you taken F4 HAL exactly? I'm asking since your import
> > > is
> > > full of CRLF line endings which we try hard to eliminate in RTEMS
> > > while
> > > original is not. Proof:
> > > $ git clone https://github.com/STMicroelectronics/STM32CubeF4.git
> > > Cloning into 'STM32CubeF4'...
> > > remote: Enumerating objects: 75365, done.
> > > remote: Counting objects: 100% (1271/1271), done.
> > > remote: Compressing objects: 100% (48/48), done.
> > > remote: Total 75365 (delta 1231), reused 1229 (delta 1221), pack-
> > > reused
> > > 74094
> > > Receiving objects: 100% (75365/75365), 157.59 MiB | 6.87 MiB/s,
> > > done.
> > > Resolving deltas: 100% (46903/46903), done.
> > > Updating files: 100% (39125/39125), done.
> > > rtems at silence:~/vcs$ cd STM32CubeF4/
> > > rtems at silence:~/vcs/STM32CubeF4$
> > > rtems at silence:~/vcs/STM32CubeF4$ git ls-files --eol|grep crlf
> > > Please use the command above to review your CRLF files.
> > > Thanks,
> > > Karel
> > I took the HAL from ST's website by downloading the zip. And yes,
> > when
> > I tried the command, all HAL files have CRLF. I will remove them in
> > the
> > next patch set.
> Have you thought about using the STM32CubeF4 repo that Karel linked
> instead of the ZIP file as a source?
> Can you please add the source for your files to the commit
> description?
> If you used a zip, provide the link, date, version (if available) and
> maybe a checksum of the file. If you used a git repository (which I
> would prefer), provide a link and the commit ID. That makes it
> simpler
> to some when find the sources that you used.
> Best regards
> Christian
Yes, in the next patch set I will replace the HAL files by those from
the repo Karel linked. I will remember to provide the link and commit
ID in the commit message.
Best,
Duc Doan
> > Thanks for the reminder,
> > Duc Doan
> > devel mailing list
> > devel at rtems.org
